JonnyAlpha
Raspberry Pi Certified Educator
Missing Task Bar and Corrupted White Desktop
Thu Jul 05, 2018 12:04 pm
Hi;
I have 6 Raspberry Pi's at school which I have flashed a new image of Stretch.
After enabling VNC and SSH for remote access (we are building robots), when logging in the start menu disappeared.
After reading a post about the same issue it suggested that there was a bug with earlier versions of Stretch after installing VNC.
The fix was to run update and upgrade.
I have just ran sudo apt-get update and sudo apt-get upgrade and now the screen is white, all of the task bar applets are small icons with a red X in and there is no start menu visable?
The kids are not going to be happy :-)
Any help would be great
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
ShiftPlusOne
Re: Missing Task Bar and Corrupted White Desktop
Thu Jul 05, 2018 1:32 pm
To help understand what happened, could you post your /var/log/apt/history.log?
The fix may be to run "sudo apt install raspberrypi-ui-mods", but it would be good to figure out what happened.
JonnyAlpha
Thu Jul 05, 2018 1:52 pm
Entering /var/log/apt/history.log
Results in the following:
bash: /var/log/apt/history.log: Permission denied
ShiftPlusOne
Thu Jul 05, 2018 1:56 pm
It's a plain text file, not an executable
cat /var/log/apt/term.log
JonnyAlpha
Thu Jul 05, 2018 2:25 pm
Here it is:
Log started: 2017-08-16  04:28:00
(Reading database ... 122646 files and directories currently installed.)
Preparing to unpack .../python3-pip_9.0.1-2+rpt2_all.deb ...
Unpacking python3-pip (9.0.1-2+rpt2) over (9.0.1-2) ...
Preparing to unpack .../python-pip_9.0.1-2+rpt2_all.deb ...
Unpacking python-pip (9.0.1-2+rpt2) over (9.0.1-2) ...
Preparing to unpack .../python-pip-whl_9.0.1-2+rpt2_all.deb ...
Unpacking python-pip-whl (9.0.1-2+rpt2) over (9.0.1-2) ...
Setting up python-pip-whl (9.0.1-2+rpt2) ...
Setting up python3-pip (9.0.1-2+rpt2) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up python-pip (9.0.1-2+rpt2) ...
Log ended: 2017-08-16  04:28:24
Log started: 2017-08-16  05:22:55
(Reading database ... 122647 files and directories currently installed.)
Preparing to unpack .../base-files_9.9+rpi1+deb9u4_armhf.deb ...
Unpacking base-files (9.9+rpi1+deb9u4) over (9.9+rpi1+deb9u1) ...
Setting up base-files (9.9+rpi1+deb9u4) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../bsdutils_1%3a2.29.2-1+deb9u1_armhf.deb ...
Unpacking bsdutils (1:2.29.2-1+deb9u1) over (1:2.29.2-1) ...
Setting up bsdutils (1:2.29.2-1+deb9u1) ...
Preparing to unpack .../util-linux_2.29.2-1+deb9u1_armhf.deb ...
Unpacking util-linux (2.29.2-1+deb9u1) over (2.29.2-1) ...
Setting up util-linux (2.29.2-1+deb9u1) ...
Preparing to unpack .../mount_2.29.2-1+deb9u1_armhf.deb ...
Unpacking mount (2.29.2-1+deb9u1) over (2.29.2-1) ...
Setting up mount (2.29.2-1+deb9u1) ...
Preparing to unpack .../ncurses-bin_6.0+20161126-1+deb9u2_armhf.deb ...
Unpacking ncurses-bin (6.0+20161126-1+deb9u2) over (6.0+20161126-1) ...
Setting up ncurses-bin (6.0+20161126-1+deb9u2) ...
Preparing to unpack .../libperl5.24_5.24.1-3+deb9u4_armhf.deb ...
Unpacking libperl5.24:armhf (5.24.1-3+deb9u4) over (5.24.1-3+deb9u1) ...
Preparing to unpack .../perl_5.24.1-3+deb9u4_armhf.deb ...
Unpacking perl (5.24.1-3+deb9u4) over (5.24.1-3+deb9u1) ...
Preparing to unpack .../perl-base_5.24.1-3+deb9u4_armhf.deb ...
Unpacking perl-base (5.24.1-3+deb9u4) over (5.24.1-3+deb9u1) ...
Setting up perl-base (5.24.1-3+deb9u4) ...
Preparing to unpack .../0-perl-modules-5.24_5.24.1-3+deb9u4_all.deb ...
Unpacking perl-modules-5.24 (5.24.1-3+deb9u4) over (5.24.1-3+deb9u1) ...
Preparing to unpack .../1-libc6-dbg_2.24-11+deb9u3_armhf.deb ...
Unpacking libc6-dbg:armhf (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Preparing to unpack .../2-libc6-dev_2.24-11+deb9u3_armhf.deb ...
Unpacking libc6-dev:armhf (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Preparing to unpack .../3-libc-dev-bin_2.24-11+deb9u3_armhf.deb ...
Unpacking libc-dev-bin (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Preparing to unpack .../4-linux-libc-dev_4.9.82-1+deb9u3+rpi1_armhf.deb ...
Unpacking linux-libc-dev:armhf (4.9.82-1+deb9u3+rpi1) over (3.18.5-1~exp1+rpi19+stretch) ...
Preparing to unpack .../5-libgomp1_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libgomp1:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../6-gcc-6-base_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking gcc-6-base:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Setting up gcc-6-base:armhf (6.3.0-18+rpi1+deb9u1) ...
(Reading database ... 122703 files and directories currently installed.)
Preparing to unpack .../libgcc1_1%3a6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libgcc1:armhf (1:6.3.0-18+rpi1+deb9u1) over (1:6.3.0-18+rpi1) ...
Setting up libgcc1:armhf (1:6.3.0-18+rpi1+deb9u1) ...
Preparing to unpack .../00-libcc1-0_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libcc1-0:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../01-libatomic1_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libatomic1:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../02-libasan3_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libasan3:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../03-libubsan0_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libubsan0:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../04-g++-6_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking g++-6 (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../05-libstdc++-6-dev_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libstdc++-6-dev:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../06-libgcc-6-dev_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libgcc-6-dev:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../07-gcc-6_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking gcc-6 (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../08-cpp-6_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking cpp-6 (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../09-libgfortran3_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libgfortran3:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Preparing to unpack .../10-libstdc++6_6.3.0-18+rpi1+deb9u1_armhf.deb ...
Unpacking libstdc++6:armhf (6.3.0-18+rpi1+deb9u1) over (6.3.0-18+rpi1) ...
Setting up libstdc++6:armhf (6.3.0-18+rpi1+deb9u1) ...
Preparing to unpack .../libc6_2.24-11+deb9u3_armhf.deb ...
Unpacking libc6:armhf (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Setting up libc6:armhf (2.24-11+deb9u3) ...
Preparing to unpack .../libdb5.3_5.3.28-12+deb9u1_armhf.deb ...
Unpacking libdb5.3:armhf (5.3.28-12+deb9u1) over (5.3.28-12) ...
Setting up libdb5.3:armhf (5.3.28-12+deb9u1) ...
Preparing to unpack .../libc-bin_2.24-11+deb9u3_armhf.deb ...
Unpacking libc-bin (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Setting up libc-bin (2.24-11+deb9u3) ...
Preparing to unpack .../ncurses-base_6.0+20161126-1+deb9u2_all.deb ...
Unpacking ncurses-base (6.0+20161126-1+deb9u2) over (6.0+20161126-1) ...
Setting up ncurses-base (6.0+20161126-1+deb9u2) ...
Preparing to unpack .../libapt-pkg5.0_1.4.8_armhf.deb ...
Unpacking libapt-pkg5.0:armhf (1.4.8) over (1.4.7) ...
Setting up libapt-pkg5.0:armhf (1.4.8) ...
Preparing to unpack .../libapt-inst2.0_1.4.8_armhf.deb ...
Unpacking libapt-inst2.0:armhf (1.4.8) over (1.4.7) ...
Preparing to unpack .../archives/apt_1.4.8_armhf.deb ...
Unpacking apt (1.4.8) over (1.4.7) ...
Setting up apt (1.4.8) ...
Preparing to unpack .../apt-utils_1.4.8_armhf.deb ...
Unpacking apt-utils (1.4.8) over (1.4.7) ...
Preparing to unpack .../libgcrypt20_1.7.6-2+deb9u3_armhf.deb ...
Unpacking libgcrypt20:armhf (1.7.6-2+deb9u3) over (1.7.6-2+deb9u1) ...
Setting up libgcrypt20:armhf (1.7.6-2+deb9u3) ...
Preparing to unpack .../gpgv_2.1.18-8~deb9u2_armhf.deb ...
Unpacking gpgv (2.1.18-8~deb9u2) over (2.1.18-6) ...
Setting up gpgv (2.1.18-8~deb9u2) ...
Preparing to unpack .../0-dbus-user-session_1.10.26-0+deb9u1_all.deb ...
Unpacking dbus-user-session (1.10.26-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../1-dbus-x11_1.10.26-0+deb9u1_armhf.deb ...
Unpacking dbus-x11 (1.10.26-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../2-dbus_1.10.26-0+deb9u1_armhf.deb ...
Unpacking dbus (1.10.26-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../3-libdbus-1-3_1.10.26-0+deb9u1_armhf.deb ...
Unpacking libdbus-1-3:armhf (1.10.26-0+deb9u1) over (1.10.18-1) ...
Preparing to unpack .../4-libapparmor1_2.11.0-3+deb9u2_armhf.deb ...
Unpacking libapparmor1:armhf (2.11.0-3+deb9u2) over (2.11.0-3) ...
Preparing to unpack .../5-systemd-sysv_232-25+deb9u2_armhf.deb ...
Unpacking systemd-sysv (232-25+deb9u2) over (232-25+deb9u1) ...
Preparing to unpack .../6-libpam-systemd_232-25+deb9u2_armhf.deb ...
Unpacking libpam-systemd:armhf (232-25+deb9u2) over (232-25+deb9u1) ...
Preparing to unpack .../7-bluez_5.43-2+rpt2+deb9u2_armhf.deb ...
Unpacking bluez (5.43-2+rpt2+deb9u2) over (5.43-2+rpi1) ...
Preparing to unpack .../8-libsystemd0_232-25+deb9u2_armhf.deb ...
Unpacking libsystemd0:armhf (232-25+deb9u2) over (232-25+deb9u1) ...
Setting up libsystemd0:armhf (232-25+deb9u2) ...
Preparing to unpack .../xserver-common_2%3a1.19.2-1+rpt1+deb9u2_all.deb ...
Unpacking xserver-common (2:1.19.2-1+rpt1+deb9u2) over (2:1.19.2-1+deb9u1+rpi1) ...
Preparing to unpack .../xserver-xorg-core_2%3a1.19.2-1+rpt1+deb9u2_armhf.deb ...
Unpacking xserver-xorg-core (2:1.19.2-1+rpt1+deb9u2) over (2:1.19.2-1+deb9u1+rpi1) ...
Preparing to unpack .../systemd_232-25+deb9u2_armhf.deb ...
Unpacking systemd (232-25+deb9u2) over (232-25+deb9u1) ...
Preparing to unpack .../udev_232-25+deb9u2_armhf.deb ...
Unpacking udev (232-25+deb9u2) over (232-25+deb9u1) ...
Preparing to unpack .../libudev1_232-25+deb9u2_armhf.deb ...
Unpacking libudev1:armhf (232-25+deb9u2) over (232-25+deb9u1) ...
Setting up libudev1:armhf (232-25+deb9u2) ...
Preparing to unpack .../libuuid1_2.29.2-1+deb9u1_armhf.deb ...
Unpacking libuuid1:armhf (2.29.2-1+deb9u1) over (2.29.2-1) ...
Setting up libuuid1:armhf (2.29.2-1+deb9u1) ...
Preparing to unpack .../libblkid1_2.29.2-1+deb9u1_armhf.deb ...
Unpacking libblkid1:armhf (2.29.2-1+deb9u1) over (2.29.2-1) ...
Setting up libblkid1:armhf (2.29.2-1+deb9u1) ...
Preparing to unpack .../libncurses5_6.0+20161126-1+deb9u2_armhf.deb ...
Unpacking libncurses5:armhf (6.0+20161126-1+deb9u2) over (6.0+20161126-1) ...
Preparing to unpack .../libtinfo5_6.0+20161126-1+deb9u2_armhf.deb ...
Unpacking libtinfo5:armhf (6.0+20161126-1+deb9u2) over (6.0+20161126-1) ...
Setting up libtinfo5:armhf (6.0+20161126-1+deb9u2) ...
Preparing to unpack .../libncursesw5_6.0+20161126-1+deb9u2_armhf.deb ...
Unpacking libncursesw5:armhf (6.0+20161126-1+deb9u2) over (6.0+20161126-1) ...
Setting up libncursesw5:armhf (6.0+20161126-1+deb9u2) ...
Preparing to unpack .../libprocps6_2%3a3.3.12-3+deb9u1_armhf.deb ...
Unpacking libprocps6:armhf (2:3.3.12-3+deb9u1) over (2:3.3.12-3) ...
Preparing to unpack .../procps_2%3a3.3.12-3+deb9u1_armhf.deb ...
Unpacking procps (2:3.3.12-3+deb9u1) over (2:3.3.12-3) ...
Preparing to unpack .../xkb-data_2.19-1+deb9u1_all.deb ...
Unpacking xkb-data (2.19-1+deb9u1) over (2.19-1) ...
Preparing to unpack .../libxfont2_1%3a2.0.1-3+deb9u1_armhf.deb ...
Unpacking libxfont2:armhf (1:2.0.1-3+deb9u1) over (1:2.0.1-3) ...
Preparing to unpack .../libmount1_2.29.2-1+deb9u1_armhf.deb ...
Unpacking libmount1:armhf (2.29.2-1+deb9u1) over (2.29.2-1) ...
Setting up libmount1:armhf (2.29.2-1+deb9u1) ...
Preparing to unpack .../00-cron_3.0pl1-128+deb9u1_armhf.deb ...
Unpacking cron (3.0pl1-128+deb9u1) over (3.0pl1-128) ...
Preparing to unpack .../01-desktop-base_9.0.2+deb9u1_all.deb ...
Unpacking desktop-base (9.0.2+deb9u1) over (9.0.2) ...
Preparing to unpack .../02-fonts-piboto_1.2_all.deb ...
Unpacking fonts-piboto (1.2) over (1.0) ...
Preparing to unpack .../03-git-man_1%3a2.11.0-3+deb9u3_all.deb ...
Unpacking git-man (1:2.11.0-3+deb9u3) over (1:2.11.0-3) ...
Preparing to unpack .../04-libtasn1-6_4.10-1.1+deb9u1_armhf.deb ...
Unpacking libtasn1-6:armhf (4.10-1.1+deb9u1) over (4.10-1.1) ...
Preparing to unpack .../05-libgnutls30_3.5.8-5+deb9u3_armhf.deb ...
Unpacking libgnutls30:armhf (3.5.8-5+deb9u3) over (3.5.8-5+deb9u2) ...
Preparing to unpack .../06-libgssapi-krb5-2_1.15-1+deb9u1_armhf.deb ...
Unpacking libgssapi-krb5-2:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../07-libkrb5-3_1.15-1+deb9u1_armhf.deb ...
Unpacking libkrb5-3:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../08-libkrb5support0_1.15-1+deb9u1_armhf.deb ...
Unpacking libkrb5support0:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../09-libk5crypto3_1.15-1+deb9u1_armhf.deb ...
Unpacking libk5crypto3:armhf (1.15-1+deb9u1) over (1.15-1) ...
Preparing to unpack .../10-libidn2-0_0.16-1+deb9u1_armhf.deb ...
Unpacking libidn2-0:armhf (0.16-1+deb9u1) over (0.16-1) ...
Preparing to unpack .../11-libldap-2.4-2_2.4.44+dfsg-5+deb9u1_armhf.deb ...
Unpacking libldap-2.4-2:armhf (2.4.44+dfsg-5+deb9u1) over (2.4.44+dfsg-5) ...
Preparing to unpack .../12-libldap-common_2.4.44+dfsg-5+deb9u1_all.deb ...
Unpacking libldap-common (2.4.44+dfsg-5+deb9u1) over (2.4.44+dfsg-5) ...
Preparing to unpack .../13-libcurl3-gnutls_7.52.1-5+deb9u6_armhf.deb ...
Unpacking libcurl3-gnutls:armhf (7.52.1-5+deb9u6) over (7.52.1-5) ...
Preparing to unpack .../14-git_1%3a2.11.0-3+deb9u3_armhf.deb ...
Unpacking git (1:2.11.0-3+deb9u3) over (1:2.11.0-3) ...
Preparing to unpack .../15-libicu57_57.1-6+deb9u2_armhf.deb ...
Unpacking libicu57:armhf (57.1-6+deb9u2) over (57.1-6) ...
Preparing to unpack .../16-libwpd-0.10-10_0.10.1-5+deb9u1_armhf.deb ...
Unpacking libwpd-0.10-10:armhf (0.10.1-5+deb9u1) over (0.10.1-5) ...
Preparing to unpack .../17-libxml2_2.9.4+dfsg1-2.2+deb9u2_armhf.deb ...
Unpacking libxml2:armhf (2.9.4+dfsg1-2.2+deb9u2) over (2.9.4+dfsg1-2.2) ...
Preparing to unpack .../18-uno-libs3_5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking uno-libs3 (5.2.7-1+rpi1+deb9u3) over (5.2.7-1+rpi1) ...
Preparing to unpack .../19-ure_5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking ure (5.2.7-1+rpi1+deb9u3) over (5.2.7-1+rpi1) ...
Preparing to unpack .../20-libreoffice-base-drivers_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-base-drivers (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../21-libreoffice-base_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-base (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../22-libreoffice-calc_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-calc (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../23-libreoffice-impress_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-impress (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../24-libreoffice-draw_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-draw (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../25-libreoffice-gtk2_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-gtk2 (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../26-libreoffice-systray_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-systray (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../27-python3-uno_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking python3-uno (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../28-libreoffice-sdbc-hsqldb_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-sdbc-hsqldb (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../29-libreoffice-base-core_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-base-core (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../30-libreoffice-report-builder-bin_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-report-builder-bin (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../31-libreoffice_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../32-libreoffice-math_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-math (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../33-libreoffice-style-galaxy_1%3a5.2.7-1+rpi1+deb9u3_all.deb ...
Unpacking libreoffice-style-galaxy (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../34-libreoffice-gtk_1%3a5.2.7-1+rpi1+deb9u3_all.deb ...
Unpacking libreoffice-gtk (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../35-libreoffice-java-common_1%3a5.2.7-1+rpi1+deb9u3_all.deb ...
Unpacking libreoffice-java-common (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../36-libreoffice-common_1%3a5.2.7-1+rpi1+deb9u3_all.deb ...
Unpacking libreoffice-common (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../37-libreoffice-avmedia-backend-gstreamer_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-avmedia-backend-gstreamer (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../38-libreoffice-writer_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-writer (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../39-libreoffice-core_1%3a5.2.7-1+rpi1+deb9u3_armhf.deb ...
Unpacking libreoffice-core (1:5.2.7-1+rpi1+deb9u3) over (1:5.2.7-1+rpi1) ...
Preparing to unpack .../40-libtiff5_4.0.8-2+deb9u2_armhf.deb ...
Unpacking libtiff5:armhf (4.0.8-2+deb9u2) over (4.0.8-2+deb9u1) ...
Preparing to unpack .../41-libgdk-pixbuf2.0-0_2.36.5-2+deb9u2_armhf.deb ...
Unpacking libgdk-pixbuf2.0-0:armhf (2.36.5-2+deb9u2) over (2.36.5-2) ...
Preparing to unpack .../42-libgdk-pixbuf2.0-common_2.36.5-2+deb9u2_all.deb ...
Unpacking libgdk-pixbuf2.0-common (2.36.5-2+deb9u2) over (2.36.5-2) ...
Preparing to unpack .../43-fonts-opensymbol_2%3a102.7+LibO5.2.7-1+rpi1+deb9u3_all.deb ...
Unpacking fonts-opensymbol (2:102.7+LibO5.2.7-1+rpi1+deb9u3) over (2:102.7+LibO5.2.7-1+rpi1) ...
Preparing to unpack .../44-libsqlite3-0_3.16.2-5+deb9u1_armhf.deb ...
Unpacking libsqlite3-0:armhf (3.16.2-5+deb9u1) over (3.16.2-5) ...
Setting up libsqlite3-0:armhf (3.16.2-5+deb9u1) ...
(Reading database ... 122707 files and directories currently installed.)
Preparing to unpack .../00-libnss3_2%3a3.26.2-1.1+deb9u1_armhf.deb ...
Unpacking libnss3:armhf (2:3.26.2-1.1+deb9u1) over (2:3.26.2-1.1) ...
Preparing to unpack .../01-python2.7-dev_2.7.13-2+deb9u2_armhf.deb ...
Unpacking python2.7-dev (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../02-libpython2.7-dev_2.7.13-2+deb9u2_armhf.deb ...
Unpacking libpython2.7-dev:armhf (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../03-libssl1.1_1.1.0f-3+deb9u2_armhf.deb ...
Unpacking libssl1.1:armhf (1.1.0f-3+deb9u2) over (1.1.0f-3) ...
Preparing to unpack .../04-libpython2.7_2.7.13-2+deb9u2_armhf.deb ...
Unpacking libpython2.7:armhf (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../05-python2.7_2.7.13-2+deb9u2_armhf.deb ...
Unpacking python2.7 (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../06-libpython2.7-stdlib_2.7.13-2+deb9u2_armhf.deb ...
Unpacking libpython2.7-stdlib:armhf (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../07-python2.7-minimal_2.7.13-2+deb9u2_armhf.deb ...
Unpacking python2.7-minimal (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../08-libpython2.7-minimal_2.7.13-2+deb9u2_armhf.deb ...
Unpacking libpython2.7-minimal:armhf (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../09-libwbclient0_2%3a4.5.12+dfsg-2+deb9u2_armhf.deb ...
Unpacking libwbclient0:armhf (2:4.5.12+dfsg-2+deb9u2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../10-libsmbclient_2%3a4.5.12+dfsg-2+deb9u2_armhf.deb ...
Unpacking libsmbclient:armhf (2:4.5.12+dfsg-2+deb9u2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../11-samba-libs_2%3a4.5.12+dfsg-2+deb9u2_armhf.deb ...
Unpacking samba-libs:armhf (2:4.5.12+dfsg-2+deb9u2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../12-samba-common_2%3a4.5.12+dfsg-2+deb9u2_all.deb ...
Unpacking samba-common (2:4.5.12+dfsg-2+deb9u2) over (2:4.5.8+dfsg-2+deb9u1) ...
Preparing to unpack .../13-openssh-sftp-server_1%3a7.4p1-10+deb9u3_armhf.deb ...
Unpacking openssh-sftp-server (1:7.4p1-10+deb9u3) over (1:7.4p1-10+deb9u1) ...
Preparing to unpack .../14-libssl1.0.2_1.0.2l-2+deb9u3_armhf.deb ...
Unpacking libssl1.0.2:armhf (1.0.2l-2+deb9u3) over (1.0.2l-2) ...
Preparing to unpack .../15-openssh-server_1%3a7.4p1-10+deb9u3_armhf.deb ...
Unpacking openssh-server (1:7.4p1-10+deb9u3) over (1:7.4p1-10+deb9u1) ...
Preparing to unpack .../16-openssh-client_1%3a7.4p1-10+deb9u3_armhf.deb ...
Unpacking openssh-client (1:7.4p1-10+deb9u3) over (1:7.4p1-10+deb9u1) ...
Preparing to unpack .../17-ssh_1%3a7.4p1-10+deb9u3_all.deb ...
Unpacking ssh (1:7.4p1-10+deb9u3) over (1:7.4p1-10+deb9u1) ...
Preparing to unpack .../18-libfdisk1_2.29.2-1+deb9u1_armhf.deb ...
Unpacking libfdisk1:armhf (2.29.2-1+deb9u1) over (2.29.2-1) ...
Setting up libfdisk1:armhf (2.29.2-1+deb9u1) ...
Preparing to unpack .../libsmartcols1_2.29.2-1+deb9u1_armhf.deb ...
Unpacking libsmartcols1:armhf (2.29.2-1+deb9u1) over (2.29.2-1) ...
Setting up libsmartcols1:armhf (2.29.2-1+deb9u1) ...
Preparing to unpack .../multiarch-support_2.24-11+deb9u3_armhf.deb ...
Unpacking multiarch-support (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Setting up multiarch-support (2.24-11+deb9u3) ...
Preparing to unpack .../sensible-utils_0.0.9+deb9u1_all.deb ...
Unpacking sensible-utils (0.0.9+deb9u1) over (0.0.9) ...
Setting up sensible-utils (0.0.9+deb9u1) ...
Preparing to unpack .../gnupg-agent_2.1.18-8~deb9u2_armhf.deb ...
Unpacking gnupg-agent (2.1.18-8~deb9u2) over (2.1.18-6) ...
Setting up gnupg-agent (2.1.18-8~deb9u2) ...
Preparing to unpack .../gnupg_2.1.18-8~deb9u2_armhf.deb ...
Unpacking gnupg (2.1.18-8~deb9u2) over (2.1.18-6) ...
Setting up gnupg (2.1.18-8~deb9u2) ...
(Reading database ... 122706 files and directories currently installed.)
Preparing to unpack .../000-tzdata_2018c-0+deb9u1_all.deb ...
Unpacking tzdata (2018c-0+deb9u1) over (2017b-1) ...
Preparing to unpack .../001-iproute2_4.9.0-1+deb9u1_armhf.deb ...
Unpacking iproute2 (4.9.0-1+deb9u1) over (4.9.0-1) ...
Preparing to unpack .../002-libisc-export160_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking libisc-export160 (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../003-libdns-export162_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking libdns-export162 (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../004-isc-dhcp-client_4.3.5-3+deb9u1_armhf.deb ...
Unpacking isc-dhcp-client (4.3.5-3+deb9u1) over (4.3.5-3) ...
Preparing to unpack .../005-isc-dhcp-common_4.3.5-3+deb9u1_armhf.deb ...
Unpacking isc-dhcp-common (4.3.5-3+deb9u1) over (4.3.5-3) ...
Preparing to unpack .../006-vim-tiny_2%3a8.0.0197-4+deb9u1_armhf.deb ...
Unpacking vim-tiny (2:8.0.0197-4+deb9u1) over (2:8.0.0197-4) ...
Preparing to unpack .../007-xxd_2%3a8.0.0197-4+deb9u1_armhf.deb ...
Unpacking xxd (2:8.0.0197-4+deb9u1) over (2:8.0.0197-4) ...
Preparing to unpack .../008-vim-common_2%3a8.0.0197-4+deb9u1_all.deb ...
Unpacking vim-common (2:8.0.0197-4+deb9u1) over (2:8.0.0197-4) ...
Preparing to unpack .../009-wget_1.18-5+deb9u2_armhf.deb ...
Unpacking wget (1.18-5+deb9u2) over (1.18-5) ...
Preparing to unpack .../010-bind9-host_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking bind9-host (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../011-libisc160_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking libisc160:armhf (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../012-libdns162_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking libdns162:armhf (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../013-libisccc140_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking libisccc140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../014-libisccfg140_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking libisccfg140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../015-libbind9-140_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking libbind9-140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../016-liblwres141_1%3a9.10.3.dfsg.P4-12.3+deb9u4_armhf.deb ...
Unpacking liblwres141:armhf (1:9.10.3.dfsg.P4-12.3+deb9u4) over (1:9.10.3.dfsg.P4-12.3+deb9u2) ...
Preparing to unpack .../017-file_1%3a5.30-1+deb9u1_armhf.deb ...
Unpacking file (1:5.30-1+deb9u1) over (1:5.30-1) ...
Preparing to unpack .../018-libmagic1_1%3a5.30-1+deb9u1_armhf.deb ...
Unpacking libmagic1:armhf (1:5.30-1+deb9u1) over (1:5.30-1) ...
Preparing to unpack .../019-libmagic-mgc_1%3a5.30-1+deb9u1_armhf.deb ...
Unpacking libmagic-mgc (1:5.30-1+deb9u1) over (1:5.30-1) ...
Preparing to unpack .../020-libc-l10n_2.24-11+deb9u3_all.deb ...
Unpacking libc-l10n (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Preparing to unpack .../021-locales_2.24-11+deb9u3_all.deb ...
Unpacking locales (2.24-11+deb9u3) over (2.24-11+deb9u1) ...
Preparing to unpack .../022-ncurses-term_6.0+20161126-1+deb9u2_all.deb ...
Unpacking ncurses-term (6.0+20161126-1+deb9u2) over (6.0+20161126-1) ...
Preparing to unpack .../023-apt-transport-https_1.4.8_armhf.deb ...
Unpacking apt-transport-https (1.4.8) over (1.4.7) ...
Preparing to unpack .../024-libbluetooth3_5.43-2+rpt2+deb9u2_armhf.deb ...
Unpacking libbluetooth3:armhf (5.43-2+rpt2+deb9u2) over (5.43-2+rpi1) ...
Preparing to unpack .../025-bluealsa_0.7_armhf.deb ...
Removed /etc/systemd/system/graphical.target.wants/bluealsa.service.
Unpacking bluealsa (0.7) over (0.4) ...
Preparing to unpack .../026-bluez-firmware_1.2-3+rpt6_all.deb ...
Unpacking bluez-firmware (1.2-3+rpt6) over (1.2-3+rpi2) ...
Preparing to unpack .../027-curl_7.52.1-5+deb9u6_armhf.deb ...
Unpacking curl (7.52.1-5+deb9u6) over (7.52.1-5) ...
Preparing to unpack .../028-libcurl3_7.52.1-5+deb9u6_armhf.deb ...
Unpacking libcurl3:armhf (7.52.1-5+deb9u6) over (7.52.1-5) ...
Preparing to unpack .../029-dhcpcd5_1%3a6.11.5-1+rpt5_armhf.deb ...
Unpacking dhcpcd5 (1:6.11.5-1+rpt5) over (1:6.10.1-1+rpi3) ...
Preparing to unpack .../030-erlang-crypto_1%3a19.2.1+dfsg-2+deb9u1_armhf.deb ...
Unpacking erlang-crypto (1:19.2.1+dfsg-2+deb9u1) over (1:19.2.1+dfsg-2) ...
Preparing to unpack .../031-erlang-syntax-tools_1%3a19.2.1+dfsg-2+deb9u1_armhf.deb ...
Unpacking erlang-syntax-tools (1:19.2.1+dfsg-2+deb9u1) over (1:19.2.1+dfsg-2) ...
Preparing to unpack .../032-erlang-base_1%3a19.2.1+dfsg-2+deb9u1_armhf.deb ...
Searching for services which depend on erlang and should be stopped...none found.
Killing epmd...it is not running.
Unpacking erlang-base (1:19.2.1+dfsg-2+deb9u1) over (1:19.2.1+dfsg-2) ...
Preparing to unpack .../033-firmware-atheros_1%3a20161130-3+rpt3_all.deb ...
Unpacking firmware-atheros (1:20161130-3+rpt3) over (1:20161130-3+rpi2) ...
Preparing to unpack .../034-firmware-brcm80211_1%3a20161130-3+rpt3_all.deb ...
Unpacking firmware-brcm80211 (1:20161130-3+rpt3) over (1:20161130-3+rpi2) ...
Preparing to unpack .../035-firmware-libertas_1%3a20161130-3+rpt3_all.deb ...
Unpacking firmware-libertas (1:20161130-3+rpt3) over (1:20161130-3+rpi2) ...
Preparing to unpack .../036-firmware-misc-nonfree_1%3a20161130-3+rpt3_all.deb ...
Unpacking firmware-misc-nonfree (1:20161130-3+rpt3) over (1:20161130-3+rpi2) ...
Preparing to unpack .../037-firmware-realtek_1%3a20161130-3+rpt3_all.deb ...
Unpacking firmware-realtek (1:20161130-3+rpt3) over (1:20161130-3+rpi2) ...
Preparing to unpack .../038-fontconfig-infinality_20130104-0ubuntu0ppa1+rpi1_all.deb ...
Unpacking fontconfig-infinality (20130104-0ubuntu0ppa1+rpi1) over (20130104-0ubuntu0ppa1+rpi) ...
Preparing to unpack .../039-geany_1.29-1+rpt1_armhf.deb ...
Unpacking geany (1.29-1+rpt1) over (1.29-1) ...
Preparing to unpack .../040-geany-common_1.29-1+rpt1_all.deb ...
Unpacking geany-common (1.29-1+rpt1) over (1.29-1) ...
Preparing to unpack .../041-gir1.2-gdkpixbuf-2.0_2.36.5-2+deb9u2_armhf.deb ...
Unpacking gir1.2-gdkpixbuf-2.0:armhf (2.36.5-2+deb9u2) over (2.36.5-2) ...
Preparing to unpack .../042-gtk2-engines-clearlookspix_1%3a2.20.5_armhf.deb ...
Unpacking gtk2-engines-clearlookspix:armhf (1:2.20.5) over (1:2.20.4) ...
Preparing to unpack .../043-idle-python2.7_2.7.13-2+deb9u2_all.deb ...
Unpacking idle-python2.7 (2.7.13-2+deb9u2) over (2.7.13-2) ...
Preparing to unpack .../044-libatspi2.0-0_2.22.0-6+deb9u1_armhf.deb ...
Unpacking libatspi2.0-0:armhf (2.22.0-6+deb9u1) over (2.22.0-6) ...
Preparing to unpack .../045-libavutil55_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libavutil55:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../046-libopenjp2-7_2.1.2-1.1+deb9u2_armhf.deb ...
Unpacking libopenjp2-7:armhf (2.1.2-1.1+deb9u2) over (2.1.2-1.1) ...
Preparing to unpack .../047-libswresample2_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libswresample2:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../048-libvorbisfile3_1.3.5-4+deb9u2_armhf.deb ...
Unpacking libvorbisfile3:armhf (1.3.5-4+deb9u2) over (1.3.5-4) ...
Preparing to unpack .../049-libvorbisenc2_1.3.5-4+deb9u2_armhf.deb ...
Unpacking libvorbisenc2:armhf (1.3.5-4+deb9u2) over (1.3.5-4) ...
Preparing to unpack .../050-libvorbis0a_1.3.5-4+deb9u2_armhf.deb ...
Unpacking libvorbis0a:armhf (1.3.5-4+deb9u2) over (1.3.5-4) ...
Preparing to unpack .../051-libvpx4_1.6.1-3+deb9u1_armhf.deb ...
Unpacking libvpx4:armhf (1.6.1-3+deb9u1) over (1.6.1-3) ...
Preparing to unpack .../052-libwavpack1_5.0.0-2+deb9u2_armhf.deb ...
Unpacking libwavpack1:armhf (5.0.0-2+deb9u2) over (5.0.0-2) ...
Preparing to unpack .../053-libavcodec57_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libavcodec57:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../054-libbluray1_1%3a0.9.3-4_armhf.deb ...
Unpacking libbluray1:armhf (1:0.9.3-4) over (1:0.9.3-3) ...
Preparing to unpack .../055-libavformat57_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libavformat57:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../056-libavresample3_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libavresample3:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../057-libpostproc54_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libpostproc54:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../058-libswscale4_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libswscale4:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../059-libavfilter6_7%3a3.2.10-1~deb9u1+rpt1_armhf.deb ...
Unpacking libavfilter6:armhf (7:3.2.10-1~deb9u1+rpt1) over (7:3.2.5-1) ...
Preparing to unpack .../060-libfm-data_1.2.5-1+rpi5_all.deb ...
Unpacking libfm-data (1.2.5-1+rpi5) over (1.2.5-1+rpi1) ...
Preparing to unpack .../061-libfm-extra4_1.2.5-1+rpi5_armhf.deb ...
Unpacking libfm-extra4:armhf (1.2.5-1+rpi5) over (1.2.5-1+rpi1) ...
Preparing to unpack .../062-libfm-gtk-data_1.2.5-1+rpi5_all.deb ...
Unpacking libfm-gtk-data (1.2.5-1+rpi5) over (1.2.5-1+rpi1) ...
Preparing to unpack .../063-libfm-gtk4_1.2.5-1+rpi5_armhf.deb ...
Unpacking libfm-gtk4:armhf (1.2.5-1+rpi5) over (1.2.5-1+rpi1) ...
Preparing to unpack .../064-libfm4_1.2.5-1+rpi5_armhf.deb ...
Unpacking libfm4:armhf (1.2.5-1+rpi5) over (1.2.5-1+rpi1) ...
Preparing to unpack .../065-libfm-modules_1.2.5-1+rpi5_armhf.deb ...
Unpacking libfm-modules:armhf (1.2.5-1+rpi5) over (1.2.5-1+rpi1) ...
Preparing to unpack .../066-libgd3_2.2.4-2+deb9u2_armhf.deb ...
Unpacking libgd3:armhf (2.2.4-2+deb9u2) over (2.2.4-2+deb9u1) ...
Preparing to unpack .../067-libwebkit2gtk-4.0-37_2.16.6-0+deb9u1+rpi1_armhf.deb ...
Unpacking libwebkit2gtk-4.0-37:armhf (2.16.6-0+deb9u1+rpi1) over (2.16.3-2+rpi1) ...
Preparing to unpack .../068-libjavascriptcoregtk-4.0-18_2.16.6-0+deb9u1+rpi1_armhf.deb ...
Unpacking libjavascriptcoregtk-4.0-18:armhf (2.16.6-0+deb9u1+rpi1) over (2.16.3-2+rpi1) ...
Preparing to unpack .../069-libmad0_0.15.1b-8+deb9u1_armhf.deb ...
Unpacking libmad0:armhf (0.15.1b-8+deb9u1) over (0.15.1b-8) ...
Preparing to unpack .../070-libobt2v5_3.6.1-4+rpi6_armhf.deb ...
Unpacking libobt2v5 (3.6.1-4+rpi6) over (3.6.1-4+rpi3) ...
Preparing to unpack .../071-libobrender32v5_3.6.1-4+rpi6_armhf.deb ...
Unpacking libobrender32v5 (3.6.1-4+rpi6) over (3.6.1-4+rpi3) ...
Preparing to unpack .../072-libpackagekit-glib2-18_1.1.5-2+deb9u1_armhf.deb ...
Unpacking libpackagekit-glib2-18:armhf (1.1.5-2+deb9u1) over (1.1.5-2) ...
Preparing to unpack .../073-poppler-utils_0.48.0-2+deb9u2_armhf.deb ...
Unpacking poppler-utils (0.48.0-2+deb9u2) over (0.48.0-2) ...
Preparing to unpack .../074-libpoppler64_0.48.0-2+deb9u2_armhf.deb ...
Unpacking libpoppler64:armhf (0.48.0-2+deb9u2) over (0.48.0-2) ...
Preparing to unpack .../075-libraw15_0.17.2-6+deb9u1_armhf.deb ...
Unpacking libraw15:armhf (0.17.2-6+deb9u1) over (0.17.2-6) ...
Preparing to unpack .../076-libruby2.3_2.3.3-1+deb9u1+rpi1_armhf.deb ...
Unpacking libruby2.3:armhf (2.3.3-1+deb9u1+rpi1) over (2.3.3-1) ...
Preparing to unpack .../077-libsdl-image1.2_1.2.12-5+deb9u1_armhf.deb ...
Unpacking libsdl-image1.2:armhf (1.2.12-5+deb9u1) over (1.2.12-5+b2) ...
Preparing to unpack .../078-libservlet3.1-java_8.5.14-1+deb9u2_all.deb ...
Unpacking libservlet3.1-java (8.5.14-1+deb9u2) over (8.5.14-1+deb9u1) ...
Preparing to unpack .../079-libsoundtouch1_1.9.2-2+deb9u1_armhf.deb ...
Unpacking libsoundtouch1:armhf (1.9.2-2+deb9u1) over (1.9.2-2) ...
Preparing to unpack .../080-libxcursor1_1%3a1.1.14-1+deb9u1_armhf.deb ...
Unpacking libxcursor1:armhf (1:1.1.14-1+deb9u1) over (1:1.1.14-1+b1) ...
Preparing to unpack .../081-libxkbcommon-x11-0_0.7.1-2~deb9u1_armhf.deb ...
Unpacking libxkbcommon-x11-0:armhf (0.7.1-2~deb9u1) over (0.7.1-1) ...
Preparing to unpack .../082-libxkbcommon0_0.7.1-2~deb9u1_armhf.deb ...
Unpacking libxkbcommon0:armhf (0.7.1-2~deb9u1) over (0.7.1-1) ...
Preparing to unpack .../083-lxinput_0.3.5-1+rpi4_armhf.deb ...
Unpacking lxinput (0.3.5-1+rpi4) over (0.3.5-1+rpi2) ...
Preparing to unpack .../084-lxpanel_0.9.3-1+rpi6_armhf.deb ...
Unpacking lxpanel (0.9.3-1+rpi6) over (0.9.3-1+rpi2) ...
Preparing to unpack .../085-lxpanel-data_0.9.3-1+rpi6_all.deb ...
Unpacking lxpanel-data (0.9.3-1+rpi6) over (0.9.3-1+rpi2) ...
Preparing to unpack .../086-lxplug-bluetooth_0.6_armhf.deb ...
Unpacking lxplug-bluetooth (0.6) over (0.3) ...
Preparing to unpack .../087-lxplug-ejecter_0.3_armhf.deb ...
Unpacking lxplug-ejecter (0.3) over (0.2) ...
Preparing to unpack .../088-raspi-config_20180518_all.deb ...
Unpacking raspi-config (20180518) over (20170811) ...
Preparing to unpack .../089-zenity_3.28.1-1.1~bpo9+1_armhf.deb ...
Unpacking zenity (3.28.1-1.1~bpo9+1) over (3.22.0-1) ...
Preparing to unpack .../090-zenity-common_3.28.1-1.1~bpo9+1_all.deb ...
Unpacking zenity-common (3.28.1-1.1~bpo9+1) over (3.22.0-1) ...
Preparing to unpack .../091-rc-gui_1.20_armhf.deb ...
Unpacking rc-gui (1.20) over (1.11) ...
Preparing to unpack .../092-lxplug-network_0.11_armhf.deb ...
Unpacking lxplug-network (0.11) over (0.2) ...
Preparing to unpack .../093-lxplug-volume_0.13_armhf.deb ...
Unpacking lxplug-volume (0.13) over (0.5) ...
Preparing to unpack .../094-nodered_0.18.7-1_armhf.deb ...
Unpacking nodered (0.18.7-1) over (0.17.4) ...
Preparing to unpack .../095-openbox_3.6.1-4+rpi6_armhf.deb ...
Unpacking openbox (3.6.1-4+rpi6) over (3.6.1-4+rpi3) ...
Preparing to unpack .../096-openssl_1.1.0f-3+deb9u2_armhf.deb ...
Unpacking openssl (1.1.0f-3+deb9u2) over (1.1.0f-3) ...
Preparing to unpack .../097-packagekit_1.1.5-2+deb9u1_armhf.deb ...
Unpacking packagekit (1.1.5-2+deb9u1) over (1.1.5-2) ...
Preparing to unpack .../098-pcmanfm_1.2.5-3+rpi4_armhf.deb ...
Unpacking pcmanfm (1.2.5-3+rpi4) over (1.2.5-3+rpi1) ...
Preparing to unpack .../099-raspberrypi-sys-mods_20180328+1_armhf.deb ...
Unpacking raspberrypi-sys-mods (20180328+1) over (20170717) ...
Preparing to unpack .../100-pi-bluetooth_0.1.8_all.deb ...
Unpacking pi-bluetooth (0.1.8) over (0.1.4) ...
Preparing to unpack .../101-pi-package-data_0.5_all.deb ...
Unpacking pi-package-data (0.5) over (0.3) ...
Preparing to unpack .../102-pi-package-session_0.5_armhf.deb ...
Unpacking pi-package-session (0.5) over (0.3) ...
Preparing to unpack .../103-pi-package_0.5_armhf.deb ...
Unpacking pi-package (0.5) over (0.3) ...
Preparing to unpack .../104-piclone_0.9_armhf.deb ...
Unpacking piclone (0.9) over (0.7) ...
Preparing to unpack .../105-pigpio_1.64-1_armhf.deb ...
Unpacking pigpio (1.64-1) over (1.60-1) ...
Preparing to unpack .../106-pipanel_20180621~152457_armhf.deb ...
Unpacking pipanel (20180621~152457) over (20170707~125920) ...
Preparing to unpack .../107-pishutdown_0.9_armhf.deb ...
Leaving 'diversion of /usr/bin/lxde-pi-shutdown-helper to /usr/bin/lxde-pi-shutdown-helper.old by pishutdown'
Unpacking pishutdown (0.9) over (0.8) ...
Preparing to unpack .../108-python-jwt_1.4.2-1+deb9u1_all.deb ...
Unpacking python-jwt (1.4.2-1+deb9u1) over (1.4.2-1) ...
Preparing to unpack .../109-python-pigpio_1.64-1_all.deb ...
Unpacking python-pigpio (1.64-1) over (1.60-1) ...
Preparing to unpack .../110-python-spidev_20170223~145721-1_all.deb ...
Unpacking python-spidev (20170223~145721-1) over (2.0~git20150907+rpi1) ...
Preparing to unpack .../111-python3-jedi_0.10.2-1+rpi1_all.deb ...
Unpacking python3-jedi (0.10.2-1+rpi1) over (0.10.0~git1+f05c071-1) ...
Preparing to unpack .../112-python3-jwt_1.4.2-1+deb9u1_all.deb ...
Unpacking python3-jwt (1.4.2-1+deb9u1) over (1.4.2-1) ...
Preparing to unpack .../113-python3-pgzero_1.2.post1-2_all.deb ...
Unpacking python3-pgzero (1.2.post1-2) over (1.1-1) ...
Preparing to unpack .../114-python3-pigpio_1.64-1_all.deb ...
Unpacking python3-pigpio (1.64-1) over (1.60-1) ...
Preparing to unpack .../115-python3-spidev_20170223~145721-1_all.deb ...
Unpacking python3-spidev (20170223~145721-1) over (2.0~git20150907+rpi1) ...
Preparing to unpack .../116-python3-thonny_2.1.16-3+rpt1_all.deb ...
Unpacking python3-thonny (2.1.16-3+rpt1) over (2.1.10-1+rpi3) ...
Preparing to unpack .../117-raspi-copies-and-fills_0.6_armhf.deb ...
Unpacking raspi-copies-and-fills (0.6) over (0.5-1) ...
Preparing to unpack .../118-raspi-gpio_0.20171123_armhf.deb ...
Unpacking raspi-gpio (0.20171123) over (0.20170105) ...
Preparing to unpack .../119-realvnc-vnc-server_6.3.0.36499_armhf.deb ...
(gconftool-2:7496): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
Unpacking realvnc-vnc-server (6.3.0.36499) over (6.1.1.28093) ...
Preparing to unpack .../120-realvnc-vnc-viewer_6.17.731.29523_armhf.deb ...
Unpacking realvnc-vnc-viewer (6.17.731.29523) over (6.1.1.28093) ...
Preparing to unpack .../121-rpd-icons_0.17_all.deb ...
Unpacking rpd-icons (0.17) over (0.10) ...
Preparing to unpack .../122-rpd-plym-splash_0.16_armhf.deb ...
Unpacking rpd-plym-splash (0.16) over (0.12) ...
Preparing to unpack .../123-rsync_3.1.2-1+deb9u1_armhf.deb ...
Unpacking rsync (3.1.2-1+deb9u1) over (3.1.2-1) ...
Preparing to unpack .../124-ruby2.3_2.3.3-1+deb9u1+rpi1_armhf.deb ...
Unpacking ruby2.3 (2.3.3-1+deb9u1+rpi1) over (2.3.3-1) ...
Preparing to unpack .../125-sonic-pi_1%3a3.0.1+1_armhf.deb ...
Unpacking sonic-pi (1:3.0.1+1) over (1:3.0.1) ...
Preparing to unpack .../126-wiringpi_2.46_armhf.deb ...
Unpacking wiringpi (2.46) over (2.44) ...
Preparing to unpack .../127-wpasupplicant_2%3a2.4-1+deb9u1_armhf.deb ...
Unpacking wpasupplicant (2:2.4-1+deb9u1) over (2:2.4-1) ...
Preparing to unpack .../128-xdg-utils_1.1.1-1+deb9u1_all.deb ...
Unpacking xdg-utils (1.1.1-1+deb9u1) over (1.1.1-1) ...
Preparing to unpack .../129-libraspberrypi-doc_1.20180619-1_armhf.deb ...
Unpacking libraspberrypi-doc (1.20180619-1) over (1.20170811-1) ...
Preparing to unpack .../130-libraspberrypi-dev_1.20180619-1_armhf.deb ...
Unpacking libraspberrypi-dev (1.20180619-1) over (1.20170811-1) ...
Preparing to unpack .../131-raspberrypi-kernel_1.20180619-1_armhf.deb ...
Adding 'diversion of /boot/bcm2708-rpi-0-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-0-w.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
Adding 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Adding 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/bmp085_i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/bmp085_i2c-sensor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c0-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c0-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c1-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c1-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/lirc-rpi.dtbo to /usr/share/rpikernelhack/overlays/lirc-rpi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-act-led.dtbo to /usr/share/rpikernelhack/overlays/pi3-act-led.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-disable-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-wifi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-miniuart-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/rpi-cirrus-wm5102.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-dac.dtbo to /usr/share/rpikernelhack/overlays/rpi-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-display.dtbo to /usr/share/rpikernelhack/overlays/rpi-display.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-proto.dtbo to /usr/share/rpikernelhack/overlays/rpi-proto.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio-1bit.dtbo to /usr/share/rpikernelhack/overlays/sdio-1bit.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdtweak.dtbo to /usr/share/rpikernelhack/overlays/sdtweak.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-hw-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-hw-cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/upstream-aux-interrupt.dtbo to /usr/share/rpikernelhack/overlays/upstream-aux-interrupt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Unpacking raspberrypi-kernel (1.20180619-1) over (1.20170811-1) ...
ShiftPlusOne
Thu Jul 05, 2018 2:36 pm
Sorry, that should've been history.log, not term.log
JonnyAlpha
Thu Jul 05, 2018 4:23 pm
DOH!
Oh well all fixed now :-)
JonnyAlpha
Sun Jul 08, 2018 11:30 am
It seemed to be a an unfinished update.
I tried to run sudo apt install raspberrypi-ui-mods and it complained saying something about dpkg not configured.
I followed the instructions and the update finished and now I have a Desktop back.
