gdw35
Adafruit_CharLCD fails due to get_platform_gpio error. Help!
Sun Apr 29, 2018 12:44 pm
Since updating my Pi to Raspbian Jessie my Adafruit RBG LCD panel has not worked. Everything is up to date but when trying to run the apps I developed and even the test applications they all fail.
The error is always the same:
File "/home/pi/Lib/Adafruit_CharLCD.py", line 95, in Adafruit_CharLCD
    gpio=GPIO.get_platform_gpio(),
 File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/GPIO.py", line 420, in get_platform_gpio
ImportError: No module named Adafruit_BBIO.GPIO
Doing a search for fixes I have been able to determine that the problem exists because get_platform_gpio is failing, or returning the wrong platform information, so it is trying to load the code for a Beagle Board, which I do not have.
Is someone able to offer some advice on how I can fix this? I tried digging into the Adafruit distribution to look at the code where it failed but it is stored in an egg and I do not know how to access to manipulate these.
Thanks in advance for any help.
B.Goode
Re: Adafruit_CharLCD fails due to get_platform_gpio error. Help!
Sun Apr 29, 2018 12:51 pm
You will certainly find previous discussions of the same issue in these forums.
I can't easily check the details just now, but I have a feeling that the Adafruit code you are using has been superceded by a later version that does not have the platform detection bug you are experiencing.
gdw35
Sun Apr 29, 2018 3:42 pm
Thanks for your reply.
Your mention that the Adafruit code had been updated made me think about it a bit more. I had only updated the Adafruit_CharLCD packages. I updated the Adafruit_GPIO package as well and the problem was resolved.
B.Goode
Sun Apr 29, 2018 3:55 pm
Thanks for the feedback and explanation. Congratulations on resolving your problem.
