simspace
RasPi Zero W and Random Screen Flashes ...
Wed Jul 18, 2018 6:27 pm
MY PROBLEM:
My RasPi Zero W is causing random screen flashes.
SOME BACKGROUND:
I have three RasPi Zero W's running Jessie Lite, that I use for displaying and syncing SD video on multiple Dell UltraSharp 1708FP (17-inch) monitors. The monitor connection is via an HDMI-to-DVI adapter. The monitor resolution is 1280 x 1024 at 75 Hz.
After days of researching a good video player that can be controlled with OSC, and even more days configuring the Pi to get it to work properly, I finally was able to play videos and control the video player remotely with OSC. All was good!
But then, while a video was playing, I lost the WIFI connection and had to reboot.
After the reboot the RasPi Zero W at first displayed nothing on the attached monitor. Then the random screen flashes started. But there was no RasPi console visible during the flashes. Only the Dell monitor's floating overlay that indicates the digital input is being used.
However, I can SSH into the RasPi no problem.
WHAT I HAVE TRIED SO FAR:
So here's what I have tried so far to debug/resolve the problem ...
I connected the problem RasPi to an HDMI monitor to confirm the RasPi was fully functional. It works fine with no display issues.
I attach the problem RasPi to a different monitor, a Dell UltraSharp 2009W (1680 x 1050 at 60 Hz), using the same HDMI-to-DVI adapter connection. After messing around with the /boot/config.txt HDMI settings, I got output on the Dell 2009W, but the console text was huge.
Then I spent days reading many posts regarding this problem and messing with every /boot/config.txt HDMI setting combination I could think of, including setting the hdmi_group=2 and the hdmi_mode=36 (which for the 1280 x 1024 at 75Hz resolution). Still no luck getting display output on the Dell 1708FP.
I flashed another SD card with a fresh Raspbian image (Stretch Lite).
I used the Stretch Lite image in a different RasPi Zero W and connected it to the monitor in question (the the Dell 1708FP). It worked great. So I can confirm the monitor works.
I have 14 Dell 1708FP monitors, so I tested the problem RasPi on a few of them, and the results were all the same ... random flashing.
I used that newly flashed SD card in the problem RasPi. The result is a black screen, no flashing.
I attach the problem RasPi with the newly flashed SD card to a different monitor, the Dell UltraSharp 2009W (1680 x 1050 at 60 Hz), using the same HDMI-to-DVI adapter connection. It works!
I tried a different HDMI-to-DVI adapter with the problem RasPi, still no luck.
This is so weird and I'm so confused!
A different RasPi with a new SD card (Stretch Lite) works on my Dell 1708FP.
The problem RasPi with the new SD card (Stretch Lite) DOES NOT work on my Dell 1708FP.
The problem RasPi with the new SD card (Stretch Lite) works on an HDMI monitor and my Dell 2009W DVI monitor.
The problem RasPi with the original SD card (Jessie Lite) works on an HDI monitor (looks normal), my Dell 2009W DVI monitor (however the text is huge), but not on my Dell 1708FP (random screen flashes).
So, I know the monitor works. And I know the RasPi works. But the combination of that specific RasPi on the Dell 1708FP is an issue.
That makes no sense to me. Does anyone have any other ideas?
It's important to me to resolve this, because I'll be using 14 RasPi's to run videos on the 14 monitors during my bands live shows. I will be triggering/syncing the videos by broadcasting OSC messages to the 14 RasPi's. So, I need to know how to resolve this issue if it should occur again.
Thanks,
Chris
L00
Re: RasPi Zero W and Random Screen Flashes ...
Wed Jul 18, 2018 7:12 pm
You said you have a Pi and a card that DO work with that monitor; when you're using that one, have you checked what resolution and frequency it's running at? Or did you also force it to 1280 x 1024 @ 75 Hz?
simspace
Thu Jul 19, 2018 3:27 pm
Problem Solved!
In a moment of desperation and frustration, I decided to try yet another Dell 1708FP monitor. I'm glad I did!
For some unknown reason, this particular monitor displayed a helpful message that basically said (I am paraphrasing) "Can't use current video mode. Please use 1280 x 1024 at 60 Hz."
So I edited the config.txt file yet again. This time I changed the video mode from 36 (75Hz) to 35 (60Hz), I uncommented "hdmi_drive" and set it to "1" which is Normal DVI mode (no sound) and I commented out any other active HDMI settings.
I'm not sure why the RasPi video output worked for a few days with the default config.txt (all settings commented out), and then it just decided to stop displaying output. But I happy it's functioning again. And I learned a lot about RasPi video configuration.
Who is online
Users browsing this forum: DrRocksalt, lubo_raykov and 38 guests
