lmarmisa
Re: Raspberry Pi 3 Ethernet Issue
Mon Jun 25, 2018 1:03 pm
Could you try these commands?
sudo /etc/init.d/networking restart
sudo dhclient -r eth0
sudo dhclient eth0
sudo dhclient -r eth1
sudo dhclient eth1
ifconfig
saihoufung
Mon Jun 25, 2018 1:21 pm
Followed as per instruction.
pi@img-2.1-722198:~$ sudo /etc/init.d/networking restart
Restarting networking (via systemctl): networking.serviceWarning: Unit file of networking.service changed on disk, 'systemctl daemon-reload' recommended.
pi@img-2.1-722198:~$ sudo ifconfig
sudo: unable to resolve host piaware-63040
eth0      Link encap:Ethernet  HWaddr b8:27:eb:72:21:98
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:32759 errors:0 dropped:0 overruns:0 frame:0
          TX packets:32759 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:15111153 (14.4 MiB)  TX bytes:15111153 (14.4 MiB)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:27:74:cd
          RX packets:34556 errors:0 dropped:33 overruns:0 frame:0
          TX packets:33718 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4330910 (4.1 MiB)  TX bytes:23230861 (22.1 MiB)
pi@img-2.1-722198:~$ sudo dhclient -r eth0
pi@img-2.1-722198:~$ sudo dhclient eth0
pi@img-2.1-722198:~$ sudo dhclient -r eth1
Killed old client process
pi@img-2.1-722198:~$ sudo dhclient eth1
sudo ifconfig
eth1      Link encap:Ethernet  HWaddr 00:0e:c6:de:c8:be
          inet addr:192.168.1.180  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: 2001:d08:e0:44be:20e:c6ff:fede:c8be/64 Scope:Global
          inet6 addr: fe80::20e:c6ff:fede:c8be/64 Scope:Link
          inet6 addr: fd82:574f:4a68:0:20e:c6ff:fede:c8be/64 Scope:Global
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:20 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1816 (1.7 KiB)  TX bytes:1710 (1.6 KiB)
          RX packets:34069 errors:0 dropped:0 overruns:0 frame:0
          TX packets:34069 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:15660324 (14.9 MiB)  TX bytes:15660324 (14.9 MiB)
After reboot of Pi.
          RX packets:144 errors:0 dropped:0 overruns:0 frame:0
          TX packets:144 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:29783 (29.0 KiB)  TX bytes:29783 (29.0 KiB)
          inet addr:192.168.1.7  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: 2001:d08:e0:44be:ba27:ebff:fe27:74cd/64 Scope:Global
          inet6 addr: fe80::ba27:ebff:fe27:74cd/64 Scope:Link
          inet6 addr: fd82:574f:4a68:0:ba27:ebff:fe27:74cd/64 Scope:Global
          RX packets:135 errors:0 dropped:22 overruns:0 frame:0
          TX packets:115 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:28312 (27.6 KiB)  TX bytes:44787 (43.7 KiB)
No longer work for eth1.
saihoufung
Mon Jun 25, 2018 1:31 pm
I tried it once again with the command:-
sudo dhclient eth0
sudo dhclient eth1
The eth1 is working again. However after reboot, the eth1 is no longer work.
Finally I found a solution.
sudo nano /etc/rc.local
sudo dhclient eth1
Reboot, and now eth1 is working.
I disconnect wlan0 connection and reboot, eth1 still working.
Hopefully this will work as it should.
Regards,
SaiHou
ejolson
Mon Jun 25, 2018 5:28 pm
sudo dhclient eth1
Glad you got it working.
Software problems of this sort seem to happen for all but the most basic system configurations. The complexity of the initialization system in Raspbian and the network configuration have resulted in problems that are difficult to fix properly and putting a few commands in rc.local to patch things up at the end is common and expedient even if not reasonable.
saihoufung
Mon Jun 25, 2018 9:59 pm
sudo dhclient eth1
Yes. Sometimes Raspbian is more "complexity". I haven't try for the eth0 if it really works or not by adding the same command at rc.local with
sudo dhclient eth0
Will give a try later.
Regards.
