Get the temperature of LAN Chip for P3B+
Posted: Sun Jul 01, 2018 1:21 pm
by Shawn1913
Hi all,
I had a post at
viewtopic.php?f=28&t=217092 which is asking a case of P3B+ always shutdown with my application running for hours, and I've logged performance counter with command
and
along the test, I can see the temperature (<65'C), Memory usage (<10), Cpu usage(<30) are all good, so I strongly suspect the
LAN Chip heat is the root cause since from the official doc
Operating Temperatur
said the
LAN Chip dead temp is just 70'C, and my application is doing most of job about the TCP/IP and Usb serial communication.
So just want to know is there any API like
vcgencmd I can use to read the LAN Chip temperature ? if there's no, how can I sure the problems like this? any system logs could help?
Re: Get the temperature of LAN Chip for P3B+
Posted: Sun Jul 01, 2018 1:39 pm
by epoch1970
I don't know the answer to that question, I imagine there is no such sensor.
However, are you talking of 70°C ambient or 70°C CPU temp?
70°C CPU temp is nothing to write home about.
At 70°C ambient temp, all the ancillaries like ethernet or usb cables are likely to start melting I think. I don't know of many ethernet cables rated to operate over 60°C ambient, for starters.
Posted: Sun Jul 01, 2018 2:14 pm
by hippy
Shawn1913 wrote: ↑Sun Jul 01, 2018 1:21 pm
There appears to be no LAN9515 datasheet publicly available, almost no data at all, but none of the LAN9512, LAN9513 and LAN9514 devices have an on-chip temperature sensor mentioned so it would be reasonable to presume it is the same and there is no way the chip can report its own temperature, and therefore no way for
vcgencmd or anything else to know or report what it would be.
About the only thing you could do is take a thermal imaging camera or temperature probe and measure what the chip's temperature is.
You could cautiously put your finger on it. You'll soon know which side of 50C it is.
Posted: Sun Jul 01, 2018 2:22 pm
by jamesh
If I remember, I'l try and get a IR image of the board under heavy network load tomorrow.
Posted: Mon Jul 02, 2018 1:21 am
by Shawn1913
jamesh wrote: ↑Sun Jul 01, 2018 2:22 pm
Hey jamesh, I can't wait for you testing result!
My case is:
- open 2 TCP connections to external device, send 5 messages(and will receive 5 response as well) in 1 seconds in each connection, and each message is about 50 bytes
- open 2 USB serial(by USB to RS232 converter) connections to another external device, send 3 message(and will receive 3 response as well) in 1 seconds in each connection, and each message is about 20 bytes
Posted: Mon Jul 02, 2018 8:15 am
by hippy
It seems hard to imagine that such a small amount of data being transferred would lead you to the suspicion that it's the LAN chip overheating and stopping working.
Obviously something is going wrong with your system but I wouldn't suspect 'thrashing the LAN chip' would be causing that.
Posted: Mon Jul 02, 2018 9:00 am
by jamesh
hippy wrote: ↑Mon Jul 02, 2018 8:15 am
Indeed. From a networking point of view, that's practically idle. Seriously doubt there are any problems with overheating due to traffic levels.
Posted: Mon Jul 02, 2018 10:11 am
by jamesh
OK, had a play with the IR camera on the ethernet chip whilst under a bit of load (copying from Samba share to SD card). Went from 54-55ºc to 55-56ºc, so not a huge rise. Hottest chip on the board though, although nowhere near any critical temperatures.
Posted: Mon Jul 02, 2018 10:38 am
by Shawn1913
jamesh wrote: ↑Mon Jul 02, 2018 10:11 am
thanks for the testing, so for my case, do you have any suggestion for further narrow down?
Posted: Mon Jul 02, 2018 1:48 pm
by jamesh
Since the Pi is apparently actually shutting down, I have no idea. Cannot think of a reason why that might happen.
Have you any logs or possible symptoms? Power issues?
Posted: Tue Jul 03, 2018 12:01 am
by Shawn1913
jamesh wrote: ↑Mon Jul 02, 2018 1:48 pm
Unlikely the power issue since my power adapter is from a famous brand with quality (but will still try another by your suggestion).
I only have the application logs which basically no help (it just suddenly stopped).
Can I check any system logs to help? could you give a hint.
Last thought, As you tested, the
LAN Chip is always(?) the hottest, and now the
SOC temp reading is 63'C, can I say the
LAN Chip must hotter than
SOC, that means it almost reached its
dead temp 70' C???
Posted: Tue Jul 03, 2018 6:43 am
by jamesh
Shawn1913 wrote: ↑Tue Jul 03, 2018 12:01 am
dead temp 70' C???
No. My tests were with an idle CPU. It will get hotter under load. There is no direct link between CPU and ethernet chip temps.
Posted: Tue Jul 03, 2018 7:13 am
by Shawn1913
jamesh wrote: ↑Tue Jul 03, 2018 6:43 am
dead temp 70' C???
Ok...
So could you give some suggestion on this kind of 'automatically shutdown' case? there's must have somewhere logged some clue.
BTW, Does
RaspeberryPi.org provide business consultant service, like consultant for technical issues?
Posted: Tue Jul 03, 2018 3:26 pm
by jamesh
Shawn1913 wrote: ↑Tue Jul 03, 2018 7:13 am
dead temp 70' C???
Ok...
BTW, Does
No, we have no paid business service. Use the forums and github issues.
TBH, the help you get from the userbase is pretty good. And since I work for Raspberry Pi as an engineer, it's not like we don't see and comment on things like this.
With regard to the issue, automatic shutdown is something I have rarely heard of. Overheating simply causes the CPU to lower is performance until the heat level drops - it does not cause a reboot.
You could look in syslog to see what happens just before the shutdown, but if this is some weird HW fault or odd driver failure, its unlikely to show anything.
Having just look through the linked thread - does it actually reboot, or does it lock up? They are different things. I wonder if this is either the test escape SOC issue , or perhaps the EEE issue , or even the tcp segmentatation offload problem. In all cases you need the latest Raspbian to mitigate the issue.
Do an
to get the latest bug fixes.
Someone has also recently reported a further problem with EEE as well, you can try and turn it off if the update above doesn't work. You'll need to do this each time you reboot, until we know if it fixes the problem.
sudo ethtool --set-eee eth0 eee off
Posted: Tue Jul 03, 2018 5:05 pm
by epoch1970
(If the OP had installed the watchdog package -a recent version at that-, I think there is a way to get it to halt the machine when the Pi temp sensor reaches a certain value... But usually you don't install watchdog inadvertently and indeed there are traces in syslog.)
Posted: Tue Jul 03, 2018 5:38 pm
by jamesh
epoch1970 wrote: ↑Tue Jul 03, 2018 5:05 pm
I really don't think this is an overheating problem. There are other more likely causes.
