Shawn1913
Pi3B+ automatically shutdown while the temperature is less than 65' C
Sat Jun 30, 2018 1:29 pm
Hi all,
I'm using Raspbian Stretch with desktop which published at 2018 JUNE.
I'm doing some performance testing with Pi3B+ by running my application, the application is just keep send/write data via TCP/IP and USB serial port to some devices.
It all looks good at beginning hours(say 6 hours), but later, I noticed the Pi just shutdown it self (no screen show, no keyboard response), I have to unplug and plug in the power cable to bring it back.
I've logged the performance counters every 60 seconds in testing by using
/opt/vc/bin/vcgencmd
related commands and
 top -n 1
for logging temp, volt, frequency, CPU/Memory usage from the beginning to shutdown, I can see the temp was keep rising from 51'C to 63.4'C, volt is quite stable around 1.3625V, frequency is quite stable by jumping at 1400000000 or 600000000, CPU usage is range from 10 to 30, memory is always around 10.
Anyone could help, where I can find the root cause of the shutdown, if it's caused by heat (though i don't believe so since it's far below the official https://www.raspberrypi.org/help/faqs/# ... emperature announced 85' C), the system must have some place to logged that, correct?
Void Frost
Re: Pi3B+ automatically shutdown while the temperature is less than 65' C
Sun Jul 01, 2018 3:13 am
Correct me if i am wrong, (anybody) but raspberry pi requires 5 volts.
Do you see a lightning bolt symbol anywhere on your screen? That signals undervoltage.
I
Raspberry Pi User. Subscribe to my YouTube channel, if you want :D https://www.youtube.com/c/VoidFrost
Sun Jul 01, 2018 5:19 am
It does, for the main supply. On board there are many voltages (3.3V, 1.8V etc). The voltage listed above is the main chip core voltage.
LTolledo
Sun Jul 01, 2018 5:41 am
Keep it cool then...
Provide/attach an appropriately sized heatsink
Test again....
If it still fails... provide even larger heatsink, or attach a fan
Test again....
Some people be like:
MaxK1
Sun Jul 01, 2018 7:33 am
Could it be a memory leak? Does anything show in the logs? (in /var/log/ )
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Shawn1913
Sun Jul 01, 2018 10:29 am
Test again....
Test again....
Is there any place(system log) logged the over heating case? i actually suspect the LAN chip since its dead temp is 70.
Shawn1913
Mon Jul 02, 2018 10:40 am
could you more specify, what logs I should to check under /var/log/ since there're plenty?
Mon Jul 02, 2018 12:01 pm
