RTL8192EU not working as AP
Posted: Tue Jun 26, 2018 7:26 pm
Hi folks,
Today, I tried to use my TP-LInk WN823Nv2 (v2, it contains a RTL8192EU) as an AP on my Pi, but hostapd gives some errors whenever I try to start hostapd with my configuration. I installed the drivers and the specific hostapd from http://hackingadventures42.blogspot.com ... point.html (the 'Sidestep for the TL-WN823N' paragraph) and if I start hostapd if gives me this message () many times and a lot other (non-error, only informative) messages). I also tried installing the driver for the chip and hostapd from links provided here: https://forum.armbian.com/topic/2586-re ... fi-driver/.
I am using Raspbian Stretch. Does anybody know what to do to make it work? I've also tried this: https://daveconroy.com/how-to/turn-your ... s-chipset/, but it seems that it is meant for version 1 of the dongle (contains a slightly different chip, a RTL8192CU, as far as I know).
Thanks in advance!
Wouter
ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported
Thanks in advance!
Wouter
