A/V connection problem
Posted: Fri Jun 29, 2018 7:57 am
by serozhax
Hi friends!
I have the Raspberry PI 3 B+.
I can't connect it whith TV via A/V output. There isn't a picture on TV.
I bought cable for MP3 player and little modified it like on schema on internet. Multimeter test is OK.
Maybe I should edit some setings on device?
Help me please.
Re: A/V connection problem
Posted: Fri Jun 29, 2018 11:06 am
by DougieLawson
https://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
What's your TV standard? The default if you add nothing to /boot/config.txt is that the AV video is NTSC 60Hz 480i.
Posted: Fri Jun 29, 2018 11:36 am
by serozhax
I followed this instruction.
And how can I find standard of my TV? It's model LG 21FS2CG-TS
Posted: Fri Jun 29, 2018 12:21 pm
by DougieLawson
What country are you in?
add
sdtv_mode=2
sdtv_aspect=1
That sets it to PAL 50Hz 576i 4:3.
Posted: Fri Jun 29, 2018 12:59 pm
by fruitoftheloom
SDTV Modes
https://www.raspberrypi.org/documentati ... t/video.md
Posted: Fri Jun 29, 2018 1:29 pm
by serozhax
add
sdtv_mode=2
sdtv_aspect=1
I'm from Russia
Posted: Fri Jun 29, 2018 1:48 pm
by drgeoff
Russia choose to follow France and use SECAM. However most TVs that can decode SECAM also decode PAL.
In any case, it is extremely rare that the wrong* setting of sdtv_mode in config.txt will of itself be the reason for nothing appearing on a TV screen.
(* Even 525/625)
Posted: Fri Jun 29, 2018 1:50 pm
by fruitoftheloom
Hi friends!
Help me please.
Cable issue ???
Posted: Fri Jun 29, 2018 2:02 pm
by pksato
Or need to force composite output disabling HDMI.
hdmi_ignore_hotplug=1
From wikipedia Russia use Secam as ATV color system. But, LG TV also is compatible with PAL.
Posted: Fri Jun 29, 2018 2:03 pm
by drgeoff
1. Is the RPi actually booting?
2. Ensure nothing is plugged in to the RPi's HDMI socket when powering up.
3. What OS is on the card? Has NOOBS been used?
Posted: Fri Jun 29, 2018 2:27 pm
by serozhax
1. I have updated system today.
2. Nothing is plugged in to the RPi's HDMI socket.
3. OS Raspbian. Installed without NOOBS.
Maybe there is cable issue... But I checked it for many times...
1 - Video
2 - Ground
3 - Right Audio
4 - Left Audio
Posted: Fri Jun 29, 2018 2:39 pm
by serozhax
How to set it up? SECAM instead PAL.
Posted: Fri Jun 29, 2018 2:46 pm
by drgeoff
TVs can often automatically switch between PAL and SECAM.
But even if the PAL/SECAM setting is not correct you would get a black and white display.
You did not confirm that the RPi is booting.
Posted: Fri Jun 29, 2018 2:55 pm
by serozhax
IT WORKS!!!! Thank you!!!
P.S. If i want connect HDMI must I change this setting?
Posted: Fri Jun 29, 2018 5:26 pm
by pksato
Yes, need to set to 0 or comment or remove the line.
Posted: Fri Jun 29, 2018 9:47 pm
by klricks
When using the default settings of Raspbian (Not NOOBS), the RPi will automatically use HDMI if connected at boot. If no HDMI is connected then the RPi will automatically switch to composite (AV) on boot.
You only need to change the setting for PAL:
sdtv_mode=2
