chuckdubs
Raspi not detecting I2C component
Mon Aug 27, 2018 6:56 pm
I purchased a few air pressure sensors that communicate via i2c and am not having luck with raspi detecting them. Running raspbien stretch on a raspberry pi zero W
Here is device drawing:
The device is listed as being able to take supply voltage of 3.3v or 5v.
Here's what I've done:
1) Turned on I2C in raspi-config and reboot
2) Verified physical pins 3 and 5 are set to 'ALT0' with 'gpio readall' command
3) Connected following pins: rpi gnd to component pin 1, rpi 3.3v to pin 2, rpi SDA to pin 3, and rpi SCL to pin 4
4) Check for device using 'gpio i2cd' and am getting all dashes
Here are images of how things are connected:
From the back of device:
from top:
gpios:
I've never used i2c before, is there some way I can troubleshoot why these devices aren't being detected?
DirkS
Re: Raspi not detecting I2C component
Mon Aug 27, 2018 7:46 pm
To me it looks as if you're using 5V instead of 3V3.
You wired it to pin 4 instead of pin 3
https://pinout.xyz/pinout/pin4_5v_power
chuckdubs
Mon Aug 27, 2018 9:04 pm
Thank you, that was the issue.
