basic.
Google assistant errors
Tue Sep 18, 2018 6:49 am
Me and a friend tried to make a smart mirror, using the Google Assistant API. However, every time we go through the process of updating everything and getting it all ready, the same error occurs: 'No module named googlesamples.assistant'. Does anyone have a solution for this? Thank you all in advance.
topguy
Re: Google assistant errors
Tue Sep 18, 2018 9:49 am
Giving us a hint to what installation guide you have been following would be helpful.
I think most guides uses "virtual environment" in Python to install the dependencies so you have to make sure you run the shell command:
source env/bin/activate
before you try to start any assistant demo.
( Assuming "env" is where you have installed this. )
