MineSweGamer
Can't connect to wifi but wifi country has been set properly (Pi 3 Model B+)
Thu Apr 05, 2018 3:47 pm
I have just set up the Pi but i still can't connect to any Wifi Networks. It just complains about setting the Wifi country which i've already done through the raspberry pi configuration gui and rebooted but it still complains about it not being set but when i go in there its already set to my country. Is there any workarounds? Is it the new wifi chip not having proper drivers?
Re: Can't connect to wifi but wifi country has been set properly (Pi 3 Model B+)
Thu Apr 05, 2018 3:56 pm
Are you sure you set the wireless country code? That dialog has two country options - make sure you get the right one.
Working in the Application's Team.
MineSweGamer
Thu Apr 05, 2018 4:15 pm
I've set Both the Locale and wifi Country.
Thu Apr 05, 2018 4:28 pm
Hmm. Not sure then. Worked fine for me when tested yesterday.
Is this a new install of Raspbian, and have you done
sudo apt update
sudo apt upgrade
Anything else you may have installed/done that may have made things go awry?
MineSweGamer
Thu Apr 05, 2018 4:59 pm
sudo apt update
sudo apt upgrade
I'll try to update. I haven't installed anything, i've just set it up with the raspberry pi configuration. Locale, Timezone, Keyboard and Wifi country are all set to Sweden in my case like normal.
MineSweGamer
Thu Apr 05, 2018 6:00 pm
sudo apt update
sudo apt upgrade
I apologize if this counts as Bumping.
I have upgraded but it didn't fix the problem. I've also found that if i set it to another country and then set it back, it works momentarily and then goes back to the problem again after rebooting. I sucessfully connected to my home Wifi on the 5GHz network and even though it still says that its not properly set up wifi still works now and it has internet connection, I've also unplugged the ethernet cable to verify and wifi is still connected and the icon now shows the signal strength but it still says "Set Wi-Fi Country on Localisation tab of Raspberry Pi Configuration to enable Wi-Fi"
When i go into "wpa_supplicant.conf" everything looks like this but i wont post my SSID and password publicly on the forums
update_config=1
country=SE
network={
	ssid="My Home SSID"
	psk="My Passkey In Plain Text"
	key_mgmt=WPA-PSK
I've also changed the Desktop wallpaper but that shouldn't cause this in the first place
Thu Apr 05, 2018 10:02 pm
If you set it to another country and leave it there, does it stay working? I wonder if its a specific issue with the swedish setting.
Try Austria or Belgium - both have the same bands as Sweden (note loads of other places do, they are just two random ones I picked)
MineSweGamer
Fri Apr 06, 2018 10:12 am
Unfortunately the issue is the same after setting it to another country. Wifi menu works like normal untill the pi reboots, after that it just asks about setting the wifi country again. It doesn't disconnect from the 5GHz Wifi network but stays connected and internet acess stilll works.
Fri Apr 06, 2018 11:01 am
Most odd. Have flagged it up to others who may have more of an idea.
chess1974lover
Fri Apr 06, 2018 11:17 am
Does the following suggestion get you further?
sudo rfkill unblock all
Your wifi might be blocked -- it was on my RPi 3B+ and unblocking it did the trick.
ShiftPlusOne
Fri Apr 06, 2018 11:42 am
What did your /etc/wpa_supplicant.conf look like?
TheHDR
Sat Apr 07, 2018 12:58 am
This fixed my issues with wifi on the 3B+, where wlan0 was not showing up in ifconfig, while wpa_supplicant was setup correctly, cheers.
MineSweGamer
Sat Apr 07, 2018 9:34 pm
Posted it above but ill post it again
update_config=1
country=SE
network={
	ssid="Linksys01341_5GHz"
	psk="*********"
	key_mgmt=WPA-PSK
SSID and psk are both correct and set to my home credentials
Starred out my password due to privacy concerns. But all details are correct. Could it be that update_config=1 be the cause that it asks to set it up after every reboot?
MineSweGamer
Sat Apr 07, 2018 9:41 pm
Tried the rfkill and it didn't help, not even after reboot. Also checked that rfkill list didn't show up anything odd and it just said
pi@raspberrypi:~ $ rfkill list
0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
ShiftPlusOne
Sat Apr 07, 2018 9:50 pm
config looks fine.
Could you please post the output of:
sudo systemctl status wifi-country
iw list
iw reg get
wpa_cli -i wlan0 scan; sleep 10
wpa_cli -i wlan0 scan_results
No need to post actual scan results if they come out, just wondering if it scans.
MineSweGamer
Sat Apr 07, 2018 10:35 pm
config looks fine.
iw list
iw reg get
pi@raspberrypi:~ $ sudo systemctl status wifi-country
● wifi-country.service - Disable WiFi if country not set
   Loaded: loaded (/lib/systemd/system/wifi-country.service; enabled; vendor preset: enabled)
   Active: inactive (dead) since Sun 2018-04-08 00:29:12 CEST; 22min ago
  Process: 297 ExecStart=/usr/lib/raspberrypi-sys-mods/wifi-country (code=exited, status=0/SUCCESS)
 Main PID: 297 (code=exited, status=0/SUCCESS)
apr 08 00:29:12 raspberrypi systemd[1]: Starting Disable WiFi if country not set...
apr 08 00:29:12 raspberrypi systemd[1]: Started Disable WiFi if country not set.
pi@raspberrypi:~ $ iw list
Wiphy phy0
        max # scan SSIDs: 10
        max scan IEs length: 2048 bytes
        max # sched scan SSIDs: 16
        max # match sets: 16
        max # scan plans: 1
        max scan plan interval: 508
        max scan plan iterations: 0
        Retry short limit: 7
        Retry long limit: 4
        Coverage class: 0 (up to 0m)
        Device supports T-DLS.
        Supported Ciphers:
                * WEP40 (00-0f-ac:1)
                * WEP104 (00-0f-ac:5)
                * TKIP (00-0f-ac:2)
                * CCMP-128 (00-0f-ac:4)
                * CMAC (00-0f-ac:6)
        Available Antennas: TX 0 RX 0
        Supported interface modes:
                 * IBSS
                 * managed
                 * AP
                 * P2P-client
                 * P2P-GO
                 * P2P-device
        Band 1:
                Capabilities: 0x1062
                        HT20/HT40
                        Static SM Power Save
                        RX HT20 SGI
                        RX HT40 SGI
                        No RX STBC
                        Max AMSDU length: 3839 bytes
                        DSSS/CCK HT40
                Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                Minimum RX AMPDU time spacing: 16 usec (0x07)
                HT TX/RX MCS rate indexes supported: 0-7
                Bitrates (non-HT):
                        * 1.0 Mbps
                        * 2.0 Mbps (short preamble supported)
                        * 5.5 Mbps (short preamble supported)
                        * 11.0 Mbps (short preamble supported)
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 2412 MHz [1] (20.0 dBm)
                        * 2417 MHz [2] (20.0 dBm)
                        * 2422 MHz [3] (20.0 dBm)
                        * 2427 MHz [4] (20.0 dBm)
                        * 2432 MHz [5] (20.0 dBm)
                        * 2437 MHz [6] (20.0 dBm)
                        * 2442 MHz [7] (20.0 dBm)
                        * 2447 MHz [8] (20.0 dBm)
                        * 2452 MHz [9] (20.0 dBm)
                        * 2457 MHz [10] (20.0 dBm)
                        * 2462 MHz [11] (20.0 dBm)
                        * 2467 MHz [12] (20.0 dBm)
                        * 2472 MHz [13] (20.0 dBm)
                        * 2484 MHz [14] (20.0 dBm)
        Band 2:
                        HT20/HT40
                        RX HT20 SGI
                        RX HT40 SGI
                        No RX STBC
                        DSSS/CCK HT40
                VHT Capabilities (0x00001020):
                        Max MPDU length: 3895
                        Supported Channel Width: neither 160 nor 80+80
                        short GI (80 MHz)
                        SU Beamformee
                VHT RX MCS set:
                        1 streams: MCS 0-9
                        2 streams: not supported
                        3 streams: not supported
                        4 streams: not supported
                        5 streams: not supported
                        6 streams: not supported
                        7 streams: not supported
                        8 streams: not supported
                VHT RX highest supported: 0 Mbps
                VHT TX MCS set:
                        1 streams: MCS 0-9
                VHT TX highest supported: 0 Mbps
                Bitrates (non-HT):
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 5170 MHz [34] (20.0 dBm)
                        * 5180 MHz [36] (20.0 dBm)
                        * 5190 MHz [38] (20.0 dBm)
                        * 5200 MHz [40] (20.0 dBm)
                        * 5210 MHz [42] (20.0 dBm)
                        * 5220 MHz [44] (20.0 dBm)
                        * 5230 MHz [46] (20.0 dBm)
                        * 5240 MHz [48] (20.0 dBm)
                        * 5260 MHz [52] (20.0 dBm)
                        * 5280 MHz [56] (20.0 dBm)
                        * 5300 MHz [60] (20.0 dBm)
                        * 5320 MHz [64] (20.0 dBm)
                        * 5500 MHz [100] (20.0 dBm)
                        * 5520 MHz [104] (20.0 dBm)
                        * 5540 MHz [108] (20.0 dBm)
                        * 5560 MHz [112] (20.0 dBm)
                        * 5580 MHz [116] (20.0 dBm)
                        * 5600 MHz [120] (20.0 dBm)
                        * 5620 MHz [124] (20.0 dBm)
                        * 5640 MHz [128] (20.0 dBm)
                        * 5660 MHz [132] (20.0 dBm)
                        * 5680 MHz [136] (20.0 dBm)
                        * 5700 MHz [140] (20.0 dBm)
                        * 5720 MHz [144] (20.0 dBm)
                        * 5745 MHz [149] (20.0 dBm)
                        * 5765 MHz [153] (20.0 dBm)
                        * 5785 MHz [157] (20.0 dBm)
                        * 5805 MHz [161] (20.0 dBm)
                        * 5825 MHz [165] (20.0 dBm)
        Supported commands:
                 * new_interface
                 * set_interface
                 * new_key
                 * start_ap
                 * join_ibss
                 * set_pmksa
                 * del_pmksa
                 * flush_pmksa
                 * remain_on_channel
                 * frame
                 * set_wiphy_netns
                 * set_channel
                 * tdls_oper
                 * start_sched_scan
                 * start_p2p_device
                 * connect
                 * disconnect
                 * crit_protocol_start
                 * crit_protocol_stop
                 * Unknown command (122)
        Supported TX frame types:
                 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
        Supported RX frame types:
                 * managed: 0x40 0xd0
                 * P2P-client: 0x40 0xd0
                 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * P2P-device: 0x40 0xd0
        software interface modes (can always be added):
        valid interface combinations:
                 * #{ managed } <= 1, #{ P2P-device } <= 1, #{ P2P-client, P2P-GO } <= 1,
                   total <= 3, #channels <= 2
                 * #{ managed } <= 1, #{ AP } <= 1, #{ P2P-client } <= 1, #{ P2P-device } <= 1,
                   total <= 4, #channels <= 1
        Device supports scan flush.
pi@raspberrypi:~ $ iw reg get
global
country 00: DFS-UNSET
        (2402 - 2472 @ 40), (N/A, 20), (N/A)
        (2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, NO-IR
        (2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, NO-IR
        (5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, NO-IR
        (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, NO-IR
        (5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, NO-IR
        (5735 - 5835 @ 80), (N/A, 20), (N/A), NO-IR
        (57240 - 63720 @ 2160), (N/A, 0), (N/A)
Running the last 2 commands come up with bssid/frequency/signal level/flags/ssid of the found networks and it found several networks and shows details about all the fopund ones.
ShiftPlusOne
Sun Apr 08, 2018 8:21 am
global
That looks like the key. For some reason in your case the country line in /etc/wpa_supplicant.conf is not applying.
As a temporary fix, this should work:
sudo iw reg set SE
Maybe the full log has some useful information:
sudo journalctl
MineSweGamer
Sun Apr 08, 2018 8:48 am
global
sudo iw reg set SE
sudo journalctl
The iw reg set SE does work as a hotfix and the Wifi panel can open normally but goes back to normal after rebooting again asking for wifi country again. Can i get the command to run on startup to make it run it automatically?
Logs came up with some red errors which seem to be from some broadcom device.
pi@raspberrypi:~ $ sudo journalctl
-- Logs begin at Thu 2016-11-03 18:16:42 CET, end at Sun 2018-04-08 10:40:27 CES
nov 03 18:16:42 raspberrypi kernel: Booting Linux on physical CPU 0x0
nov 03 18:16:42 raspberrypi kernel: Linux version 4.14.30-v7+ (dc4@dc4-XPS13-933
nov 03 18:16:42 raspberrypi kernel: CPU: ARMv7 Processor [410fd034] revision 4 (
nov 03 18:16:42 raspberrypi kernel: CPU: div instructions available: patching di
nov 03 18:16:42 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIP
nov 03 18:16:42 raspberrypi kernel: OF: fdt: Machine model: Raspberry Pi 3 Model
nov 03 18:16:42 raspberrypi kernel: Memory policy: Data cache writealloc
nov 03 18:16:42 raspberrypi kernel: cma: Reserved 8 MiB at 0x3ac00000
nov 03 18:16:42 raspberrypi kernel: On node 0 totalpages: 242688
nov 03 18:16:42 raspberrypi kernel: free_area_init_node: node 0, pgdat 80c7edc0,
nov 03 18:16:42 raspberrypi kernel:   Normal zone: 2133 pages used for memmap
nov 03 18:16:42 raspberrypi kernel:   Normal zone: 0 pages reserved
nov 03 18:16:42 raspberrypi kernel:   Normal zone: 242688 pages, LIFO batch:31
nov 03 18:16:42 raspberrypi kernel: random: fast init done
nov 03 18:16:42 raspberrypi kernel: percpu: Embedded 17 pages/cpu @ba34a000 s387
nov 03 18:16:42 raspberrypi kernel: pcpu-alloc: s38720 r8192 d22720 u69632 alloc
nov 03 18:16:42 raspberrypi kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
nov 03 18:16:42 raspberrypi kernel: Built 1 zonelists, mobility grouping on.  To
nov 03 18:16:42 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708
nov 03 18:16:42 raspberrypi kernel: PID hash table entries: 4096 (order: 2, 1638
nov 03 18:16:42 raspberrypi kernel: Dentry cache hash table entries: 131072 (ord
nov 03 18:16:42 raspberrypi kernel: Inode-cache hash table entries: 65536 (order
lines 1-23...skipping...
-- Logs begin at Thu 2016-11-03 18:16:42 CET, end at Sun 2018-04-08 10:40:27 CEST. --
nov 03 18:16:42 raspberrypi kernel: Linux version 4.14.30-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1102 SMP Mon Mar 26 16:45:49 BST 2018
nov 03 18:16:42 raspberrypi kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
nov 03 18:16:42 raspberrypi kernel: CPU: div instructions available: patching division code
nov 03 18:16:42 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
nov 03 18:16:42 raspberrypi kernel: OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
nov 03 18:16:42 raspberrypi kernel: free_area_init_node: node 0, pgdat 80c7edc0, node_mem_map ba3a1000
nov 03 18:16:42 raspberrypi kernel: percpu: Embedded 17 pages/cpu @ba34a000 s38720 r8192 d22720 u69632
nov 03 18:16:42 raspberrypi kernel: pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
nov 03 18:16:42 raspberrypi kernel: Built 1 zonelists, mobility grouping on.  Total pages: 240555
nov 03 18:16:42 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,11520
nov 03 18:16:42 raspberrypi kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
nov 03 18:16:42 raspberrypi kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
nov 03 18:16:42 raspberrypi kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
nov 03 18:16:42 raspberrypi kernel: Memory: 940260K/970752K available (7168K kernel code, 550K rwdata, 2048K rodata, 1024K init, 706K bss, 22300K reserved, 8192K cma-reserved)
nov 03 18:16:42 raspberrypi kernel: Virtual kernel memory layout:
                                        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                        vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                                        lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                                        modules : 0x7f000000 - 0x80000000   (  16 MB)
                                          .text : 0x80008000 - 0x80800000   (8160 kB)
                                          .init : 0x80b00000 - 0x80c00000   (1024 kB)
                                          .data : 0x80c00000 - 0x80c8986c   ( 551 kB)
                                           .bss : 0x80c90f40 - 0x80d417f4   ( 707 kB)
nov 03 18:16:42 raspberrypi kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
nov 03 18:16:42 raspberrypi kernel: ftrace: allocating 24918 entries in 74 pages
nov 03 18:16:42 raspberrypi kernel: Hierarchical RCU implementation.
nov 03 18:16:42 raspberrypi kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
nov 03 18:16:42 raspberrypi kernel: arch_timer: cp15 timer(s) running at 19.20MHz (phys).
nov 03 18:16:42 raspberrypi kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
nov 03 18:16:42 raspberrypi kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
nov 03 18:16:42 raspberrypi kernel: Switching to timer-based delay loop, resolution 52ns
nov 03 18:16:42 raspberrypi kernel: Console: colour dummy device 80x30
nov 03 18:16:42 raspberrypi kernel: console [tty1] enabled
nov 03 18:16:42 raspberrypi kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
nov 03 18:16:42 raspberrypi kernel: pid_max: default: 32768 minimum: 301
nov 03 18:16:42 raspberrypi kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
nov 03 18:16:42 raspberrypi kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
nov 03 18:16:42 raspberrypi kernel: Disabling memory control group subsystem
nov 03 18:16:42 raspberrypi kernel: CPU: Testing write buffer coherency: ok
nov 03 18:16:42 raspberrypi kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
nov 03 18:16:42 raspberrypi kernel: Setting up static identity map for 0x100000 - 0x10003c
nov 03 18:16:42 raspberrypi kernel: Hierarchical SRCU implementation.
nov 03 18:16:42 raspberrypi kernel: smp: Bringing up secondary CPUs ...
nov 03 18:16:42 raspberrypi kernel: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
nov 03 18:16:42 raspberrypi kernel: CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
nov 03 18:16:42 raspberrypi kernel: CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
nov 03 18:16:42 raspberrypi kernel: smp: Brought up 1 node, 4 CPUs
nov 03 18:16:42 raspberrypi kernel: SMP: Total of 4 processors activated (153.60 BogoMIPS).
nov 03 18:16:42 raspberrypi kernel: CPU: All CPU(s) started in HYP mode.
nov 03 18:16:42 raspberrypi kernel: CPU: Virtualization extensions available.
nov 03 18:16:42 raspberrypi kernel: devtmpfs: initialized
nov 03 18:16:42 raspberrypi kernel: VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
nov 03 18:16:42 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
nov 03 18:16:42 raspberrypi kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
nov 03 18:16:42 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
nov 03 18:16:42 raspberrypi kernel: NET: Registered protocol family 16
nov 03 18:16:42 raspberrypi kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
nov 03 18:16:42 raspberrypi kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
nov 03 18:16:42 raspberrypi kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
nov 03 18:16:42 raspberrypi kernel: Serial: AMBA PL011 UART driver
nov 03 18:16:42 raspberrypi kernel: bcm2835-mbox 3f00b880.mailbox: mailbox enabled
nov 03 18:16:42 raspberrypi kernel: uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
nov 03 18:16:42 raspberrypi kernel: bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
nov 03 18:16:42 raspberrypi kernel: SCSI subsystem initialized
nov 03 18:16:42 raspberrypi kernel: usbcore: registered new interface driver usbfs
nov 03 18:16:42 raspberrypi kernel: usbcore: registered new interface driver hub
nov 03 18:16:42 raspberrypi kernel: usbcore: registered new device driver usb
nov 03 18:16:42 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2018-03-23 16:31
nov 03 18:16:42 raspberrypi kernel: clocksource: Switched to clocksource arch_sys_counter
nov 03 18:16:42 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
nov 03 18:16:42 raspberrypi kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
nov 03 18:16:42 raspberrypi kernel: FS-Cache: Loaded
nov 03 18:16:42 raspberrypi kernel: CacheFiles: Loaded
nov 03 18:16:42 raspberrypi kernel: NET: Registered protocol family 2
nov 03 18:16:42 raspberrypi kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
nov 03 18:16:42 raspberrypi kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
nov 03 18:16:42 raspberrypi kernel: TCP: Hash tables configured (established 8192 bind 8192)
nov 03 18:16:42 raspberrypi kernel: UDP hash table entries: 512 (order: 2, 16384 bytes)
nov 03 18:16:42 raspberrypi kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
nov 03 18:16:42 raspberrypi kernel: RPC: Registered named UNIX socket transport module.
nov 03 18:16:42 raspberrypi kernel: RPC: Registered udp transport module.
nov 03 18:16:42 raspberrypi kernel: RPC: Registered tcp transport module.
nov 03 18:16:42 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
nov 03 18:16:42 raspberrypi kernel: hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
nov 03 18:16:42 raspberrypi kernel: workingset: timestamp_bits=14 max_order=18 bucket_order=4
nov 03 18:16:42 raspberrypi kernel: FS-Cache: Netfs 'nfs' registered for caching
nov 03 18:16:42 raspberrypi kernel: NFS: Registering the id_resolver key type
nov 03 18:16:42 raspberrypi kernel: Key type id_resolver registered
nov 03 18:16:42 raspberrypi kernel: Key type id_legacy registered
nov 03 18:16:42 raspberrypi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
nov 03 18:16:42 raspberrypi kernel: io scheduler noop registered
nov 03 18:16:42 raspberrypi kernel: io scheduler deadline registered (default)
nov 03 18:16:42 raspberrypi kernel: io scheduler cfq registered
nov 03 18:16:42 raspberrypi kernel: io scheduler mq-deadline registered
nov 03 18:16:42 raspberrypi kernel: io scheduler kyber registered
nov 03 18:16:42 raspberrypi kernel: BCM2708FB: allocated DMA memory fad00000
nov 03 18:16:42 raspberrypi kernel: BCM2708FB: allocated DMA channel 0 @ bb813000
nov 03 18:16:42 raspberrypi kernel: Console: switching to colour frame buffer device 240x67
nov 03 18:16:42 raspberrypi kernel: bcm2835-rng 3f104000.rng: hwrng registered
nov 03 18:16:42 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
nov 03 18:16:42 raspberrypi kernel: vc-sm: Videocore shared memory driver
nov 03 18:16:42 raspberrypi kernel: gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
nov 03 18:16:42 raspberrypi kernel: brd: module loaded
nov 03 18:16:42 raspberrypi kernel: loop: module loaded
nov 03 18:16:42 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
nov 03 18:16:42 raspberrypi kernel: libphy: Fixed MDIO Bus: probed
nov 03 18:16:42 raspberrypi kernel: usbcore: registered new interface driver lan78xx
nov 03 18:16:42 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
nov 03 18:16:42 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
nov 03 18:16:42 raspberrypi kernel: Core Release: 2.80a
nov 03 18:16:42 raspberrypi kernel: Setting default values for core params
nov 03 18:16:42 raspberrypi kernel: Finished setting default values for core params
nov 03 18:16:42 raspberrypi kernel: Using Buffer DMA mode
nov 03 18:16:42 raspberrypi kernel: Periodic Transfer Interrupt Enhancement - disabled
nov 03 18:16:42 raspberrypi kernel: Multiprocessor Interrupt Enhancement - disabled
nov 03 18:16:42 raspberrypi kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
nov 03 18:16:42 raspberrypi kernel: Dedicated Tx FIFOs mode
nov 03 18:16:42 raspberrypi kernel: WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
nov 03 18:16:42 raspberrypi kernel: FIQ FSM acceleration enabled for :
                                    Non-periodic Split Transactions
                                    Periodic Split Transactions
                                    High-Speed Isochronous Endpoints
                                    Interrupt/Control Split Transaction hack enabled
nov 03 18:16:42 raspberrypi kernel: dwc_otg: Microframe scheduler enabled
nov 03 18:16:42 raspberrypi kernel: WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805d2774
nov 03 18:16:42 raspberrypi kernel: WARN::hcd_init_fiq:460: FIQ ASM at 0x805d2adc length 36
nov 03 18:16:42 raspberrypi kernel: WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87e000
nov 03 18:16:42 raspberrypi kernel: dwc_otg 3f980000.usb: DWC OTG Controller
nov 03 18:16:42 raspberrypi kernel: dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
nov 03 18:16:42 raspberrypi kernel: dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
nov 03 18:16:42 raspberrypi kernel: Init: Port Power? op_state=1
nov 03 18:16:42 raspberrypi kernel: Init: Power Port (0)
nov 03 18:16:42 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
nov 03 18:16:42 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
nov 03 18:16:42 raspberrypi kernel: usb usb1: Product: DWC OTG Controller
nov 03 18:16:42 raspberrypi kernel: usb usb1: Manufacturer: Linux 4.14.30-v7+ dwc_otg_hcd
nov 03 18:16:42 raspberrypi kernel: usb usb1: SerialNumber: 3f980000.usb
nov 03 18:16:42 raspberrypi kernel: hub 1-0:1.0: USB hub found
nov 03 18:16:42 raspberrypi kernel: hub 1-0:1.0: 1 port detected
nov 03 18:16:42 raspberrypi kernel: dwc_otg: FIQ enabled
nov 03 18:16:42 raspberrypi kernel: dwc_otg: NAK holdoff enabled
nov 03 18:16:42 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
nov 03 18:16:42 raspberrypi kernel: Module dwc_common_port init
nov 03 18:16:42 raspberrypi kernel: usbcore: registered new interface driver usb-storage
nov 03 18:16:42 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
nov 03 18:16:42 raspberrypi kernel: IR NEC protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR RC5(x/sz) protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR RC6 protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR JVC protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR Sony protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR SANYO protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR Sharp protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR MCE Keyboard/mouse protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: IR XMP protocol handler initialized
nov 03 18:16:42 raspberrypi kernel: bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
nov 03 18:16:42 raspberrypi kernel: bcm2835-cpufreq: min=600000 max=1400000
nov 03 18:16:42 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
nov 03 18:16:42 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
nov 03 18:16:42 raspberrypi kernel: mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
nov 03 18:16:42 raspberrypi kernel: sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
nov 03 18:16:42 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
nov 03 18:16:42 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
nov 03 18:16:42 raspberrypi kernel: hidraw: raw HID events driver (C) Jiri Kosina
nov 03 18:16:42 raspberrypi kernel: usbcore: registered new interface driver usbhid
nov 03 18:16:42 raspberrypi kernel: usbhid: USB HID core driver
nov 03 18:16:42 raspberrypi kernel: vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
nov 03 18:16:42 raspberrypi kernel: [vc_sm_connected_init]: start
nov 03 18:16:42 raspberrypi kernel: [vc_sm_connected_init]: end - returning 0
nov 03 18:16:42 raspberrypi kernel: Initializing XFRM netlink socket
nov 03 18:16:42 raspberrypi kernel: NET: Registered protocol family 17
nov 03 18:16:42 raspberrypi kernel: Key type dns_resolver registered
nov 03 18:16:42 raspberrypi kernel: Registering SWP/SWPB emulation handler
nov 03 18:16:42 raspberrypi kernel: registered taskstats version 1
nov 03 18:16:42 raspberrypi kernel: uart-pl011 3f201000.serial: cts_event_workaround enabled
nov 03 18:16:42 raspberrypi kernel: 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
nov 03 18:16:42 raspberrypi kernel: mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
nov 03 18:16:42 raspberrypi kernel: mmc-bcm2835 3f300000.mmc: DMA channel allocated
nov 03 18:16:42 raspberrypi kernel: sdhost: log_buf @ bad13000 (fad13000)
nov 03 18:16:42 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
nov 03 18:16:42 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
nov 03 18:16:42 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
nov 03 18:16:42 raspberrypi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
nov 03 18:16:42 raspberrypi kernel: of_cfs_init
nov 03 18:16:42 raspberrypi kernel: of_cfs_init: OK
nov 03 18:16:42 raspberrypi kernel: Waiting for root device PARTUUID=f31e05f2-02...
nov 03 18:16:42 raspberrypi kernel: mmc1: new high speed SDIO card at address 0001
nov 03 18:16:42 raspberrypi kernel: Indeed it is in host mode hprt0 = 00021501
nov 03 18:16:42 raspberrypi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
nov 03 18:16:42 raspberrypi kernel: mmc0: new high speed SDXC card at address 0001
nov 03 18:16:42 raspberrypi kernel: mmcblk0: mmc0:0001 FC8HT 59.6 GiB
nov 03 18:16:42 raspberrypi kernel:  mmcblk0: p1 p2
nov 03 18:16:42 raspberrypi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
nov 03 18:16:42 raspberrypi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
nov 03 18:16:42 raspberrypi kernel: devtmpfs: mounted
nov 03 18:16:42 raspberrypi kernel: Freeing unused kernel memory: 1024K
nov 03 18:16:42 raspberrypi kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
nov 03 18:16:42 raspberrypi kernel: Indeed it is in host mode hprt0 = 00001101
nov 03 18:16:42 raspberrypi kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=2514
nov 03 18:16:42 raspberrypi kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
nov 03 18:16:42 raspberrypi kernel: hub 1-1:1.0: USB hub found
nov 03 18:16:42 raspberrypi kernel: hub 1-1:1.0: 4 ports detected
nov 03 18:16:42 raspberrypi systemd[1]: System time before build time, advancing clock.
nov 03 18:16:42 raspberrypi kernel: NET: Registered protocol family 10
nov 03 18:16:42 raspberrypi kernel: Segment Routing with IPv6
nov 03 18:16:42 raspberrypi kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
nov 03 18:16:42 raspberrypi systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
nov 03 18:16:42 raspberrypi systemd[1]: Detected architecture arm.
nov 03 18:16:42 raspberrypi systemd[1]: Set hostname to <raspberrypi>.
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1: new high-speed USB device number 3 using dwc_otg
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
nov 03 18:16:42 raspberrypi kernel: hub 1-1.1:1.0: USB hub found
nov 03 18:16:42 raspberrypi kernel: hub 1-1.1:1.0: 3 ports detected
nov 03 18:16:42 raspberrypi systemd[1]: Listening on Syslog Socket.
nov 03 18:16:42 raspberrypi systemd[1]: Started Forward Password Requests to Wall Directory Watch.
nov 03 18:16:42 raspberrypi systemd[1]: Listening on udev Kernel Socket.
nov 03 18:16:42 raspberrypi systemd[1]: Listening on udev Control Socket.
nov 03 18:16:42 raspberrypi systemd[1]: Listening on Journal Socket.
nov 03 18:16:42 raspberrypi systemd[1]: Created slice User and Session Slice.
nov 03 18:16:42 raspberrypi systemd[1]: Listening on fsck to fsckd communication Socket.
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1.2: new full-speed USB device number 4 using dwc_otg
nov 03 18:16:42 raspberrypi kernel: i2c /dev entries driver
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1.2: New USB device found, idVendor=046d, idProduct=c52b
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1.2: Product: USB Receiver
nov 03 18:16:42 raspberrypi kernel: usb 1-1.1.2: Manufacturer: Logitech
nov 03 18:16:42 raspberrypi systemd-journald[89]: Journal started
nov 03 18:16:42 raspberrypi systemd-journald[89]: Runtime journal (/run/log/journal/01b9bc89c90e4b94b6d90c184a62fd99) is 5.7M, max 46.3M, 40.5M free.
nov 03 18:16:42 raspberrypi systemd-modules-load[87]: Inserted module 'i2c_dev'
apr 08 10:36:58 raspberrypi fake-hwclock[92]: sön  8 apr 2018 08:36:58 UTC
apr 08 10:36:58 raspberrypi systemd[1]: Time has been changed
apr 08 10:36:58 raspberrypi systemd-fsck[90]: e2fsck 1.43.4 (31-Jan-2017)
apr 08 10:36:58 raspberrypi systemd[1]: Started Restore / save the current clock.
apr 08 10:36:58 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
apr 08 10:36:58 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
apr 08 10:36:58 raspberrypi systemd-fsck[90]: rootfs: rent, 138275/3861792 filer, 1338327/15618048 block
apr 08 10:36:58 raspberrypi systemd[1]: Started File System Check on Root Device.
apr 08 10:36:58 raspberrypi kernel: usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
apr 08 10:36:58 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
apr 08 10:36:58 raspberrypi systemd[1]: Started udev Kernel Device Manager.
apr 08 10:36:58 raspberrypi kernel: usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
apr 08 10:36:58 raspberrypi kernel: usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
apr 08 10:36:58 raspberrypi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
apr 08 10:36:58 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
apr 08 10:36:58 raspberrypi systemd[1]: Starting Load/Save Random Seed...
apr 08 10:36:58 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
apr 08 10:36:58 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
apr 08 10:36:58 raspberrypi systemd[1]: Started Set the console keyboard layout.
apr 08 10:36:58 raspberrypi mtp-probe[139]: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
apr 08 10:36:58 raspberrypi mtp-probe[139]: bus: 1, device: 5 was not an MTP device
apr 08 10:36:58 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
apr 08 10:36:58 raspberrypi mtp-probe[141]: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2"
apr 08 10:36:58 raspberrypi mtp-probe[141]: bus: 1, device: 4 was not an MTP device
apr 08 10:36:58 raspberrypi systemd[1]: Started Load/Save Random Seed.
apr 08 10:36:58 raspberrypi systemd-journald[89]: Runtime journal (/run/log/journal/01b9bc89c90e4b94b6d90c184a62fd99) is 11.5M, max 46.3M, 34.7M free.
apr 08 10:36:58 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
apr 08 10:36:58 raspberrypi kernel: logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.1.2/input2
apr 08 10:36:58 raspberrypi kernel: libphy: lan78xx-mdiobus: probed
apr 08 10:36:58 raspberrypi systemd[1]: Started udev Coldplug all Devices.
apr 08 10:36:58 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
apr 08 10:36:58 raspberrypi kernel: input: Logitech K400 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input0
apr 08 10:36:58 raspberrypi kernel: logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-3f980000.usb-1.1.2:1
apr 08 10:36:58 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
apr 08 10:36:58 raspberrypi systemd[1]: Reached target Encrypted Volumes.
apr 08 10:36:58 raspberrypi systemd[1]: Reached target Paths.
apr 08 10:36:58 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
apr 08 10:36:59 raspberrypi systemd[1]: Found device /dev/serial1.
apr 08 10:36:59 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/f31e05f2-01.
apr 08 10:36:59 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/f31e05f2-01...
apr 08 10:36:59 raspberrypi kernel: snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
apr 08 10:36:59 raspberrypi kernel: bcm2835_alsa bcm2835_alsa: card created with 8 channels
apr 08 10:36:59 raspberrypi kernel: brcmfmac: F1 signature read @0x18000000=0x15264345
apr 08 10:36:59 raspberrypi mtp-probe[203]: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
apr 08 10:36:59 raspberrypi mtp-probe[202]: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2"
apr 08 10:36:59 raspberrypi mtp-probe[202]: bus: 1, device: 4 was not an MTP device
apr 08 10:36:59 raspberrypi kernel: brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
apr 08 10:36:59 raspberrypi kernel: usbcore: registered new interface driver brcmfmac
apr 08 10:36:59 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
apr 08 10:36:59 raspberrypi mtp-probe[203]: bus: 1, device: 5 was not an MTP device
apr 08 10:36:59 raspberrypi systemd[1]: Reached target Sound Card.
apr 08 10:36:59 raspberrypi systemd-fsck[197]: fsck.fat 4.1 (2017-01-24)
apr 08 10:36:59 raspberrypi systemd-fsck[197]: /dev/mmcblk0p1: 162 files, 44045/84261 clusters
apr 08 10:36:59 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/f31e05f2-01.
apr 08 10:36:59 raspberrypi systemd[1]: Mounting /boot...
apr 08 10:36:59 raspberrypi systemd[1]: Mounted /boot.
apr 08 10:36:59 raspberrypi systemd[1]: Reached target Local File Systems.
apr 08 10:36:59 raspberrypi systemd[1]: Starting Raise network interfaces...
apr 08 10:36:59 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
apr 08 10:36:59 raspberrypi systemd[1]: Starting Set console font and keymap...
apr 08 10:36:59 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
apr 08 10:36:59 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
apr 08 10:36:59 raspberrypi systemd[1]: Started Preprocess NFS configuration.
apr 08 10:36:59 raspberrypi systemd[1]: Reached target NFS client services.
apr 08 10:36:59 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
apr 08 10:36:59 raspberrypi systemd[1]: Reached target Remote File Systems.
apr 08 10:36:59 raspberrypi systemd[1]: Started Set console font and keymap.
apr 08 10:36:59 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
apr 08 10:36:59 raspberrypi kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
apr 08 10:36:59 raspberrypi kernel: brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
apr 08 10:36:59 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
apr 08 10:36:59 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
apr 08 10:36:59 raspberrypi kernel: random: crng init done
apr 08 10:36:59 raspberrypi systemd-udevd[149]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
apr 08 10:36:59 raspberrypi systemd[1]: Starting Network Time Synchronization...
apr 08 10:36:59 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
apr 08 10:37:00 raspberrypi systemd-udevd[150]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
apr 08 10:37:00 raspberrypi systemd[1]: Started Network Time Synchronization.
apr 08 10:37:00 raspberrypi systemd[1]: Reached target System Initialization.
apr 08 10:37:00 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
apr 08 10:37:00 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
apr 08 10:37:00 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
apr 08 10:37:00 raspberrypi systemd[1]: Listening on triggerhappy.socket.
apr 08 10:37:00 raspberrypi systemd[1]: Reached target Sockets.
apr 08 10:37:00 raspberrypi systemd[1]: Reached target Basic System.
apr 08 10:37:00 raspberrypi systemd[1]: Started D-Bus System Message Bus.
apr 08 10:37:00 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
apr 08 10:37:00 raspberrypi systemd[1]: Starting Disable WiFi if country not set...
apr 08 10:37:00 raspberrypi systemd[1]: Starting Check for v3d driver...
apr 08 10:37:00 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
apr 08 10:37:00 raspberrypi systemd[1]: Starting System Logging Service...
apr 08 10:37:00 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
apr 08 10:37:00 raspberrypi systemd[1]: Starting Login Service...
apr 08 10:37:00 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
apr 08 10:37:00 raspberrypi systemd[1]: Started Regular background program processing daemon.
apr 08 10:37:00 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
apr 08 10:37:00 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
apr 08 10:37:00 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
apr 08 10:37:00 raspberrypi systemd[1]: Reached target System Time Synchronized.
apr 08 10:37:00 raspberrypi cron[307]: (CRON) INFO (pidfile fd = 3)
apr 08 10:37:00 raspberrypi systemd[1]: apt-daily.timer: Adding 11h 11min 54.072852s random time.
apr 08 10:37:00 raspberrypi systemd[1]: Started Daily apt download activities.
apr 08 10:37:00 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 45min 58.595256s random time.
apr 08 10:37:00 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
apr 08 10:37:00 raspberrypi systemd[1]: Reached target Timers.
apr 08 10:37:00 raspberrypi systemd[1]: Started Disable WiFi if country not set.
apr 08 10:37:00 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
apr 08 10:37:00 raspberrypi thd[311]: Found socket passed from systemd
apr 08 10:37:00 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
apr 08 10:37:00 raspberrypi cron[307]: (CRON) INFO (Running @reboot jobs)
apr 08 10:37:00 raspberrypi avahi-daemon[295]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
apr 08 10:37:00 raspberrypi avahi-daemon[295]: Successfully dropped root privileges.
apr 08 10:37:00 raspberrypi avahi-daemon[295]: avahi-daemon 0.6.32 starting up.
apr 08 10:37:00 raspberrypi dhcpcd[304]: dev: loaded udev
apr 08 10:37:00 raspberrypi avahi-daemon[295]: Successfully called chroot().
apr 08 10:37:00 raspberrypi avahi-daemon[295]: Successfully dropped remaining capabilities.
apr 08 10:37:00 raspberrypi liblogging-stdlog[299]:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="299" x-info="http://www.rsyslog.com"] start
apr 08 10:37:00 raspberrypi dhcpcd[304]: forked to background, child pid 339
apr 08 10:37:00 raspberrypi avahi-daemon[295]: No service file found in /etc/avahi/services.
apr 08 10:37:00 raspberrypi systemd[1]: Started System Logging Service.
apr 08 10:37:00 raspberrypi avahi-daemon[295]: Network interface enumeration completed.
apr 08 10:37:00 raspberrypi avahi-daemon[295]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 2334770342.
apr 08 10:37:00 raspberrypi systemd[1]: Started Check for v3d driver.
apr 08 10:37:00 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
apr 08 10:37:00 raspberrypi kernel: uart-pl011 3f201000.serial: no DMA platform data
apr 08 10:37:00 raspberrypi systemd-logind[301]: New seat seat0.
apr 08 10:37:00 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
apr 08 10:37:00 raspberrypi systemd[1]: Started Login Service.
apr 08 10:37:00 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
apr 08 10:37:00 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
apr 08 10:37:00 raspberrypi dhcpcd-run-hooks[361]: wlan0: starting wpa_supplicant
apr 08 10:37:00 raspberrypi kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
apr 08 10:37:00 raspberrypi kernel: brcmfmac: power management disabled
apr 08 10:37:01 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 169 (plymouthd).
apr 08 10:37:01 raspberrypi dhcpcd[339]: eth0: waiting for carrier
apr 08 10:37:01 raspberrypi dhcpcd[339]: wlan0: waiting for carrier
apr 08 10:37:01 raspberrypi dhcpcd[339]: wlan0: carrier acquired
apr 08 10:37:01 raspberrypi kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
apr 08 10:37:01 raspberrypi dhcpcd[339]: DUID 00:01:00:01:22:3b:18:6a:b8:27:eb:7a:d8:df
apr 08 10:37:01 raspberrypi dhcpcd[339]: wlan0: IAID eb:7a:d8:df
apr 08 10:37:01 raspberrypi dhcpcd[339]: wlan0: adding address fe80::4cd4:aa:c9be:cf5d
apr 08 10:37:01 raspberrypi dhcpcd[339]: wlan0: carrier lost
apr 08 10:37:01 raspberrypi dhcpcd[339]: wlan0: deleting address fe80::4cd4:aa:c9be:cf5d
apr 08 10:37:01 raspberrypi dhcpcd[339]: eth0: carrier acquired
apr 08 10:37:01 raspberrypi dhcpcd[339]: eth0: IAID eb:2f:8d:8a
apr 08 10:37:01 raspberrypi dhcpcd[339]: eth0: adding address fe80::3179:af96:9a90:b9de
apr 08 10:37:01 raspberrypi dhcpcd[339]: eth0: soliciting a DHCP lease
apr 08 10:37:01 raspberrypi dhcpcd[339]: eth0: carrier lost
apr 08 10:37:01 raspberrypi dhcpcd[339]: eth0: deleting address fe80::3179:af96:9a90:b9de
apr 08 10:37:02 raspberrypi dphys-swapfile[300]: Starting dphys-swapfile swapfile setup ...
apr 08 10:37:02 raspberrypi systemd[1]: Started Raise network interfaces.
apr 08 10:37:02 raspberrypi systemd[1]: Reached target Network.
apr 08 10:37:02 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
apr 08 10:37:02 raspberrypi systemd[1]: Starting Permit User Sessions...
apr 08 10:37:02 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
apr 08 10:37:02 raspberrypi systemd[1]: Started VNC Server in Service Mode daemon.
apr 08 10:37:02 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
apr 08 10:37:02 raspberrypi systemd[1]: Started Permit User Sessions.
apr 08 10:37:02 raspberrypi systemd[1]: Starting Light Display Manager...
apr 08 10:37:02 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
apr 08 10:37:02 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
apr 08 10:37:02 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 169 (plymouthd).
apr 08 10:37:02 raspberrypi dphys-swapfile[300]: want /var/swap=100MByte, checking existing: keeping it
apr 08 10:37:02 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
apr 08 10:37:02 raspberrypi systemd[1]: Started Hold until boot process finishes up.
apr 08 10:37:02 raspberrypi systemd[1]: Started Getty on tty1.
apr 08 10:37:02 raspberrypi systemd[1]: Reached target Login Prompts.
apr 08 10:37:02 raspberrypi kernel: Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
apr 08 10:37:02 raspberrypi dphys-swapfile[300]: done.
apr 08 10:37:02 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
apr 08 10:37:02 raspberrypi sshd[444]: Server listening on 0.0.0.0 port 22.
apr 08 10:37:02 raspberrypi sshd[444]: Server listening on :: port 22.
apr 08 10:37:02 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
apr 08 10:37:02 raspberrypi vncserver-x11[432]: ServerManager: Server started
apr 08 10:37:02 raspberrypi lightdm[426]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
apr 08 10:37:02 raspberrypi systemd[1]: Started Light Display Manager.
apr 08 10:37:03 raspberrypi vncserver-x11[432]: ConsoleDisplay: Cannot find a running X server on vt1
apr 08 10:37:03 raspberrypi raspi-config[298]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
apr 08 10:37:03 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
apr 08 10:37:03 raspberrypi vncserver-x11[432]: AgentInitCheck: agent comms failure
apr 08 10:37:03 raspberrypi vncserver-x11[432]: ConsoleDisplay: Found running X server (pid=446)
apr 08 10:37:03 raspberrypi dhcpcd[339]: wlan0: carrier acquired
apr 08 10:37:03 raspberrypi kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
apr 08 10:37:03 raspberrypi dhcpcd[339]: wlan0: IAID eb:7a:d8:df
apr 08 10:37:03 raspberrypi dhcpcd[339]: wlan0: adding address fe80::ed95:7e08:7006:283f
apr 08 10:37:03 raspberrypi systemd-udevd[462]: Process '/sbin/crda' failed with exit code 255.
apr 08 10:37:04 raspberrypi dhcpcd[339]: wlan0: rebinding lease of 192.168.1.133
apr 08 10:37:04 raspberrypi dhcpcd[339]: wlan0: probing address 192.168.1.133/24
apr 08 10:37:04 raspberrypi dhcpcd[339]: wlan0: soliciting an IPv6 router
apr 08 10:37:04 raspberrypi lightdm[476]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
apr 08 10:37:04 raspberrypi lightdm[476]: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
apr 08 10:37:05 raspberrypi systemd[1]: Created slice User Slice of pi.
apr 08 10:37:05 raspberrypi systemd[1]: Starting User Manager for UID 1000...
apr 08 10:37:05 raspberrypi systemd-logind[301]: New session c1 of user pi.
apr 08 10:37:05 raspberrypi systemd[1]: Started Session c1 of user pi.
apr 08 10:37:05 raspberrypi systemd[484]: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
apr 08 10:37:05 raspberrypi systemd[484]: Reached target Timers.
apr 08 10:37:05 raspberrypi systemd[484]: Listening on GnuPG cryptographic agent (access for web browsers).
apr 08 10:37:05 raspberrypi systemd[484]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
apr 08 10:37:05 raspberrypi systemd[484]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
apr 08 10:37:05 raspberrypi systemd[484]: Starting D-Bus User Message Bus Socket.
apr 08 10:37:05 raspberrypi systemd[484]: Listening on GnuPG cryptographic agent and passphrase cache.
apr 08 10:37:05 raspberrypi systemd[484]: Reached target Paths.
apr 08 10:37:05 raspberrypi systemd[484]: Listening on D-Bus User Message Bus Socket.
apr 08 10:37:05 raspberrypi systemd[484]: Reached target Sockets.
apr 08 10:37:05 raspberrypi systemd[484]: Reached target Basic System.
apr 08 10:37:05 raspberrypi systemd[484]: Reached target Default.
apr 08 10:37:05 raspberrypi systemd[484]: Startup finished in 74ms.
apr 08 10:37:05 raspberrypi systemd[1]: Started User Manager for UID 1000.
apr 08 10:37:05 raspberrypi lightdm[426]: Error opening audit socket: Protocol not supported
apr 08 10:37:05 raspberrypi systemd[484]: Started D-Bus User Message Bus.
apr 08 10:37:05 raspberrypi avahi-daemon[295]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::ed95:7e08:7006:283f.
apr 08 10:37:05 raspberrypi avahi-daemon[295]: New relevant interface wlan0.IPv6 for mDNS.
apr 08 10:37:05 raspberrypi avahi-daemon[295]: Registering new address record for fe80::ed95:7e08:7006:283f on wlan0.*.
apr 08 10:37:06 raspberrypi kernel: Bluetooth: Core ver 2.22
apr 08 10:37:06 raspberrypi kernel: NET: Registered protocol family 31
apr 08 10:37:06 raspberrypi kernel: Bluetooth: HCI device and connection manager initialized
apr 08 10:37:06 raspberrypi kernel: Bluetooth: HCI socket layer initialized
apr 08 10:37:06 raspberrypi kernel: Bluetooth: L2CAP socket layer initialized
apr 08 10:37:06 raspberrypi kernel: Bluetooth: SCO socket layer initialized
apr 08 10:37:06 raspberrypi btuart[310]: bcm43xx_init
apr 08 10:37:06 raspberrypi btuart[310]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
apr 08 10:37:06 raspberrypi btuart[310]: Set BDADDR UART: b8:27:eb:85:27:20
apr 08 10:37:06 raspberrypi btuart[310]: Set Controller UART speed to 3000000 bit/s
apr 08 10:37:06 raspberrypi btuart[310]: Device setup complete
apr 08 10:37:06 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
apr 08 10:37:06 raspberrypi kernel: Bluetooth: HCI UART driver ver 2.3
apr 08 10:37:06 raspberrypi kernel: Bluetooth: HCI UART protocol H4 registered
apr 08 10:37:06 raspberrypi kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
apr 08 10:37:06 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
apr 08 10:37:06 raspberrypi systemd[1]: Starting Bluetooth service...
apr 08 10:37:06 raspberrypi bluetoothd[563]: Bluetooth daemon 5.43
apr 08 10:37:06 raspberrypi dbus-daemon[501]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
apr 08 10:37:06 raspberrypi systemd[484]: Starting Virtual filesystem service...
apr 08 10:37:06 raspberrypi systemd[1]: Started Bluetooth service.
apr 08 10:37:06 raspberrypi systemd[1]: Started BluezALSA proxy.
apr 08 10:37:06 raspberrypi systemd[1]: Reached target Multi-User System.
apr 08 10:37:06 raspberrypi systemd[1]: Reached target Graphical Interface.
apr 08 10:37:06 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
apr 08 10:37:06 raspberrypi bluetoothd[563]: Starting SDP server
apr 08 10:37:06 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
apr 08 10:37:06 raspberrypi systemd[1]: Reached target Bluetooth.
apr 08 10:37:06 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
apr 08 10:37:06 raspberrypi systemd[1]: Startup finished in 1.435s (kernel) + 9.936s (userspace) = 11.372s.
apr 08 10:37:06 raspberrypi kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
apr 08 10:37:06 raspberrypi kernel: Bluetooth: BNEP filters: protocol multicast
apr 08 10:37:06 raspberrypi kernel: Bluetooth: BNEP socket layer initialized
apr 08 10:37:06 raspberrypi dbus[293]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
apr 08 10:37:06 raspberrypi bluetoothd[563]: Bluetooth management interface 1.14 initialized
apr 08 10:37:06 raspberrypi bluetoothd[563]: Failed to obtain handles for "Service Changed" characteristic
apr 08 10:37:07 raspberrypi bluetoothd[563]: Sap driver initialization failed.
apr 08 10:37:07 raspberrypi bluetoothd[563]: sap-server: Operation not permitted (1)
apr 08 10:37:07 raspberrypi bluetoothd[563]: Endpoint registered: sender=:1.9 path=/A2DP/SBC/Source/1
apr 08 10:37:07 raspberrypi systemd[1]: Starting Hostname Service...
apr 08 10:37:07 raspberrypi bluetoothd[563]: Endpoint registered: sender=:1.9 path=/A2DP/SBC/Sink/1
apr 08 10:37:07 raspberrypi kernel: Bluetooth: RFCOMM TTY layer initialized
apr 08 10:37:07 raspberrypi kernel: Bluetooth: RFCOMM socket layer initialized
apr 08 10:37:07 raspberrypi kernel: Bluetooth: RFCOMM ver 1.11
apr 08 10:37:07 raspberrypi dbus-daemon[501]: Successfully activated service 'org.gtk.vfs.Daemon'
apr 08 10:37:07 raspberrypi systemd[484]: Started Virtual filesystem service.
apr 08 10:37:07 raspberrypi login[435]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
apr 08 10:37:07 raspberrypi systemd-logind[301]: New session c2 of user pi.
apr 08 10:37:07 raspberrypi systemd[1]: Started Session c2 of user pi.
apr 08 10:37:07 raspberrypi dhcpcd[339]: wlan0: Router Advertisement from fe80::6238:e0ff:febd:96c8
apr 08 10:37:07 raspberrypi dhcpcd[339]: wlan0: adding address 2001:9b0:215:1d00:f298:a2e1:67d2:c870/64
apr 08 10:37:07 raspberrypi dhcpcd[339]: wlan0: adding route to 2001:9b0:215:1d00::/64
apr 08 10:37:07 raspberrypi dhcpcd[339]: wlan0: requesting DHCPv6 information
apr 08 10:37:07 raspberrypi kernel: fuse init (API version 7.26)
apr 08 10:37:07 raspberrypi systemd[1]: Mounting FUSE Control File System...
apr 08 10:37:07 raspberrypi systemd[1]: Mounted FUSE Control File System.
apr 08 10:37:07 raspberrypi dbus[293]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
apr 08 10:37:07 raspberrypi systemd[1]: Starting Authorization Manager...
apr 08 10:37:07 raspberrypi dbus[293]: [system] Successfully activated service 'org.freedesktop.hostname1'
apr 08 10:37:07 raspberrypi systemd[1]: Started Hostname Service.
apr 08 10:37:07 raspberrypi polkitd[687]: started daemon version 0.105 using authority implementation `local' version `0.105'
apr 08 10:37:07 raspberrypi dbus[293]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
apr 08 10:37:07 raspberrypi systemd[1]: Started Authorization Manager.
apr 08 10:37:07 raspberrypi polkitd(authority=local)[687]: Registered Authentication Agent for unix-session:c1 (system bus name :1.12 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale sv_SE.UTF-8)
apr 08 10:37:08 raspberrypi avahi-daemon[295]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::ed95:7e08:7006:283f.
apr 08 10:37:08 raspberrypi avahi-daemon[295]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2001:9b0:215:1d00:f298:a2e1:67d2:c870.
apr 08 10:37:08 raspberrypi avahi-daemon[295]: Registering new address record for 2001:9b0:215:1d00:f298:a2e1:67d2:c870 on wlan0.*.
apr 08 10:37:08 raspberrypi avahi-daemon[295]: Withdrawing address record for fe80::ed95:7e08:7006:283f on wlan0.
apr 08 10:37:08 raspberrypi dbus-daemon[501]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
apr 08 10:37:08 raspberrypi systemd[484]: Starting Virtual filesystem service - disk device monitor...
apr 08 10:37:08 raspberrypi dhcpcd[339]: wlan0: leased 192.168.1.133 for 86400 seconds
apr 08 10:37:08 raspberrypi avahi-daemon[295]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.133.
apr 08 10:37:08 raspberrypi avahi-daemon[295]: New relevant interface wlan0.IPv4 for mDNS.
apr 08 10:37:08 raspberrypi dhcpcd[339]: wlan0: adding route to 192.168.1.0/24
apr 08 10:37:08 raspberrypi avahi-daemon[295]: Registering new address record for 192.168.1.133 on wlan0.IPv4.
apr 08 10:37:08 raspberrypi dhcpcd[339]: wlan0: adding default route via 192.168.1.1
apr 08 10:37:09 raspberrypi dbus[293]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
apr 08 10:37:09 raspberrypi systemd[1]: Starting Disk Manager...
apr 08 10:37:09 raspberrypi udisksd[840]: udisks daemon version 2.1.8 starting
apr 08 10:37:09 raspberrypi dbus[293]: [system] Successfully activated service 'org.freedesktop.UDisks2'
apr 08 10:37:09 raspberrypi systemd[1]: Started Disk Manager.
apr 08 10:37:09 raspberrypi udisksd[840]: Acquired the name org.freedesktop.UDisks2 on the system message bus
apr 08 10:37:09 raspberrypi dbus-daemon[501]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
apr 08 10:37:09 raspberrypi systemd[484]: Started Virtual filesystem service - disk device monitor.
apr 08 10:37:09 raspberrypi dbus-daemon[501]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
apr 08 10:37:09 raspberrypi systemd[484]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
apr 08 10:37:09 raspberrypi dbus-daemon[501]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
apr 08 10:37:09 raspberrypi systemd[484]: Started Virtual filesystem service - GNOME Online Accounts monitor.
apr 08 10:37:09 raspberrypi dbus-daemon[501]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
apr 08 10:37:09 raspberrypi systemd[484]: Starting Virtual filesystem service - Apple File Conduit monitor...
apr 08 10:37:09 raspberrypi gvfs-afc-volume-monitor[857]: Volume monitor alive
apr 08 10:37:09 raspberrypi dbus-daemon[501]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
apr 08 10:37:09 raspberrypi systemd[484]: Started Virtual filesystem service - Apple File Conduit monitor.
apr 08 10:37:09 raspberrypi dbus-daemon[501]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
apr 08 10:37:09 raspberrypi systemd[484]: Starting Virtual filesystem service - digital camera monitor...
apr 08 10:37:10 raspberrypi dbus-daemon[501]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
apr 08 10:37:10 raspberrypi systemd[484]: Started Virtual filesystem service - digital camera monitor.
apr 08 10:37:10 raspberrypi dbus-daemon[501]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
apr 08 10:37:10 raspberrypi systemd[484]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
apr 08 10:37:10 raspberrypi dbus-daemon[501]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
apr 08 10:37:10 raspberrypi systemd[484]: Started Virtual filesystem service - Media Transfer Protocol monitor.
apr 08 10:37:17 raspberrypi kernel: logitech-hidpp-device 0003:046D:4024.0004: HID++ 2.0 device connected.
apr 08 10:37:37 raspberrypi systemd[484]: Time has been changed
apr 08 10:37:37 raspberrypi systemd[1]: Time has been changed
apr 08 10:37:37 raspberrypi systemd-timesyncd[250]: Synchronized to time server 194.71.144.71:123 (2.debian.pool.ntp.org).
apr 08 10:37:37 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 46min 34.700656s random time.
apr 08 10:37:37 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 24min 53.581745s random time.
apr 08 10:38:03 raspberrypi dhcpcd[339]: wlan0: deleting address 2001:9b0:215:1d00:f298:a2e1:67d2:c870/64
apr 08 10:38:03 raspberrypi avahi-daemon[295]: Withdrawing address record for 2001:9b0:215:1d00:f298:a2e1:67d2:c870 on wlan0.
apr 08 10:38:03 raspberrypi dhcpcd[339]: wlan0: deleting route to 2001:9b0:215:1d00::/64
apr 08 10:38:03 raspberrypi avahi-daemon[295]: Leaving mDNS multicast group on interface wlan0.IPv6 with address 2001:9b0:215:1d00:f298:a2e1:67d2:c870.
apr 08 10:38:03 raspberrypi avahi-daemon[295]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::ed95:7e08:7006:283f.
apr 08 10:38:03 raspberrypi avahi-daemon[295]: Registering new address record for fe80::ed95:7e08:7006:283f on wlan0.*.
apr 08 10:38:04 raspberrypi sshd[1053]: Accepted password for pi from 192.168.1.124 port 49822 ssh2
apr 08 10:38:04 raspberrypi sshd[1053]: pam_unix(sshd:session): session opened for user pi by (uid=0)
apr 08 10:38:04 raspberrypi systemd-logind[301]: New session c3 of user pi.
apr 08 10:38:04 raspberrypi systemd[1]: Started Session c3 of user pi.
apr 08 10:38:09 raspberrypi dhcpcd[339]: wlan0: Router Advertisement from fe80::6238:e0ff:febd:96c8
apr 08 10:38:09 raspberrypi dhcpcd[339]: wlan0: requesting DHCPv6 information
apr 08 10:38:11 raspberrypi dhcpcd[339]: wlan0: Router Advertisement from fe80::6238:e0ff:febd:96c8
apr 08 10:38:11 raspberrypi dhcpcd[339]: wlan0: adding address 2001:9b0:215:1d00:f298:a2e1:67d2:c870/64
apr 08 10:38:11 raspberrypi dhcpcd[339]: wlan0: adding route to 2001:9b0:215:1d00::/64
apr 08 10:38:11 raspberrypi dhcpcd[339]: wlan0: requesting DHCPv6 information
apr 08 10:38:13 raspberrypi avahi-daemon[295]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::ed95:7e08:7006:283f.
apr 08 10:38:13 raspberrypi avahi-daemon[295]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2001:9b0:215:1d00:f298:a2e1:67d2:c870.
apr 08 10:38:13 raspberrypi avahi-daemon[295]: Registering new address record for 2001:9b0:215:1d00:f298:a2e1:67d2:c870 on wlan0.*.
apr 08 10:38:13 raspberrypi avahi-daemon[295]: Withdrawing address record for fe80::ed95:7e08:7006:283f on wlan0.
apr 08 10:39:03 raspberrypi sudo[1362]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/sbin/iw reg set SE
apr 08 10:39:03 raspberrypi sudo[1362]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
apr 08 10:39:03 raspberrypi sudo[1362]: pam_unix(sudo:session): session closed for user root
apr 08 10:40:03 raspberrypi dhcpcd[339]: wlan0: deleting address 2001:9b0:215:1d00:f298:a2e1:67d2:c870/64
apr 08 10:40:03 raspberrypi dhcpcd[339]: wlan0: deleting route to 2001:9b0:215:1d00::/64
apr 08 10:40:03 raspberrypi avahi-daemon[295]: Withdrawing address record for 2001:9b0:215:1d00:f298:a2e1:67d2:c870 on wlan0.
apr 08 10:40:03 raspberrypi avahi-daemon[295]: Leaving mDNS multicast group on interface wlan0.IPv6 with address 2001:9b0:215:1d00:f298:a2e1:67d2:c870.
apr 08 10:40:04 raspberrypi avahi-daemon[295]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::ed95:7e08:7006:283f.
apr 08 10:40:04 raspberrypi avahi-daemon[295]: Registering new address record for fe80::ed95:7e08:7006:283f on wlan0.*.
apr 08 10:40:08 raspberrypi dhcpcd[339]: wlan0: Router Advertisement from fe80::6238:e0ff:febd:96c8
apr 08 10:40:08 raspberrypi dhcpcd[339]: wlan0: requesting DHCPv6 information
apr 08 10:40:10 raspberrypi dhcpcd[339]: wlan0: Router Advertisement from fe80::6238:e0ff:febd:96c8
apr 08 10:40:10 raspberrypi dhcpcd[339]: wlan0: adding address 2001:9b0:215:1d00:f298:a2e1:67d2:c870/64
apr 08 10:40:10 raspberrypi dhcpcd[339]: wlan0: adding route to 2001:9b0:215:1d00::/64
apr 08 10:40:10 raspberrypi dhcpcd[339]: wlan0: requesting DHCPv6 information
apr 08 10:40:12 raspberrypi avahi-daemon[295]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::ed95:7e08:7006:283f.
apr 08 10:40:12 raspberrypi avahi-daemon[295]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2001:9b0:215:1d00:f298:a2e1:67d2:c870.
apr 08 10:40:12 raspberrypi avahi-daemon[295]: Registering new address record for 2001:9b0:215:1d00:f298:a2e1:67d2:c870 on wlan0.*.
apr 08 10:40:12 raspberrypi avahi-daemon[295]: Withdrawing address record for fe80::ed95:7e08:7006:283f on wlan0.
apr 08 10:40:27 raspberrypi sudo[1589]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
apr 08 10:40:27 raspberrypi sudo[1589]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Lines Marked as an error (Red color)
ShiftPlusOne
Re: Can't connect to wifi but wifi country has been set properly (Pi 3 Model B+)
Sun Apr 08, 2018 8:53 am
This looks relevant:
I don't have any answers right now, but I'll look into it.
MineSweGamer
Sun Apr 08, 2018 11:25 am
Thank you, would appreciate a response back if you find anything.
N964
Tue Apr 10, 2018 12:44 am
I am having a similar problem here in Australia. I purchased the new Pi 3 B+ for my son's birthday and I have been unable to connect to the house wifi. Instead of the wifi symbol there are two parallel lines with red crosses through them, and it is asking me to set my country (which I have done, both through the command prompt and the menu (I can't remember the header, configuration or personalise?).
I have a very basic computer knowledge and I hope I'm not doing something silly but I have checked quite a few different sites for troubleshooting, tried unblocking, configured the wifi details and password and I am still not getting anywhere.
Any thoughts would be appreciated, or if you found a solution please let me know!
Kind Regards,
Nelly
ShiftPlusOne
Wed Apr 11, 2018 12:35 pm
Have you done anything in /etc/default/crda ? Does anything change if you put REGDOMAIN=SE in there and reboot?
MineSweGamer
Wed Apr 11, 2018 3:44 pm
I have added SE but it didn't fix the issue.
ShiftPlusOne
Wed Apr 11, 2018 3:54 pm
Its blank after opening the file, no country is listed how can i edit it as the normal text editor doesn't work. How can i change it?
sudo nano /etc/default/crda
Make the change
ctrl+x, y, enter
MineSweGamer
Wed Apr 11, 2018 4:02 pm
Make the change
ctrl+x, y, enter
Have done it now but it didn't fix the issue. The file now has SE in it, even after reboot though so it has saved the setting properly.
