7fh3498f
Init 6 causing turning off after last update...
Sat Jun 30, 2018 1:56 pm
I just updated my RPi3B+ to #1122 firmware.
After update my device behaves strange. Init 6 command is causing some sort of turn off state. Weird thing is that all LED's are off and device is not responding. Usualy red LED stayed solid on. I have no clue how to even start troubleshooting. I tried from clean image dated 2018-06-27, same thing. Init 0 also working same way. Any help appreciate. Thank you.
Re: Init 6 causing turning off after last update...
Sat Jun 30, 2018 4:21 pm
Try sudo rpi-update - there's a fix for the not rebooting from a USB device in there today.
This is a doctor free zone.
B.Goode
Sat Jun 30, 2018 4:56 pm
Could this be related to the issue you have found with your use of Eltech's Exagear Desktop?
viewtopic.php?f=29&t=217093
Can the problem be replicated in a standard unmodified installation of Raspbian?
7fh3498f
Sat Jun 30, 2018 5:07 pm
Solution works. Firmware bumped to #1123 Thank you for your help.
7fh3498f
Looks like it has nothing to do with Exagear. Thanks anyway...
