I'm beginner with Rapsberry PI ZERO W, I try a simple thing : counting the number of steps when I turn the incremental encoder PEC11R-4220F-N0012 (datasheet: https://www.mouser.fr/datasheet/2/54/EC11R-777457.pdf)
My problem is : Whatever I may rotate or not the encoder, the PI count anyway.
I cannot figure out what isgoing wrong. I show you how I have wired :
This is the result I get on my terminal :
I give you the code of 'Paul Versteeg' that I use.
import RPi.GPIO as GPIO
from time import sleep
# Global constants & variables
# Constants
__author__ = 'Paul Versteeg'
counter = 10 # starting point for the running directional counter
# GPIO Ports
Enc_A = 23 # Encoder input A: input GPIO 23 (active high)
Enc_B = 24 # Encoder input B: input GPIO 24 (active high)
def init():
Initializes a number of settings and prepares the environment
before we start the main program.
print "Rotary Encoder Test Program"
GPIO.setwarnings(True)
# Use the Raspberry Pi BCM pins
GPIO.setmode(GPIO.BCM)
# define the Encoder switch inputs
GPIO.setup(Enc_A, GPIO.IN) # pull-ups are too weak, they introduce noise
GPIO.setup(Enc_B, GPIO.IN)
# setup an event detection thread for the A encoder switch
GPIO.add_event_detect(Enc_A, GPIO.RISING, callback=rotation_decode, bouncetime=2) # bouncetime in mSec
return
def rotation_decode(Enc_A):
This function decodes the direction of a rotary encoder and in- or
decrements a counter.
The code works from the "early detection" principle that when turning the
encoder clockwise, the A-switch gets activated before the B-switch.
When the encoder is rotated anti-clockwise, the B-switch gets activated
before the A-switch. The timing is depending on the mechanical design of
the switch, and the rotational speed of the knob.
This function gets activated when the A-switch goes high. The code then
looks at the level of the B-switch. If the B switch is (still) low, then
the direction must be clockwise. If the B input is (still) high, the
direction must be anti-clockwise.
All other conditions (both high, both low or A=0 and B=1) are filtered out.
To complete the click-cycle, after the direction has been determined, the
code waits for the full cycle (from indent to indent) to finish.
global counter
sleep(0.002) # extra 2 mSec de-bounce time
# read both of the switches
Switch_A = GPIO.input(Enc_A)
Switch_B = GPIO.input(Enc_B)
if (Switch_A == 1) and (Switch_B == 0) : # A then B ->
counter += 1
print "direction -> ", counter
# at this point, B may still need to go high, wait for it
while Switch_B == 0:
# now wait for B to drop to end the click cycle
while Switch_B == 1:
return
elif (Switch_A == 1) and (Switch_B == 1): # B then A <-
counter -= 1
print "direction <- ", counter
# A is already high, wait for A to drop to end the click cycle
while Switch_A == 1:
return
else: # discard all other combinations
return
def main():
The main routine.
try:
init()
while True :
# wait for an encoder click
sleep(1)
except KeyboardInterrupt: # Ctrl-C to terminate the program
GPIO.cleanup()
if __name__ == '__main__':
main()
