Hello All.
Inserting the boot USB into different USB ports on the B+ produces different results. Looking at the usb edge of the Pi, the ethernet socket is on the left, there's 2 usb ports in the center, and 2 usb ports on the right.
When the boot usb is inserted in one of the right side usb ports, everything works perfectly. Pi boots, ethernet connects, wifi AP is up. Nil issues. This is consistent boot after boot.
When the boot usb is inserted in the left usb ports, ethernet never connects, wifi AP is down. This is headless without monitor, so verifying the boot is tricky. Red/Green led activity is identical to a normal boot, ethernet leds remain off.
Here's the kicker, if I connect a hdmi monitor, it boots perfectly every time. If a keyboard or mouse is connected to either right side port, it boots perfectly.
Summary
- Boot usb in the upper left usb port
- Ethernet connected
- Nothing else connected = fail
- HDMI connected = boots ok
- HID device in any right usb port = boots ok
- 2 brand new pi's behave identically
- Clean install of raspbian-stretch-lite-2018-06-27
- The default image (no updates or changes) = same problem
- Updated using: sudo apt update && sudo apt full-upgrade -y
- After updates = same problem
- Different usb drives tested
- Only happens on Pi3 B+, our systems on Pi3 B don't have these symptoms
This may seem trivial, but we have space constrained installs into Cinch HD housings, the boot usb must reside in the top left usb port.
Question: Are there steps I can take to make the top left USB port behave like the ones on the right?
Headless Pi3 B+ USB Boot hangs in left USB ports
Re: Headless Pi3 B+ USB Boot in different USB ports
paasys wrote: ↑Fri Aug 31, 2018 7:53 amHello All.
Summary
May one ask what you are using for a power supply ? as the 3B+ is more power hungry than the 3B:
https://www.raspberrypi.org/products/ra ... er-supply/
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Power supplies I've used for these tests
- Official pi supply ex RS Components 5v 2.5amp (new current model)
- Official pi supply ex RS Components 5v 2.0amp (previous model)
- Laboratory bench supply 10.0amp rated
- Purpose built 4.5amp supplies, we use in our pi3 B machine controllers
All of these power supplies produce the same symptoms.
Re: Headless Pi3 B+ USB Boot hangs in left USB ports
Hi All, some further testing shows the boot hangs when the usb is the left ports.
In /boot/config.txt -> uncomment hdmi_force_hotplug=1
Now I can plug a monitor in after starting the pi. I can see it hangs at approx 1.9025 while it's dealing with usb ports.
If the boot usb is in one of the left ports, it hangs here every time. If I plug a keyboard (or anything) into a right usb, the boot continues normally, and everything works fine. This is LOG NO1 below.
If the usb is in one of the right ports, it works correctly every time. This is LOG NO2 below.
Any suggestions or help would be greatly appreciated.
Many thanks!
(Sorry for the long traces, didn' t want to leave anything out)
LOG NO1 - usb in left port, boot hangs:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.62-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1134 SMP Tue Aug 14 17:10:10 BST 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] free_area_init_node: node 0, pgdat 80c85000, node_mem_map ba39f000
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 17 pages/cpu @ba348000 s38720 r8192 d22720 u69632
[ 0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=5971da25-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940228K/970752K available (7168K kernel code, 575K rwdata, 2076K rodata, 1024K init, 706K bss, 22332K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c8fef4 ( 576 kB)
.bss : 0x80c96f34 - 0x80d478b4 ( 707 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 25267 entries in 75 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000023] Switching to timer-based delay loop, resolution 52ns
[ 0.000272] Console: colour dummy device 80x30
[ 0.000804] console [tty1] enabled
[ 0.000841] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000880] pid_max: default: 32768 minimum: 301
[ 0.001208] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001241] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002198] Disabling memory control group subsystem
[ 0.002290] CPU: Testing write buffer coherency: ok
[ 0.002715] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003130] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003270] Hierarchical SRCU implementation.
[ 0.003962] smp: Bringing up secondary CPUs ...
[ 0.004749] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005586] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006403] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006507] smp: Brought up 1 node, 4 CPUs
[ 0.006578] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.006600] CPU: All CPU(s) started in HYP mode.
[ 0.006618] CPU: Virtualization extensions available.
[ 0.007509] devtmpfs: initialized
[ 0.017696] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[ 0.018369] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.018613] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018655] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.019226] pinctrl core: initialized pinctrl subsystem
[ 0.020020] NET: Registered protocol family 16
[ 0.022603] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.027433] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.027465] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.027674] Serial: AMBA PL011 UART driver
[ 0.029346] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.029827] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.061535] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[ 0.062983] SCSI subsystem initialized
[ 0.063227] usbcore: registered new interface driver usbfs
[ 0.063297] usbcore: registered new interface driver hub
[ 0.063397] usbcore: registered new device driver usb
[ 0.070078] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-08-16 17:30
[ 0.071391] clocksource: Switched to clocksource arch_sys_counter
[ 0.147838] VFS: Disk quotas dquot_6.6.0
[ 0.147950] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.148151] FS-Cache: Loaded
[ 0.148364] CacheFiles: Loaded
[ 0.157227] NET: Registered protocol family 2
[ 0.157965] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.158094] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.158296] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.158441] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.158503] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.158747] NET: Registered protocol family 1
[ 0.159213] RPC: Registered named UNIX socket transport module.
[ 0.159237] RPC: Registered udp transport module.
[ 0.159256] RPC: Registered tcp transport module.
[ 0.159275] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.160755] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.163535] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.171691] FS-Cache: Netfs 'nfs' registered for caching
[ 0.172313] NFS: Registering the id_resolver key type
[ 0.172356] Key type id_resolver registered
[ 0.172376] Key type id_legacy registered
[ 0.172404] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.174349] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.174505] io scheduler noop registered
[ 0.174526] io scheduler deadline registered (default)
[ 0.174821] io scheduler cfq registered
[ 0.174842] io scheduler mq-deadline registered
[ 0.174862] io scheduler kyber registered
[ 0.177146] BCM2708FB: allocated DMA memory fad00000
[ 0.177190] BCM2708FB: allocated DMA channel 0 @ bb813000
[ 0.186652] Console: switching to colour frame buffer device 80x30
[ 0.195874] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.198599] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.204344] vc-sm: Videocore shared memory driver
[ 0.207324] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.222699] brd: module loaded
[ 0.234152] loop: module loaded
[ 0.236891] Loading iSCSI transport class v2.0-870.
[ 0.240195] libphy: Fixed MDIO Bus: probed
[ 0.242959] usbcore: registered new interface driver lan78xx
[ 0.245682] usbcore: registered new interface driver smsc95xx
[ 0.248301] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.276431] dwc_otg 3f980000.usb: base=0xf0980000
[ 0.479257] Core Release: 2.80a
[ 0.481843] Setting default values for core params
[ 0.484374] Finished setting default values for core params
[ 0.687150] Using Buffer DMA mode
[ 0.689680] Periodic Transfer Interrupt Enhancement - disabled
[ 0.692328] Multiprocessor Interrupt Enhancement - disabled
[ 0.695019] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.697742] Dedicated Tx FIFOs mode
[ 0.700812] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
[ 0.706489] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.719799] dwc_otg: Microframe scheduler enabled
[ 0.719855] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e8e80
[ 0.722426] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e91e8 length 36
[ 0.725000] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[ 0.727637] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.730256] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.735460] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.738256] Init: Port Power? op_state=1
[ 0.740964] Init: Power Port (0)
[ 0.743822] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.746613] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.752080] usb usb1: Product: DWC OTG Controller
[ 0.754861] usb usb1: Manufacturer: Linux 4.14.62-v7+ dwc_otg_hcd
[ 0.757658] usb usb1: SerialNumber: 3f980000.usb
[ 0.760989] hub 1-0:1.0: USB hub found
[ 0.763746] hub 1-0:1.0: 1 port detected
[ 0.766908] dwc_otg: FIQ enabled
[ 0.766913] dwc_otg: NAK holdoff enabled
[ 0.766918] dwc_otg: FIQ split-transaction FSM enabled
[ 0.766928] Module dwc_common_port init
[ 0.767155] usbcore: registered new interface driver usb-storage
[ 0.770016] mousedev: PS/2 mouse device common for all mice
[ 0.772737] IR NEC protocol handler initialized
[ 0.775353] IR RC5(x/sz) protocol handler initialized
[ 0.777997] IR RC6 protocol handler initialized
[ 0.780648] IR JVC protocol handler initialized
[ 0.783268] IR Sony protocol handler initialized
[ 0.785854] IR SANYO protocol handler initialized
[ 0.788405] IR Sharp protocol handler initialized
[ 0.790900] IR MCE Keyboard/mouse protocol handler initialized
[ 0.793466] IR XMP protocol handler initialized
[ 0.796640] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.799512] bcm2835-cpufreq: min=600000 max=1400000
[ 0.802401] sdhci: Secure Digital Host Controller Interface driver
[ 0.804965] sdhci: Copyright(c) Pierre Ossman
[ 0.807816] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.810781] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.813550] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.817647] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.820427] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.823251] usbcore: registered new interface driver usbhid
[ 0.825918] usbhid: USB HID core driver
[ 0.829116] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[ 0.833311] [vc_sm_connected_init]: start
[ 0.843055] [vc_sm_connected_init]: end - returning 0
[ 0.846396] Initializing XFRM netlink socket
[ 0.849086] NET: Registered protocol family 17
[ 0.851843] Key type dns_resolver registered
[ 0.854886] Registering SWP/SWPB emulation handler
[ 0.858118] registered taskstats version 1
[ 0.866756] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.869638] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.877253] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.880274] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 0.942020] sdhost: log_buf @ bad13000 (fad13000)
[ 0.980530] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.981506] Indeed it is in host mode hprt0 = 00021501
[ 0.987912] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.992359] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.997904] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.031408] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.042463] of_cfs_init
[ 1.045079] of_cfs_init: OK
[ 1.048042] Waiting for root device PARTUUID=5971da25-02...
[ 1.060183] random: fast init done
[ 1.088023] mmc1: new high speed SDIO card at address 0001
[ 1.191439] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.194072] Indeed it is in host mode hprt0 = 00001101
[ 1.431662] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 1.434308] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.437499] hub 1-1:1.0: USB hub found
[ 1.440199] hub 1-1:1.0: 4 ports detected
[ 1.761418] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.891660] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
[ 1.894349] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.899912] hub 1-1.1:1.0: USB hub found
[ 1.902527] hub 1-1.1:1.0: 3 ports detected
Boot hangs here indefinitely
Plug usb keyboard in any right port, boot contiues immediately below
[ 40.116189] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 40.571413] usb 1-1.1: reset high-speed USB device number 3 using dwc_otg
[ 40.941431] usb 1-1.1: USB disconnect, device number 3
[ 41.041409] usb 1-1.1: new high-speed USB device number 4 using dwc_otg
[ 41.171649] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
[ 41.174375] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 41.180319] hub 1-1.1:1.0: USB hub found
[ 41.183182] hub 1-1.1:1.0: 3 ports detected
[ 41.281418] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ 41.458315] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2113
[ 41.461198] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 41.466794] usb 1-1.3: Product: Dell KB216 Wired Keyboard
[ 41.486126] input: Dell KB216 Wired Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2113.0001/input/input0
[ 41.521426] usb 1-1.1.2: new high-speed USB device number 6 using dwc_otg
[ 41.562053] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3f980000.usb-1.3/input0
[ 41.578318] input: Dell KB216 Wired Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:413C:2113.0002/input/input1
[ 41.651633] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3f980000.usb-1.3/input1
[ 41.658971] usb 1-1.1.2: New USB device found, idVendor=0781, idProduct=5583
[ 41.662464] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 41.669187] usb 1-1.1.2: Product: Ultra Fit
[ 41.672572] usb 1-1.1.2: Manufacturer: SanDisk
[ 41.675899] usb 1-1.1.2: SerialNumber: 4C531001390216122220
[ 41.679846] usb-storage 1-1.1.2:1.0: USB Mass Storage device detected
[ 41.683585] scsi host0: usb-storage 1-1.1.2:1.0
[ 41.981418] usb 1-1.1.1: new high-speed USB device number 7 using dwc_otg
[ 42.111799] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
[ 42.115288] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 42.254940] NOHZ: local_softirq_pending 01
[ 42.258483] NOHZ: local_softirq_pending 01
[ 42.261777] NOHZ: local_softirq_pending 01
[ 42.264957] NOHZ: local_softirq_pending 01
[ 42.268004] NOHZ: local_softirq_pending 01
[ 42.270892] NOHZ: local_softirq_pending 01
[ 42.274773] NOHZ: local_softirq_pending 01
[ 42.277397] NOHZ: local_softirq_pending 01
[ 42.279859] NOHZ: local_softirq_pending 01
[ 42.285578] NOHZ: local_softirq_pending 01
[ 42.393537] libphy: lan78xx-mdiobus: probed
[ 42.712805] scsi 0:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
[ 42.717610] sd 0:0:0:0: [sda] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
[ 42.722489] sd 0:0:0:0: [sda] Write Protect is off
[ 42.724620] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 42.725015] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 42.738447] sda: sda1 sda2
[ 42.742553] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 42.748141] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
[ 42.750340] EXT4-fs (sda2): write access will be enabled during recovery
[ 42.830157] EXT4-fs (sda2): recovery complete
[ 42.834099] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 42.838320] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[ 42.847809] devtmpfs: mounted
[ 42.853135] Freeing unused kernel memory: 1024K
[ 43.010244] random: crng init done
[ 43.294563] systemd[1]: System time before build time, advancing clock.
[ 43.407687] NET: Registered protocol family 10
[ 43.411906] Segment Routing with IPv6
[ 43.424519] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 43.450500] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 43.460838] systemd[1]: Detected architecture arm.
[ 43.476301] systemd[1]: Set hostname to <raspberrypi>.
[ 43.958615] systemd[1]: Listening on Syslog Socket.
[ 43.965738] systemd[1]: Listening on udev Control Socket.
[ 43.993141] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 44.003954] systemd[1]: Created slice User and Session Slice.
[ 44.011296] systemd[1]: Created slice System Slice.
[ 44.018150] systemd[1]: Reached target Slices.
[ 44.028207] systemd[1]: Mounting POSIX Message Queue File System...
[ 44.605676] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 44.753057] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ 45.196972] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 45.200518] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 45.337694] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 45.347147] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
[ 45.347936] usbcore: registered new interface driver brcmfmac
[ 45.505070] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 45.650734] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 45.651285] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
[ 46.787442] uart-pl011 3f201000.serial: no DMA platform data
[ 47.276313] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 47.276329] brcmfmac: power management disabled
[ 47.337309] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS
[ 47.575780] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 47.588897] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 53.611844] Bluetooth: Core ver 2.22
[ 53.611926] NET: Registered protocol family 31
[ 53.611932] Bluetooth: HCI device and connection manager initialized
[ 53.611959] Bluetooth: HCI socket layer initialized
[ 53.611972] Bluetooth: L2CAP socket layer initialized
[ 53.612003] Bluetooth: SCO socket layer initialized
[ 53.627996] Bluetooth: HCI UART driver ver 2.3
[ 53.628009] Bluetooth: HCI UART protocol H4 registered
[ 53.628015] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 53.628212] Bluetooth: HCI UART protocol Broadcom registered
[ 53.825386] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 53.825394] Bluetooth: BNEP filters: protocol multicast
[ 53.825405] Bluetooth: BNEP socket layer initialized
pi@raspberrypi:~ $
LOG NO2 - usb in right port, boots correctly:
[ 0.000274] Console: colour dummy device 80x30
[ 0.000808] console [tty1] enabled
[ 0.000846] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000886] pid_max: default: 32768 minimum: 301
[ 0.001212] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001245] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002203] Disabling memory control group subsystem
[ 0.002295] CPU: Testing write buffer coherency: ok
[ 0.002718] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003134] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003274] Hierarchical SRCU implementation.
[ 0.003964] smp: Bringing up secondary CPUs ...
[ 0.004752] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005583] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006402] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006506] smp: Brought up 1 node, 4 CPUs
[ 0.006599] CPU: All CPU(s) started in HYP mode.
[ 0.006617] CPU: Virtualization extensions available.
[ 0.007504] devtmpfs: initialized
[ 0.017697] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[ 0.018612] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.019224] pinctrl core: initialized pinctrl subsystem
[ 0.020019] NET: Registered protocol family 16
[ 0.022623] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.027457] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.027490] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.027701] Serial: AMBA PL011 UART driver
[ 0.029376] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.029856] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.061563] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[ 0.063014] SCSI subsystem initialized
[ 0.063256] usbcore: registered new interface driver usbfs
[ 0.063326] usbcore: registered new interface driver hub
[ 0.063425] usbcore: registered new device driver usb
[ 0.070079] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-08-16 17:30
[ 0.071410] clocksource: Switched to clocksource arch_sys_counter
[ 0.147906] VFS: Disk quotas dquot_6.6.0
[ 0.148020] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.148223] FS-Cache: Loaded
[ 0.148435] CacheFiles: Loaded
[ 0.157332] NET: Registered protocol family 2
[ 0.158069] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.158198] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.158400] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.158545] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.158607] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.158851] NET: Registered protocol family 1
[ 0.159324] RPC: Registered named UNIX socket transport module.
[ 0.159348] RPC: Registered udp transport module.
[ 0.159367] RPC: Registered tcp transport module.
[ 0.159386] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.160871] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.163654] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.171812] FS-Cache: Netfs 'nfs' registered for caching
[ 0.172436] NFS: Registering the id_resolver key type
[ 0.172490] Key type id_resolver registered
[ 0.172509] Key type id_legacy registered
[ 0.172538] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.174489] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.174645] io scheduler noop registered
[ 0.174667] io scheduler deadline registered (default)
[ 0.174961] io scheduler cfq registered
[ 0.174983] io scheduler mq-deadline registered
[ 0.175003] io scheduler kyber registered
[ 0.177303] BCM2708FB: allocated DMA memory fad00000
[ 0.177347] BCM2708FB: allocated DMA channel 0 @ bb813000
[ 0.186769] Console: switching to colour frame buffer device 80x30
[ 0.196016] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.198747] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.204489] vc-sm: Videocore shared memory driver
[ 0.207474] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.222833] brd: module loaded
[ 0.234287] loop: module loaded
[ 0.237026] Loading iSCSI transport class v2.0-870.
[ 0.240344] libphy: Fixed MDIO Bus: probed
[ 0.243098] usbcore: registered new interface driver lan78xx
[ 0.245825] usbcore: registered new interface driver smsc95xx
[ 0.248453] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.276590] dwc_otg 3f980000.usb: base=0xf0980000
[ 0.479409] Core Release: 2.80a
[ 0.481982] Setting default values for core params
[ 0.484515] Finished setting default values for core params
[ 0.687306] Using Buffer DMA mode
[ 0.689843] Periodic Transfer Interrupt Enhancement - disabled
[ 0.692497] Multiprocessor Interrupt Enhancement - disabled
[ 0.695194] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.697916] Dedicated Tx FIFOs mode
[ 0.701001] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
[ 0.706697] FIQ FSM acceleration enabled for :
[ 0.720044] dwc_otg: Microframe scheduler enabled
[ 0.720095] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e8e80
[ 0.722659] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e91e8 length 36
[ 0.725237] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[ 0.727890] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.730511] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.735720] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.738517] Init: Port Power? op_state=1
[ 0.741227] Init: Power Port (0)
[ 0.744081] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.746871] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.752332] usb usb1: Product: DWC OTG Controller
[ 0.755104] usb usb1: Manufacturer: Linux 4.14.62-v7+ dwc_otg_hcd
[ 0.757896] usb usb1: SerialNumber: 3f980000.usb
[ 0.761202] hub 1-0:1.0: USB hub found
[ 0.763956] hub 1-0:1.0: 1 port detected
[ 0.767115] dwc_otg: FIQ enabled
[ 0.767120] dwc_otg: NAK holdoff enabled
[ 0.767124] dwc_otg: FIQ split-transaction FSM enabled
[ 0.767134] Module dwc_common_port init
[ 0.767357] usbcore: registered new interface driver usb-storage
[ 0.770202] mousedev: PS/2 mouse device common for all mice
[ 0.772923] IR NEC protocol handler initialized
[ 0.775532] IR RC5(x/sz) protocol handler initialized
[ 0.778168] IR RC6 protocol handler initialized
[ 0.780811] IR JVC protocol handler initialized
[ 0.783422] IR Sony protocol handler initialized
[ 0.786003] IR SANYO protocol handler initialized
[ 0.788549] IR Sharp protocol handler initialized
[ 0.791043] IR MCE Keyboard/mouse protocol handler initialized
[ 0.793611] IR XMP protocol handler initialized
[ 0.796775] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.799635] bcm2835-cpufreq: min=600000 max=1400000
[ 0.802522] sdhci: Secure Digital Host Controller Interface driver
[ 0.805081] sdhci: Copyright(c) Pierre Ossman
[ 0.807934] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.810892] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.813668] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.817722] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.820502] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.823381] usbcore: registered new interface driver usbhid
[ 0.826045] usbhid: USB HID core driver
[ 0.829268] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[ 0.833451] [vc_sm_connected_init]: start
[ 0.843231] [vc_sm_connected_init]: end - returning 0
[ 0.846575] Initializing XFRM netlink socket
[ 0.849265] NET: Registered protocol family 17
[ 0.852021] Key type dns_resolver registered
[ 0.855062] Registering SWP/SWPB emulation handler
[ 0.858286] registered taskstats version 1
[ 0.866898] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.869773] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.877426] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.880442] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 0.942036] sdhost: log_buf @ bad13000 (fad13000)
[ 0.981326] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.981529] Indeed it is in host mode hprt0 = 00021501
[ 0.988684] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.993158] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.998742] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.021427] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.042499] of_cfs_init
[ 1.045146] of_cfs_init: OK
[ 1.048136] Waiting for root device PARTUUID=5971da25-02...
[ 1.052201] random: fast init done
[ 1.089621] mmc1: new high speed SDIO card at address 0001
[ 1.201434] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.204084] Indeed it is in host mode hprt0 = 00001101
[ 1.441683] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 1.444345] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.447551] hub 1-1:1.0: USB hub found
[ 1.450273] hub 1-1:1.0: 4 ports detected
[ 1.771438] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.901679] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
[ 1.904388] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.909975] hub 1-1.1:1.0: USB hub found
[ 1.912605] hub 1-1.1:1.0: 3 ports detected
[ 2.057309] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 2.691438] usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
[ 2.821843] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
[ 2.824483] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.921636] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 2.962507] NOHZ: local_softirq_pending 01
[ 2.966485] NOHZ: local_softirq_pending 01
[ 2.970360] NOHZ: local_softirq_pending 01
[ 2.975380] NOHZ: local_softirq_pending 01
[ 2.980297] NOHZ: local_softirq_pending 01
[ 2.993141] NOHZ: local_softirq_pending 01
[ 2.999018] NOHZ: local_softirq_pending 01
[ 3.007054] NOHZ: local_softirq_pending 01
[ 3.010411] NOHZ: local_softirq_pending 01
[ 3.015933] NOHZ: local_softirq_pending 01
[ 3.057014] usb 1-1.3: New USB device found, idVendor=0781, idProduct=5583
[ 3.059137] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.063331] usb 1-1.3: Product: Ultra Fit
[ 3.065426] usb 1-1.3: Manufacturer: SanDisk
[ 3.067490] usb 1-1.3: SerialNumber: 4C531001390216122220
[ 3.077565] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 3.085384] scsi host0: usb-storage 1-1.3:1.0
[ 3.098010] libphy: lan78xx-mdiobus: probed
[ 4.152844] scsi 0:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
[ 4.157777] sd 0:0:0:0: [sda] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
[ 4.162828] sd 0:0:0:0: [sda] Write Protect is off
[ 4.164951] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 4.165308] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 4.178583] sda: sda1 sda2
[ 4.182688] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.205449] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.210585] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[ 4.220606] devtmpfs: mounted
[ 4.226453] Freeing unused kernel memory: 1024K
[ 4.638946] systemd[1]: System time before build time, advancing clock.
[ 4.749532] NET: Registered protocol family 10
[ 4.753952] Segment Routing with IPv6
[ 4.766758] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.787402] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.795850] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.806229] systemd[1]: Detected architecture arm.
[ 4.822043] systemd[1]: Set hostname to <raspberrypi>.
[ 4.857186] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.879511] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 5.199036] random: crng init done
[ 5.202157] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.306830] systemd[1]: Listening on Syslog Socket.
[ 5.314220] systemd[1]: Listening on Journal Socket.
[ 5.321500] systemd[1]: Created slice System Slice.
[ 5.329143] systemd[1]: Created slice system-getty.slice.
[ 5.341138] systemd[1]: Starting Load Kernel Modules...
[ 5.348271] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.358359] systemd[1]: Mounting RPC Pipe File System...
[ 5.890971] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 6.013546] systemd-journald[105]: Received request to flush runtime journal from PID 1
[ 6.549913] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.553671] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 6.684256] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.693916] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
[ 6.694640] usbcore: registered new interface driver brcmfmac
[ 6.836136] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.003973] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 7.004540] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
[ 7.967338] uart-pl011 3f201000.serial: no DMA platform data
[ 8.431074] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS
[ 8.578630] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.578845] brcmfmac: power management disabled
[ 8.749445] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.757238] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.559836] Bluetooth: Core ver 2.22
[ 14.559921] NET: Registered protocol family 31
[ 14.559924] Bluetooth: HCI device and connection manager initialized
[ 14.560735] Bluetooth: HCI socket layer initialized
[ 14.560748] Bluetooth: L2CAP socket layer initialized
[ 14.560777] Bluetooth: SCO socket layer initialized
[ 14.569821] Bluetooth: HCI UART driver ver 2.3
[ 14.569829] Bluetooth: HCI UART protocol H4 registered
[ 14.569831] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.569938] Bluetooth: HCI UART protocol Broadcom registered
[ 14.719338] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.719348] Bluetooth: BNEP filters: protocol multicast
[ 14.719364] Bluetooth: BNEP socket layer initialized
pi@raspberrypi:~ $
Many thanks!
pi@raspberrypi:~ $
pi@raspberrypi:~ $
- HawaiianPi
Has your Raspbian OS been updated?
There is some new firmware that is supposed to fix some USB boot issues.
- davidcoton
- Contact: Website
FTFY (misplaced hyphen, full-upgrade not apt-full)HawaiianPi wrote: ↑Mon Sep 03, 2018 8:36 amHas your Raspbian OS been updated?There is some new firmware that is supposed to fix some USB boot issues.Code: Select all
Thanks for the replies. I updated again this morining (same as yesterday: sudo apt update && sudo apt full-upgrade -y).
Now Sandisk 32gb work about 1 in 5 boots, in the left usb ports.
But Sandisk 16gb work perfectly, every time, on any usb port now (tested multiple 16gb drives on two different Pi3 B+). The image gets reduced to 4gb anyway for fast cloning, so will stick with 16gb drives.
Many Thanks!
Many Thanks!
- HawaiianPi
I was unable to find any difference in how my 3B+ USB boots, regardless of the port I used. However, I'm not using Ethernet at the moment, so that could be a factor.
Not that it would directly explain why it happens to you but left ports are different than right ports. On pi 3B+ there are two cascaded usb hubs. From Pi cpu usb goes to first hub with two right ports and second usb hub is connected to its third port. This second hub has two left ports and ethernet connected to its third port. So when booted from left ports the usb data go across two cascaded usb hubs and the device is connected to same hub as ethernet. While it should work (and it works perfectly for me, never noticed any difference between left and right ports with usb booting even with ethernet connected) it may be that this triggers some bug somewhere with your specific setup.
EDIT:
I have posted more info about nested hubs here https://www.raspberrypi.org/forums/view ... 3#p1290763
EDIT:
Tried replicating this with my USB HDD boot RPi3B+ with the latest Raspian Stretch Desktop
The USB HDD was plugged in the top left USB port
The logitech unifying receiver plugged in the bottom left USB port
Nothing on the right ports
It booted with both WiFi and Ethenet enabled, and with Ethernet connection only
Shutdown, then exchanged the positions of USB HDD and unifying receiver
Ethernet only connection
Rebooted.... It booted
:~ $ lsusb
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 006: ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
~ $ lsusb
Some people be like:
Have you found any solution for this problem ?
I have the same symptoms. I have Rpi 3B+ with usb flash drive inserted in center USB port. Roughly one of five boots the Rpi3B+ doesn't start ethernet (no ethernet leds are on) and the flash drive is not present to the system. When I after that put usb keyboard on the right usb port the ethernet and flash drive starts working. I am using latest rasbian stretch packages.
4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
ii raspberrypi-bootloader 1.20190819~stretch-1 armhf Raspberry Pi bootloader
ii raspberrypi-kernel 1.20190819~stretch-1 armhf Raspberry Pi bootloader
ii raspberrypi-net-mods 1.2.7 all Network configuration for the Raspberry Pi UI
ii raspberrypi-sys-mods 20181127 armhf System tweaks for the Raspberry Pi
When flash drive is in right usb port no issue is detected.
I have tested it for 20 Rpi3B+ and all have the same symptoms. When the same image is on Rpi3B no issue is present and everything is ok.
It's not a power supply issue. I have tested it with original Rpi 2.5A power supply.
This is log for 1 phase before I plugged the keyboard to right usb port
- Nov 3 18:16:44 promotion kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Nov 3 18:16:44 promotion kernel: [ 0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
Nov 3 18:16:44 promotion kernel: [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Nov 3 18:16:44 promotion kernel: [ 0.000000] CPU: div instructions available: patching division code
Nov 3 18:16:44 promotion kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Nov 3 18:16:44 promotion kernel: [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
Nov 3 18:16:44 promotion kernel: [ 0.000000] Memory policy: Data cache writealloc
Nov 3 18:16:44 promotion kernel: [ 0.000000] cma: Reserved 8 MiB at 0x2f800000
Nov 3 18:16:44 promotion kernel: [ 0.000000] On node 0 totalpages: 196608
Nov 3 18:16:44 promotion kernel: [ 0.000000] Normal zone: 1728 pages used for memmap
Nov 3 18:16:44 promotion kernel: [ 0.000000] Normal zone: 0 pages reserved
Nov 3 18:16:44 promotion kernel: [ 0.000000] Normal zone: 196608 pages, LIFO batch:63
Nov 3 18:16:44 promotion kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
Nov 3 18:16:44 promotion kernel: [ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
Nov 3 18:16:44 promotion kernel: [ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
Nov 3 18:16:44 promotion kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Nov 3 18:16:44 promotion kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 194880
Nov 3 18:16:44 promotion kernel: [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.mode=skip logo.nologo quiet loglevel=3 vt.global_cursor_default=0 consoleblank=10 rootwait noswap ro
Nov 3 18:16:44 promotion kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.000000] Memory: 756388K/786432K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 21852K reserved, 8192K cma-reserved)
Nov 3 18:16:44 promotion kernel: [ 0.000000] Virtual kernel memory layout:
Nov 3 18:16:44 promotion kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] vmalloc : 0xb0800000 - 0xff800000 (1264 MB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] lowmem : 0x80000000 - 0xb0000000 ( 768 MB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (9184 kB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 630 kB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 822 kB)
Nov 3 18:16:44 promotion kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Nov 3 18:16:44 promotion kernel: [ 0.000000] ftrace: allocating 26394 entries in 78 pages
Nov 3 18:16:44 promotion kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Nov 3 18:16:44 promotion kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Nov 3 18:16:44 promotion kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Nov 3 18:16:44 promotion kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Nov 3 18:16:44 promotion kernel: [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Nov 3 18:16:44 promotion kernel: [ 0.000019] Switching to timer-based delay loop, resolution 52ns
Nov 3 18:16:44 promotion kernel: [ 0.000287] Console: colour dummy device 80x30
Nov 3 18:16:44 promotion kernel: [ 0.000306] console [tty3] enabled
Nov 3 18:16:44 promotion kernel: [ 0.000352] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Nov 3 18:16:44 promotion kernel: [ 0.000368] pid_max: default: 32768 minimum: 301
Nov 3 18:16:44 promotion kernel: [ 0.000710] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.000725] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.001633] CPU: Testing write buffer coherency: ok
Nov 3 18:16:44 promotion kernel: [ 0.002099] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Nov 3 18:16:44 promotion kernel: [ 0.002748] Setting up static identity map for 0x100000 - 0x10003c
Nov 3 18:16:44 promotion kernel: [ 0.002895] rcu: Hierarchical SRCU implementation.
Nov 3 18:16:44 promotion kernel: [ 0.003689] smp: Bringing up secondary CPUs ...
Nov 3 18:16:44 promotion kernel: [ 0.004528] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Nov 3 18:16:44 promotion kernel: [ 0.005452] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Nov 3 18:16:44 promotion kernel: [ 0.006314] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Nov 3 18:16:44 promotion kernel: [ 0.006437] smp: Brought up 1 node, 4 CPUs
Nov 3 18:16:44 promotion kernel: [ 0.006448] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Nov 3 18:16:44 promotion kernel: [ 0.006454] CPU: All CPU(s) started in HYP mode.
Nov 3 18:16:44 promotion kernel: [ 0.006459] CPU: Virtualization extensions available.
Nov 3 18:16:44 promotion kernel: [ 0.007401] devtmpfs: initialized
Nov 3 18:16:44 promotion kernel: [ 0.020638] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Nov 3 18:16:44 promotion kernel: [ 0.020878] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Nov 3 18:16:44 promotion kernel: [ 0.020896] futex hash table entries: 1024 (order: 4, 65536 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.021487] pinctrl core: initialized pinctrl subsystem
Nov 3 18:16:44 promotion kernel: [ 0.022341] NET: Registered protocol family 16
Nov 3 18:16:44 promotion kernel: [ 0.025381] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Nov 3 18:16:44 promotion kernel: [ 0.031168] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Nov 3 18:16:44 promotion kernel: [ 0.031177] hw-breakpoint: maximum watchpoint size is 8 bytes.
Nov 3 18:16:44 promotion kernel: [ 0.031379] Serial: AMBA PL011 UART driver
Nov 3 18:16:44 promotion kernel: [ 0.033675] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Nov 3 18:16:44 promotion kernel: [ 0.068749] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
Nov 3 18:16:44 promotion kernel: [ 0.070435] SCSI subsystem initialized
Nov 3 18:16:44 promotion kernel: [ 0.070659] usbcore: registered new interface driver usbfs
Nov 3 18:16:44 promotion kernel: [ 0.070720] usbcore: registered new interface driver hub
Nov 3 18:16:44 promotion kernel: [ 0.070814] usbcore: registered new device driver usb
Nov 3 18:16:44 promotion kernel: [ 0.090125] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
Nov 3 18:16:44 promotion kernel: [ 0.100387] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
Nov 3 18:16:44 promotion kernel: [ 0.111817] clocksource: Switched to clocksource arch_sys_counter
Nov 3 18:16:44 promotion kernel: [ 0.200943] VFS: Disk quotas dquot_6.6.0
Nov 3 18:16:44 promotion kernel: [ 0.201024] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.201212] FS-Cache: Loaded
Nov 3 18:16:44 promotion kernel: [ 0.201423] CacheFiles: Loaded
Nov 3 18:16:44 promotion kernel: [ 0.211465] NET: Registered protocol family 2
Nov 3 18:16:44 promotion kernel: [ 0.212266] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.212303] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.212413] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.212598] TCP: Hash tables configured (established 8192 bind 8192)
Nov 3 18:16:44 promotion kernel: [ 0.212739] UDP hash table entries: 512 (order: 2, 16384 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.212785] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.213094] NET: Registered protocol family 1
Nov 3 18:16:44 promotion kernel: [ 0.213666] RPC: Registered named UNIX socket transport module.
Nov 3 18:16:44 promotion kernel: [ 0.213672] RPC: Registered udp transport module.
Nov 3 18:16:44 promotion kernel: [ 0.213678] RPC: Registered tcp transport module.
Nov 3 18:16:44 promotion kernel: [ 0.213684] RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 3 18:16:44 promotion kernel: [ 0.215412] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Nov 3 18:16:44 promotion kernel: [ 0.218417] Initialise system trusted keyrings
Nov 3 18:16:44 promotion kernel: [ 0.218602] workingset: timestamp_bits=14 max_order=18 bucket_order=4
Nov 3 18:16:44 promotion kernel: [ 0.228589] FS-Cache: Netfs 'nfs' registered for caching
Nov 3 18:16:44 promotion kernel: [ 0.229160] NFS: Registering the id_resolver key type
Nov 3 18:16:44 promotion kernel: [ 0.229194] Key type id_resolver registered
Nov 3 18:16:44 promotion kernel: [ 0.229200] Key type id_legacy registered
Nov 3 18:16:44 promotion kernel: [ 0.229217] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Nov 3 18:16:44 promotion kernel: [ 0.231462] Key type asymmetric registered
Nov 3 18:16:44 promotion kernel: [ 0.231471] Asymmetric key parser 'x509' registered
Nov 3 18:16:44 promotion kernel: [ 0.231520] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Nov 3 18:16:44 promotion kernel: [ 0.231676] io scheduler noop registered
Nov 3 18:16:44 promotion kernel: [ 0.231684] io scheduler deadline registered (default)
Nov 3 18:16:44 promotion kernel: [ 0.231938] io scheduler cfq registered
Nov 3 18:16:44 promotion kernel: [ 0.231946] io scheduler mq-deadline registered (default)
Nov 3 18:16:44 promotion kernel: [ 0.231954] io scheduler kyber registered
Nov 3 18:16:44 promotion kernel: [ 0.234141] bcm2708_fb soc:fb: FB found 1 display(s)
Nov 3 18:16:44 promotion kernel: [ 0.292597] Console: switching to colour frame buffer device 240x67
Nov 3 18:16:44 promotion kernel: [ 0.327941] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
Nov 3 18:16:44 promotion kernel: [ 0.329086] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
Nov 3 18:16:44 promotion kernel: [ 0.330551] bcm2835-rng 3f104000.rng: hwrng registered
Nov 3 18:16:44 promotion kernel: [ 0.330853] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Nov 3 18:16:44 promotion kernel: [ 0.331385] vc-sm: Videocore shared memory driver
Nov 3 18:16:44 promotion kernel: [ 0.331702] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Nov 3 18:16:44 promotion kernel: [ 0.342733] brd: module loaded
Nov 3 18:16:44 promotion kernel: [ 0.353325] loop: module loaded
Nov 3 18:16:44 promotion kernel: [ 0.353973] Loading iSCSI transport class v2.0-870.
Nov 3 18:16:44 promotion kernel: [ 0.354692] libphy: Fixed MDIO Bus: probed
Nov 3 18:16:44 promotion kernel: [ 0.354805] usbcore: registered new interface driver lan78xx
Nov 3 18:16:44 promotion kernel: [ 0.354864] usbcore: registered new interface driver smsc95xx
Nov 3 18:16:44 promotion kernel: [ 0.354882] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Nov 3 18:16:44 promotion kernel: [ 0.382742] dwc_otg 3f980000.usb: base=(ptrval)
Nov 3 18:16:44 promotion kernel: [ 0.582982] Core Release: 2.80a
Nov 3 18:16:44 promotion kernel: [ 0.582992] Setting default values for core params
Nov 3 18:16:44 promotion kernel: [ 0.583027] Finished setting default values for core params
Nov 3 18:16:44 promotion kernel: [ 0.783349] Using Buffer DMA mode
Nov 3 18:16:44 promotion kernel: [ 0.783355] Periodic Transfer Interrupt Enhancement - disabled
Nov 3 18:16:44 promotion kernel: [ 0.783362] Multiprocessor Interrupt Enhancement - disabled
Nov 3 18:16:44 promotion kernel: [ 0.783369] OTG VER PARAM: 0, OTG VER FLAG: 0
Nov 3 18:16:44 promotion kernel: [ 0.783386] Dedicated Tx FIFOs mode
Nov 3 18:16:44 promotion kernel: [ 0.783870] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = af914000 dma = 0xef914000 len=9024
Nov 3 18:16:44 promotion kernel: [ 0.783900] FIQ FSM acceleration enabled for :
Nov 3 18:16:44 promotion kernel: [ 0.783900] Non-periodic Split Transactions
Nov 3 18:16:44 promotion kernel: [ 0.783900] Periodic Split Transactions
Nov 3 18:16:44 promotion kernel: [ 0.783900] High-Speed Isochronous Endpoints
Nov 3 18:16:44 promotion kernel: [ 0.783900] Interrupt/Control Split Transaction hack enabled
Nov 3 18:16:44 promotion kernel: [ 0.783908] dwc_otg: Microframe scheduler enabled
Nov 3 18:16:44 promotion kernel: [ 0.783969] WARN::hcd_init_fiq:457: FIQ on core 1
Nov 3 18:16:44 promotion kernel: [ 0.783980] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
Nov 3 18:16:44 promotion kernel: [ 0.783993] WARN::hcd_init_fiq:497: MPHI regs_base at b0810000
Nov 3 18:16:44 promotion kernel: [ 0.784012] dwc_otg 3f980000.usb: DWC OTG Controller
Nov 3 18:16:44 promotion kernel: [ 0.784045] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Nov 3 18:16:44 promotion kernel: [ 0.784081] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
Nov 3 18:16:44 promotion kernel: [ 0.784130] Init: Port Power? op_state=1
Nov 3 18:16:44 promotion kernel: [ 0.784136] Init: Power Port (0)
Nov 3 18:16:44 promotion kernel: [ 0.784398] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Nov 3 18:16:44 promotion kernel: [ 0.784410] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 3 18:16:44 promotion kernel: [ 0.784419] usb usb1: Product: DWC OTG Controller
Nov 3 18:16:44 promotion kernel: [ 0.784429] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
Nov 3 18:16:44 promotion kernel: [ 0.784438] usb usb1: SerialNumber: 3f980000.usb
Nov 3 18:16:44 promotion kernel: [ 0.785082] hub 1-0:1.0: USB hub found
Nov 3 18:16:44 promotion kernel: [ 0.785135] hub 1-0:1.0: 1 port detected
Nov 3 18:16:44 promotion kernel: [ 0.785717] dwc_otg: FIQ enabled
Nov 3 18:16:44 promotion kernel: [ 0.785723] dwc_otg: NAK holdoff enabled
Nov 3 18:16:44 promotion kernel: [ 0.785729] dwc_otg: FIQ split-transaction FSM enabled
Nov 3 18:16:44 promotion kernel: [ 0.785739] Module dwc_common_port init
Nov 3 18:16:44 promotion kernel: [ 0.786000] usbcore: registered new interface driver usb-storage
Nov 3 18:16:44 promotion kernel: [ 0.786183] mousedev: PS/2 mouse device common for all mice
Nov 3 18:16:44 promotion kernel: [ 0.787056] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Nov 3 18:16:44 promotion kernel: [ 0.787296] bcm2835-cpufreq: min=600000 max=1400000
Nov 3 18:16:44 promotion kernel: [ 0.787769] sdhci: Secure Digital Host Controller Interface driver
Nov 3 18:16:44 promotion kernel: [ 0.787776] sdhci: Copyright(c) Pierre Ossman
Nov 3 18:16:44 promotion kernel: [ 0.788158] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
Nov 3 18:16:44 promotion kernel: [ 0.788541] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Nov 3 18:16:44 promotion kernel: [ 0.788664] sdhci-pltfm: SDHCI platform and OF driver helper
Nov 3 18:16:44 promotion kernel: [ 0.791061] ledtrig-cpu: registered to indicate activity on CPUs
Nov 3 18:16:44 promotion kernel: [ 0.791216] hidraw: raw HID events driver (C) Jiri Kosina
Nov 3 18:16:44 promotion kernel: [ 0.791423] usbcore: registered new interface driver usbhid
Nov 3 18:16:44 promotion kernel: [ 0.791429] usbhid: USB HID core driver
Nov 3 18:16:44 promotion kernel: [ 0.792335] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
Nov 3 18:16:44 promotion kernel: [ 0.794041] [vc_sm_connected_init]: start
Nov 3 18:16:44 promotion kernel: [ 0.803835] [vc_sm_connected_init]: end - returning 0
Nov 3 18:16:44 promotion kernel: [ 0.804969] Initializing XFRM netlink socket
Nov 3 18:16:44 promotion kernel: [ 0.804996] NET: Registered protocol family 17
Nov 3 18:16:44 promotion kernel: [ 0.805118] Key type dns_resolver registered
Nov 3 18:16:44 promotion kernel: [ 0.805692] Registering SWP/SWPB emulation handler
Nov 3 18:16:44 promotion kernel: [ 0.806361] registered taskstats version 1
Nov 3 18:16:44 promotion kernel: [ 0.806380] Loading compiled-in X.509 certificates
Nov 3 18:16:44 promotion kernel: [ 0.813659] uart-pl011 3f201000.serial: cts_event_workaround enabled
Nov 3 18:16:44 promotion kernel: [ 0.813749] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
Nov 3 18:16:44 promotion kernel: [ 0.815648] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
Nov 3 18:16:44 promotion kernel: [ 0.815658] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
Nov 3 18:16:44 promotion kernel: [ 0.842109] sdhost: log_buf @ (ptrval) (ef913000)
Nov 3 18:16:44 promotion kernel: [ 0.877464] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.879049] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.880634] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.883470] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Nov 3 18:16:44 promotion kernel: [ 0.890595] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Nov 3 18:16:44 promotion kernel: [ 0.891984] of_cfs_init
Nov 3 18:16:44 promotion kernel: [ 0.892084] of_cfs_init: OK
Nov 3 18:16:44 promotion kernel: [ 0.893380] Waiting for root device /dev/mmcblk0p2...
Nov 3 18:16:44 promotion kernel: [ 0.957472] random: fast init done
Nov 3 18:16:44 promotion kernel: [ 0.965991] mmc1: new high speed SDIO card at address 0001
Nov 3 18:16:44 promotion kernel: [ 0.981690] mmc0: host does not support reading read-only switch, assuming write-enable
Nov 3 18:16:44 promotion kernel: [ 0.985487] mmc0: new high speed SDHC card at address aaaa
Nov 3 18:16:44 promotion kernel: [ 0.986696] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
Nov 3 18:16:44 promotion kernel: [ 0.989710] mmcblk0: p1 p2 p3
Nov 3 18:16:44 promotion kernel: [ 1.001963] Indeed it is in host mode hprt0 = 00021501
Nov 3 18:16:44 promotion kernel: [ 1.024030] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Nov 3 18:16:44 promotion kernel: [ 1.024083] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Nov 3 18:16:44 promotion kernel: [ 1.031388] devtmpfs: mounted
Nov 3 18:16:44 promotion kernel: [ 1.063921] Freeing unused kernel memory: 1024K
Nov 3 18:16:44 promotion kernel: [ 1.112241] Run /sbin/init as init process
Nov 3 18:16:44 promotion kernel: [ 1.211874] usb 1-1: new high-speed USB device number 2 using dwc_otg
Nov 3 18:16:44 promotion kernel: [ 1.212046] Indeed it is in host mode hprt0 = 00001101
Nov 3 18:16:44 promotion kernel: [ 1.452183] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Nov 3 18:16:44 promotion kernel: [ 1.452200] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 3 18:16:44 promotion kernel: [ 1.452938] hub 1-1:1.0: USB hub found
Nov 3 18:16:44 promotion kernel: [ 1.453037] hub 1-1:1.0: 4 ports detected
Nov 3 18:16:44 promotion kernel: [ 1.715891] NET: Registered protocol family 10
Nov 3 18:16:44 promotion kernel: [ 1.717254] Segment Routing with IPv6
Nov 3 18:16:44 promotion kernel: [ 1.746889] random: systemd: uninitialized urandom read (16 bytes read)
Nov 3 18:16:44 promotion kernel: [ 1.749335] random: systemd: uninitialized urandom read (16 bytes read)
Nov 3 18:16:44 promotion kernel: [ 1.771889] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Nov 3 18:16:44 promotion kernel: [ 1.827363] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
Nov 3 18:16:44 promotion kernel: [ 1.902356] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Nov 3 18:16:44 promotion kernel: [ 1.902372] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 3 18:16:44 promotion kernel: [ 1.903066] hub 1-1.1:1.0: USB hub found
Nov 3 18:16:44 promotion kernel: [ 1.903154] hub 1-1.1:1.0: 3 ports detected
Nov 3 18:16:44 promotion kernel: [ 2.486079] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Nov 3 18:16:44 promotion kernel: [ 3.243593] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Nov 3 18:16:44 promotion kernel: [ 3.246165] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Nov 3 18:16:44 promotion kernel: [ 3.246182] [vc_sm_connected_init]: start
Nov 3 18:16:44 promotion kernel: [ 3.252066] [vc_sm_connected_init]: installed successfully
Nov 3 18:16:44 promotion kernel: [ 3.254766] media: Linux media interface: v0.10
Nov 3 18:16:44 promotion kernel: [ 3.313393] videodev: Linux video capture interface: v2.00
Nov 3 18:16:44 promotion kernel: [ 3.368711] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Nov 3 18:16:44 promotion kernel: [ 3.369030] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Nov 3 18:16:44 promotion kernel: [ 3.392732] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Nov 3 18:16:44 promotion kernel: [ 3.403246] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Nov 3 18:16:44 promotion kernel: [ 3.419963] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Nov 3 18:16:44 promotion kernel: [ 3.419980] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Nov 3 18:16:44 promotion kernel: [ 3.430911] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Nov 3 18:16:44 promotion kernel: [ 3.430927] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Nov 3 18:16:44 promotion kernel: [ 3.441792] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Nov 3 18:16:44 promotion kernel: [ 3.441874] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Nov 3 18:16:44 promotion kernel: [ 3.543222] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Nov 3 18:16:44 promotion kernel: [ 3.651309] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Nov 3 18:16:44 promotion kernel: [ 3.736748] brcmfmac: F1 signature read @0x18000000=0x15264345
Nov 3 18:16:44 promotion kernel: [ 3.748671] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Nov 3 18:16:44 promotion kernel: [ 3.749195] usbcore: registered new interface driver brcmfmac
Nov 3 18:16:44 promotion kernel: [ 4.014920] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Nov 3 18:16:44 promotion kernel: [ 4.036060] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
Nov 3 18:16:44 promotion kernel: [ 4.532537] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Nov 3 18:17:02 promotion kernel: [ 22.137027] uart-pl011 3f201000.serial: no DMA platform data
Nov 3 18:17:06 promotion kernel: [ 26.041319] random: crng init done
Nov 3 18:17:06 promotion kernel: [ 26.041334] random: 7 urandom warning(s) missed due to ratelimiting
- Nov 3 18:19:48 promotion kernel: [ 188.119873] dwc_otg_handle_wakeup_detected_intr lxstate = 2
Nov 3 18:19:49 promotion kernel: [ 188.571864] usb 1-1.1: reset high-speed USB device number 3 using dwc_otg
Nov 3 18:19:49 promotion kernel: [ 188.941898] usb 1-1.1: USB disconnect, device number 3
Nov 3 18:19:49 promotion kernel: [ 189.041870] usb 1-1.1: new high-speed USB device number 4 using dwc_otg
Nov 3 18:19:49 promotion kernel: [ 189.172120] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Nov 3 18:19:49 promotion kernel: [ 189.172136] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 3 18:19:49 promotion kernel: [ 189.172899] hub 1-1.1:1.0: USB hub found
Nov 3 18:19:49 promotion kernel: [ 189.172994] hub 1-1.1:1.0: 3 ports detected
Nov 3 18:19:49 promotion kernel: [ 189.491862] usb 1-1.1.3: new high-speed USB device number 5 using dwc_otg
Nov 3 18:19:50 promotion kernel: [ 189.623001] usb 1-1.1.3: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00
Nov 3 18:19:50 promotion kernel: [ 189.623017] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 3 18:19:50 promotion kernel: [ 189.623027] usb 1-1.1.3: Product: Flash Drive FIT
Nov 3 18:19:50 promotion kernel: [ 189.623037] usb 1-1.1.3: Manufacturer: Samsung
Nov 3 18:19:50 promotion kernel: [ 189.623046] usb 1-1.1.3: SerialNumber: 0318819110003560
Nov 3 18:19:50 promotion kernel: [ 189.623963] usb-storage 1-1.1.3:1.0: USB Mass Storage device detected
Nov 3 18:19:50 promotion kernel: [ 189.627327] scsi host0: usb-storage 1-1.1.3:1.0
Nov 3 18:19:50 promotion kernel: [ 189.703987] usbcore: registered new interface driver uas
Nov 3 18:19:50 promotion kernel: [ 189.731875] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
Nov 3 18:19:50 promotion kernel: [ 189.873366] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
Nov 3 18:19:50 promotion kernel: [ 189.873383] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Nov 3 18:19:50 promotion kernel: [ 189.873393] usb 1-1.2: Product: USB2.0 Hub
Nov 3 18:19:50 promotion kernel: [ 189.874309] hub 1-1.2:1.0: USB hub found
Nov 3 18:19:50 promotion kernel: [ 189.874647] hub 1-1.2:1.0: 4 ports detected
Nov 3 18:19:50 promotion kernel: [ 189.971861] usb 1-1.1.1: new high-speed USB device number 7 using dwc_otg
Nov 3 18:19:50 promotion kernel: [ 190.102315] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
Nov 3 18:19:50 promotion kernel: [ 190.102331] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 3 18:19:50 promotion kernel: [ 190.201835] usb 1-1.2.1: new low-speed USB device number 8 using dwc_otg
Nov 3 18:19:50 promotion kernel: [ 190.364905] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
Nov 3 18:19:50 promotion kernel: [ 190.365456] libphy: lan78xx-mdiobus: probed
Nov 3 18:19:50 promotion kernel: [ 190.371096] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
Nov 3 18:19:50 promotion kernel: [ 190.404667] br0: port 1(eth0) entered blocking state
Nov 3 18:19:50 promotion kernel: [ 190.404675] br0: port 1(eth0) entered disabled state
Nov 3 18:19:50 promotion kernel: [ 190.404874] device eth0 entered promiscuous mode
Nov 3 18:19:50 promotion kernel: [ 190.407845] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Nov 3 18:19:50 promotion kernel: [ 190.484104] usb 1-1.2.1: New USB device found, idVendor=04d9, idProduct=0006, bcdDevice= 1.10
Nov 3 18:19:50 promotion kernel: [ 190.484113] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 3 18:19:50 promotion kernel: [ 190.484117] usb 1-1.2.1: Product: RPI Wired Keyboard 4
Nov 3 18:19:50 promotion kernel: [ 190.484121] usb 1-1.2.1: Manufacturer:
Nov 3 18:19:50 promotion kernel: [ 190.551522] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:04D9:0006.0001/input/input0
Nov 3 18:19:51 promotion kernel: [ 190.612211] hid-generic 0003:04D9:0006.0001: input,hidraw0: USB HID v1.11 Keyboard [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.2.1/input0
Nov 3 18:19:51 promotion kernel: [ 190.665178] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:04D9:0006.0002/input/input1
Nov 3 18:19:51 promotion kernel: [ 190.731989] hid-generic 0003:04D9:0006.0002: input,hidraw1: USB HID v1.11 Device [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.2.1/input1
Nov 3 18:19:51 promotion kernel: [ 190.918517] scsi 0:0:0:0: Direct-Access Samsung Flash Drive FIT 1100 PQ: 0 ANSI: 6
Nov 3 18:19:51 promotion kernel: [ 190.919973] sd 0:0:0:0: [sda] 62656641 512-byte logical blocks: (32.1 GB/29.9 GiB)
Nov 3 18:19:51 promotion kernel: [ 190.920271] sd 0:0:0:0: [sda] Write Protect is off
Nov 3 18:19:51 promotion kernel: [ 190.920294] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
Nov 3 18:19:51 promotion kernel: [ 190.920718] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov 3 18:19:51 promotion kernel: [ 190.932971] sda: sda1
Nov 3 18:19:51 promotion kernel: [ 190.935294] sd 0:0:0:0: [sda] Attached SCSI removable disk
Nov 3 18:19:51 promotion kernel: [ 190.938557] sd 0:0:0:0: Attached scsi generic sg0 type 0
Nov 3 18:19:51 promotion kernel: [ 191.453583] EXT4-fs (sda1): recovery complete
Nov 3 18:19:51 promotion kernel: [ 191.454806] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Nov 3 18:19:52 promotion kernel: [ 192.463446] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Nov 3 18:19:52 promotion kernel: [ 192.463638] br0: port 1(eth0) entered blocking state
Nov 3 18:19:52 promotion kernel: [ 192.463648] br0: port 1(eth0) entered forwarding state
