ejolson
VM is only supported on ARMv7+ VFP [solved]
Thu Apr 26, 2018 7:15 am
I downloaded the most recent version of Raspbian 2018-04-18-raspbian-stretch-lite and then tried to installed Mathematica using
# apt-get install wolfram-engine
I received the error messages
Error occurred during initialization of VM
Server VM is only supported on ARMv7+ VFP
Which appear to be coming from attempts to configure ca-certificates-java, openjdk-9-jre and openjdk-9-jre-headless on a Pi Zero.
Are new versions of Raspbian and Mathematica compatible with ARMv6 machines?
What should I do to solve this problem?
bensimmo
Re: VM is only supported on ARMv7+ VFP
Thu Apr 26, 2018 9:37 am
It may be these three packages and nothing to do with the Zero.
These do not install when trying to install Octave on a Pi3 (well the -8- versions)
viewtopic.php?f=63&t=211166&p=1307164#p1307164
(and above post from there for background)
Of couse it might not be and just a coincidence :-)
ejolson
Sat Apr 28, 2018 3:04 am
I found another user reporting the same error. It appears that wolfram-engine automatically pulls in java dependencies and chooses Java 9 by default. Unfortunately, Java 9 is not compatible with ARMv6 so it doesn't work on Pi Zero, Zero W, 1B and 1B+ models. This type of failed install created a circular mess of held packages which I eventually sorted out. The better way is to install the dependencies manually beforehand as follows
# apt-get install openjdk-8-jre-headless openjdk-8-jre
# apt-get install libpcre16-3
Then everything works fine.
One more issue that I'll mention here is that Mathematica won't run unless you are a member of the video group. This is true by default for the pi user, but may not be the case for additional users you create. It appears Mathematica needs access to the video hardware to verify that it is licensed to run on the Pi hardware.
