gounthar
Connecting via USB Jabra 510 Speaker/Mic
Tue Oct 02, 2018 4:48 pm
I connected via USB a Jabra 510 Speaker/Mic on a B+ running
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.4 (stretch)
Release:        9.4
Codename:       stretch
It's a server version, without X. I would like to use the Jabra as a mic and sync it with the camera later on.
But for the time being, I'm stuck.
lsusb gives me
 lsusb
Bus 001 Device 007: ID 0b0e:0422 GN Netcom
and dmesg
[3038344.071987] usb 1-1.2: new full-speed USB device number 7 using dwc_otg
[3038344.220403] usb 1-1.2: New USB device found, idVendor=0b0e, idProduct=0422
[3038344.220417] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=3
[3038344.220426] usb 1-1.2: Product: Jabra SPEAK 510 USB
[3038344.220434] usb 1-1.2: SerialNumber: 745C4B18D743020A00
[3038344.250896] input: Jabra SPEAK 510 USB as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:0B0E:0422.0003/input/input2
[3038344.312903] hid-generic 0003:0B0E:0422.0003: input,hiddev96,hidraw0: USB HID v1.11 Device [Jabra SPEAK 510 USB] on usb-3f980000.usb-1.2/input3
[3038344.538302] usbcore: registered new interface driver snd-usb-audio
alsa control
$ sudo alsactl init
Found hardware: "bcm2835_alsa" "Broadcom Mixer" "" "" ""
Hardware is initialized using a generic method
and of course
 aplay -l
aplay: device_list:270: no soundcards found...
I modified /etc/modprobe.d/alsa-base.conf
# This sets the index value of the cards but doesn't reorder.
options snd_usb_audio index=0
options snd_bcm2835 index=1
# Does the reordering.
options snd slots=snd_usb_audio,snd_bcm2835
and commented
#options snd-usb-audio index=-2
in /lib/modprobe.d/aliases.conf so that I now get
  cat /proc/asound/cards
 0 [USB            ]: USB-Audio - Jabra SPEAK 510 USB
                      Jabra SPEAK 510 USB at usb-3f980000.usb-1.2, full speed
 1 [ALSA           ]: bcm2835_alsa - bcm2835 ALSA
                      bcm2835 ALSA
I still get
aplay -l
Strangely this command works and produces sound:
 sudo aplay -D default /usr/share/sounds/alsa/Front_Center.wav
Playing WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
I can record and play though...
 sudo arecord -vv -fdat foo.wav
Recording WAVE 'foo.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
Plug PCM: Route conversion PCM (sformat=S16_LE)
  Transformation table:
    0 <- 0
    1 <- 0
Its setup is:
  stream       : CAPTURE
  access       : RW_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 48000
  exact rate   : 48000 (48000/1)
  msbits       : 16
  buffer_size  : 24576
  period_size  : 3072
  period_time  : 64000
  tstamp_mode  : NONE
  tstamp_type  : MONOTONIC
  period_step  : 1
  avail_min    : 3072
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 24576
  silence_threshold: 0
  silence_size : 0
  boundary     : 1610612736
Slave: Rate conversion PCM (16000, sformat=S16_LE)
Converter: linear-interpolation
Protocol version: 10002
Its setup is:
  stream       : CAPTURE
  access       : MMAP_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 1
  rate         : 48000
  msbits       : 16
  buffer_size  : 24576
  period_size  : 3072
  period_time  : 64000
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 3072
  period_event : 0
  start_threshold  : 1
  silence_size : 0
Slave: Direct Snoop PCM
Its setup is:
  stream       : CAPTURE
  format       : S16_LE
  subformat    : STD
  channels     : 1
  rate         : 16000
  exact rate   : 16000 (16000/1)
  msbits       : 16
  buffer_size  : 8192
  period_size  : 1024
  period_time  : 64000
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 1024
  period_event : 0
  start_threshold  : 0
  stop_threshold   : 8192
  silence_size : 0
  boundary     : 1073741824
Hardware PCM card 0 'Jabra SPEAK 510 USB' device 0 subdevice 0
Its setup is:
  stream       : CAPTURE
  format       : S16_LE
  subformat    : STD
  channels     : 1
  rate         : 16000
  msbits       : 16
  buffer_size  : 16384
  period_size  : 1024
  period_time  : 64000
  tstamp_mode  : ENABLE
  period_step  : 1
  avail_min    : 1024
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 1073741824
  silence_size : 0
  appl_ptr     : 0
  hw_ptr       : 0
#     +                                            | 10%^C
Aborted by signal Interrupt...
arecord: pcm_read:2103: read error: Interrupted system call
HypriotOS/armv7: pirate@arm-gitlab-runner-1 in ~
$ sudo aplay -D default foo.wav
Playing WAVE 'foo.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
I'm sure I missed some steps in order to get this working.
Could someone please give me a pointer?
Thanks in advance.
2*3B at home for the kids
7*3B+ at work for serious business (gitlab-runner, broadcasting conference, openSTF server...)
Hoping to get a few hats in the following weeks
