rohanlele wrote: ↑Fri Apr 27, 2018 5:05 am
I am using latest raspbian image on my Pi B+. I have set a static IP for my Pi.
How (and why) did you do that?
In my experience setting a static IP is usually the cause of connection problems. I suggest you start over with an unmolested Raspbian install and use your serial console connection to find the DHCP assigned IP of your Pi.
This is the procedure I use for setting up headless boot with SSH and wireless network. It works with Raspbian Jessie or Stretch, Desktop or Lite, and with the built-in WiFi on the Pi3B(+) & Pi Zero W, or a Raspbian compatible USB WiFi dongle on other models. Everything is done before you boot, and can be done on a Windows or Mac computer which only has access to the small FAT32 "boot" partition of a Raspbian imaged SD card.
- Grab the latest Raspbian image from https://www.raspberrypi.org/downloads/raspbian/
- Grab the Etcher software from https://etcher.io/
- Install Etcher and use it to write the Raspbian image to your SD card.
- You don't need to extract the image or format the card prior to writing.
- Just run Etcher, choose the Raspbian .zip you downloaded, pick your SD card and write.
- If you have trouble, verify the SHA256 checksum of the download.
- Remove and reinsert the SD card so that your Windows or Mac PC can see the small FAT32 partition on the card (labelled "boot").
- If you get a message telling you the card must be formatted, cancel it.
- On that small FAT32 partition, create a file with the name ssh (or ssh.txt). It can be empty, the contents don't matter.
- To connect to a wireless network, create another file on the card called wpa_supplicant.conf, which has the following inside:
update_config=1
country=US
network={
ssid="Your network name/SSID"
psk="Your WPA/WPA2 security key"
key_mgmt=WPA-PSK
- Edit country=, ssid= and psk= with your information and save the file.
- Use the 2 letter country abbreviation in CAPS.
- Use a pure text editor, not a word processor, to edit the wpa_supplicant.conf file.
- Make sure that both files are in the main directory of the small FAT32 partition, not in any folder.
- Safely eject the card from your PC and use it to boot the Pi.
If Raspbian finds an ssh file it will enable SSH and delete the file. If it finds a wpa_supplicant.conf file, it will move it to its correct location and connect to your wireless network. Give your Pi some time to boot and connect to your network (the first boot always takes longer), then you should be able to SSH into the Pi and configure it how you like.
If you have a Zeroconf network service installed (Apple's iTunes, Bonjour or Quicktime install Zeroconf), you can SSH into pi@raspberrypi.local (provided you don't have any other Pi computers on your network with the same default hostname). Otherwise you must SSH into your Pi's IP address, which you can find by logging into your router and checking the list of connected clients, or using a network scanner app (like Fing for smartphones) to find your Pi on your network (or in your case you could use the serial console connection).
If you really want a fixed IP, the best way to do that is to reserve the IP address in your router's DHCP configuration. Since the IP is reserved by MAC address your Pi will always get the same IP with no OS configuration (and regardless of OS).
