samsonbull
Scratching my head- getting started
Fri Jul 20, 2018 3:44 pm
I have a Pi 3 + b and am using the latest build of Raspian. At first I was unable to sudo apt-get update because it would throw an error:
E: Malformed line 1 in source list /etc/apt/sources.list.d/raspi.list (type)
E: The list of sources could not be read.
When I ran a cat of /etc/apt/sources.list.d/raspi.list it had a bunch of special characters $$$$$$$
I then did a sudo vi of the file and deleted the lines and then added:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
The i re ran the sudo apt-get update and it worked like a champ.
Next I wanted to install tcpreplay. I issued the command: sudo apt-get install tcpreplay and it seeed to go normally until it asked to very that I wanted to install it and showed the small disk space. After pressing "Y" and enter I got:
"dpkg: error: fgets gave an empty string from '/var/lib/dpkg/triggers/File'
E: Sub-process /usr/bin/dpkg returned an error code (2)"
Did my image come down as corrupt, or are others having problems as well? Any suggestions would be greatly appreciated.
Re: Scratching my head- getting started
Fri Jul 20, 2018 5:38 pm
Raspbian Jessie went end of life a year ago and pre-dates the RPi 3B+.
I would suggest you grab a new genuine Class10 SD Card and use Etcher to create a bootable Raspbian Stretch with Debian SD Card:
https://www.raspberrypi.org/downloads/raspbian/
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
B.Goode
Fri Jul 20, 2018 5:43 pm
Unfortunately you probably now have a broken, confused or unstable Operating System.
The current/latest release of Raspbian at the time of writing is based on the Stretch version, and has been since mid-August 2017. Adding repositories for the prior Jessie release is probably not appropriate.
The underlying cause may be a faulty or failing microSD card rather than an issue with the image distributed by the Raspberry Pi Foundation.
