andies
[SOLVED] wlan1 (5GHz) does not come up
Sun Apr 22, 2018 9:23 am
I am using RPi3 with
Linux FHEM 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux.
I want to connect my RPi with a 2.4 as well as the 5GHz band. I am using the internal Wifi to connect to 2.4 GHz and this works fine. For the 5GHz I am using a USB-Adapt DWA-172. Because I was not sure I compiled the driver as it is described in
https://layereight.de/raspberry-pi/2016 ... 812au.html
Everything went fine, still wlan1 does not show up.
The USB is recognized, because dmesg says
[    2.811446] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[    2.942544] usb 1-1.4: New USB device found, idVendor=2001, idProduct=3318
[    2.942564] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.942573] usb 1-1.4: Product: 11ac adapter
[    2.942582] usb 1-1.4: Manufacturer: D-Link Corporation
[    2.942590] usb 1-1.4: SerialNumber: 00e04c000001
The network configuration is
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wireless-power off
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
    wireless-power off
and the wifi passwort is working as well:
country=DE
update_config=1
network={
        ssid="WLAN-120954"
        scan_ssid=1
       psk="well_I_am_not_telling_here"
Does anyone has an idea what is wrong? Running iwconfig I get
wlan0     IEEE 802.11  ESSID:"WLAN-120954"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:87:33:51:00:35
          Bit Rate=54 Mb/s   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=45/70  Signal level=-65 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
lo        no wireless extensions.
eth0      no wireless extensions.
and no wlan1 shows up?! messages as well as kern.log do not say what is wrong.
raspberry B, Noir camera, Mac Book Air, iPhone, Bezzera
bensimmo
Re: wlan1 (5GHz) does not come up
Sun Apr 22, 2018 9:41 am
Did the 5G/.ac dongle not work out of the box?
No idea but it'll be the driver as it's not seeing it properly I would guess.
lsusb sees it ?
A quick look and FHEM is just a package install over Raspbian OS ?
andies
Sun Apr 22, 2018 9:46 am
Thanks for your help. It DID work out of the box but after I upgraded kernel and system it stoped working. lsusb shows it:
Bus 001 Device 006: ID 2001:3318 D-Link Corp.
FHEM is just a perl package that I installed over it, very straightforward.
(Or maybe simply the dongle is not working?)
bensimmo
Sun Apr 22, 2018 9:53 am
Ah this is MrEngman's (on here) knowledge...
viewtopic.php?t=62371
bensimmo
Re: [SOLVED] wlan1 (5GHz) does not come up
Sun Apr 22, 2018 4:07 pm
I see the title change, what fixed it. Just so others who search, find this and need a solution know.
andies
Mon Apr 23, 2018 8:03 am
MrEngman has on his webpage an sh-file that I ran. This file did everything, installing the driver as well as activating it.
Unfortunately, I just realized that it is only with 2.4GHz, not 5GHz. I am sure that this is not a software issue.
MrEngman
Mon Apr 23, 2018 9:23 am
Hi andies,
I am using the driver you are installing for your DWA-172 wifi, but I am using a Netgear A6100 wifi. I have it connected to a Pi 3B and it is using my 5GHz access point. The built in Broadcom wifi is connected at 2.4GHz. I also have another wifi, TP-Link TL-WN725N, connected to my Pi 3B running at 2.4GHz.
I also have a Edimax EW-7811UTC connected to a Pi 2B using the same driver running at 5GHz.
So shouldn't be a driver problem.
As you are running the latest kernel version, especially if you are using kernel Stretch, I'm wondering why you have edited file /etc/network/interfaces.
My /etc/network/interfaces file is
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
and file /etc/wpa_supplicant/wpa_supplicant.conf is
update_config=1
country=GB
network={
        ssid="AP-2.4GHz"
        psk="password"
        key_mgmt=WPA-PSK
network={
        ssid="AP-5GHz"
        psk="password"
        key_mgmt=WPA-PSK
andies
Mon Apr 23, 2018 10:20 am
Don't I have to declare the usual "auto lo // iface lo inet loopback..." under stretch? I just used my old interfaces-file from the former version.
MrEngman
Mon Apr 23, 2018 10:24 am
No
bensimmo
Mon Apr 23, 2018 10:26 am
It'll creates an entry when it see the WiFi adaptor.
It does on mine for the adaptors I use.
