Resizing the partitions "resize-sd" for Manjaro-Arm is not properly working
Posted: Thu Jun 14, 2018 5:40 pm
by grims
http://wiki.manjaro-arm.org/index.php/G ... Installing
By default, the partitions that are created within the image are just large enough to support the OS. To have any usable space, you must first resize the partitions to fill the remainder of the sdcard. There is an included script that automates to minimize the risk of errors or data corruption. To run this script, simple run:
sudo resize-sd
Once completed, the script will prompt you to reboot the device. Once the reboot has finished, you should see that the available space has been completely filled with the root '/' partition and the filesystem has been resized to match.
But this does not happen:
Error: The device /dev/autofs is so small that it cannot possibly store a file system or partition table.  Perhaps you selected the wrong device?
Warning: Error fsyncing/closing /dev/autofs: Invalid argument
Retry/Ignore?
Solution for raspberry pi 3:
findmnt / -o source -n
should be approximately: "mmcblk0p2"
enter commands:
sudo sed -i '/PART_DEV=/c\PART_DEV="/dev/mmcblk0p2"' /usr/bin/resize-sd
sudo sed -i '/parted -m/c\parted -m $DEV u s resizepart $PART_NUM yes $END_SECTOR' /usr/bin/resize-sd
sudo sed -i '/df -h/c\df -h | egrep "Filesystem|$PART_NAME"' /usr/bin/resize-sd
Further:
sudo resize-sd
Reboot!
Profit!
P.S. Images Manjaro-Arm_Mate_rpi2_18.05.img
Re: Resizing the partitions "resize-sd" for Manjaro-Arm is not properly working
Posted: Thu Jun 14, 2018 6:16 pm
by DougieLawson
Post your question on https://forum.manjaro.org/c/manjaro-arm you are much more likely to get an answer over there.
Posted: Thu Jun 14, 2018 7:06 pm
by grims
Thanks, but it's not a question, it's the answer.
Posted: Thu Jun 14, 2018 9:53 pm
by cjan
they fixed in 18.06 mini.img or wait mate-18.06.img.
