g8gkq
Solved: Has a recent update broken hello_pi on Stretch Lite?
Tue Aug 21, 2018 5:33 pm
Hi
I have been using hello_mmal_encode for over a year now on Jessie Lite and Stretch Lite. However, in the last month or so it has started throwing an error at compile time.
If I build a new card using the 2018-06-27-raspbian-stretch-lite.img and then
cd /opt/vc/src/hello_pi/
./rebuild.sh
, it compiles fine. If I then
cd ~
sudo apt-get update
sudo apt-get -y dist-upgrade
./rebuild.sh
I get this error
make -C hello_mmal_encode
make[1]: Entering directory '/opt/vc/src/hello_pi/hello_mmal_encode'
cc -DSTANDALONE -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -DTARGET_POSIX -D_LINUX -fPIC -DPIC -D_REENTRANT -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -U_FORTIFY_SOURCE -Wall -g -DHAVE_LIBOPENMAX=2 -DOMX -DOMX_SKIP64BIT -ftree-vectorize -pipe -DUSE_EXTERNAL_OMX -DHAVE_LIBBCM_HOST -DUSE_EXTERNAL_LIBBCM_HOST -DUSE_VCHIQ_ARM -Wno-psabi -I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -I./ -I/opt/vc/src/hello_pi/libs/ilclient -I/opt/vc/src/hello_pi/libs/vgfont -g -c mmal_encode.c -o mmal_encode.o -Wno-deprecated-declarations
cc -o hello_mmal_encode.bin -Wl,--whole-archive mmal_encode.o -lmmal -lmmal_core -lmmal_components -lmmal_util -lmmal_vc_client --no-as-needed -L/opt/vc/lib/ -lbrcmGLESv2 -lbrcmEGL -lopenmaxil -lbcm_host -lvcos -lvchiq_arm -lpthread -lrt -lm -L/opt/vc/src/hello_pi/libs/ilclient -L/opt/vc/src/hello_pi/libs/vgfont -Wl,--no-whole-archive -rdynamic
cc: error: unrecognized command line option ‘--no-as-needed’; did you mean ‘--no-assert’?
../Makefile.include:19: recipe for target 'hello_mmal_encode.bin' failed
make[1]: *** [hello_mmal_encode.bin] Error 1
rm mmal_encode.o
make[1]: Leaving directory '/opt/vc/src/hello_pi/hello_mmal_encode'
Makefile:10: recipe for target 'apps' failed
make: *** [apps] Error 2
Adding
-Wl,
in front of
--no-as-needed
in the Makefile clears the error, but hello_mmal_encode seems to be non-functional afterwards.
Has something changed to break this, or have I missed something?
Dave
g8gkq
Re: Has a recent update broken hello_pi on Stretch Lite?
Thu Aug 23, 2018 9:12 am
Hi
I would appreciate any advice on how I should elevate this problem. Is there a formal reporting method for this sort of issue with hello_pi upgrades?
Dave, G8GKQ
DirkS
Thu Aug 23, 2018 9:16 am
Report it on the userland repo on github
https://github.com/raspberrypi/userland/issues
g8gkq
Thu Aug 23, 2018 11:21 am
Thanks, I've raised the issue here: https://github.com/raspberrypi/firmware/issues/1027 as it seems to be the userspace library code in /opt/vc rather than userland that is causing the issue.
Dave
g8gkq
Re: Solved: Has a recent update broken hello_pi on Stretch Lite?
Wed Sep 05, 2018 9:27 pm
This was 2 issues:
The first was that there was an error in the compile instructions for hello_mmal. This was fixed in kernel 4.14.66 and will make its way through to release in due course.
The second was that there had been undocumented changes to the IL port definition and checking. More details here: https://github.com/raspberrypi/firmware/issues/1027.
Thanks to 6by9 and F5OEO for identifying the fixes.
Dave, G8GKQ
