Psychokiller1888
sudo reboot
Sun Jun 10, 2018 4:37 pm
Hi!
I have a few raspberrie pi at home. One in particular, a raspi 3b+, updated/upgraded, on latest raspbian strech, running solely on a mSata (no sd card) through an x805 mSata hat is causing me problems.
Before I had the mSATA, I could "sudo reboot" normally. It would.... reboot....
Since I installed the mSATA (fresh, flashed it, reinstalled everything), whenever I do a "sudo reboot" it turns off... No more leds, no activity led, no network leds, ssh goes down, everything stops. But it stays dead, until I unplug it and replug it.... Any advices where to search for an answer?
Re: sudo reboot
Sun Jun 10, 2018 5:13 pm
Try sudo rpi-update to get a 4.14.48 kernel and bootcode that fixes the "won't reboot" bug. It's slightly experimental but the latest build is now four days old.
Psychokiller1888
Re: sudo reboot
Sun Jun 10, 2018 6:34 pm
Thanks for the answer!
Is it based on a changelog that you say it's gonna fix it? I'm just asking, because rpi-update is not just rpi-update, it breaks the respeaker support and other things that take time to fix then...
Re: sudo reboot
Sun Jun 10, 2018 6:44 pm
It's based on the commits at https://github.com/hexxeh/rpi-firmware.
If rpi-update causes a problem you may be able to copy just bootcode.bin, start_cd.elf, start_db.elf, start.elf, start_x.elf, fixup_cd.dat, fixup.dat, fixup_db.dat & fixup_x.dat and leave your special kernel & /lib/modules in place.
Psychokiller1888
Re: sudo reboot
Sun Jun 10, 2018 6:45 pm
Oh ok, so I'm gonna give that a shot and give the results back here, thank you for your time!
Psychokiller1888
Re: sudo reboot
Mon Jun 11, 2018 12:38 pm
Ok, not only it did not correct the reboot problem, but I can't reinstall my respeaker now :)
The actual kernel, after update is 4.14.48-v7+
Re: sudo reboot
Mon Jun 11, 2018 1:20 pm
Time to recover that backup you took before running rpi-update.
Psychokiller1888
Re: sudo reboot
Mon Jun 11, 2018 1:21 pm
Reverted to 4.14.34+ :)
fred44nl
Re: sudo reboot
Mon Jun 11, 2018 3:36 pm
is there any idea when this kernel comes available for "normal" update/upgrade ??
headless RPi 3B running from usbhdd.
Re: sudo reboot
Mon Jun 11, 2018 3:39 pm
It will happen sometime in the future when the RPF/RP(T)Ltd. folks decide the time is right for the next version of NOOBS and plain Raspbian.
fred44nl
Re: sudo reboot
Tue Jun 26, 2018 9:26 am
running kernel 4.14.48 for a while.
but a reboot will not work.
always have to pull the power-supply, after 5 mins. waiting.
this is the output of dmesg:
fred44nl@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.48-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1118 SMP Thu Jun 7 16:40:27 BST 2018
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 8 MiB at 0x3ac00000
[    0.000000] On node 0 totalpages: 242688
[    0.000000] free_area_init_node: node 0, pgdat 80c84fc0, node_mem_map ba3a1000
[    0.000000]   Normal zone: 2133 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 242688 pages, LIFO batch:31
[    0.000000] percpu: Embedded 17 pages/cpu @ba34a000 s38720 r8192 d22720 u69632
[    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
[    0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait rootdelay=5
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 940236K/970752K available (7168K kernel code, 575K rwdata, 2072K rodata, 1024K init, 706K bss, 22324K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                   lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                   modules : 0x7f000000 - 0x80000000   (  16 MB)
                     .text : 0x80008000 - 0x80800000   (8160 kB)
                     .init : 0x80b00000 - 0x80c00000   (1024 kB)
                     .data : 0x80c00000 - 0x80c8feb4   ( 576 kB)
                      .bss : 0x80c96f40 - 0x80d478b4   ( 707 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 25253 entries in 75 pages
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000023] Switching to timer-based delay loop, resolution 52ns
[    0.000273] Console: colour dummy device 80x30
[    0.000807] console [tty1] enabled
[    0.000846] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.000886] pid_max: default: 32768 minimum: 301
[    0.001215] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001248] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002197] Disabling memory control group subsystem
[    0.002296] CPU: Testing write buffer coherency: ok
[    0.002709] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003106] Setting up static identity map for 0x100000 - 0x10003c
[    0.003239] Hierarchical SRCU implementation.
[    0.003891] smp: Bringing up secondary CPUs ...
[    0.004600] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005351] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.006083] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.006187] smp: Brought up 1 node, 4 CPUs
[    0.006258] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.006279] CPU: All CPU(s) started in HYP mode.
[    0.006297] CPU: Virtualization extensions available.
[    0.007169] devtmpfs: initialized
[    0.016906] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[    0.017571] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.017815] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.017859] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.018435] pinctrl core: initialized pinctrl subsystem
[    0.019201] NET: Registered protocol family 16
[    0.021819] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.026592] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.026624] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.026853] Serial: AMBA PL011 UART driver
[    0.028489] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.028966] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.059850] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[    0.061379] SCSI subsystem initialized
[    0.061617] usbcore: registered new interface driver usbfs
[    0.061692] usbcore: registered new interface driver hub
[    0.061794] usbcore: registered new device driver usb
[    0.070077] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-06-07 15:31
[    0.071398] clocksource: Switched to clocksource arch_sys_counter
[    0.148423] VFS: Disk quotas dquot_6.6.0
[    0.148535] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.148739] FS-Cache: Loaded
[    0.148949] CacheFiles: Loaded
[    0.157775] NET: Registered protocol family 2
[    0.158505] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.158635] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.158837] TCP: Hash tables configured (established 8192 bind 8192)
[    0.158984] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.159045] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.159289] NET: Registered protocol family 1
[    0.159740] RPC: Registered named UNIX socket transport module.
[    0.159764] RPC: Registered udp transport module.
[    0.159784] RPC: Registered tcp transport module.
[    0.159802] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.161212] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.164029] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.171981] FS-Cache: Netfs 'nfs' registered for caching
[    0.172589] NFS: Registering the id_resolver key type
[    0.172642] Key type id_resolver registered
[    0.172662] Key type id_legacy registered
[    0.172691] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.174532] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.174677] io scheduler noop registered
[    0.174699] io scheduler deadline registered (default)
[    0.174990] io scheduler cfq registered
[    0.175011] io scheduler mq-deadline registered
[    0.175031] io scheduler kyber registered
[    0.177691] BCM2708FB: allocated DMA memory fad10000
[    0.177737] BCM2708FB: allocated DMA channel 0 @ bb813000
[    0.188203] Console: switching to colour frame buffer device 90x30
[    0.197102] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    0.200972] bcm2835-rng 3f104000.rng: hwrng registered
[    0.203747] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.209638] vc-sm: Videocore shared memory driver
[    0.212854] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    0.225368] brd: module loaded
[    0.236899] loop: module loaded
[    0.239761] Loading iSCSI transport class v2.0-870.
[    0.243222] libphy: Fixed MDIO Bus: probed
[    0.246061] usbcore: registered new interface driver lan78xx
[    0.248919] usbcore: registered new interface driver smsc95xx
[    0.251691] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.482590] Core Release: 2.80a
[    0.485332] Setting default values for core params
[    0.488064] Finished setting default values for core params
[    0.690981] Using Buffer DMA mode
[    0.693647] Periodic Transfer Interrupt Enhancement - disabled
[    0.696405] Multiprocessor Interrupt Enhancement - disabled
[    0.699200] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.702033] Dedicated Tx FIFOs mode
[    0.705194] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[    0.711183] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.725575] dwc_otg: Microframe scheduler enabled
[    0.725631] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e7c5c
[    0.728425] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e7fc4 length 36
[    0.731133] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87e000
[    0.733808] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.736501] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.739259] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.742016] Init: Port Power? op_state=1
[    0.744673] Init: Power Port (0)
[    0.747543] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.750325] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.753117] usb usb1: Product: DWC OTG Controller
[    0.755867] usb usb1: Manufacturer: Linux 4.14.48-v7+ dwc_otg_hcd
[    0.758636] usb usb1: SerialNumber: 3f980000.usb
[    0.761967] hub 1-0:1.0: USB hub found
[    0.764676] hub 1-0:1.0: 1 port detected
[    0.767796] dwc_otg: FIQ enabled
[    0.767802] dwc_otg: NAK holdoff enabled
[    0.767806] dwc_otg: FIQ split-transaction FSM enabled
[    0.767816] Module dwc_common_port init
[    0.768056] usbcore: registered new interface driver usb-storage
[    0.770891] mousedev: PS/2 mouse device common for all mice
[    0.773663] IR NEC protocol handler initialized
[    0.776276] IR RC5(x/sz) protocol handler initialized
[    0.778805] IR RC6 protocol handler initialized
[    0.781309] IR JVC protocol handler initialized
[    0.783777] IR Sony protocol handler initialized
[    0.786248] IR SANYO protocol handler initialized
[    0.788732] IR Sharp protocol handler initialized
[    0.791137] IR MCE Keyboard/mouse protocol handler initialized
[    0.793576] IR XMP protocol handler initialized
[    0.796676] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.799459] bcm2835-cpufreq: min=600000 max=1200000
[    0.802321] sdhci: Secure Digital Host Controller Interface driver
[    0.804874] sdhci: Copyright(c) Pierre Ossman
[    0.807723] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    0.810419] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.814479] ledtrig-cpu: registered to indicate activity on CPUs
[    0.817292] hidraw: raw HID events driver (C) Jiri Kosina
[    0.820078] usbcore: registered new interface driver usbhid
[    0.822730] usbhid: USB HID core driver
[    0.825906] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[    0.830028] [vc_sm_connected_init]: start
[    0.839683] [vc_sm_connected_init]: end - returning 0
[    0.842973] Initializing XFRM netlink socket
[    0.845658] NET: Registered protocol family 17
[    0.848376] Key type dns_resolver registered
[    0.851431] Registering SWP/SWPB emulation handler
[    0.854640] registered taskstats version 1
[    0.863033] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    0.865880] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    0.873443] sdhost: log_buf @ bad07000 (fad07000)
[    0.951425] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.955422] of_cfs_init
[    0.958476] of_cfs_init: OK
[    0.961673] Waiting 5 sec before mounting root device...
[    0.981569] Indeed it is in host mode hprt0 = 00021501
[    1.071919] random: fast init done
[    1.153022] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.159073] mmc0: new high speed SDHC card at address aaaa
[    1.162450] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    1.171355]  mmcblk0: p1 p2
[    1.191441] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.194435] Indeed it is in host mode hprt0 = 00001101
[    1.431650] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    1.434565] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.437972] hub 1-1:1.0: USB hub found
[    1.440925] hub 1-1:1.0: 5 ports detected
[    1.761425] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.891632] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    1.894604] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.900083] smsc95xx v1.0.6
[    1.994372] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b9:bc:51
[    2.731425] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    2.862801] usb 1-1.2: New USB device found, idVendor=0480, idProduct=a200
[    2.865871] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[    2.868930] usb 1-1.2: Product: External USB 3.0
[    2.871972] usb 1-1.2: Manufacturer: TOSHIBA
[    2.875032] usb 1-1.2: SerialNumber: 20170306001281F
[    2.878643] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[    2.882240] scsi host0: usb-storage 1-1.2:1.0
[    3.912230] scsi 0:0:0:0: Direct-Access     TOSHIBA  External USB 3.0 0    PQ: 0 ANSI: 6
[    5.491903] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    5.495558] sd 0:0:0:0: [sda] Write Protect is off
[    5.498726] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    5.499174] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.511702]  sda: sda1
[    5.516698] sd 0:0:0:0: [sda] Attached SCSI disk
[    6.037767] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[    6.040965] EXT4-fs (sda1): write access will be enabled during recovery
[    6.717880] EXT4-fs (sda1): recovery complete
[    6.752026] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    6.755345] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
[    6.786360] devtmpfs: mounted
[    6.792486] Freeing unused kernel memory: 1024K
[    8.024298] systemd[1]: System time before build time, advancing clock.
[    8.369614] NET: Registered protocol family 10
[    8.374112] Segment Routing with IPv6
[    8.435650] ip_tables: (C) 2000-2006 Netfilter Core Team
[    8.539915] random: systemd: uninitialized urandom read (16 bytes read)
[    8.595216] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    8.605658] systemd[1]: Detected architecture arm.
[    8.669923] systemd[1]: Set hostname to <raspberrypi>.
[    8.806629] random: systemd: uninitialized urandom read (16 bytes read)
[    8.849569] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[    9.662164] urandom_read: 3 callbacks suppressed
[    9.662172] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[   10.030214] random: crng init done
[   11.888153] systemd[1]: [/etc/systemd/system/deluged.service:22] Unknown lvalue 'RequiresMountsFor' in section 'Install'
[   11.895044] systemd[1]: [/etc/systemd/system/deluged.service:24] Unknown lvalue 'BindsTo' in section 'Install'
[   12.004111] systemd[1]: docker.socket: Cannot add dependency job, ignoring: Unit docker.socket is masked.
[   12.011487] systemd[1]: cups.socket: Cannot add dependency job, ignoring: Unit cups.socket is masked.
[   12.019249] systemd[1]: cups-browsed.service: Cannot add dependency job, ignoring: Unit cups-browsed.service is masked.
[   12.027329] systemd[1]: docker.service: Cannot add dependency job, ignoring: Unit docker.service is masked.
[   12.036079] systemd[1]: atd.service: Cannot add dependency job, ignoring: Unit atd.service is masked.
[   16.753410] EXT4-fs (sda1): re-mounted. Opts: (null)
[   16.905647] systemd-journald[99]: Received request to flush runtime journal from PID 1
[   18.535431] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   23.124751] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   23.196118] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
[   24.681146] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
skcasb
Re: sudo reboot
Wed Jul 11, 2018 3:32 pm
I had the same issue using the Raspbian Stretch Lite downloaded from https://downloads.raspberrypi.org/raspbian_lite_latest on my RPI 3B+ and a usb memory stick of 16GB.
Without installing other packages, the first command I gave after login was "sudo reboot" command but the RPI 3B+ won't reboot.
The only way to restart the raspberry was to turn off and on the power supply.
I solved the problem only after this command sequence:
apt-get update
apt-get upgrade
apt-get dist-upgrade
The kernel has been updated to the version 4.14.52-v7+ #1123
With this Kernel version I no longer noticed problems with the sudo reboot command
fred44nl
Re: sudo reboot
Wed Jul 11, 2018 5:37 pm
I did get kernel version 4.14.52-v7+ #1123 a few days ago and in order to get that kernel active, I tried to reboot, which did not go.
had to take the power off and on - not just once, but 3 times.
did not reboot again, as I was happy that it came back up and running.
so, now I did a reboot and it worked.
don't really understand, why it did not reboot moving to the present kernel.
and now it does.
sapnho
Re: sudo reboot
Mon Sep 10, 2018 12:40 pm
apt-get update
apt-get upgrade
Thanks so much, that worked for me, too.
www.TheDigitalPictureFrame.com - Build a really great digital picture frame with the Raspberry Pi.
With lots of great tips from this forum.
Please submit your digital picture frame project to the user gallery here: bit.ly/2WkyjW1
