ise7
3.2 touch inverted axis; need help with proper transformation
Wed Jul 18, 2018 10:54 pm
Hey i bought a 3.2 touch screen on ebay that looks to be based off the waveshare one.
I installed the screen using instructions located on https://www.waveshare.com/wiki/3.2inch_RPi_LCD_(B) using the tar.gz install file
The screen works with touch registering but my touches but my axis are inverted. Moving my finger Left goes up; moving my finger R moves down. Moving my finger Down goes L; moving my finger Up goes R
I googled around and this seems to be a common problem. Using the command below my x axis works as intended by my y axis is still inverted.
xinput set-prop 'ADS7846 Touchscreen' 'Coordinate Transformation Matrix' 0 1 0 1 0 0 0 0 1
I played around with other values in the http://www.calcul.com/show/calculator/m ... iplication and 0 -1 0 1 0 0 0 0 1 seems to give me the correct transformation but my cursor is then just stuck to the left side of the screen.
Can anyone help with the proper transformation?
lmarmisa
Re: 3.2 touch inverted axis; need help with proper transformation
Thu Jul 19, 2018 9:11 am
Take a look at this link (option LCD_ROTATE file /boot/config.txt):
https://www.raspberrypi.org/documentati ... t/video.md
DirkS
Thu Jul 19, 2018 10:53 am
That doesn't help if just touch orientation is wrong.
