Shahriar Al Rabbi
"sudo ifup wlan0" shows "unknown interface wlan0"
Mon May 14, 2018 10:00 am
In the desktop, the internet connectivity logo, ethernet works fine but shows "no wireless device detected.
I installed the April 2018 raspbian stretch properly and still doesn't work.
If there is a solution, please let me know.
Or the product might have been damaged before it came to me.
"ifconfig" shows "eth0", "lo" as well as "wlan0" .
So, there might be a solution.
copperly
RE: "sudo ifup wlan0" shows "unknown interface wlan0"
Mon May 14, 2018 12:45 pm
I second that motion
mahjongg
Re: "sudo ifup wlan0" shows "unknown interface wlan0"
Mon May 14, 2018 12:52 pm
Split off from topic marked [SOLVED]
MrEngman
Mon May 14, 2018 1:39 pm
Try these
sudo ip link set wlan0 down
sudo ip link set wlan0 up
PeterO
Mon May 14, 2018 1:54 pm
Try running "ifconfig" to see
a) if the interfaces exist
b) What they are called.
PeterO
Cowpoke
Sun Jul 08, 2018 2:20 pm
Finally, are the ifup and ifdown commands obsolete?
SurferTim
Sun Jul 08, 2018 2:21 pm
Yes.
rohtua
Mon Jul 09, 2018 10:02 am
Hi, I had some similar problems a while ago on a fresh raspbian install I think what sorted it for me in the end was the Wi-Fi localisation options in raspi-config, when I looked I'd set the timezone options but now you get separate options for setting your Wi-Fi country. Might not do a lot but if I remember rightly it did help with the issues I was having at the time.
HermannSW
Fri Sep 07, 2018 2:56 pm
Try these
Thank you, that worked for me while ifup did not.
Pi ZeroW was connected to ESP-01s module access point. For some reason the connection dropped and "ip link show" showed wlan0 in DORMANT state. First I tried only your 2nd command, that did not help. But running both did work!
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw      https://github.com/Hermann-SW/userland
https://github.com/Hermann-SW/wireless-control-Eachine-E52-drone      https://twitter.com/HermannSW
