horgh
Re: Raspberry Pi 3 B+ lockups
Fri Mar 30, 2018 4:22 pm
I updated to that new firmware yesterday as well.
On the plus side the Pi has not completely crashed. But I was running several applications inside a tmux session and I checked this morning and tmux was dead, including all the applications.
There is this message in the logs which is the only hint I can see:
Mar 30 04:18:08 rpi5 kernel: [52139.938037] Unhandled prefetch abort: unknown 1 (0x001) at 0x8dd0401a
drencor
Fri Mar 30, 2018 5:41 pm
PhilE wrote:
Wed Mar 28, 2018 8:19 pm
3B+ users may be able to eliminate some of the known problems by running "sudo rpi-update" (quiet, Dougie) to pick up a kernel with a patch that may prevent some of the crashes. They may also, depending on their network infrastructure, get improved networking stability at the cost of some power consumption by adding "dtparam=eee=off" to their config.txt.
Well even after running all the available updates today, rpi-update, and the config.txt option still getting the following dump:
rpi3bp_dump2.zip
(2.01 KiB) Downloaded 46 times
horgh
Sat Mar 31, 2018 2:56 pm
I had another crash.
[email protected]:~ $ cat /boot/.firmware_revision
2148253d340d7c646583cb8f0be6403511522cc4
I have some output from the kernel that went to my ssh session:
Message from [email protected] at Mar 30 22:49:01 ...
 kernel:[33987.226328] Internal error: : 1 [#1] SMP ARM
 kernel:[33987.269221] Process sshd (pid: 7877, stack limit = 0xb9c68210)
 kernel:[33987.271769] Stack: (0xb9c69cd0 to 0xb9c6a000)
 kernel:[33987.274317] 9cc0:                                     b9c69d04 b9c69ce0 803265ac 8079ef64
 kernel:[33987.279447] 9ce0: 00000000 b9c69dc0 ba442861 00000000 00000000 ba442860 b9c69d74 b9c69d08
 kernel:[33987.284516] 9d00: 80335f60 80326588 40000013 ffffffff b9c69d5c ba442860 b9c69e44 b9c69d28
 kernel:[33987.289597] 9d20: 8079f680 801eda18 80ffffec ba442861 00001000 00000000 10000022 b2000001
 kernel:[33987.294868] 9d40: 427e0000 00000ba4 ba442860 00000000 00001000 427e0000 00000ba4 ba442860
 kernel:[33987.300470] 9d60: 00001000 00000000 b9c69e44 b9c69d78 80355cf4 80335f14 80355868 80d162ac
 kernel:[33987.306363] 9d80: 00000001 00000000 00000000 00000000 78daaef1 ba442860 7f000000 00000000
 kernel:[33987.312502] 9da0: 00000000 00000001 00001000 ba442861 00000001 00000ba4 427e1000 00000ba4
 kernel:[33987.318979] 9dc0: 00000000 00000000 427e0000 00001000 00000000 00000000 00000000 b640e820
 kernel:[33987.325631] 9de0: b9c69e04 b9c69df0 8078b708 8078b644 b9c69e1c ba442864 b9c69e2c b9c69e08
 kernel:[33987.332468] 9e00: 8021d0d8 8078b6f8 00000000 00000000 00000000 00000000 b640e81c 00000000
 kernel:[33987.339453] 9e20: ba442860 ba442861 b9d94f00 b9c69ef0 b9c69f08 ba442860 b9c69e64 b9c69e48
 kernel:[33987.346512] 9e40: 80334270 80355914 80334204 00000000 ba442860 b640e81c b9c69ecc b9c69e68
 kernel:[33987.353571] 9e60: 8022036c 80334210 b97ad6e8 b9c69e78 8029a528 8029a178 00080001 00000000
 kernel:[33987.360629] 9e80: 00000001 ffffffff b9d94f68 00000fff b640e730 b9c68000 00000000 b9c69ea8
 kernel:[33987.367679] 9ea0: 8029afa0 b9d94f00 b9c69f80 00000000 00000000 00000200 00000000 00000000
 kernel:[33987.374733] 9ec0: b9c69edc b9c69ed0 80327bc4 8021fe9c b9c69f4c b9c69ee0 8028a6cc 80327b8c
 kernel:[33987.381303] 9ee0: 00000200 b9c69ee8 7ea75670 00000200 00000000 00000000 00000200 b9c69ee8
 kernel:[33987.384329] 9f00: 00000001 8079a468 b9d94f00 00000000 00000000 00000000 00000000 00000000
 kernel:[33987.387358] 9f20: 00000000 00000000 00000200 b9d94f00 7ea75670 b9c69f80 80108224 b9c68000
 kernel:[33987.390380] 9f40: b9c69f7c b9c69f50 8028a7b8 8028a5f8 00000000 802aadbc b9c69f7c b9d94f00
 kernel:[33987.393401] 9f60: b9d94f00 00000200 7ea75670 80108224 b9c69fa4 b9c69f80 8028ad68 8028a728
 kernel:[33987.396429] 9f80: 00000000 00000000 00012e57 00000008 76fd3960 00000003 00000000 b9c69fa8
 kernel:[33987.399457] 9fa0: 80108080 8028ad20 00012e57 00000008 00000003 7ea75670 00000200 00000000
 kernel:[33987.402486] 9fc0: 00012e57 00000008 76fd3960 00000003 00000003 7ea75670 76fd3b48 7ea75624
 kernel:[33987.405515] 9fe0: 76fd2cf0 7ea755cc 76fa92c0 76fbc4ec 00000010 00000003 00000000 00000000
 kernel:[33987.436081] Code: e52de004 e8bd4000 f590f000 e1903f9f (e2933001)
packet_write_wait: Connection to 192.168.1.10 port 22: Broken pipe
Some interesting logs in kern.log:
Mar 30 22:49:01 rpi5 kernel: [33987.220493] Alignment trap: not handling instruction e1903f9f at [<8079ef70>]
Mar 30 22:49:01 rpi5 kernel: [33987.220510] Unhandled fault: alignment exception (0x001) at 0xba4429ed
Mar 30 22:49:01 rpi5 kernel: [33987.222504] pgd = b9f7c000
Mar 30 22:49:01 rpi5 kernel: [33987.224400] [ba4429ed] *pgd=3a41141e(bad)
Mar 30 22:49:01 rpi5 kernel: [33987.226328] Internal error: : 1 [#1] SMP ARM
Mar 30 22:49:01 rpi5 kernel: [33987.228248] Modules linked in: ip6table_filter ip6_tables xt_tcpudp nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack iptable_filter sg brcmfmac brcmutil cfg80211 rfkill snd_bcm2835(C) snd_pcm snd_timer snd uio_pdrv_genirq uio fixed ip_tables x_tables ipv6
Mar 30 22:49:01 rpi5 kernel: [33987.237083] CPU: 1 PID: 7877 Comm: sshd Tainted: G         C      4.14.31-v7+ #1104
Mar 30 22:49:01 rpi5 kernel: [33987.241838] Hardware name: BCM2835
Mar 30 22:49:01 rpi5 kernel: [33987.244212] task: b72e8f00 task.stack: b9c68000
Mar 30 22:49:01 rpi5 kernel: [33987.246637] PC is at _raw_read_lock+0x1c/0x38
Mar 30 22:49:01 rpi5 kernel: [33987.249041] LR is at ext4_es_lookup_extent+0x30/0x244
Mar 30 22:49:01 rpi5 kernel: [33987.251491] pc : [<8079ef74>]    lr : [<803265ac>]    psr: 00000013
Mar 30 22:49:01 rpi5 kernel: [33987.254016] sp : b9c69cd0  ip : b9c69ce0  fp : b9c69cdc
Mar 30 22:49:01 rpi5 kernel: [33987.256529] r10: 00000000  r9 : 00001000  r8 : ba4429ed
Mar 30 22:49:01 rpi5 kernel: [33987.259030] r7 : 00000000  r6 : 427e0000  r5 : b9c69d28  r4 : ba442861
Mar 30 22:49:01 rpi5 kernel: [33987.261558] r3 : 00000000  r2 : b9c69d28  r1 : 427e0000  r0 : ba4429ed
Mar 30 22:49:01 rpi5 kernel: [33987.264064] Flags: nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Mar 30 22:49:01 rpi5 kernel: [33987.266663] Control: 10c5383d  Table: 39f7c06a  DAC: 00000055
Mar 30 22:49:01 rpi5 kernel: [33987.269221] Process sshd (pid: 7877, stack limit = 0xb9c68210)
Mar 30 22:49:01 rpi5 kernel: [33987.271769] Stack: (0xb9c69cd0 to 0xb9c6a000)
Mar 30 22:49:01 rpi5 kernel: [33987.274317] 9cc0:                                     b9c69d04 b9c69ce0 803265ac 8079ef64
Mar 30 22:49:01 rpi5 kernel: [33987.279447] 9ce0: 00000000 b9c69dc0 ba442861 00000000 00000000 ba442860 b9c69d74 b9c69d08
Mar 30 22:49:01 rpi5 kernel: [33987.284516] 9d00: 80335f60 80326588 40000013 ffffffff b9c69d5c ba442860 b9c69e44 b9c69d28
Mar 30 22:49:01 rpi5 kernel: [33987.289597] 9d20: 8079f680 801eda18 80ffffec ba442861 00001000 00000000 10000022 b2000001
Mar 30 22:49:01 rpi5 kernel: [33987.294868] 9d40: 427e0000 00000ba4 ba442860 00000000 00001000 427e0000 00000ba4 ba442860
Mar 30 22:49:01 rpi5 kernel: [33987.300470] 9d60: 00001000 00000000 b9c69e44 b9c69d78 80355cf4 80335f14 80355868 80d162ac
Mar 30 22:49:01 rpi5 kernel: [33987.306363] 9d80: 00000001 00000000 00000000 00000000 78daaef1 ba442860 7f000000 00000000
Mar 30 22:49:01 rpi5 kernel: [33987.312502] 9da0: 00000000 00000001 00001000 ba442861 00000001 00000ba4 427e1000 00000ba4
Mar 30 22:49:01 rpi5 kernel: [33987.318979] 9dc0: 00000000 00000000 427e0000 00001000 00000000 00000000 00000000 b640e820
Mar 30 22:49:01 rpi5 kernel: [33987.325631] 9de0: b9c69e04 b9c69df0 8078b708 8078b644 b9c69e1c ba442864 b9c69e2c b9c69e08
Mar 30 22:49:01 rpi5 kernel: [33987.332468] 9e00: 8021d0d8 8078b6f8 00000000 00000000 00000000 00000000 b640e81c 00000000
Mar 30 22:49:01 rpi5 kernel: [33987.339453] 9e20: ba442860 ba442861 b9d94f00 b9c69ef0 b9c69f08 ba442860 b9c69e64 b9c69e48
Mar 30 22:49:01 rpi5 kernel: [33987.346512] 9e40: 80334270 80355914 80334204 00000000 ba442860 b640e81c b9c69ecc b9c69e68
Mar 30 22:49:01 rpi5 kernel: [33987.353571] 9e60: 8022036c 80334210 b97ad6e8 b9c69e78 8029a528 8029a178 00080001 00000000
Mar 30 22:49:01 rpi5 kernel: [33987.360629] 9e80: 00000001 ffffffff b9d94f68 00000fff b640e730 b9c68000 00000000 b9c69ea8
Mar 30 22:49:01 rpi5 kernel: [33987.367679] 9ea0: 8029afa0 b9d94f00 b9c69f80 00000000 00000000 00000200 00000000 00000000
Mar 30 22:49:01 rpi5 kernel: [33987.374733] 9ec0: b9c69edc b9c69ed0 80327bc4 8021fe9c b9c69f4c b9c69ee0 8028a6cc 80327b8c
Mar 30 22:49:01 rpi5 kernel: [33987.381303] 9ee0: 00000200 b9c69ee8 7ea75670 00000200 00000000 00000000 00000200 b9c69ee8
Mar 30 22:49:01 rpi5 kernel: [33987.384329] 9f00: 00000001 8079a468 b9d94f00 00000000 00000000 00000000 00000000 00000000
Mar 30 22:49:01 rpi5 kernel: [33987.387358] 9f20: 00000000 00000000 00000200 b9d94f00 7ea75670 b9c69f80 80108224 b9c68000
Mar 30 22:49:01 rpi5 kernel: [33987.390380] 9f40: b9c69f7c b9c69f50 8028a7b8 8028a5f8 00000000 802aadbc b9c69f7c b9d94f00
Mar 30 22:49:01 rpi5 kernel: [33987.393401] 9f60: b9d94f00 00000200 7ea75670 80108224 b9c69fa4 b9c69f80 8028ad68 8028a728
Mar 30 22:49:01 rpi5 kernel: [33987.396429] 9f80: 00000000 00000000 00012e57 00000008 76fd3960 00000003 00000000 b9c69fa8
Mar 30 22:49:01 rpi5 kernel: [33987.399457] 9fa0: 80108080 8028ad20 00012e57 00000008 00000003 7ea75670 00000200 00000000
Mar 30 22:49:01 rpi5 kernel: [33987.402486] 9fc0: 00012e57 00000008 76fd3960 00000003 00000003 7ea75670 76fd3b48 7ea75624
Mar 30 22:49:01 rpi5 kernel: [33987.405515] 9fe0: 76fd2cf0 7ea755cc 76fa92c0 76fbc4ec 00000010 00000003 00000000 00000000
Mar 30 22:49:01 rpi5 kernel: [33987.408543] [<8079ef74>] (_raw_read_lock) from [<803265ac>] (ext4_es_lookup_extent+0x30/0x244)
Mar 30 22:49:01 rpi5 kernel: [33987.411583] [<803265ac>] (ext4_es_lookup_extent) from [<80335f60>] (ext4_map_blocks+0x58/0x610)
Mar 30 22:49:01 rpi5 kernel: [33987.414636] [<80335f60>] (ext4_map_blocks) from [<80355cf4>] (ext4_mpage_readpages+0x3ec/0x8b4)
Mar 30 22:49:01 rpi5 kernel: [33987.417692] [<80355cf4>] (ext4_mpage_readpages) from [<80334270>] (ext4_readpage+0x6c/0xe0)
Mar 30 22:49:01 rpi5 kernel: [33987.420753] [<80334270>] (ext4_readpage) from [<8022036c>] (generic_file_read_iter+0x4dc/0x9d0)
Mar 30 22:49:01 rpi5 kernel: [33987.423815] [<8022036c>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:49:01 rpi5 kernel: [33987.426892] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:49:01 rpi5 kernel: [33987.429967] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:49:01 rpi5 kernel: [33987.431544] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:49:01 rpi5 kernel: [33987.433105] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 22:49:01 rpi5 kernel: [33987.436081] Code: e52de004 e8bd4000 f590f000 e1903f9f (e2933001)
Mar 30 22:49:01 rpi5 kernel: [33987.437639] ---[ end trace 782b237550c7e2e4 ]---
Mar 30 22:53:22 rpi5 kernel: [34248.668444] INFO: rcu_sched self-detected stall on CPU
Mar 30 22:53:22 rpi5 kernel: [34248.669925] 	2-...: (2099 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=1050
Mar 30 22:53:22 rpi5 kernel: [34248.672768] 	 (t=2100 jiffies g=139900 c=139899 q=298)
Mar 30 22:53:22 rpi5 kernel: [34248.674183] NMI backtrace for cpu 2
Mar 30 22:53:22 rpi5 kernel: [34248.675550] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 22:53:22 rpi5 kernel: [34248.678225] Hardware name: BCM2835
Mar 30 22:53:22 rpi5 kernel: [34248.679529] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 22:53:22 rpi5 kernel: [34248.682099] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 22:53:22 rpi5 kernel: [34248.683427] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 22:53:22 rpi5 kernel: [34248.685921] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 22:53:22 rpi5 kernel: [34248.688438] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 22:53:22 rpi5 kernel: [34248.691044] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 22:53:22 rpi5 kernel: [34248.693689] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 22:53:22 rpi5 kernel: [34248.696406] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 22:53:22 rpi5 kernel: [34248.699166] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 22:53:22 rpi5 kernel: [34248.701989] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 22:53:22 rpi5 kernel: [34248.704893] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 22:53:22 rpi5 kernel: [34248.707910] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 22:53:22 rpi5 kernel: [34248.710935] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 22:53:22 rpi5 kernel: [34248.714032] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 22:53:22 rpi5 kernel: [34248.717133] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 22:53:22 rpi5 kernel: [34248.720217] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 22:53:22 rpi5 kernel: [34248.723307] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 22:53:22 rpi5 kernel: [34248.726410] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 22:53:22 rpi5 kernel: [34248.729502] Exception stack(0xb9eddd80 to 0xb9edddc8)
Mar 30 22:53:22 rpi5 kernel: [34248.731036] dd80: b97c9a60 00000000 00000000 b9edddf4 ba443c81 00000040 ba443c81 ba443c94
Mar 30 22:53:22 rpi5 kernel: [34248.734050] dda0: 80c045e8 00000000 80c8826c b9edddec bb3c3400 b9edddd0 ba443c80 8078b6a8
Mar 30 22:53:22 rpi5 kernel: [34248.737052] ddc0: a0000013 ffffffff
Mar 30 22:53:22 rpi5 kernel: [34248.738521] [<8079f6fc>] (__irq_svc) from [<8078b6a8>] (__radix_tree_lookup+0x70/0xb4)
Mar 30 22:53:22 rpi5 kernel: [34248.741435] [<8078b6a8>] (__radix_tree_lookup) from [<8078b708>] (radix_tree_lookup_slot+0x1c/0x2c)
Mar 30 22:53:22 rpi5 kernel: [34248.744365] [<8078b708>] (radix_tree_lookup_slot) from [<8021d0d8>] (find_get_entry+0x30/0x110)
Mar 30 22:53:22 rpi5 kernel: [34248.747291] [<8021d0d8>] (find_get_entry) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 22:53:22 rpi5 kernel: [34248.750210] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 22:53:22 rpi5 kernel: [34248.753131] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:53:22 rpi5 kernel: [34248.756061] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:53:22 rpi5 kernel: [34248.758980] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:53:22 rpi5 kernel: [34248.760499] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:53:22 rpi5 kernel: [34248.762006] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 22:54:25 rpi5 kernel: [34311.698876] INFO: rcu_sched self-detected stall on CPU
Mar 30 22:54:25 rpi5 kernel: [34311.700343] 	2-...: (8394 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=4196
Mar 30 22:54:25 rpi5 kernel: [34311.703255] 	 (t=8403 jiffies g=139900 c=139899 q=1045)
Mar 30 22:54:25 rpi5 kernel: [34311.704708] NMI backtrace for cpu 2
Mar 30 22:54:25 rpi5 kernel: [34311.706113] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 22:54:25 rpi5 kernel: [34311.708866] Hardware name: BCM2835
Mar 30 22:54:25 rpi5 kernel: [34311.710211] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 22:54:25 rpi5 kernel: [34311.712862] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 22:54:25 rpi5 kernel: [34311.714228] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 22:54:25 rpi5 kernel: [34311.716809] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 22:54:25 rpi5 kernel: [34311.719409] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 22:54:25 rpi5 kernel: [34311.722030] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 22:54:25 rpi5 kernel: [34311.724709] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 22:54:25 rpi5 kernel: [34311.727437] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 22:54:25 rpi5 kernel: [34311.730197] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 22:54:25 rpi5 kernel: [34311.733025] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 22:54:25 rpi5 kernel: [34311.735938] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 22:54:25 rpi5 kernel: [34311.738954] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 22:54:25 rpi5 kernel: [34311.741981] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 22:54:25 rpi5 kernel: [34311.745081] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 22:54:25 rpi5 kernel: [34311.748178] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 22:54:25 rpi5 kernel: [34311.751271] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 22:54:25 rpi5 kernel: [34311.754365] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 22:54:25 rpi5 kernel: [34311.757469] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 22:54:25 rpi5 kernel: [34311.760558] Exception stack(0xb9edddb8 to 0xb9edde00)
Mar 30 22:54:25 rpi5 kernel: [34311.762091] dda0:                                                       bb3c3400 ba443c94
Mar 30 22:54:25 rpi5 kernel: [34311.765027] ddc0: bb3c3410 bb3c3400 00000001 00000000 00000000 b97c9a60 80c045e8 00000000
Mar 30 22:54:25 rpi5 kernel: [34311.767919] dde0: 80c8826c b9edde2c 00000000 b9edde08 ba443c80 8021d12c 60000013 ffffffff
Mar 30 22:54:25 rpi5 kernel: [34311.770814] [<8079f6fc>] (__irq_svc) from [<8021d12c>] (find_get_entry+0x84/0x110)
Mar 30 22:54:25 rpi5 kernel: [34311.773700] [<8021d12c>] (find_get_entry) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 22:54:25 rpi5 kernel: [34311.776591] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 22:54:25 rpi5 kernel: [34311.779496] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:54:25 rpi5 kernel: [34311.782389] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:54:25 rpi5 kernel: [34311.785280] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:54:25 rpi5 kernel: [34311.786762] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:54:25 rpi5 kernel: [34311.788222] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 22:55:28 rpi5 kernel: [34374.729308] INFO: rcu_sched self-detected stall on CPU
Mar 30 22:55:28 rpi5 kernel: [34374.730771] 	2-...: (14689 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=7342
Mar 30 22:55:28 rpi5 kernel: [34374.733680] 	 (t=14706 jiffies g=139900 c=139899 q=1853)
Mar 30 22:55:28 rpi5 kernel: [34374.735133] NMI backtrace for cpu 2
Mar 30 22:55:28 rpi5 kernel: [34374.736536] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 22:55:28 rpi5 kernel: [34374.739282] Hardware name: BCM2835
Mar 30 22:55:28 rpi5 kernel: [34374.740624] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 22:55:28 rpi5 kernel: [34374.743268] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 22:55:28 rpi5 kernel: [34374.744632] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 22:55:28 rpi5 kernel: [34374.747208] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 22:55:28 rpi5 kernel: [34374.749804] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 22:55:28 rpi5 kernel: [34374.752413] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 22:55:28 rpi5 kernel: [34374.755091] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 22:55:28 rpi5 kernel: [34374.757818] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 22:55:28 rpi5 kernel: [34374.760577] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 22:55:28 rpi5 kernel: [34374.763406] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 22:55:28 rpi5 kernel: [34374.766317] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 22:55:28 rpi5 kernel: [34374.769333] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 22:55:28 rpi5 kernel: [34374.772360] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 22:55:28 rpi5 kernel: [34374.775456] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 22:55:28 rpi5 kernel: [34374.778548] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 22:55:28 rpi5 kernel: [34374.781641] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 22:55:28 rpi5 kernel: [34374.784730] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 22:55:28 rpi5 kernel: [34374.787833] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 22:55:28 rpi5 kernel: [34374.790924] Exception stack(0xb9edddb8 to 0xb9edde00)
Mar 30 22:55:28 rpi5 kernel: [34374.792455] dda0:                                                       bb3c3400 ba443c94
Mar 30 22:55:28 rpi5 kernel: [34374.795386] ddc0: bb3c3410 bb3c3400 00000001 00000000 00000000 b97c9a60 80c045e8 00000000
Mar 30 22:55:28 rpi5 kernel: [34374.798275] dde0: 80c8826c b9edde2c bb3c3400 b9edde08 ba443c80 8021d108 60000013 ffffffff
Mar 30 22:55:28 rpi5 kernel: [34374.801165] [<8079f6fc>] (__irq_svc) from [<8021d108>] (find_get_entry+0x60/0x110)
Mar 30 22:55:28 rpi5 kernel: [34374.804046] [<8021d108>] (find_get_entry) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 22:55:28 rpi5 kernel: [34374.806937] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 22:55:28 rpi5 kernel: [34374.809834] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:55:28 rpi5 kernel: [34374.812725] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:55:28 rpi5 kernel: [34374.815613] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:55:28 rpi5 kernel: [34374.817094] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:55:28 rpi5 kernel: [34374.818552] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 22:56:31 rpi5 kernel: [34437.759741] INFO: rcu_sched self-detected stall on CPU
Mar 30 22:56:31 rpi5 kernel: [34437.761202] 	2-...: (20984 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=10488
Mar 30 22:56:31 rpi5 kernel: [34437.764115] 	 (t=21009 jiffies g=139900 c=139899 q=2529)
Mar 30 22:56:31 rpi5 kernel: [34437.765566] NMI backtrace for cpu 2
Mar 30 22:56:31 rpi5 kernel: [34437.766970] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 22:56:31 rpi5 kernel: [34437.769722] Hardware name: BCM2835
Mar 30 22:56:31 rpi5 kernel: [34437.771066] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 22:56:31 rpi5 kernel: [34437.773710] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 22:56:31 rpi5 kernel: [34437.775075] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 22:56:31 rpi5 kernel: [34437.777659] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 22:56:31 rpi5 kernel: [34437.780259] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 22:56:31 rpi5 kernel: [34437.782873] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 22:56:31 rpi5 kernel: [34437.785554] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 22:56:31 rpi5 kernel: [34437.788282] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 22:56:31 rpi5 kernel: [34437.791039] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 22:56:31 rpi5 kernel: [34437.793875] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 22:56:31 rpi5 kernel: [34437.796787] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 22:56:31 rpi5 kernel: [34437.799802] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 22:56:31 rpi5 kernel: [34437.802829] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 22:56:31 rpi5 kernel: [34437.805925] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 22:56:31 rpi5 kernel: [34437.809017] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 22:56:31 rpi5 kernel: [34437.812115] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 22:56:31 rpi5 kernel: [34437.815208] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 22:56:31 rpi5 kernel: [34437.818313] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 22:56:31 rpi5 kernel: [34437.821402] Exception stack(0xb9eddda8 to 0xb9edddf0)
Mar 30 22:56:31 rpi5 kernel: [34437.822932] dda0:                   b97c9a60 00000000 bb3c3410 bb3c3400 00000001 00000000
Mar 30 22:56:31 rpi5 kernel: [34437.825924] ddc0: 00000000 b97c9a60 80c045e8 00000000 80c8826c b9edde2c b9edde08 b9edddf8
Mar 30 22:56:31 rpi5 kernel: [34437.828905] dde0: 8021d0d8 8078b6f4 60000013 ffffffff
Mar 30 22:56:31 rpi5 kernel: [34437.830391] [<8079f6fc>] (__irq_svc) from [<8078b6f4>] (radix_tree_lookup_slot+0x8/0x2c)
Mar 30 22:56:31 rpi5 kernel: [34437.833315] [<8078b6f4>] (radix_tree_lookup_slot) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 22:56:31 rpi5 kernel: [34437.836249] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 22:56:31 rpi5 kernel: [34437.839183] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:56:31 rpi5 kernel: [34437.842108] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:56:31 rpi5 kernel: [34437.845032] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:56:31 rpi5 kernel: [34437.846529] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:56:31 rpi5 kernel: [34437.848008] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 22:57:34 rpi5 kernel: [34500.790174] INFO: rcu_sched self-detected stall on CPU
Mar 30 22:57:34 rpi5 kernel: [34500.791632] 	2-...: (27279 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=13633
Mar 30 22:57:34 rpi5 kernel: [34500.794470] 	 (t=27312 jiffies g=139900 c=139899 q=3411)
Mar 30 22:57:34 rpi5 kernel: [34500.795891] NMI backtrace for cpu 2
Mar 30 22:57:34 rpi5 kernel: [34500.797265] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 22:57:34 rpi5 kernel: [34500.800008] Hardware name: BCM2835
Mar 30 22:57:34 rpi5 kernel: [34500.801352] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 22:57:34 rpi5 kernel: [34500.803994] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 22:57:34 rpi5 kernel: [34500.805359] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 22:57:34 rpi5 kernel: [34500.807943] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 22:57:34 rpi5 kernel: [34500.810542] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 22:57:34 rpi5 kernel: [34500.813156] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 22:57:34 rpi5 kernel: [34500.815834] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 22:57:34 rpi5 kernel: [34500.818561] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 22:57:34 rpi5 kernel: [34500.821318] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 22:57:34 rpi5 kernel: [34500.824157] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 22:57:34 rpi5 kernel: [34500.827070] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 22:57:34 rpi5 kernel: [34500.830084] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 22:57:34 rpi5 kernel: [34500.833113] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 22:57:34 rpi5 kernel: [34500.836206] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 22:57:34 rpi5 kernel: [34500.839298] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 22:57:34 rpi5 kernel: [34500.842394] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 22:57:34 rpi5 kernel: [34500.845485] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 22:57:34 rpi5 kernel: [34500.848587] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 22:57:34 rpi5 kernel: [34500.851673] Exception stack(0xb9eddda8 to 0xb9edddf0)
Mar 30 22:57:34 rpi5 kernel: [34500.853200] dda0:                   b97c9a60 00000000 bb3c3410 bb3c3400 00000001 00000000
Mar 30 22:57:34 rpi5 kernel: [34500.856195] ddc0: 00000000 b97c9a60 80c045e8 00000000 80c8826c b9edde2c b9edde08 b9edddf8
Mar 30 22:57:34 rpi5 kernel: [34500.859174] dde0: 8021d0d8 8078b6f4 60000013 ffffffff
Mar 30 22:57:34 rpi5 kernel: [34500.860659] [<8079f6fc>] (__irq_svc) from [<8078b6f4>] (radix_tree_lookup_slot+0x8/0x2c)
Mar 30 22:57:34 rpi5 kernel: [34500.863582] [<8078b6f4>] (radix_tree_lookup_slot) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 22:57:34 rpi5 kernel: [34500.866511] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 22:57:34 rpi5 kernel: [34500.869438] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:57:34 rpi5 kernel: [34500.872360] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:57:34 rpi5 kernel: [34500.875278] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:57:34 rpi5 kernel: [34500.876775] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:57:34 rpi5 kernel: [34500.878250] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 22:58:37 rpi5 kernel: [34563.820608] INFO: rcu_sched self-detected stall on CPU
Mar 30 22:58:37 rpi5 kernel: [34563.822063] 	2-...: (33574 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=16779
Mar 30 22:58:37 rpi5 kernel: [34563.824892] 	 (t=33615 jiffies g=139900 c=139899 q=4078)
Mar 30 22:58:37 rpi5 kernel: [34563.826316] NMI backtrace for cpu 2
Mar 30 22:58:37 rpi5 kernel: [34563.827690] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 22:58:37 rpi5 kernel: [34563.830433] Hardware name: BCM2835
Mar 30 22:58:37 rpi5 kernel: [34563.831775] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 22:58:37 rpi5 kernel: [34563.834417] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 22:58:37 rpi5 kernel: [34563.835784] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 22:58:37 rpi5 kernel: [34563.838370] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 22:58:37 rpi5 kernel: [34563.840969] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 22:58:37 rpi5 kernel: [34563.843582] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 22:58:37 rpi5 kernel: [34563.846263] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 22:58:37 rpi5 kernel: [34563.848987] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 22:58:37 rpi5 kernel: [34563.851750] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 22:58:37 rpi5 kernel: [34563.854586] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 22:58:37 rpi5 kernel: [34563.857500] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 22:58:37 rpi5 kernel: [34563.860515] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 22:58:37 rpi5 kernel: [34563.863540] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 22:58:37 rpi5 kernel: [34563.866629] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 22:58:37 rpi5 kernel: [34563.869726] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 22:58:37 rpi5 kernel: [34563.872820] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 22:58:37 rpi5 kernel: [34563.875909] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 22:58:37 rpi5 kernel: [34563.879013] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 22:58:37 rpi5 kernel: [34563.882097] Exception stack(0xb9edddb8 to 0xb9edde00)
Mar 30 22:58:37 rpi5 kernel: [34563.883625] dda0:                                                       bb3c3400 ba443c94
Mar 30 22:58:37 rpi5 kernel: [34563.886559] ddc0: 00000000 b9edddf4 00000001 00000000 00000000 b97c9a60 80c045e8 00000000
Mar 30 22:58:37 rpi5 kernel: [34563.889451] dde0: 80c8826c b9edde2c bb3c3400 b9edde08 ba443c80 8021d0ec a0000013 ffffffff
Mar 30 22:58:37 rpi5 kernel: [34563.892343] [<8079f6fc>] (__irq_svc) from [<8021d0ec>] (find_get_entry+0x44/0x110)
Mar 30 22:58:37 rpi5 kernel: [34563.895225] [<8021d0ec>] (find_get_entry) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 22:58:37 rpi5 kernel: [34563.898117] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 22:58:37 rpi5 kernel: [34563.901010] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:58:37 rpi5 kernel: [34563.903912] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:58:37 rpi5 kernel: [34563.906804] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:58:37 rpi5 kernel: [34563.908285] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:58:37 rpi5 kernel: [34563.909749] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 22:59:40 rpi5 kernel: [34626.851038] INFO: rcu_sched self-detected stall on CPU
Mar 30 22:59:40 rpi5 kernel: [34626.852499] 	2-...: (39869 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=19925
Mar 30 22:59:40 rpi5 kernel: [34626.855414] 	 (t=39918 jiffies g=139900 c=139899 q=4714)
Mar 30 22:59:40 rpi5 kernel: [34626.856868] NMI backtrace for cpu 2
Mar 30 22:59:40 rpi5 kernel: [34626.858271] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 22:59:40 rpi5 kernel: [34626.861021] Hardware name: BCM2835
Mar 30 22:59:40 rpi5 kernel: [34626.862360] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 22:59:40 rpi5 kernel: [34626.865004] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 22:59:40 rpi5 kernel: [34626.866374] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 22:59:40 rpi5 kernel: [34626.868956] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 22:59:40 rpi5 kernel: [34626.871554] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 22:59:40 rpi5 kernel: [34626.874165] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 22:59:40 rpi5 kernel: [34626.876841] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 22:59:40 rpi5 kernel: [34626.879558] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 22:59:40 rpi5 kernel: [34626.882319] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 22:59:40 rpi5 kernel: [34626.885154] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 22:59:40 rpi5 kernel: [34626.888065] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 22:59:40 rpi5 kernel: [34626.891080] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 22:59:40 rpi5 kernel: [34626.894108] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 22:59:40 rpi5 kernel: [34626.897197] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 22:59:40 rpi5 kernel: [34626.900299] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 22:59:40 rpi5 kernel: [34626.903396] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 22:59:40 rpi5 kernel: [34626.906490] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 22:59:40 rpi5 kernel: [34626.909597] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 22:59:40 rpi5 kernel: [34626.912680] Exception stack(0xb9eddd80 to 0xb9edddc8)
Mar 30 22:59:40 rpi5 kernel: [34626.914209] dd80: b97c9a60 00000000 00000000 b9edddf4 ba443c81 00000040 ba443c81 b97c9a60
Mar 30 22:59:40 rpi5 kernel: [34626.917229] dda0: 80c045e8 00000000 80c8826c b9edddec 0000003f b9edddd0 8078b708 8078b688
Mar 30 22:59:40 rpi5 kernel: [34626.920241] ddc0: a0000013 ffffffff
Mar 30 22:59:40 rpi5 kernel: [34626.921710] [<8079f6fc>] (__irq_svc) from [<8078b688>] (__radix_tree_lookup+0x50/0xb4)
Mar 30 22:59:40 rpi5 kernel: [34626.924630] [<8078b688>] (__radix_tree_lookup) from [<8078b708>] (radix_tree_lookup_slot+0x1c/0x2c)
Mar 30 22:59:40 rpi5 kernel: [34626.927560] [<8078b708>] (radix_tree_lookup_slot) from [<8021d0d8>] (find_get_entry+0x30/0x110)
Mar 30 22:59:40 rpi5 kernel: [34626.930476] [<8021d0d8>] (find_get_entry) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 22:59:40 rpi5 kernel: [34626.933396] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 22:59:40 rpi5 kernel: [34626.936328] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 22:59:40 rpi5 kernel: [34626.939259] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 22:59:40 rpi5 kernel: [34626.942181] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 22:59:40 rpi5 kernel: [34626.943701] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 22:59:40 rpi5 kernel: [34626.945204] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 23:00:43 rpi5 kernel: [34689.881474] INFO: rcu_sched self-detected stall on CPU
Mar 30 23:00:43 rpi5 kernel: [34689.882943] 	2-...: (46164 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=23071
Mar 30 23:00:43 rpi5 kernel: [34689.885852] 	 (t=46221 jiffies g=139900 c=139899 q=5543)
Mar 30 23:00:43 rpi5 kernel: [34689.887308] NMI backtrace for cpu 2
Mar 30 23:00:43 rpi5 kernel: [34689.888713] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 23:00:43 rpi5 kernel: [34689.891461] Hardware name: BCM2835
Mar 30 23:00:43 rpi5 kernel: [34689.892800] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 23:00:43 rpi5 kernel: [34689.895445] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 23:00:43 rpi5 kernel: [34689.896812] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 23:00:43 rpi5 kernel: [34689.899394] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 23:00:43 rpi5 kernel: [34689.901993] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 23:00:43 rpi5 kernel: [34689.904607] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 23:00:43 rpi5 kernel: [34689.907284] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 23:00:43 rpi5 kernel: [34689.910003] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 23:00:43 rpi5 kernel: [34689.912766] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 23:00:43 rpi5 kernel: [34689.915602] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 23:00:43 rpi5 kernel: [34689.918514] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 23:00:43 rpi5 kernel: [34689.921530] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 23:00:43 rpi5 kernel: [34689.924555] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 23:00:43 rpi5 kernel: [34689.927643] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 23:00:43 rpi5 kernel: [34689.930750] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 23:00:43 rpi5 kernel: [34689.933844] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 23:00:43 rpi5 kernel: [34689.936938] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 23:00:43 rpi5 kernel: [34689.940043] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 23:00:43 rpi5 kernel: [34689.943125] Exception stack(0xb9edddb8 to 0xb9edde00)
Mar 30 23:00:43 rpi5 kernel: [34689.944653] dda0:                                                       bb3c3400 ba443c94
Mar 30 23:00:43 rpi5 kernel: [34689.947594] ddc0: bb3c3410 bb3c3400 00000001 00000000 00000000 b97c9a60 80c045e8 00000000
Mar 30 23:00:43 rpi5 kernel: [34689.950491] dde0: 80c8826c b9edde2c 00000000 b9edde08 ba443c80 8021d0cc 60000013 ffffffff
Mar 30 23:00:43 rpi5 kernel: [34689.953383] [<8079f6fc>] (__irq_svc) from [<8021d0cc>] (find_get_entry+0x24/0x110)
Mar 30 23:00:43 rpi5 kernel: [34689.956267] [<8021d0cc>] (find_get_entry) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 23:00:43 rpi5 kernel: [34689.959154] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 23:00:43 rpi5 kernel: [34689.962052] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 23:00:43 rpi5 kernel: [34689.964955] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 23:00:43 rpi5 kernel: [34689.967845] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 23:00:43 rpi5 kernel: [34689.969325] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 23:00:43 rpi5 kernel: [34689.970784] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
Mar 30 23:01:46 rpi5 kernel: [34752.911909] INFO: rcu_sched self-detected stall on CPU
Mar 30 23:01:46 rpi5 kernel: [34752.913370] 	2-...: (52459 ticks this GP) idle=7e2/140000000000001/0 softirq=217394/217394 fqs=26214
Mar 30 23:01:46 rpi5 kernel: [34752.916282] 	 (t=52524 jiffies g=139900 c=139899 q=6341)
Mar 30 23:01:46 rpi5 kernel: [34752.917735] NMI backtrace for cpu 2
Mar 30 23:01:46 rpi5 kernel: [34752.919138] CPU: 2 PID: 7937 Comm: exim4 Tainted: G      D  C      4.14.31-v7+ #1104
Mar 30 23:01:46 rpi5 kernel: [34752.921880] Hardware name: BCM2835
Mar 30 23:01:46 rpi5 kernel: [34752.923219] [<8010fff8>] (unwind_backtrace) from [<8010c260>] (show_stack+0x20/0x24)
Mar 30 23:01:46 rpi5 kernel: [34752.925866] [<8010c260>] (show_stack) from [<80783ac4>] (dump_stack+0xd4/0x118)
Mar 30 23:01:46 rpi5 kernel: [34752.927235] [<80783ac4>] (dump_stack) from [<80789984>] (nmi_cpu_backtrace+0x124/0x128)
Mar 30 23:01:46 rpi5 kernel: [34752.929818] [<80789984>] (nmi_cpu_backtrace) from [<80789a68>] (nmi_trigger_cpumask_backtrace+0xe0/0x120)
Mar 30 23:01:46 rpi5 kernel: [34752.932415] [<80789a68>] (nmi_trigger_cpumask_backtrace) from [<8010e63c>] (arch_trigger_cpumask_backtrace+0x20/0x24)
Mar 30 23:01:46 rpi5 kernel: [34752.935028] [<8010e63c>] (arch_trigger_cpumask_backtrace) from [<80185950>] (rcu_dump_cpu_stacks+0xa8/0xd8)
Mar 30 23:01:46 rpi5 kernel: [34752.937702] [<80185950>] (rcu_dump_cpu_stacks) from [<801851bc>] (rcu_check_callbacks+0x7a4/0x934)
Mar 30 23:01:46 rpi5 kernel: [34752.940417] [<801851bc>] (rcu_check_callbacks) from [<8018b4dc>] (update_process_times+0x40/0x6c)
Mar 30 23:01:46 rpi5 kernel: [34752.943181] [<8018b4dc>] (update_process_times) from [<8019d0bc>] (tick_sched_handle+0x64/0x70)
Mar 30 23:01:46 rpi5 kernel: [34752.946017] [<8019d0bc>] (tick_sched_handle) from [<8019d2fc>] (tick_sched_timer+0x50/0xac)
Mar 30 23:01:46 rpi5 kernel: [34752.948929] [<8019d2fc>] (tick_sched_timer) from [<8018c448>] (__hrtimer_run_queues+0x154/0x2f0)
Mar 30 23:01:46 rpi5 kernel: [34752.951942] [<8018c448>] (__hrtimer_run_queues) from [<8018c820>] (hrtimer_interrupt+0xcc/0x220)
Mar 30 23:01:46 rpi5 kernel: [34752.954961] [<8018c820>] (hrtimer_interrupt) from [<80639710>] (arch_timer_handler_phys+0x40/0x48)
Mar 30 23:01:46 rpi5 kernel: [34752.958050] [<80639710>] (arch_timer_handler_phys) from [<8017a4ec>] (handle_percpu_devid_irq+0x88/0x23c)
Mar 30 23:01:46 rpi5 kernel: [34752.961155] [<8017a4ec>] (handle_percpu_devid_irq) from [<80174f10>] (generic_handle_irq+0x34/0x44)
Mar 30 23:01:46 rpi5 kernel: [34752.964251] [<80174f10>] (generic_handle_irq) from [<80175550>] (__handle_domain_irq+0x6c/0xc4)
Mar 30 23:01:46 rpi5 kernel: [34752.967343] [<80175550>] (__handle_domain_irq) from [<80101504>] (bcm2836_arm_irqchip_handle_irq+0xa8/0xac)
Mar 30 23:01:46 rpi5 kernel: [34752.970445] [<80101504>] (bcm2836_arm_irqchip_handle_irq) from [<8079f6fc>] (__irq_svc+0x5c/0x7c)
Mar 30 23:01:46 rpi5 kernel: [34752.973522] Exception stack(0xb9eddd80 to 0xb9edddc8)
Mar 30 23:01:46 rpi5 kernel: [34752.975055] dd80: b97c9a60 00000000 00000000 b9edddf4 ba443c81 00000040 ba443c81 b97c9a60
Mar 30 23:01:46 rpi5 kernel: [34752.978072] dda0: 80c045e8 00000000 80c8826c b9edddec ba443c90 b9edddd0 ba443c80 8078b6a0
Mar 30 23:01:46 rpi5 kernel: [34752.981084] ddc0: a0000013 ffffffff
Mar 30 23:01:46 rpi5 kernel: [34752.982552] [<8079f6fc>] (__irq_svc) from [<8078b6a0>] (__radix_tree_lookup+0x68/0xb4)
Mar 30 23:01:46 rpi5 kernel: [34752.985470] [<8078b6a0>] (__radix_tree_lookup) from [<8078b708>] (radix_tree_lookup_slot+0x1c/0x2c)
Mar 30 23:01:46 rpi5 kernel: [34752.988394] [<8078b708>] (radix_tree_lookup_slot) from [<8021d0d8>] (find_get_entry+0x30/0x110)
Mar 30 23:01:46 rpi5 kernel: [34752.991313] [<8021d0d8>] (find_get_entry) from [<8021d2c8>] (pagecache_get_page+0x44/0x2d0)
Mar 30 23:01:46 rpi5 kernel: [34752.994237] [<8021d2c8>] (pagecache_get_page) from [<80220090>] (generic_file_read_iter+0x200/0x9d0)
Mar 30 23:01:46 rpi5 kernel: [34752.997172] [<80220090>] (generic_file_read_iter) from [<80327bc4>] (ext4_file_read_iter+0x44/0x5c)
Mar 30 23:01:46 rpi5 kernel: [34753.000106] [<80327bc4>] (ext4_file_read_iter) from [<8028a6cc>] (__vfs_read+0xe0/0x130)
Mar 30 23:01:46 rpi5 kernel: [34753.003028] [<8028a6cc>] (__vfs_read) from [<8028a7b8>] (vfs_read+0x9c/0x168)
Mar 30 23:01:46 rpi5 kernel: [34753.004543] [<8028a7b8>] (vfs_read) from [<8028ad68>] (SyS_read+0x54/0xb0)
Mar 30 23:01:46 rpi5 kernel: [34753.006047] [<8028ad68>] (SyS_read) from [<80108080>] (ret_fast_syscall+0x0/0x28)
I tried to get output from the screen before power cycling but there was no source detected when I hooked up the HDMI cable.
horgh
Sat Mar 31, 2018 3:13 pm
I found a couple possibly related GitHub issues: https://github.com/raspberrypi/linux/issues/2481 and https://github.com/raspberrypi/linux/issues/2449
In case it's relevant, I'm running over wifi - no ethernet cable involved.
PhilE
Sat Mar 31, 2018 4:55 pm
Can you try adding "arm_freq=1200 and "sdram_freq=450" to config.txt?
horgh
Sat Mar 31, 2018 5:26 pm
Okay I've done that & rebooted. I'll let you know if there are any issues. Thank you for the help so far!
YorkshireTyke
Sat Mar 31, 2018 10:03 pm
I have a IQaudio PiDAC+ hat attached to my pi, which I removed to see if that was causing the problem. Whilst I haven't had a crash like the last few days, it did slow down to a craw. The task manager showed that I'd used most of the memory, so I've been looking at the log files.
I have "ufw" installed and it's writing to the log file a report every 5-6 seconds! It reports a UFW BLOCK with a "DST=224.0.0.1", so I'm guessing this log file gets so big that I run out of space. Any one else have this too?
OpenSociett
Sun Apr 01, 2018 6:34 am
Up until yesterday I also had a USB hard drive connected (via a USB hub), and for troubleshooting purposes I removed it and so far I haven't had any crashes. It should be noted I've ever only used Wifi with my 3B+.
drencor
Mon Apr 02, 2018 1:53 am
Here is next log output!
putty_rpi3bp_201804012018.zip
(8.92 KiB) Downloaded 41 times
drencor
Mon Apr 02, 2018 5:45 am
I would also like to point out some trouble shooting observations I have been noticing.
When using the full Raspbian Stretch 2018-03-13 image, all updates and most current rpi-update.
Booting to the GUI Desktop without the Raspberry Pi 3 B+ plugged into a router or ethernet switch the system seems to boot fine every time so far.
Booting to the GUI Desktop with the Raspberry Pi 3 B+ with the Raspberry Pi 3 B+ plugged into a router/ethernet switch crashes once in a while.
Using raspi-config to disable Desktop boot, but booting to text/command line login, but splash screen still enabled and Raspberry Pi 3 B+ plugged into ethernet port on router/ethernet switch the system crashes more often that when the GUI was enabled.
Using raspi-config to disable Desktop boot, having the system load to text/command line login, and having splash screen disabled and Raspberry Pi 3 B+ plugged into ethernet port on router/ethernet switch the system crashes every time on startup.
So not sure if that helps, but I notice a pattern here. :(
Mon Apr 02, 2018 6:53 am
Sound like a race condition on ethernet driver startup. I think there is a bug fix in rpi-update that had some impact there, but might be misremembering.
drencor
Mon Apr 02, 2018 11:25 pm
Well as I had stated in previous post I had run rpi-update and here is the current string that the Raspberry Pi 3 B+ pops out at me when I login:
Linux raspberrypi 4.14.31-v7+ #1104 SMP Thu Mar 29 16:52:18 BST 2018 armv7l
So I have run:
sudo su
apt-get update
apt-get upgrade -y
apt-get dist-upgrade -y
rpi-update
and I did that before my last post where I went through giving the steps I did and at the frequency of the crashes.
BrentD
Tue Apr 03, 2018 12:18 am
Sorry if this is the wrong topic to post to, but I'm stuck. My new B+ never gets to the ACT light, but I get a very deliberate pattern on the red status LED; four long flashes followed immediately by four short flashes, pause, then repeat. Input voltage to the 7704 PMIC is 4.98 volts, new burn of noobs that work fine on a B. I can't find any documentation of error codes on the RED LED. Thanks for anything you can offer!
drencor
Tue Apr 03, 2018 6:04 am
The only information I have found myself about the Raspberry Pi RED Power LED blinking is when the voltage drops below 4.75V.
The Raspberry Pi 3 B and Raspberry Pi 3 B+ you should be using the official 2.5A 5V power supply. If you are using any other power supply that is not rated for 2.5A then you could be browning out when the Raspberry Pi 3 B+ is trying to pull more current than your PSU can handle.
PhilE
Tue Apr 03, 2018 7:39 am
Ignore for a moment the fact that it's the red LED flashing and not the green(*). A pattern of 4 long+4 short flashes says the platform is not supported by the image.
When you say it is a new NOOBS, when did you download it? Only the most recent (2018-03-14) image has support for the 3B+.
(*) Pin assignments change between models, so if the platform isn't recognised then it is possible that the wrong GPIO is being toggled. Specifically, the GPIO that drove the green ACT LED on the 3B now drives the red PWR LED on the 3B+.
NoSheds
Wed Apr 04, 2018 11:57 am
Hi. I am having problems too with Pi 3 B+s. This is my first post here so please excuse any mistakes I may make. I hope it is OK to add to this thread rather than start a new one.
I had a Pi3b (not plus) that was successfully running as a server to backup machines on my network. It was running Backuppc and also as a destination for SimpleBackup (sbackup a Linux program). The Pi3b had a USB hard disk plugged into it to receive the backed up files. Once the 3B+ was released, I brought two of them. I updated my sd card with apt-get update, upgrade & dist-upgrade etc and it successfully updated to the latest version. I swapped the 3B for a 3B+. Booted. Except it didn't boot (flashing leds). I went back to the 3B and did a rpi-update. Swapped the 3B+ back in, and it booted OK.
Then the problems started.
Two distinct problems.
1) Backuppc failing with a "Broken Pipe" message. It communicates between the server and the machine via RSync/RSyncd. I *think* this problem is caused by no activity occurring over the connection between the client and server for a long while, and I think I have solved it by tweaking my setup to artificially limit the network transfer speed that backuppc's rsync is usuing, and tweaking settings to keep the connection alive. The problem only occured when doing a full backup of lots of files on two servers - a very slow and disk & network intensive process. This "fix" is not really a satisfactory one as the process was working fine on the 3B but now fails without the "fix" on the 3B+, machines that I brought specifically because they are faster.
2) Crash/Lockup. This seems to occur when a full server backup is occurring using SBackup. The Pi3B+ just dies. It happened to me twice since yesterday evening. On both occasions, the green and red lights on the pi were lit up, and the disk access light was lit on the USB drive, but the PI was completely unresponsive to pings or SSH. Again, this process used to work on the 3B. Again, this will be a processor and disk intensive task. Examining the log files, I can see no errors listed. The machine runs headless, so I don't see any problems on screen when it crashes, because there isn't one!
To try and fix this, I have regularly performed apt-get update, upgrade & dist-upgrade etc and rpi-update's. I have tried both of my Pi 3B+s. I have cloned the SD card (using the SD Card copier built in to Raspbian). I have bought a ventilated case with a fan to keep the pi's temperature low (now constantly below 40C according to "vcgencmd measure_temp"). I have also regularly performed a fsck on the sd card partitions, and the USB drive, each time there was a lock-up. I have even replaced the USB drive with a different bigger one with its own power supply. Every single component except the PSU has been swapped out for a different one. The PSU is an official Pi branded 2.5A one.
This morning, after the latest crash, I have tried the apt-get update, upgrade & dist-upgrade etc again (all were up-to-date) and rpi-update (which installed the latest version).
I was really glad to find this thread as it seems other people are having problems with disk and/or network intensive tasks. I'm really quite disappointed as the 3B+ was supposed to be faster (& "better"), but for my use, as far as I can see, is proving unreliable.
I don't really know what else I can try. Can anyone help?
horgh
Wed Apr 04, 2018 2:59 pm
An update: After adding "arm_freq=1200 and "sdram_freq=450" to config.txt, my Pi has been completely stable:
 07:55:12 up 3 days, 21:37, 11 users,  load average: 0.12, 0.19, 0.13
So that's great!
By the way: I'd be happy to make further changes or run a custom kernel or something to help debug the original problem, even if it introduces instability again.
Thanks for the help!
PhilE
Wed Apr 04, 2018 3:01 pm
Thank you for the feedback and the offer. I'm going to wait until we have a hypothesis rather than get you to change stuff randomly, but I'll take a rain check.
PhilE
Wed Apr 04, 2018 3:03 pm
Actually, you could comment out each of those settings individually to see if either one on its own is enough to make your 3B+ stable.
PeterO
Wed Apr 04, 2018 3:26 pm
Can those values be incrementally increased for testing stability ?
We know arm frequency is 1400 by default, but what is the defualt for the sdram speed ?
PeterO (Currently running his 3B+ at 1200/450)
PhilE
Wed Apr 04, 2018 3:37 pm
If you want to try bisecting the two value to find the maximum safe value then go ahead. If you find that the Pi is sensitive to sdram_freq then you could try increasing over_voltage_sdram_p above the default of 2 to see if that increases stability.
You can find the defaults yourself by running "vcgencmd get_config int", which will tell you that "sdram_freq=500". Remember that those are the "turbo" values - the baseline is still 600 for the arm_freq and 400 for sdram_freq.
drencor
Thu Apr 05, 2018 3:42 am
I thought I would let you know that I did a
sudo rpi-update
and got a update this afternoon. The new version of the kernel files is
Linux coconet 4.14.32-v7+ #1106 SMP Wed Apr 4 18:19:23 BST 2018 armv7l
and I decided to turn off the GUI and turn off the splash screen to see if the system would do a kernel dump on boot and so far it is looking good. So far I have rebooted a few times with default config.txt file system is booting to command line. I will continue to test for stability.
hjimbens
Re: Raspberry Pi 3 B+ lockups
Thu Apr 05, 2018 2:57 pm
Earlier in this thread I reported that I have two Pi 3 B+'s, one of which repeatedly freezes after a few minutes, even with "arm_freq=700". However after adding "arm_freq=1200 and "sdram_freq=450" to config.txt I have not seen any freezes yet. Right now I am trying with only "sdram_freq=450" and I have not seen a freeze yet.
PhilE
Thu Apr 05, 2018 3:30 pm
Thanks - that's a very useful datapoint. Assuming that remains stable and you are prepared to experiment further, try with these settings:
sdram_freq=500
over_voltage_sdram_p=4
over_voltage_sdram_c=4
If that is also stable you can progressively lower the voltages individually until it fails.
crocky
Fri Apr 06, 2018 2:00 am
Just did the rpi-update and the others to my pi3+ In the effort to overcome the nightly lockup. I am running the-script and really not over working it. See how it goes tonight....
