Problem for undervoltage
Posted: Wed Sep 19, 2018 7:56 am
by raspTest
Hi everyone!
I'm developing a system that uses the rxtx libraries of java to communicate with an arduino, via serial with usb, and with a webcam (using opencv).
If I launch everything from the computer, the program does not have problems even after a whole day.
If I use the rasberry as a computer, I noticed that after a while 'in the system logs appears an undervoltage warning and below, the rasp disables and reactivates the USB and Ethernet, causing a malfunction of the program with the modification of the ports on the arduino and the webcam are attached.
The arduino is attached via usb to the raspberry, powered by it. It has several sensors and actuators on board.
The raspberry is powered with 5v by 2.5A
How can I solve this problem?
Re: Problem for undervoltage
Posted: Wed Sep 19, 2018 8:06 am
by Joel_Mckay
Your power supply may be too low try a 5V 5A minimum supply if you have usb devices plugged in....
Otherwise you may need an external powered USB hub.
Often the USB driver power-save modes will periodically reset devices, and can be rather involved to disable.
Good Luck,
J
Posted: Wed Sep 19, 2018 8:16 am
by drgeoff
Joel_Mckay wrote: ↑Wed Sep 19, 2018 8:06 am
The polyfuse on the micro-USB power input will not pass 5 Amps. A PSU that truly meets the specified 2.5 Amps at 5 Volts is adequate.
Posted: Wed Sep 19, 2018 8:49 am
by raspTest
On system's logs, I have a series of this messages:
Under-voltage detected! (0x00050005)
Voltage normalised (0x00000000)
rpi_firmware_get_throttled: 3 callbacks suppressed
Posted: Wed Sep 19, 2018 8:52 am
by RaTTuS
or your micro usb lead is made from damp string - get a much better [thicker] one
Posted: Wed Sep 19, 2018 8:53 am
by Joel_Mckay
Let us assume you already enabled max_usb_current=1 ...
This site is wrong for 3 reasons:.
https://www.raspberrypi.org/help/faqs/#powerReqs
1. The 5v header pins do not pass through the poly fuse.
2. While 1.2A for the USB port is fine, that optimistic minimum 400mA core draw should be more like 1.8A with a pi3B+ desktop running wifi. (that is a 3A draw)
3. Most cheap power supplies lie about the output, so de-rate by 40% unless you plan to fry eggs on the inductor or fets..
I have been building embedded devices since 1994, but please educate me if I am missing something.
Posted: Wed Sep 19, 2018 8:58 am
by RaTTuS
Joel_Mckay wrote: ↑Wed Sep 19, 2018 8:53 am
ignore that - that was only for older pi's nothing done in the last couple of years needs it
Posted: Wed Sep 19, 2018 9:07 am
by markost
- pi3.PNG (39.53 KiB) Viewed 7975 times
Posted: Wed Sep 19, 2018 9:10 am
by markost
try to use the power supply arduino separately and not through the usb port
Posted: Wed Sep 19, 2018 9:32 am
by Joel_Mckay
@markost
That is the usb port input, not the 5v/VCC gpio header pin 2 and 4.
The 3B+ looks like it has kept this external shield power feature.
Posted: Wed Sep 19, 2018 9:37 am
by LTolledo
raspTest wrote: ↑Wed Sep 19, 2018 7:56 am
How about doing this:
1. Power the Raspberry Pi with its own 5v 2.5A PSU with thick microSUB cable.
2. Power the Arduino with its own PSU (5V 2A perhaps)
3. Connect the USB deviced thru a powered Hub..
Its still up to you to apply the solution....... or continue wondering why you still have undervoltage problem.....
anything else is irrelevant....
Posted: Wed Sep 19, 2018 9:50 am
by markost
Joel_Mckay wrote: ↑Wed Sep 19, 2018 9:32 am
@markost
the power supply comes via the microUSB, it goes over the polyfuse. Here we have "first" 5v, which is the same as the GPIO expansion pin 2 and 4.
So, does the 5v header pins pass or not through the poly fuse?
Posted: Wed Sep 19, 2018 9:55 am
by markost
LTolledo wrote: ↑Wed Sep 19, 2018 9:37 am
This is correct instead step 3.
3. Connect GND of both power supply together
and
4. remove 5V and GND from arduino USB, only TX and RX are needed
Posted: Wed Sep 19, 2018 10:04 am
by Joel_Mckay
markost wrote: ↑Wed Sep 19, 2018 9:50 am
1. The GPIO header 5v pins do not pass through a fuse
2. micro-USB are rated for a theoretical 3A maximum, but the polyfuse will never allow this limit
3. As other users have said, a powered external USB expansion hub may be a simpler solution
Best of luck,
J
Posted: Wed Sep 19, 2018 10:15 am
by markost
OK,
can you show me on schematic where is the 5V input for the GPIO header (from where this voltage is coming)?
Obviously I'm looking at something wrong
Thank you!
Posted: Wed Sep 19, 2018 10:53 am
by Joel_Mckay
@markost
The two giant black arrows in the 3B+pow.png image show the pi's 5v rail and external VCC GPIO header pins 2 and 4 are connected with copper.
In schematic drawings people use symbols to label common things like ground and power rails to simplify the number of lines needed to describe a circuit.
The external powered USB expansion adapter option may be less complicated and safer if you are not comfortable with electronics.
Cheers,
J
Posted: Wed Sep 19, 2018 11:47 am
by markost
@Joel_Mckay
Thanks for your point of view.
I agree for the 5V power rail (all marked as 5V on schematic are on the same rail), but I don't agree that the 5V on the GPIO (pin 2 and pin 4) are not after polyfuse.
I don't have RPi3B+, only 3B.
If 5V on the GPIO doesn't go through the polyfuse than must go directly to the microUSB pin1.
If that is true, that mean that test point PP1&PP2 are connected directly with the GPIO2&4. But they are not connected (for RPi3B).
5V on the GPIO(pin2&4) are connected to the test point PP7.
Test point PP7 is behind the polyfuse.
So, for me, 5V on GPIO is after polyfuse.
Regards
Posted: Wed Sep 19, 2018 12:03 pm
by drgeoff
The 5 volt pin of the micro-USB socket and the 5 volt pins of the GPIO header are on opposite ends of the polyfuse.
Posted: Wed Sep 19, 2018 12:36 pm
by raspTest
thanks a lot! i will ltry !!!
Posted: Wed Sep 19, 2018 3:31 pm
by raspTest
it seems to be solved! I connected the arduino's power supply of the externally, and then I connected arduino and raspberry through the usb for communication. for now the rasp has not launched any warnings on the voltage!
Thanks!!!
