Xbox One S Controller bluetooth connection
Posted: Sat May 12, 2018 3:21 am
I've followed every guide I've found and I've hit an error I haven't seen anywhere.
In bluetoothctl, I enter the command:
and I get back:
And it puts me back where I started. If I try to connect using the bluetooth menu on the panel I get org.bluez.Error.Failed Input/Output Error
I have the controller firmware updated and the latest versions of xpad and xboxdvr installed. I'm running Raspbian on a Pi Zero W. The controller model is 1708.
Does anyone know what's going on?
connect ##:##:##:##:##:##Code: Select all
[CHG] Device ##:##:##:##:##:## Connected: yes
[CHG] Device ##:##:##:##:##:## ServicesResolved: yes
Failed to connect: org.bluez.Error.Failed
[CHG] Device ##:##:##:##:##:## ServicesResolved: no
[CHG] Device ##:##:##:##:##:## Connected: noI have the controller firmware updated and the latest versions of xpad and xboxdvr installed. I'm running Raspbian on a Pi Zero W. The controller model is 1708.
