Massi
help debugging mysql python script that hangs
Tue Apr 10, 2018 7:10 am
i've a "curious" problem with my setup.
Raspberry pi (jessie)
python 3.5
a service that reads from mqtt topics and stores data on a mysql db
the db is in lan, on a qnap nas
Problem: it works, but after a "random" time, it simply hangs. it hangs while executing mysql commands. Linux says the service is active, but it's hung.
I can't find a way to debug this.
Any idea?
the code is really simple: it uses the "official" mysql module, in the connection config i have:
- raise on warning: true
- buffered: true
- a pool name
- pool size 16
- connection timeout 5
the code:
- mysql.connector.connect
- cursor
- cursor execute
- connection commit
- cursor close
-connection close
as i said, sometimes this works for some days flawlessly, other times this hangs after 15 minutes or so
Consider this is executing something like 10 insert queries every 5 minutes, so by far this is not a stressing condition.
Can this depend on the qnap nas itself?
help :(
