drmacro
Image burning fails first time, works second
Wed Jul 25, 2018 1:07 pm
I typically used the following in a terminal window on Ubuntu to burn the rasbian image to a SD card:
sudo dd bs=4M if=2018-06-27-raspbian-stretch.img of=/dev/sdb
then a sync command.
Most of the time, it results in a corrupt SD card that won't boot.
But, if I run the exact commands again on the card, it results in a bootable SD.
The other day I used etcher and had the same experience.
Any idea why this would be? :?:
topguy
Re: Image burning fails first time, works second
Fri Jul 27, 2018 10:54 am
Ubuntu usually automounts SD cards, do you unmount it before attempt to dd to it ?
jahboater
Fri Jul 27, 2018 10:59 am
+1
sounds likely
I use "cp" by the way, its simpler to type (and fractionally faster).
sudo cp 2018-06-27-raspbian-stretch.img /dev/sdb
instead of
then the sync.
drmacro
Fri Jul 27, 2018 11:49 am
Hmm...I think??? I've tried it after un-mounting and the same results.
I'm doing some Iot/mqtt stuff at the moment with multiple pi's, so I think I'll get the chance to "play" with it again. ;)
