Plasmatikk
After password, it's the terms
Sat Sep 29, 2018 11:00 am
What i have to do when it shows a dollar with terms of law or something like that?
epoch1970
Re: After password, it's the terms
Sat Sep 29, 2018 12:00 pm
This is the Pi's command-line. You can enter shell commands and summon applications from there.
For example "sudo raspi-config" would start Raspbian's built-in setup utility.
https://projects.raspberrypi.org/en/pro ... pi-using/9
HawaiianPi
Sat Sep 29, 2018 12:23 pm
Are you using Raspbian Lite or Desktop?
If you installed the Lite version and don't know how to use it, try the Desktop version. The Lite version has no graphical user interface, you interact with it by typing commands.
klricks
Sat Sep 29, 2018 3:31 pm
If you are logging in remotely by ssh then that is text console only. If you are expecting desktop (GUI) over remote connection then use RealVNC instead of ssh.
