Using Etcher to write an image file to MicroSD card
Posted: Mon Apr 23, 2018 9:06 pm
by theMusicMan
Hi All
So i have installed Etcher on my Mac, and have downloaded a copy of Parrot OS which I want to use on my Pi3B. I extracted the downloaded file and have the .img file, then used Etcher to prepare the file as a bootable file for the Pi.
When I insert the microSd card into the Pi and power up, I see the colour swash spash graphic, a yellow power symbol in the top right corner of the Pi, and the red LED on the Pi flashes - then nothing happens!
I was going to ask for advice but as I am writing this it has occurred to me that maybe I should have formatted the new unused microSD card as FAT32 format - which I didn't do. I had assumed the Etcher tool would have taken care of this. i will try it but as I am here writing this post I guess I could ask experts here if this is correct?
Re: Using Etcher to write an image file to MicroSD card
Posted: Mon Apr 23, 2018 9:33 pm
by FTrevorGowen
Hi All
In "reverse order" ---
1) Etcher does not need a uSDHC card to be formatted in order to write the *.img file
2) If by "a yellow power symbol" you mean the "lightning bolt" symbol - that's one "low-voltage" warning & the other is the red PoWeR led flashing, therefore you probably need a better 5V PSU (not a 'phone charger!) and/or a shorter (lower resistance) uUSB connecting lead.
3) Are you sure that the version of "Parrot OS" you're using is P3B compatible (and you have a P3B and not a P3B+)?
4) Whilst, AFAIK, this may be less-likely for a Mac, "built-in" card slots are not always fully SDHC compatible, depending upon the m/c's age and an external, USB-card writer may be better.
Trev.
Posted: Mon Apr 23, 2018 9:36 pm
by drgeoff
Also, Etcher is able to use the zip file. No need to extract the .img from it.
Posted: Mon Apr 23, 2018 10:06 pm
by davidcoton
Your symptoms point to running a non-compatible OS on a Pi3B+. As FTG says, check your Pi version. If Pi3B, it could be a power problem. More likely you have a Pi3B+, and will have to wait until Parrot OS is released in a compatible version.
Posted: Mon Apr 23, 2018 11:05 pm
by theMusicMan
Hi All
Thanks for the prompt replies.
I have an official Pi3B+ with official 2.5A supply (not using a USB phone charger type supply) - so that's not the issue as the Pi boots up fine with Kali-linux and also the Raspbian card supplied preinstalled. So I guess it is down to my attempting to run Parrot OS on the Pi3B+ when it has not been update so to do as yet.
Thanks for the info folks.
