waayne
[VNC] Cannot currently show the dekstop
Mon Jun 25, 2018 9:46 pm
Hey,
I have a problem with my Pi 3+. I activated the VNC server and tried to connect to it on my tablet via the VNCViewer app.
But when I am connected to it there is an error (see attachment).
What can I do to fix that?
klricks
Re: [VNC] Cannot currently show the dekstop
Tue Jun 26, 2018 1:23 am
Hey,
The RPi must be set to boot to desktop (service mode).
If a HDMI monitor is not attached then you need to specify a screen resolution in config.txt
Use GUI config tool or sudo raspi-config to do that.
If not booting to desktop then you need to use virtual mode. (Run vncserver from the command line).
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
coldsprite
Thu Jul 05, 2018 9:27 pm
I have same problem.
I enabled service mode desktop auto login, and default resolution.
Still see same "Cannot currently show the desktop" error on VNC.
coldsprite
Thu Jul 05, 2018 9:29 pm
I have the same problem.
Already tried the recommendation, still same error.
klricks
Thu Jul 05, 2018 9:38 pm
Do not use default resolution. Choose something else.
jkellogg11
Sun Jul 08, 2018 11:34 pm
You need to install a window manager.
Check out this post.
viewtopic.php?f=66&t=133691
My .xsession-errors file showed this. After installing LXDE I could login.
[email protected]:~# cat .xsession-errors
Xsession: X session started for root at Wed 18 Apr 13:50:07 UTC 2018
Xsession: unable to start X session --- no "/root/.xsession" file, no
"/root/.Xsession" file, no session managers, no window managers, and no
terminal emulators found; aborting.
olafvandekuijt
Mon Jul 09, 2018 6:49 am
I had the same problem.
After changing the resolution to the highest it was solved (sudo raspi-config)
Olaf
pk_rulz
Fri Aug 31, 2018 9:54 am
If everything was working fine and it stopped suddenly then there is possibility that you might have run out of space on the SD card.
I am listing it down to help someone who have such a problem
The following thread should help you to fix that issue
https://www.raspberrypi.org/forums/view ... hp?t=71520
In a nutshell
If you can connect over ssh, this should show you if your /dev/root is full
df -h
If it is, this should help you locate the culprit folder/file. Remove it and vnc should work fine.
sudo du -xh / | grep -P "G\t"
For more advanced options the thread link at the stop should help
demian
Thu Oct 04, 2018 7:09 am
In my case...
I installed lxsession(sudo apt-get install lxsession)
, then work OK.
nikitakaps
Fri May 24, 2019 3:47 pm
I tried everything mentioned in this thread, but nothing worked. What helped me was deleting the /home/pi/.profile using sudo rm .profile
After rebooting I was automatically logged in and everything worked as before. Hope this helps!
Anantasak
Sun Jun 09, 2019 7:37 am
For some case:
Found that problem cause by lxsession file damage. Try PD by running lxsession and find out which package broken then reinstall specific package.
[email protected]:~ $ lxsession
lxsession: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/libgtk-x11-2.0.so.0: nonzero padding in e_ident
Fixed by checking md5 libgtk-x11-2.0.so.0 a.k.a libgtk-x11-2.0.so.0.2400.31
[email protected]:/usr/lib/arm-linux-gnueabihf $ md5sum libgtk-x11-2.0.so.0.2400.31
845a355f212cfb3ac3e9cb6926002615 libgtk-x11-2.0.so.0.2400.31
then rerun install package
sudo apt-get install --reinstall libgtk2.0-0
to resolved lxsession
[email protected]:/usr/lib/arm-linux-gnueabihf $ lxsession
** Message: main.vala:102: Session is (null)
** Message: main.vala:103: DE is (null)
** Message: main.vala:107: No session set, fallback to LXDE session
** Message: main.vala:113: No desktop environnement set, fallback to LXDE
RottenRonnie
Fri Jun 14, 2019 4:45 pm
I used these steps to get the RealVNC server to work after reading the posts above:
(Note that resetting the max resolution in raspi-config had no effect and I was still seeing the error message.)
[email protected]:~ $ cat .xsession-errors
The error that I saw:
/usr/bin/x-session-manager: 33: exec: /usr/bin/lxsession: not found
[email protected]:~ $ ls /usr/share/xsessions
lightdm-xsession.desktop  openbox.desktop
[email protected]:~ $ cat /usr/share/xsessions/lightdm-xsession.desktop
[Desktop Entry]
Version=1.0
Name=Default Xsession
Exec=default
Icon=
Type=Application
[email protected]:~ $ sudo apt-get install --reinstall lxsession
Success!!! I'm currently logged into the regular pixel desktop. :mrgreen:
macd2point0
Wed Jun 26, 2019 2:35 am
Changing the resolution worked for me. That's all i got.
Andyroo
Wed Jun 26, 2019 2:19 pm
N Buster it seems that you need to set the resolution before using VNC either by the GUI or command line raspi-config.
SimUK
Wed Jun 26, 2019 2:23 pm
seandex
Thu Jun 27, 2019 7:46 am
Hey,
Where is the example for the config.txt?
Whoever put his meth-face on as profile picture should get banned. not the humourous signature.
Man in a van
Thu Jun 27, 2019 10:51 am
Hey,
sudo raspi-config
Select 7 Advanced Operations
Select 5 Resolution
Andyroo
Thu Jun 27, 2019 11:27 am
The entries in config.txt are three lines
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=35
But the values differ depending on the mode and are set by lines 1539 onwards of raspi-config (as of the time of this posting).
BUT it is getting more complex with additions for the Pi 4 (HDMI vs Composite) so I would just follow Man in a vans process above
I cannot remember if the GUI version of the configuration tool has resolution controls and the Pi computers I can get to at the mo are running Lite.
Shad0w1and
Fri Jul 05, 2019 12:09 am
sudo raspi-config
Select 5 Resolution
Thanks, this worked for me!
tom408881465
Thu Jul 25, 2019 3:06 am
Hi
I changed Boot Options, set boot into a desktop ,it was solved.
gufronra
Thu Aug 29, 2019 1:10 am
I had the same problem. just reboot your raspberry (don't close vnc session that show black screen "Cannot currently show the desktop") and wait a minute till raspberry full loaded the desktop :D
The German
Sun Sep 08, 2019 11:35 pm
I could not switch away from GNOME to KDE or another desktop, the automatic logon did not work anymore and VNC never worked after the initial installation and updates. I like to tinker, but "Buster" is a piece of crap that should not have been released with all the bugs and incompatibilities. The PI 4 is pretty much useless to me as there is no real compatible and stable OS. Disappointing.
cyberflame
Wed Sep 25, 2019 6:50 am
I've tried all of these things, none of which work.
ohilton576
Sun Sep 29, 2019 8:14 pm
Why are you trying to use VNC anyway?
I found that good old windows RDP (Remote Desktop) works just fine. Use port 3389. Sorted. No need for any additional apps like vnc or anydesk.
ahammedx007
Thu Oct 10, 2019 11:16 am
sudo raspi-config
Then
Select 5 Resolution
