saihoufung
sudo apt-get update && sudo apt-get upgrade error on Jessie
Wed Aug 08, 2018 3:41 am
I tried to update the packages for my Raspbian Jessie and at last there are few files in errors and cannot completed the installation.
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up procps (2:3.3.9-9+deb8u1) ...
insserv: Script dump is broken: missing end of LSB comment.
insserv: exiting now!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package procps (--configure):
 subprocess installed post-installation script returned error exit status 1
Setting up dbus (1.8.22-0+deb8u1) ...
dpkg: error processing package dbus (--configure):
Setting up rpcbind (0.2.1-6+deb8u2) ...
insserv: warning: current start runlevel(s) (empty) of script `rpcbind' overrides LSB defaults (S).
insserv: warning: current stop runlevel(s) (0 1 6 S) of script `rpcbind' overrides LSB defaults (0 1 6).
dpkg: error processing package rpcbind (--configure):
Setting up raspi-config (20170705) ...
insserv: warning: script 'dump' missing LSB tags and overrides
Can't exec "systemctl": No such file or directory at /usr/sbin/update-rc.d line 68.
dpkg: error processing package raspi-config (--configure):
 procps
 dbus
 rpcbind
 raspi-config
Any solution / clue to solve it? Thank you very much.
Regards.
Re: sudo apt-get update && sudo apt-get upgrade error on Jessie
Wed Aug 08, 2018 6:17 am
 procps
 dbus
 rpcbind
 raspi-config
Regards.
You should when using apt-get run the update command first
sudo apt-get update
apt-get has various options for 'fixing'
https://linux.die.net/man/8/apt-get
Please note that Raspbian Jessie became end of life 12 months ago !
Thinking outside the box is better than burying your head in the sand...
saihoufung
Wed Aug 08, 2018 10:21 am
 procps
 dbus
 rpcbind
 raspi-config
Regards.
sudo apt-get update
Hi there,
Firstly I am using apt-get update then apt-get upgrade.
But at the end there are few packages not installed with the errors shown.
Above what you see is portion, if I copy started from apt-get update, all the lists will overloaded in this page, that is why I only paste the "apt-get upgrade".
