PanjaNL
[Question] Are my Rpi 3B+ speeds normal?
Tue Sep 04, 2018 7:31 pm
I recently purchased a Rpi 3B+ with an official Rpi 5.1v/2.5a power supply.
I have searched and found that the 3B+ should have these default speeds:
  • CPU: 1400 MHz
    CORE: 400 MHz
    RAM: 500 MHz
    GPU: 300 MHz
Installed RetroPie and updated all packages to the latest (4.4.2).
If I run these commands:
vcgencmd get_config int | grep arm_freq
vcgencmd get_config int | grep core_freq
vcgencmd get_config int | grep sdram_freq
vcgencmd get_config int | grep gpu_freq
I'm getting different speeds:
  • arm_freq=1400
    core_freq=250
    sdram_freq=450
    gpu_freq=300
Is there something wrong with my 3B+?
Source: https://www.raspberrypi.org/documentati ... locking.md
[edit]
Changed formatting
DarkPlatinum
Contact: Website YouTube
Re: [Question] Are my Rpi 3B+ speeds normal?
Tue Sep 04, 2018 7:55 pm
I am not 100% sure, but doesn't the clock speed deacrease while not taxed heavily? Correct me if im wrong.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
PanjaNL
Tue Sep 04, 2018 7:57 pm
As far as I know you are correct.
Though these commands should give me the max speeds and not the current (idle or decreased speeds).
So I think they are still not correct.
DarkPlatinum
Tue Sep 04, 2018 8:03 pm
Check your config.txt file, retropie might have a default clockspeed.
pfletch101
Tue Sep 04, 2018 8:17 pm
Interesting!
On my 3B+, vcgencmd gives:
arm_freq=1400
core_freq=400
gpu_freq=300
sdram_freq=450
A couple of these are a bit lower than the specs you quote, but at least the arm_freq is on spec. On the one of my (fairly new) 3Bs that is currently in use, vcgencmd gives:
arm_freq=1200
core_freq=400
gpu_freq=300
sdram_freq=450
Are you sure that your 3B+ isn't really an older 3B?!
PanjaNL
Tue Sep 04, 2018 8:42 pm
That was the first thing that I thought of as well. But on the PCB it says:
Raspberry Pi 3 Model B+
Raspberry Pi 2017
Core speed is way off!
Also ram should be 500 MHz...
The config.txt is default.
There are no settings for over or underclocking.
MaxVMH
Tue Sep 04, 2018 9:12 pm
Here are my results :)
Raspberry Pi 3B+, same results as pfletch101:
23:05:28 up 101 days, 10:02,  1 user,  load average: 0.30, 0.27, 0.27
arm_freq=1400
core_freq=400
gpu_freq=300
sdram_freq=500
Raspberry Pi 3B:
23:03:27 up 101 days, 10:00,  1 user,  load average: 0.43, 0.33, 0.29
arm_freq=1200
core_freq=400
gpu_freq=300
sdram_freq=450
Webserver stack: 2x Pi 3B | 1x Pi 3B+ ||| Pi Zero W for fooling around
Working on a soccer prediction web app:
https://github.com/MaxVMH/mijnscore
Attempt at writing up-to-date tutorials on making a Raspberry Pi webserver:
http://blog.mijnscore.be/
PanjaNL
Tue Sep 04, 2018 9:17 pm
Not completely the same. Your ram speed is 500 MHz. Which should be the default.
Keeps getting stranger and stranger...
MaxVMH
Tue Sep 04, 2018 9:24 pm
Yes, looks like you're right. I got a better one :lol:
Wed Sep 05, 2018 8:57 am
Try the latest Raspbian.
hippy
Wed Sep 05, 2018 9:19 am
Raspberry Pi 3B:
arm_freq=1200
core_freq=400
gpu_freq=300
sdram_freq=450
My quite old Pi 3B but running updated Stretch gives -
arm_freq=1200
core_freq=250    <---- ?
gpu_freq=300
sdram_freq=450
There is nothing in config.txt which sets core_freq I can see, and I am sure it's a stock install and raspi-config won't allow overclocking so can't see that I have ever overclocked or underclocked.
Then I noticed that the UART has been enabled and that's probably what has auto-adjusted the core_freq.
Perhaps that's why the OP's core_freq is also 250. I have no idea why their sdram_freq on the 3B+ is 450 not 500.
PanjaNL
Wed Sep 05, 2018 9:28 am
Then I noticed that the UART has been enabled and that's probably what has auto-adjusted the core_frequency.
Perhaps that's why your core_freq is also 250.
Indeed UART is enabled, this is done automatically by installing the safe shutdown script for the Nespi Case+
https://github.com/RetroFlag/retroflag-picase
Safe shutdown install.sh script:
#Step 2) enable UART----------------------------------------
cd /boot/
File=config.txt
if grep -q "enable_uart=1" "$File";
	then
		echo "UART already enabled. Doing nothing."
	else
		echo "enable_uart=1" >> $File
		echo "UART enabled."
fi
Tonight I will try a fresh install of RetroPie or/and Rasbian without the safe shutdown script (UART disabled that way) and report back.
hippy
Wed Sep 05, 2018 9:39 am
Once I get home tonight I will try a fresh install of RetroPie or/and Rasbian without the safe shutdown script (UART disabled that way) and report back.
You might not have to do a complete reinstall, may just be able to edit config.txt.
I ran raspi-config on my 3B, disabled UART, rebooted, and my core_freq is back to the expected 400.
You should be able to use the UART and have core_freq=400 by setting force_turbo if my reading of the documentation is right -
"The Linux console can be re-enabled by adding enable_uart=1 to config.txt. This also fixes the core_freq to 250Mhz (unless force_turbo is set, when it will fixed to 400Mhz), which means that the UART baud rate stays consistent".
https://www.raspberrypi.org/documentati ... on/uart.md
I haven't read the full documentation and don't have a good understanding of what all the clocking options are or mean so have no idea what any other consequence of setting force_turbo might be.
PanjaNL
Wed Sep 05, 2018 9:49 am
Thanks! I will have a go tonight.
As far as I know "force_turbo" sets the speed to full all the time.
So when the Rpi is idle normally it goes back to arm_freq=600 but with this option it stays at arm_freq=1400 all time time.
PanjaNL
Wed Sep 05, 2018 3:07 pm
Confirmed!
If I remove the "enable_uart=1" line in my /boot/config.txt the core_freq is back to 400.
The strange thing is that the shutdown and reset button on the Nespi Case+ keep on working, even when I remov the "enable_uart=1" line in my /boot/config.txt
So now I'm wondering why do I need UART enabled anyways?
ejolson
Wed Sep 05, 2018 5:14 pm
Confirmed!
While 250 is smaller than 400, does the core frequency affect anything other than the serial ports?
PanjaNL
Wed Sep 05, 2018 6:32 pm
Copy/paste from the Rpi documentation site:
core_freq
Frequency of the GPU processor core in MHz. It has an impact on CPU performance because it drives the L2 cache and memory bus. The default value is 250 for the Pi 1/Pi 2 and 400 for the Pi 3 and Pi Zero and Pi Zero W. Note that the L2 cache benefits only the Pi Zero/Pi Zero W and Pi 1, but there is a small benefit for SDRAM on the Pi 2/Pi.
hippy
Wed Sep 05, 2018 6:50 pm
It would be nice to have that "small" quantified in some meaningful way.
PanjaNL
Wed Sep 05, 2018 7:49 pm
Still don’t have a clue why I need UART enabled...
bensimmo
Wed Sep 05, 2018 8:30 pm
The ram speed was dropped (along with a timing setting) and so should not be 500 anymore, it was found some where unstable at that speed.
These are set at boot up in 'firmware' (and overridden in config.txt ) if I have that right.
DarkPlatinum
Wed Sep 05, 2018 8:33 pm
So before reading your comment i had clocked it at 500, should i decrease it back to what value now? Is 400mhz ok?
bensimmo
Thu Sep 06, 2018 6:01 am
If you're forcing it to 500 and it doesn't crash after being left on for a day or two, leave it at 500.
I believe most (if not all but a small batch) should run at 500.
500 was the speed it was released at originally.
(Find a thread from around the first few weeks from launch day about the Pi3B+ crashing, they did a lot of diagnosis from people with the problem).
bensimmo
Thu Sep 06, 2018 6:14 am
I assume w.r.t. Pi1 being large.
From a recent thread, the Pi2&3 have onboard cache for the ARM and do not use the L2 cache, hence why it isn't a problem for them.
Also the Pi1's and Zero and Pi2 should not see the problem with Serial (gpio UART) as they don't need it since they don't use the miniUART. I assume that setting is not set when Serial Port is enabled (?) for them.
Only the WiFI/BT Pi (W and 3's ) will see the problem, of course the slowest one is hit the hardest, though I don't think it's ever been a problem for my usage.
One for the benchmarkers to have a play with ;-)
