File attachments
Posted: Sun Jul 15, 2018 2:55 pm
by RDK
I just tried to attach a .txt. file to a reply and it was rejected. What is the best way to include text file data in a reply?.....RDK
Re: File attachments
Posted: Sun Jul 15, 2018 3:05 pm
by DougieLawson
Stick it on google docs or github.io or pastebin.com, stick a link on here.
Posted: Sun Jul 15, 2018 3:28 pm
by RDK
Dougie...Thanks, but somehow that is not the same a adding an attachment. But it works....RDK
Posted: Sun Jul 15, 2018 3:30 pm
by DirkS
Douggie...Thanks, but somehow that is not the same a adding an attachment. But it works....RDK
File types and size are limited, so for a lot of file types it's the only way.
Exactly what is (not) allowed depends on board settings.
Posted: Sun Jul 15, 2018 3:35 pm
by rpdom
Zip the file and attach that. Zip files are allowed.
by DougieLawson
It's not the same, it's only about a 1,000,000 times better.
There's even a pastebin program you can install on Raspbian to automatically create them.
I won't unzip a zip file on here, because there's no antivirus scrutiny of attachments.
Posted: Sun Jul 15, 2018 5:13 pm
by hippy
If it's not too large you could include it in-line wrapped in [ code ] ... [ /code ] tags which will preserve its spacing.
If it is too large it might be worth asking yourself if it needs to be that large, if you need to post the full file.
The level of support provided for attachments is usually a debated issue on every forum; attachments take up server space but forcing them to be hosted elsewhere means they are prone to disappearing and being lost over time.
