DoTheEyeThing
Relay Issues
Sat Jun 09, 2018 8:46 pm
So I ordered a 24v relay
https://www.amazon.com/gp/product/B0789 ... SLEZQ&th=1
There are jumpers to switch between LOW and HIGH triggers. Currently they are HIGH as LOW turned all of the relays on and I wasn't able to turn them off.
I have 24v + and - from an A/C adapter into the relay, followed by 4 gpio pins from RBpi, and COM on the relay to RBpi ground.
My script sets GPIO's to Output.LOW initially (the relays are off) and then when I set them to HIGH they turn on.
Problem is they're acting weird.
1st relay - LED lit, 1-2 seconds later relay closes.
2nd relay - LED lit and instant close.
3rd relay - LED lit and instant close.
4th relay - LED lit, never closes.
I've seen posts saying external power should go through JD-VCC but this relay doesn't have that available. I feel like I must have this wired wrong but I'm too inexperienced to know. Do I need to wire this up with transistor/resistors?
#!/usr/bin/python
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
# init list with pin numbers
pinList = [18, 17, 27, 22]
# loop through pins and set mode and state to 'LOW'
for i in pinList:
    GPIO.setup(i, GPIO.OUT)
    GPIO.output(i, GPIO.LOW)
# time to sleep between operations in the main loop
SleepTimeL = 1
# main loop
try:
  GPIO.output(18, GPIO.HIGH)
  print("ONE")
  time.sleep(SleepTimeL);
  GPIO.output(17, GPIO.HIGH)
  print("TWO")
  GPIO.output(27, GPIO.HIGH)
  print("THREE")
  GPIO.output(22, GPIO.HIGH)
  print("FOUR")
  GPIO.cleanup()
  print("Good bye!")
# End program cleanly with keyboard
except KeyboardInterrupt:
  print("  Quit")
  # Reset GPIO settings
  GPIO.cleanup()
DoTheEyeThing
Re: Relay Issues
Sat Jun 09, 2018 11:13 pm
I resposted this on reddit and someone helped identify that I need at least 5v to trigger the relays, so I'm looking into ways of doing that. : )
Z80 Refugee
Re: Relay Issues
Sat Jun 09, 2018 11:21 pm
That's not what it says on the advertised product details. If you can find me a circuit diagram for the relay board I will be able to comment further.
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
klricks
Re: Relay Issues
Sat Jun 09, 2018 11:36 pm
Test each relay by connecting the IN of each relay to 3V3 GPIO pin 1.
If not working try each IN to 5V GPIO pin 2.
If that does not work the relay is bad.
pcmanbob
Re: Relay Issues
Sun Jun 10, 2018 10:57 am
probably easier to switch back to low level trigger and use a 2n2222 transistor and a 470Ω resistor like this
So now when you apply a high signal to the transistor base you will trigger the relay by connecting a ground to the CH / IN pin.
tlfong01
Re: Relay Issues
Wed Jun 13, 2018 12:27 pm
I also have a module with High/Low trigger selectable. I made guesses and drafted a schematic. I have proofread 90% of it. You might like to use it for reference. I think Rpi works only when High trigger is selected. Arduino should work in both High or Low trigger select.
relay high low select
I am an electronics and smart home hobbyist.
