haunty
No global IPv6
Wed Apr 18, 2018 6:19 pm
I just got a new ISP that only supports IPv6 and DSLite. Therefore I have to reconfigure my raspberry that works as an server for VPN, seafile etc. Before I changed my ISP, everything worked perfectly with IPv4 and Dyndns. I have googled a lot and tried to set up a global IP for my Pi But nothing helped so far. I use raspbian jessie. My pi is connected via ethernet to my router, fritzbox 6490.
Here is my output for ifconfig:
eth0 Link encap:Ethernet HWaddr 02:05:07:80:a1:2c
inet addr:192.168.178.21 Bcast:192.168.178.255 Mask:255.255.255.0
inet6 addr: fe80::5:7ff:fe80:a12c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:207 errors:0 dropped:0 overruns:0 frame:0
TX packets:220 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:26460 (25.8 KiB) TX bytes:43204 (42.1 KiB)
Interrupt:117 Base address:0xc000
/etc/dhcpcd.conf Output:
# Inform the DHCP server of our hostname for DDNS.
hostname
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
#slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface eth0
static ip_address=192.168.178.21
static routers=192.168.178.1
static domain_name_servers=192.168.178.1 8.8.8.8
/etc/network/interfaces output:
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet static
pre-up /etc/firewall-openvpn-rules.sh
address 192.168.178.21
netmask 255.255.255.0
network 192.168.178.0
broadcast 192.168.178.255
gateway 192.168.178.1
# IPv6
iface eth0 inet6 static
pre-up modprobe ipv6
address fe80::1
netmask 64
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
I also tried to connect with my laptop to my Pi in my LAN using the local IPv6. But it also does not work. I typed in my browser http://[fe80::5:7ff:fe80:a12c] but i get a connection timeout. With my IPv4 it works (website with nginx server).
Thanks for help :-)
Re: No global IPv6
Wed Apr 18, 2018 8:58 pm
Have you enabled DHCPv6 on your Fritz!box?
Do you have a globally unique IPv6 unicast prefix (in the 2000::/3 subnet)?
https://en.avm.de/service/fritzbox/frit ... FRITZ-Box/
I'll do your homework for you for a suitable fee.
haunty
Re: No global IPv6
Thu Apr 19, 2018 2:58 pm
Hello DougieLawson,
Please see my attached settings of my fritz.box. They are according to the fritz.box manual.
How can I check this?
Bildschirmfoto 2018-04-19 um 16.54.16.png (56.96 KiB) Viewed 3650 times
Bildschirmfoto 2018-04-19 um 16.54.06.png (73.25 KiB) Viewed 3650 times
Re: No global IPv6
Thu Apr 19, 2018 5:26 pm
an FD00::/8 ULA isn't the same as a globally unique 2000:/3 address. The FD00:: block is only available within your LAN. You still need DHCPv6 (or radvd) running so that each LAN station can see the addresses for every other station.
haunty
Re: No global IPv6
Thu Apr 19, 2018 6:22 pm
Ok. I have heard radvd before. How do I need to configure it?
/etc/radvd.conf ?
Re: No global IPv6
Thu Apr 19, 2018 6:32 pm
You're probably going to have to ask on your ISP's forum. My TP-LINK router/VDSL2 modem does the IPv6 stuff for free (simple switch) - all I had to do was disable the HE tunnel on my Raspberry.
I ran radvd on that HE tunnel with a very minimal config with just my global unicast /64 prefix defined in there.
interface eth0
        AdvSendAdvert on;
        AdvLinkMTU 1280;
        AdvOtherConfigFlag on;
        prefix 2001:pppp:pppp:pppp::1/64
                AdvOnLink on;
                AdvRouterAddr on;
        route ::/0
haunty
Re: No global IPv6
Thu Apr 19, 2018 6:41 pm
Hmm ok. Unfortunately I could not find any information at the ISP forum. Can I share any more information that would help for radvd config?
Re: No global IPv6
Thu Apr 19, 2018 8:27 pm
My problem is the complete lack of documentation for your Fritz!box. Even the German stuff lacks enough detail.
haunty
Re: No global IPv6
Fri Apr 20, 2018 6:08 pm
Ok understood.
But why is not possible to connect in LAN to my pi via IPv6 address?
manawyrm
Re: No global IPv6
Fri Apr 20, 2018 6:17 pm
Lot of stuff going on here, I'll try to explain as best as I can.
First off:
address fe80::1
netmask 64
This disables all the autoconfiguration mechanisms for the interface. You don't want that.
Set "iface eth0 inet6 auto".
http://[fe80::5:7ff:fe80:a12c] can't work. fe80::-addresses are what is called link-local addresses.
These only work when specified with an interface name e.g. fe80::1%eth0. The same address could exist on multiple interfaces.
Browsers don't support link-local addresses, so you can't connect to your nginx, even when suppling the interface name.
Your Fritz!Box configuration is correct. Please don't change anything there.
Your Raspberry Pi needs to do a thing called SLAAC to get an IPv6 address.
The line "pre-up /etc/firewall-openvpn-rules.sh" in your config leads me to believe that you might have turned ip_forwarding on. Is that correct?
If yes: The kernel disables SLAAC in this case.
You might want to look here for further info: https://blog.dhampir.no/content/using-i ... lt-gateway
Best wishes,
Tobias
haunty
Re: No global IPv6
Fri Apr 20, 2018 8:28 pm
Thank you very much for your explanations :-)
ip_forwarding
How can I check if it is on or off?
I have changed my interfaces settings:
and I added "accept_ra 2"
In addition I disabled pre-up /etc/firewall-openvpn-rules.sh
When i type in "ip -6 route"
I get following error:
unreachable fe80::/64 dev lo proto kernel metric 256 error -101
fe80::/64 dev eth0 proto kernel metric 256
and still no global ipv6 :-(
manawyrm
Re: No global IPv6
Fri Apr 20, 2018 8:31 pm
sysctl net.ipv6.conf.all.forwarding
will print 0 if it's disabled.
haunty
Re: No global IPv6
Sat Apr 21, 2018 7:23 am
It was set to 1. I disabled it.
But still no global IPv6.
manawyrm
Re: No global IPv6
Sat Apr 21, 2018 7:26 am
You set it to 0? Have you rebooted since?
EDIT: These settings need to be in /etc/sysctl.conf to be permanent. That's also the place where you need to enable the accept_ra.
haunty
Re: No global IPv6
Sat Apr 21, 2018 7:32 am
Yes, sure.
I also added "accept_ra 2". If I check
it returns 0
Do you not think it has something to do with
manawyrm
Re: No global IPv6
Sat Apr 21, 2018 7:37 am
It's a bit strange.
Could you post your:
/etc/sysctl.conf
output of the command "ip6tables -L"
output of the command "ip a"
here? (in a code tag)
haunty
Re: No global IPv6
Sat Apr 21, 2018 7:45 am
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
auto lo
#        pre-up /etc/firewall-openvpn-rules.sh
    pre-up echo 2 > /proc/sys/net/ipv6/conf/eth0/accept_ra
# IPv6
        accept_ra 2
allow-hotplug wlan0
allow-hotplug wlan1
/etc/sysctl.conf
# /etc/sysctl.conf - Configuration file for setting system variables
# See /etc/sysctl.d/ for additional system variables.
# See sysctl.conf (5) for information.
#kernel.domainname = example.com
# Uncomment the following to stop low-level messages on console
#kernel.printk = 3 4 1 3
##############################################################3
# Functions previously found in netbase
# Uncomment the next two lines to enable Spoof protection (reverse-path filter)
# Turn on Source Address Verification in all interfaces to
# prevent some spoofing attacks
#net.ipv4.conf.default.rp_filter=1
#net.ipv4.conf.all.rp_filter=1
# Uncomment the next line to enable TCP/IP SYN cookies
# See http://lwn.net/Articles/277146/
# Note: This may impact IPv6 TCP sessions too
#net.ipv4.tcp_syncookies=1
# Uncomment the next line to enable packet forwarding for IPv4
net.ipv4.ip_forward=1
# Uncomment the next line to enable packet forwarding for IPv6
#  Enabling this option disables Stateless Address Autoconfiguration
#  based on Router Advertisements for this host
#net.ipv6.conf.all.forwarding=1
accept_ra 2
Chain INPUT (policy DROP)
target     prot opt source               destination
ACCEPT     all      anywhere             anywhere             ctstate RELATED,ESTABLISHED
DROP       all      anywhere             anywhere             ctstate INVALID
ACCEPT     ipv6-icmp    anywhere             anywhere             ipv6-icmp echo-request ctstate NEW
UDP        udp      anywhere             anywhere             ctstate NEW
TCP        tcp      anywhere             anywhere             tcp flags:FIN,SYN,RST,ACK/SYN ctstate NEW
REJECT     udp      anywhere             anywhere             reject-with icmp6-adm-prohibited
REJECT     tcp      anywhere             anywhere             reject-with icmp6-port-unreachable
REJECT     all      anywhere             anywhere             reject-with icmp6-adm-prohibited
Chain FORWARD (policy DROP)
Chain OUTPUT (policy ACCEPT)
Chain TCP (1 references)
ACCEPT     tcp      anywhere             anywhere             tcp dpt:1193
ACCEPT     udp      anywhere             anywhere             udp dpt:openvpn
ACCEPT     tcp      anywhere             anywhere             tcp dpt:8001
ACCEPT     tcp      anywhere             anywhere             tcp dpt:8082
ACCEPT     tcp      anywhere             anywhere             tcp dpt:http
ACCEPT     tcp      anywhere             anywhere             tcp dpt:https
ACCEPT     tcp      anywhere             anywhere             tcp dpt:netbios-dgm
ACCEPT     tcp      anywhere             anywhere             tcp dpt:netbios-ssn
ACCEPT     tcp      anywhere             anywhere             tcp dpt:microsoft-ds
Chain UDP (1 references)
ACCEPT     udp      anywhere             anywhere             udp dpt:netbios-ns
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
       valid_lft forever preferred_lft forever
2: bond0: <NO-CARRIER,BROADCAST,MULTICAST,MASTER,UP> mtu 1500 qdisc noqueue state DOWN group default
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 02:05:07:80:a1:2c brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.21/24 brd 192.168.178.255 scope global eth0
    inet6 fe80::5:7ff:fe80:a12c/64 scope link
4: tunl0: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/ipip 0.0.0.0 brd 0.0.0.0
5: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 100
    link/none
    inet 10.8.0.1 peer 10.8.0.2/32 scope global tun0
manawyrm
Re: No global IPv6
Sat Apr 21, 2018 8:15 am
Ah! Yes, there's the problem.
You have IPv6-firewall rules configured. They are probably blocking the autoconfiguration.
I suppose you have installed a VPN server on the Pi a while back? Do you remember where it's scripts are? Especially something that calls the ip6tables?
haunty
Re: No global IPv6
Sat Apr 21, 2018 8:30 am
Yes, I use following script:
# delete all existing rules
iptables -F
iptables -X
ip6tables -F
ip6tables -X
# basic rules
iptables -N TCP
iptables -N UDP
ip6tables -N TCP
ip6tables -N UDP
iptables -P FORWARD DROP
iptables -P OUTPUT ACCEPT
iptables -P INPUT DROP
ip6tables -P FORWARD DROP
ip6tables -P OUTPUT ACCEPT
ip6tables -P INPUT DROP
# keep existing connections
iptables -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
ip6tables -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
# allow loopback traffic
iptables -A INPUT -i lo -j ACCEPT
ip6tables -A INPUT -i lo -j ACCEPT
# drop all traffic with "INVALID" state
iptables -A INPUT -m conntrack --ctstate INVALID -j DROP
ip6tables -A INPUT -m conntrack --ctstate INVALID -j DROP
# allow new incomming ping requests
iptables -A INPUT -p icmp --icmp-type 8 -m conntrack --ctstate NEW -j ACCEPT
ip6tables -A INPUT -p icmpv6 --icmpv6-type 128 -m conntrack --ctstate NEW -j ACCEPT
# open ports for http, https, ssh
#ssh
iptables -A TCP -p tcp --dport 1993 -j ACCEPT
#vpn
iptables -A UDP -p udp --dport 1194 -j ACCEPT
#seafile
iptables -A TCP -p tcp --dport 8001 -j ACCEPT
iptables -A TCP -p tcp --dport 8082 -j ACCEPT
#Samba
iptables -A UDP -p udp --dport 137 -j ACCEPT
iptables -A TCP -p tcp --dport 138 -j ACCEPT
iptables -A TCP -p tcp --dport 139 -j ACCEPT
iptables -A TCP -p tcp --dport 445 -j ACCEPT
iptables -A TCP -p tcp --dport 80 -j ACCEPT
iptables -A TCP -p tcp --dport 443 -j ACCEPT
ip6tables -A TCP -p tcp --dport 1193 -j ACCEPT
ip6tables -A TCP -p udp --dport 1194 -j ACCEPT
ip6tables -A TCP -p tcp --dport 8001 -j ACCEPT
ip6tables -A TCP -p tcp --dport 8082 -j ACCEPT
ip6tables -A TCP -p tcp --dport 80 -j ACCEPT
ip6tables -A TCP -p tcp --dport 443 -j ACCEPT
ip6tables -A UDP -p udp --dport 137 -j ACCEPT
ip6tables -A TCP -p tcp --dport 138 -j ACCEPT
ip6tables -A TCP -p tcp --dport 139 -j ACCEPT
ip6tables -A TCP -p tcp --dport 445 -j ACCEPT
# handle all new incomming connections for tcp and udp
iptables -A INPUT -p udp -m conntrack --ctstate NEW -j UDP
iptables -A INPUT -p tcp --syn -m conntrack --ctstate NEW -j TCP
ip6tables -A INPUT -p udp -m conntrack --ctstate NEW -j UDP
ip6tables -A INPUT -p tcp --syn -m conntrack --ctstate NEW -j TCP
# reject tcp and udp connections if the port is not open
iptables -A INPUT -p udp -j REJECT --reject-with icmp-port-unreachable
iptables -A INPUT -p tcp -j REJECT --reject-with tcp-rst
ip6tables -A INPUT -p udp -j REJECT --reject-with icmp6-adm-prohibited
ip6tables -A INPUT -p tcp -j REJECT
# reject all other connections
iptables -A INPUT -j REJECT --reject-with icmp-proto-unreachable
ip6tables -A INPUT -j REJECT --reject-with icmp6-adm-prohibited
# save the firewall rules
iptables-save > /etc/iptables/iptables.rules
ip6tables-save > /etc/iptables/ip6tables.rules
echo -------------------------
echo Job Finished
#read -n1 -r -p "Press any key to continue..." key
manawyrm
Re: No global IPv6
Sat Apr 21, 2018 8:36 am
Ah!
Make a copy of that script, remove all the ip6tables lines and reboot the Pi.
If it then works, we‘ll go from there ;)
haunty
Re: No global IPv6
Sat Apr 21, 2018 8:51 am
I removed all ip6 lines.
The problem is that I something messed up with iptables.
I executed the new script without IPv6
sudo sh /usr/local/bin/iptables.sh
But when I want to enable
sudo systemctl enable iptables ip6tables
Failed to execute operation: No such file or directory
systemctl status iptables ip6tables
● iptables.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
● ip6tables.service
sudo systemctl start iptables ip6tables
Failed to start iptables.service: Unit iptables.service failed to load: No such file or directory.
Failed to start ip6tables.service: Unit ip6tables.service failed to load: No such file or directory.
manawyrm
Re: No global IPv6
Sat Apr 21, 2018 8:57 am
iptables and ip6tables are not services, you don't need to start them via systemctl.
If your script ran and configured the ip6tables properly it should work.
Have you rebooted in between?
haunty
Re: No global IPv6
Sat Apr 21, 2018 9:01 am
I did it according to this manual
https://blog.doenselmann.com/firewall-f ... banana-pi/
Yes I restarted but still does not work. I get following output for
ip6tables -L
Chain INPUT (policy ACCEPT)
Chain FORWARD (policy ACCEPT)
manawyrm
Re: No global IPv6
Sat Apr 21, 2018 9:06 am
OK. I don't see a reason why your Pi needs a firewall configuration at all, but that's another story.
net.ipv6.conf.all.forwarding=0
net.ipv6.conf.all.accept_ra=2
net.ipv6.conf.all.eth0.accept_ra=2
net.ipv6.conf.all.default.accept_ra=2
Try putting this in your /etc/sysctl.conf. Reboot after that.
haunty
Re: No global IPv6
Sat Apr 21, 2018 9:59 am
It finally works :-) I have got an ipv6 global address :-) Thank you very much manawyrm for your help to clean up my code :-) You are a genius ;-)
In
/etc/dhcpcd.conf
I changed "slaac private" to "slaac hwaddr" and now it works.
I think it was a combination of iptables and slaac config. SSH and nginx webserver already checked and they work with my global ipv6 address. Only seafile with https is left.
