nachiketh
eth0 unstable on rpi
Sat Aug 18, 2018 12:56 pm
The ethernet interface bound to a static IP on my rpi3 model B keeps going down every few minutes, the system logs show the following:
Aug 18 18:18:43 raspberrypi kernel: [ 3895.679071] ERROR::dwc_otg_hcd_urb_enqueue:487: Not connected
Aug 18 18:18:43 raspberrypi avahi-daemon[361]: Interface eth0.IPv6 no longer relevant for mDNS.
Aug 18 18:18:43 raspberrypi avahi-daemon[361]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::2fea:caf0:f2ad:36a8.
Aug 18 18:18:43 raspberrypi dhcpcd[561]: eth0: carrier lost
Aug 18 18:18:43 raspberrypi avahi-daemon[361]: Interface eth0.IPv4 no longer relevant for mDNS.
Aug 18 18:18:43 raspberrypi kernel: [ 3895.748827] usb 1-1: USB disconnect, device number 83
Aug 18 18:18:43 raspberrypi kernel: [ 3895.748842] usb 1-1.1: USB disconnect, device number 84
Aug 18 18:18:43 raspberrypi kernel: [ 3895.749131] smsc95xx 1-1.1:1.0 eth0: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
Aug 18 18:18:43 raspberrypi kernel: [ 3895.749178] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Aug 18 18:18:43 raspberrypi avahi-daemon[361]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.111.1.
Aug 18 18:18:43 raspberrypi avahi-daemon[361]: Withdrawing address record for fe80::2fea:caf0:f2ad:36a8 on eth0.
Aug 18 18:18:43 raspberrypi avahi-daemon[361]: Withdrawing address record for 192.168.111.1 on eth0.
Aug 18 18:18:43 raspberrypi dhcpcd[561]: eth0: deleting address fe80::2fea:caf0:f2ad:36a8
Aug 18 18:18:43 raspberrypi dhcpcd[561]: eth0: deleting route to 192.168.111.0/24
Aug 18 18:18:43 raspberrypi dhcpcd[561]: eth0: removing interface
Aug 18 18:18:43 raspberrypi kernel: [ 3895.998707] Indeed it is in host mode hprt0 = 00021501
Aug 18 18:18:44 raspberrypi kernel: [ 3896.198587] usb 1-1: new high-speed USB device number 85 using dwc_otg
Aug 18 18:18:44 raspberrypi kernel: [ 3896.198708] Indeed it is in host mode hprt0 = 00001101
Aug 18 18:18:44 raspberrypi kernel: [ 3896.428785] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Aug 18 18:18:44 raspberrypi kernel: [ 3896.428799] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 18 18:18:44 raspberrypi kernel: [ 3896.429621] hub 1-1:1.0: USB hub found
Aug 18 18:18:44 raspberrypi kernel: [ 3896.429706] hub 1-1:1.0: 5 ports detected
Aug 18 18:18:44 raspberrypi kernel: [ 3896.748483] usb 1-1.1: new high-speed USB device number 86 using dwc_otg
Aug 18 18:18:44 raspberrypi kernel: [ 3896.878725] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Aug 18 18:18:44 raspberrypi kernel: [ 3896.878739] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 18 18:18:44 raspberrypi kernel: [ 3896.881709] smsc95xx v1.0.5
Aug 18 18:18:44 raspberrypi mtp-probe: checking bus 1, device 86: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Aug 18 18:18:44 raspberrypi mtp-probe: bus: 1, device: 86 was not an MTP device
Aug 18 18:18:44 raspberrypi kernel: [ 3896.982566] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c9:a3:a9
Aug 18 18:18:45 raspberrypi dhcpcd[561]: eth0: waiting for carrier
Aug 18 18:18:45 raspberrypi kernel: [ 3897.180647] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Aug 18 18:18:45 raspberrypi kernel: [ 3897.180986] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Aug 18 18:18:46 raspberrypi dhcpcd[561]: eth0: carrier acquired
Aug 18 18:18:46 raspberrypi kernel: [ 3898.671369] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Aug 18 18:18:46 raspberrypi kernel: [ 3898.672276] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
Aug 18 18:18:46 raspberrypi dhcpcd[561]: eth0: IAID eb:c9:a3:a9
Aug 18 18:18:46 raspberrypi dhcpcd[561]: eth0: adding address fe80::2fea:caf0:f2ad:36a8
Aug 18 18:18:46 raspberrypi dhcpcd[561]: eth0: probing address 192.168.111.1/24
Aug 18 18:18:46 raspberrypi dhcpcd[561]: eth0: soliciting an IPv6 router
Aug 18 18:18:47 raspberrypi avahi-daemon[361]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::2fea:caf0:f2ad:36a8.
Aug 18 18:18:47 raspberrypi avahi-daemon[361]: New relevant interface eth0.IPv6 for mDNS.
Aug 18 18:18:47 raspberrypi avahi-daemon[361]: Registering new address record for fe80::2fea:caf0:f2ad:36a8 on eth0.*.
Aug 18 18:18:51 raspberrypi dhcpcd[561]: eth0: using static address 192.168.111.1/24
Aug 18 18:18:51 raspberrypi avahi-daemon[361]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.111.1.
Aug 18 18:18:51 raspberrypi avahi-daemon[361]: New relevant interface eth0.IPv4 for mDNS.
Aug 18 18:18:51 raspberrypi avahi-daemon[361]: Registering new address record for 192.168.111.1 on eth0.IPv4.
Aug 18 18:18:51 raspberrypi dhcpcd[561]: eth0: adding route to 192.168.111.0/24
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.1 (stretch)
Release: 9.1
Codename: stretch
any ideas as to what could be going wrong in this? :roll:
DirkS
Re: eth0 unstable on rpi
Sat Aug 18, 2018 2:06 pm
First thing to check is your power supply.
Does the red power LED stay on at all times?
What's the rating of the PSU and are you sure you're using a good quality cable between PSU and Pi?
