I've moved from a 3b to a 3b+. That required a distribution upgrade (Jessie to Stretch), so I've changed a few variables at the same time.
Since moving I've had a two problems
1) z-way-server (Razberry) has fallen over (Thus far it's never done that on me) and needed restarting
2) The whole pi locked up with a kernel panic, and I had to power off and power on again (LEDS: Red and Green both locked on). Kernel panic was at wicd, which makes me think it's something pretty fundamental.
And the fact I've had two similarly unexplained problems is making me think hardware.
PSU is a good quality tablet PSU, I've got an "Official" psu on order.
Supplier is telling me the only "Supported" answer is to run from a virgin install and that a 3b+ isn't supported with an upgraded OS. Honestly feels like I'm being fobbed off, but happy to listen to the experience of others.
Mar 23 05:37:12 raspberrypi kernel: [208010.943170] Alignment trap: not handling instruction e1921f9f at [<8023f878>]
Mar 23 05:37:12 raspberrypi kernel: [208010.943177] Unhandled fault: alignment exception (0x001) at 0xbd75000e
Mar 23 05:37:12 raspberrypi kernel: [208010.943274] pgd = b2a38000
Mar 23 05:37:12 raspberrypi kernel: [208010.943310] [bd75000e] *pgd=3d61141e(bad)
Mar 23 05:37:12 raspberrypi kernel: [208010.943370] Internal error: : 1 [#1] SMP ARM
Mar 23 05:37:12 raspberrypi kernel: [208010.943423] Modules linked in: appletalk psnap llc ax25 bluetooth brcmfmac brcmutil cfg80211 snd_bcm2835 snd_pcm rfkill snd_timer snd bcm2835_gpiomem fixed uio_pdrv_genirq uio ip_tables x_tables ipv6
Mar 23 05:37:12 raspberrypi kernel: [208010.943714] CPU: 0 PID: 905 Comm: wicd Not tainted 4.9.80-v7+ #1098
Mar 23 05:37:12 raspberrypi kernel: [208010.943788] Hardware name: BCM2835
Mar 23 05:37:12 raspberrypi kernel: [208010.943830] task: b220ac40 task.stack: b21f0000
Mar 23 05:37:12 raspberrypi kernel: [208010.943890] PC is at do_wp_page+0x138/0x734
Mar 23 05:37:12 raspberrypi kernel: [208010.943942] LR is at do_wp_page+0x34/0x734
Mar 23 05:37:12 raspberrypi kernel: [208010.943994] pc : [<8023f87c>] lr : [<8023f778>] psr: 00000113
Mar 23 05:37:12 raspberrypi kernel: [208010.943994] sp : b21f1de8 ip : 0003d7f6 fp : b21f1e3c
Mar 23 05:37:12 raspberrypi kernel: [208010.944124] r10: 00000055 r9 : bc3fc738 r8 : bc3fc700
Mar 23 05:37:12 raspberrypi kernel: [208010.944186] r7 : b2298a50 r6 : 39bfd7df r5 : b21f1e5c r4 : bd75cf94
Mar 23 05:37:12 raspberrypi kernel: [208010.944262] r3 : bd74fffe r2 : bd75000e r1 : 76978000 r0 : bd75cf94
Mar 23 05:37:12 raspberrypi kernel: [208010.944339] Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Mar 23 05:37:12 raspberrypi kernel: [208010.944421] Control: 10c5383d Table: 32a3806a DAC: 00000055
Mar 23 05:37:12 raspberrypi kernel: [208010.944489] Process wicd (pid: 905, stack limit = 0xb21f0210)
Mar 23 05:37:12 raspberrypi kernel: [208010.944557] Stack: (0xb21f1de8 to 0xb21f2000)
Mar 23 05:37:12 raspberrypi kernel: [208010.944612] 1de0: 00000001 b21f1f00 00000000 00000001 b21f1e1c b21f1e08
Mar 23 05:37:12 raspberrypi kernel: [208010.944708] 1e00: 80280aa4 8025f87c b21f1e60 00000000 b21f1ecc b2298a50 39bfd7df 00000055
Mar 23 05:37:12 raspberrypi kernel: [208010.950372] 1e20: 00000040 bc3fc700 bc3fc738 00000055 b21f1ea4 b21f1e40 80242588 8023f750
Mar 23 05:37:12 raspberrypi kernel: [208010.956469] 1e40: 00000000 00000068 b21f1ea8 00000000 00000000 80463c18 b21f1e94 b2298a50
Mar 23 05:37:12 raspberrypi kernel: [208010.963143] 1e60: 76978000 00000055 b2a39da0 b22975e0 bd64bd58 00000000 b21f1ea4 b21f1fb0
Mar 23 05:37:12 raspberrypi kernel: [208010.970252] 1e80: b220ac40 0000080f 769782b0 bc3fc700 bc3fc738 00000055 b21f1efc b21f1ea8
Mar 23 05:37:12 raspberrypi kernel: [208010.977737] 1ea0: 80728030 80242068 0000000f 00000000 00000000 00002bc0 000041ed 00000005
Mar 23 05:37:12 raspberrypi kernel: [208010.985628] 1ec0: 00000000 00000000 00000800 00000008 00000000 80c0947c 0000080f 80727cf8
Mar 23 05:37:12 raspberrypi kernel: [208010.994126] 1ee0: 769782b0 b21f1fb0 002ca000 76bdca12 b21f1fac b21f1f00 801011e8 80727d04
Mar 23 05:37:12 raspberrypi kernel: [208011.003147] 1f00: 5ab165c5 1ad2747f 00002bc0 00000000 7ecf6550 7ecf6550 76f05ce8 7ecf6550
Mar 23 05:37:12 raspberrypi kernel: [208011.012611] 1f20: 000000c3 80108244 b21f0000 00000000 b21f1fa4 b21f1f40 802767e0 802762ac
Mar 23 05:37:12 raspberrypi kernel: [208011.022451] 1f40: 00002bc0 00000000 0000000f 000041ed 00000005 00000000 00000000 00000000
Mar 23 05:37:12 raspberrypi kernel: [208011.032629] 1f60: 00000000 00000000 5ab165d8 3b01ff5d 5ab165c5 1ad2747f 5ab165c5 1ad2747f
Mar 23 05:37:12 raspberrypi kernel: [208011.043227] 1f80: 00001000 000861f4 20000010 000861f4 20000010 ffffffff 10c5383d 10c5387d
Mar 23 05:37:12 raspberrypi kernel: [208011.053937] 1fa0: 00000000 b21f1fb0 80727864 801011ac 00000002 0033409c 00000001 000004f8
Mar 23 05:37:12 raspberrypi kernel: [208011.064625] 1fc0: 3c6811ea 00000000 76bdca10 762625c0 769782b0 002ca000 76bdca12 76262480
Mar 23 05:37:12 raspberrypi kernel: [208011.075298] 1fe0: 000566b4 7ecf5d78 00000001 000861f4 20000010 ffffffff 00000000 00000000
Mar 23 05:37:12 raspberrypi kernel: [208011.085993] [<8023f87c>] (do_wp_page) from [<80242588>] (handle_mm_fault+0x52c/0xd98)
Mar 23 05:37:12 raspberrypi kernel: [208011.096532] [<80242588>] (handle_mm_fault) from [<80728030>] (do_page_fault+0x338/0x3bc)
Mar 23 05:37:12 raspberrypi kernel: [208011.106806] [<80728030>] (do_page_fault) from [<801011e8>] (do_DataAbort+0x48/0xc4)
Mar 23 05:37:12 raspberrypi kernel: [208011.116792] [<801011e8>] (do_DataAbort) from [<80727864>] (__dabt_usr+0x44/0x60)
Mar 23 05:37:12 raspberrypi kernel: [208011.126461] Exception stack(0xb21f1fb0 to 0xb21f1ff8)
Mar 23 05:37:12 raspberrypi kernel: [208011.131153] 1fa0: 00000002 0033409c 00000001 000004f8
Mar 23 05:37:12 raspberrypi kernel: [208011.140298] 1fc0: 3c6811ea 00000000 76bdca10 762625c0 769782b0 002ca000 76bdca12 76262480
Mar 23 05:37:12 raspberrypi kernel: [208011.149385] 1fe0: 000566b4 7ecf5d78 00000001 000861f4 20000010 ffffffff
Mar 23 05:37:12 raspberrypi kernel: [208011.153954] Code: 01a03004 e2832010 f592f000 e1921f9f (e2811001)
Mar 23 05:37:12 raspberrypi kernel: [208011.160914] ---[ end trace fc68db74ccf5ec38 ]---
