Page 1 of 2
High CPU usage when booting from USB
Posted: Tue Apr 24, 2018 9:42 pm
by colonelpanic
Ever since I set my pi up to boot from a USB flash drive, the system has been pegging the cpu at right around 0.25 24/7.
To troubleshoot I performed:
echo workqueue:workqueue_queue_work > /sys/kernel/debug/tracing/set_event
cat /sys/kernel/debug/tracing/trace_pipe > out.txt
and see a stream of entries for:
kworker/1:2-65 [001] d... 296.694258: workqueue_queue_work: work struct=b9ff9878 function=set_brightness_delayed workqueue=b9c06300 req_cpu=4 cpu=1
Additionally, running:
watch -n1 -d cat /proc/interrupts
shows lots of constant interrupts for the line:
62: 186502 0 0 0 ARMCTRL-level 64 Edge dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
The kworker in the first column of the workqueue output is the same as the worker taxing the CPU, but I do not know how to troubleshoot further as I have found no other information on what the other fields mean. What brightness is being set?
How can I stop this?
Additional info:
I am running a fully patched (including firmware) Raspbian Lite 9.4 system.
I do not have a GUI installed.
I am using this as a Pi-Hole and OpenVPN host.
This issue does not happen when booting the same system from the SD card.
Re: High CPU usage when booting from USB
Posted: Wed Apr 25, 2018 1:34 am
by wh7qq
Using htop on my B+ pi-hole, it is running at less than 5% pretty constantly. It is headless but otherwise a stock Raspbian (full) distro. That would seem to point at the openVPN hosting application or something it runs.
Posted: Wed Apr 25, 2018 12:10 pm
by colonelpanic
The issue is resolved when I boot from the SD card instead. The filesystem on the USB is unchanged, but simply booting from SD instead of USB solves the problem. Something about booting from USB is triggering a lot of interrupt requests.
Posted: Wed Apr 25, 2018 1:26 pm
by jamesh
colonelpanic wrote: ↑Wed Apr 25, 2018 12:10 pm
When you boot from SD card do you still have the USB drive attached?
Posted: Wed Apr 25, 2018 6:20 pm
by fanoush
Not sure if it is the same thing but when booting from usb and having system being idle I saw kworker 2:0 and 2:2 eating about 8-10% CPU always one or the other, not both at once. Also I noticed green led blinking periodically. What stopped it was inserting microsd card! Then it stopped and both kworkers went down to 0% and green led blinking stopped. Below it can be seen both have quite high time consumed in total after 15 minutes system uptime.
1035 root 20 0 0 0 0 I 0.0 0.0 0:00.07 ├─ kworker/0:1
1034 root 20 0 0 0 0 I 0.0 0.0 0:16.85 ├─ kworker/2:0
739 root 10 -10 0 0 0 S 0.0 0.0 0:00.00 ├─ krfcommd
65 root -51 0 0 0 0 S 0.0 0.0 0:00.17 ├─ irq/92-mmc1
64 root 20 0 0 0 0 I 0.0 0.0 0:41.24 ├─ kworker/2:2
63 root 10 -10 0 0 0 S 0.0 0.0 0:00.00 ├─ SMIO
EDIT:
after inserting microsd it got mounted under /media/pi/boot,root automatically so after ejecting/unmounting via taskbar applet I tried to remove the card again and once the card was physically removed the green led blinking started again and one of kworker/2:x started eating cpu again. And this time it was kworker 2:1
2427 root 20 0 0 0 0 I 0.0 0.0 0:00.08 ├─ kworker/0:2
2426 root 20 0 0 0 0 R 11.2 0.0 0:02.91 ├─ kworker/2:1
2412 root 20 0 0 0 0 I 0.0 0.0 0:00.17 ├─ kworker/0:1
So it looks like it checks for card insertion periodically? or something tries to touch /dev/mmcblk0pX devices?
Posted: Thu May 03, 2018 2:28 am
by jerrm
I am seeing the same behavior.
Minimal Stretch-Lite install from latest image, no GUI, nothing extra installed.
USB Boot without SD card and a kworker thread stays at 8-10%.
USB Boot with blank SD card installed - no kworker utilization.
Posted: Mon May 14, 2018 7:32 pm
by jerrm
Has anyone else seen this CPU utilization behavior?
It seems surprising more haven't complained, but the utilization may be hidden in some "top" programs (htop at least) unless they are set to view kernel threads.
The Heisenberg principle sometimes applies to CPU monitoring, but the kworker utilization seems consistent and repeatable. The kworker thread does not give up it's CPU usage even when the system is maxed out under sysbench, memtester, or other similar.
Doesn't seem like we should need to buy an SD card just to get full performance if USB booting.
Posted: Wed May 16, 2018 2:05 pm
by odoy
same here. thx for the hint with the empty sd card.
Posted: Fri May 25, 2018 5:03 pm
by RichardS
I also got hit with this. It was a nightmare getting USB HD booting to work. I went through 3 SATA - USB adapters, and tried each with 2 different SATA Hard drives before I found ONE combination that would even boot - and now that it is booting, I also seem to be hit by exactly the same FLASHING GREEN LED issue, plus high cpu and sluggish performance reported by other above.
Is there a patch to fix this available upstream somewhere that I can apply, if not, is one even being worked on?
And, in the mean time, as a second related question, are there any settings I can apply to the config or command line configuration files that will improve USB boot compatibility (increased boot delay, etc) ???
Posted: Fri May 25, 2018 7:01 pm
by HawaiianPi
When USB booting I often leave a non-bootable SD card in the system, because it eliminates the 5 second delay, and as others have suggested, it also eliminates the kworker issue. When booting from SD card I used to keep a USB flash drive in the system for backing up configuration files, scripts and such, and now the SD card is used for that when booting from my USB SSD.
RichardS wrote: ↑Fri May 25, 2018 5:03 pm
If you want more boot delay (more wait time for USB drives to get ready), there is another OTP bit for that. Add "program_usb_boot_timeout=1" to config.txt on a Raspbian SD card and boot it once in the system. After that the system will wait up to 5 seconds for USB drives to become ready (default is 2 seconds).
The new 3B+ model has an improved bootloader with better device compatibility, but other than that there is not much that can be done. If your system can't boot from a particular device, there is no way the system can read configuration files from that device.
Posted: Fri May 25, 2018 7:33 pm
by RichardS
HawaiianPi wrote: ↑Fri May 25, 2018 7:01 pm
When USB booting I often leave an non-bootable SD card in the system for faster boot (eliminates the 5 second delay), and as others have suggested, it also eliminates the kworker issue. When booting from SD card I used to keep a USB flash drive in the system for backing up configuration files, scripts and such, and now the SD card is used for that when booting from my USB SSD.
Thanks for jumping in with that fast reply, I had noted that in the thread above, but was looking to completely eliminate the SD card and set up Raspbian to boot from one of those switch selectable read-only USB thumb drives, to create a totally bullet proof, just boot it up and it ALWAYS WORKS purpose built device that would not be subject to corruption issues.
If I add a blank SD card, and that card takes a power hit and becomes unreadable (not just Locked to read-only, but totally unreadable, returning an error, for the boot sector) would the Pi boot anyway, or just FREEZE?
I ask, because I have built such systems in the past based on SD cards, and every one of them had issues within a few months, despite using high quality known genuine SD cards. I have heard that Raspbian and the Pi have improved quite a bit in regard to SD reliability, and have personally found the high endurance SanDisk microSD cards to be fairly good - so I might end up doing something like you mentioned eventually, and using a microSD to create a writable "home" folder - but first I want to get the application working in a totally read-only environment without relying on an SD card.
Posted: Sat May 26, 2018 9:43 am
by LTolledo
did some testing on my own... USB device is 2.5" 1TB HDD in Orico enclosure USB3.0, microSD is class10 16GB formatted to maximum.
USB device boot, no microSD in slot, boots normally, green activity LED flashes regularly every 1.48 to 1.58 secs.
USB device boot, blank partition microSD in slot, boots normally, green activity LED no regular flashing
USB device boot, blank FAT32 formatted microSD in slot, boots normally, green activity LED flashes about once between 10 to 40 secs (and I get 1 extra FAT32 disk space in the microSD)
USB device boot, blank NTFS formatted microSD in slot, DID NOT BOOT.
USB device boot, blank EXT4 formatted microSD in slot, boots normally, green activity LED flashes erratically between 8 successive short pulses 1.2secs in between to about 0.5sec pulse 30secs in between (and I get 1 extra EXT4 disk space in the microSD).
these are my findings, you may get different results/reading on your test...
Posted: Sun May 27, 2018 12:59 am
by RichardS
LTolledo wrote: ↑Sat May 26, 2018 9:43 am
Thanks! That's really good info.
Just a few quick questions. Was that on a Raspberry Pi 3B or 3B+ ?
... and when you say 1 extra FAT or EXT4, do you mean that
the Pi is creating an additional phantom partition on the microSD that was not there originally?
If so, that seems very strange doesn't it? I wonder what kind of info do you suppose it's trying to log?
Posted: Sun May 27, 2018 5:48 am
by PeterO
RichardS wrote: ↑Sun May 27, 2018 12:59 am
It's not logging, it's polling the sd slot to see it you've inserted an sd card. If you USB boot you can hot plug sd-cards but I believe the PI doesn't use a "card inserted" physical switch so the kernel has to poll the slot by trying to read the card.
PeterO
Posted: Sun May 27, 2018 5:51 am
by LTolledo
Raspberry Pi 3 model B V1.2
RichardS wrote:
... and when you say 1 extra FAT or EXT4, do you mean that the Pi is creating an additional phantom partition on the microSD that was not there originally?
Oh maybe I got the wordings wrong.... I meant that the formatted partition in the microSD (FAT32, EXT4) can be accessed as an additional mounted volume.
Haven't tried removing/inserting the microSD with RPi still powered ON, but I think it may be possible....
Posted: Sun May 27, 2018 2:24 pm
by jerrm
PeterO wrote: ↑Sun May 27, 2018 5:48 am
But it is an insane amount of CPU usage for such a simple task. There may well be hardware deficiencies that requires such intense CPU usage, but that doesn't mean the current state of things is acceptable.
Ideally we would have tunables to disable the scan or increase the interval.
At minimum the USB boot documentation should make folks aware of the issue and the easiest work around (blank SD).
Posted: Mon May 28, 2018 3:45 pm
by PaultheElder
It appears to me that to boot Raspberry Pi from a USB device brings tremendous advantages regardless of any modest gain or loss in performance. For one, the opportunity for individuals within goups to effectively own their personalised operating environment / workspace and transfer it from, say home to education place (where they could use any of a suite of Pi's) on a USB stick, is obvious. Such use alone must place this issue well within the Foundation's worthy goals.
Please, this whole 'problem' could be resolved to everyone's benefit if those visionary folks at Pi Towers would reveal fully how they intend this feature can be utilized to best advantage, thereby solving the "mysteries of blank SD cards and flashing green LED's" which are a diversion from the real purpose of the Pi.
Posted: Mon May 28, 2018 7:22 pm
by jerrm
USB Boot is nearly two years old and is now enabled by default on the 3B+. I doubt there are any grand revelations coming. The advantages and uses are self evident.
A 10% hit to performance is more than modest. It essentially negates the the CPU improvement between the 3B and 3B+. It also has a small (about 1C no heatsink or fan) but measurable impact on idle CPU temp, probably indicating power consumption is also impacted.
It adds $5 to the cost if someone wants the advantages of USB boot without taking a performance hit.
It shouldn't take benchmarking or searching forums to know there is an issue.
None of this is world ending news, but not being documented is inexcusable.
Posted: Mon May 28, 2018 8:17 pm
by fanoush
Posted: Tue May 29, 2018 1:33 pm
by fanoush
looks like there is a fix coming, there will be a device tree overlay parameter to set in config.txt to detect the card only once at boot time and disable the polling
Posted: Tue May 29, 2018 8:36 pm
by fanoush
Looks like there are currently two ways to avoid the card polling and high kworker cpu usage. Using newer sdtweak.dtbo from github issue linked above and adding one line to /boot/config.txt
This marks the slot as non-removable which disables any polling for changes. Another way is unbinding microsd slot driver at runtime. This basically disables microsd slot completely. If you have card mounted then unmount it before trying this.
root@raspberrypi:~# echo -n "3f202000.mmc" >/sys/bus/platform/drivers/sdhost-bcm2835/unbind
One can rebind the driver again to reenable the slot and/or scan for card changes.
root@raspberrypi:~# echo -n "3f202000.mmc" >/sys/bus/platform/drivers/sdhost-bcm2835/bind
The 3f202000.mmc value is valid for Pi3B+, correct name of mmc interface may be different on different pi models (?) and can be see when lisiting /sys/bus/platform/drivers/sdhost-bcm2835 folder before unbinding.
root@raspberrypi:~# ls -l /sys/bus/platform/drivers/sdhost-bcm2835/
total 0
lrwxrwxrwx 1 root root 0 May 29 22:31 3f202000.mmc -> ../../../../devices/platform/soc/3f202000.mmc
Posted: Wed May 30, 2018 4:46 am
by jerrm
Below is a crude systemd unit to unbind the driver if no card is present at boot. No doubt a lot more checks should be built in for differing configurations, but it suffices for my needs - simple one file fix I can make part of my standard config (assuming no issues come up with further testing).
Tested ONLY on Pi3B and Pi3B+ !
# !! ** USE AT YOUR OWN RISK ** !!
# This is a crude systemd unit to disable the sd card slot if no
# sd card is installed at boot. Thanks to @fanoush.
# See https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=211912#p1321458
# Nothing is changed if the expected device name is not found.
# Nothing is changed if an sd card appears present in the slot.
# Paste this text into a file named /etc/systemd/system/disable-mmc-rescan
# execute "chmod 644 /etc/systemd/system/disable-mmc-rescan"
# Enable the service with "systemctl enable disable-mmc-rescan" and reboot.
# To re-enable the sd slot after boot - stop the service - "systemctl stop disable-mmc-rescan"
# Only basic testing has been done on Pi3B and Pi3B+
# under Raspbian Stretch-Lite and Jessie-Lite(Pi3B only) current as of 06/01/2018.
# No claims are made your system will remain stable or even boot.
[Unit]
Description=Disable MMC Rescan
DefaultDependencies=no
[Service]
Type=oneshot
ExecStart=/bin/bash -c " dpath=/sys/bus/platform/drivers/sdhost-bcm2835 ; \
dname=3f202000 ; \
dfull=$( /bin/ls -d $dpath/$dname.{mmc,sdhost} 2> /dev/null) ; \
[ a$dfull = a ] && { \
echo $dname 'device not present. no changes made.' ; \
exit 1 ; \
dlink=$( /usr/bin/basename $dfull ) ; \
[ ! -L $dpath/$dlink ] && { \
echo $dlink 'link not found. no changes made.'; exit 1 ; \
[ -b /dev/mmcblk0 ] && { \
echo 'sd card found - no changes made' ; \
exit 1; \
echo $dlink > /var/run/%n ; \
echo -n $dlink > $dpath/unbind ; \
echo 'no sd card found - driver binding removed - sd card rescan disabled.' ; \
RemainAfterExit=true
ExecStop=/bin/bash -c " dpath=/sys/bus/platform/drivers/sdhost-bcm2835 ; \
dname=3f202000 ; \
status=a$(/bin/systemctl is-system-running) ; \
[ $status = astopping ] && { \
echo 'System Shutting Down - Skipping driver reload' ; \
exit 0 ; \
dlink=$( /bin/cat /var/run/%n ) ; \
[[ ! a$dlink =~ a$dname.(mmc|sdhost) ]] && { \
echo 'valid device name not found. no changes made.' ; \
exit 1 ; \
echo -n $dlink > $dpath/bind ; \
echo 'sd card rescan enabled.' ; \
StandardOutput=journal
[Install]
WantedBy=sysinit.target
EDIT: Updated to work with Jessie.
Posted: Wed May 30, 2018 10:11 am
by fanoush
Nice. However having system set to 'stop' such service and initialize card at shutdown right before poweroff is not very optimal. Hopefuly the worst case is that the shutdown will be a tiny bit slower.
Posted: Wed May 30, 2018 10:19 am
by LTolledo
fanoush wrote: ↑Tue May 29, 2018 8:36 pm
If I deploy this, can the inserted microSD card be accessed as a mounted volume (if formatted)?
Posted: Wed May 30, 2018 11:31 am
by fanoush
LTolledo wrote: ↑Wed May 30, 2018 10:19 am
Yes, it will work with the poll_once option if card is already inserted at boot time. After boot it will detect no changes (card removal or insert) unless you unbind and bind the driver after the change.
And BTW you need to download updated sdtweak.dtbo from the link posted to github issue
https://drive.google.com/file/d/1JOwJpv ... sp=sharing and replace your older one in /boot/overlays/ otherwise new options will have no effect.
