Page 8 of 19
Re: Raspberry Pi 3 B+ lockups
Posted: Mon Apr 16, 2018 10:10 pm
by gkreidl
leon22 wrote: ↑Mon Apr 16, 2018 8:31 pm
Hi!
Here my test results (suggested by a member of the LibreElec board):
memtester version 4.3.0 (32-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
want 512MB (536870912 bytes)
got 512MB (536870912 bytes), trying mlock ...locked.
Loop 1:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Sequential Increment: ok
Solid Bits : ok
Block Sequential : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 2:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 3:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 4:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 5:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 6:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 7:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 8:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 9:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 10:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 11:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 12:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 13:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 14:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 15:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 16:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Solid Bits : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
No errors after 16 loops!
vcgencmd get_throttled
throttled=0x0
So I tend to send my 3B+ back to Amazon to get a new one without this issues! What do you think?
Greets
Which issues?
From what you wrote before, it looks more like a crappy CD card.
Posted: Tue Apr 17, 2018 1:37 am
by Nachteule
Hi!
throttled=0x0
Greets
I don't think that you'll get back a better board. I did the same, my first part I got from Pollin (it was a package from Farnell). I was sending it back after 12 days and ordered a 2nd one from another reseller (the new one is a package from RS components)
But what should I say, same crap
. Randomly crashes even while system is idle.
Posted: Tue Apr 17, 2018 2:24 am
by horgh
PhilE wrote: ↑Mon Apr 16, 2018 8:11 am
If anyone has a board that fails "sudo MEMTESTER_TEST_MASK=0x1000 memtester 128M" in a few minutes
with the default settings (no sdram_freq, arm_freq, over_voltage* etc.) who hasn't already PMd or emailed me (
phil@raspberrypi.org), especially if you are in the UK, then please get in touch.
I tried this and let it run for ~55 minutes without issue. I suppose my issue may be something different then? Weird that the sdram_freq setting seems to have helped in my case though.
Posted: Tue Apr 17, 2018 9:54 am
by milhouse
Greets
You haven't submitted a crashlog to the
LibreELEC forum as I suggested or even a kodi debug log (as others from the LE community have subsequently requested) so there's every chance the Kodi crashes you are experiencing have nothing to do with your 3B+ board which you may be replacing unnecessarily, and the crashes will continue with the replacement board.
Not every random software crash on a Pi3B+ is going to be due to these initial firmware/marginal hardware niggles, so I'd advise against rushing to that conclusion. However if you still want a replacement, then sure, go ahead...just be aware you may not have a problem with your board at all.
Posted: Tue Apr 17, 2018 6:36 pm
by leon22
milhouse wrote: ↑Tue Apr 17, 2018 9:54 am
Greets
Hi!
There is no crash log as already mentioned but I can post the normal log file:
(btw I can reproduce the crash: always during movie library update)
15:12:16.744 T:1944736320 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:12:16.744 T:1944736320 NOTICE: -----------------------------------------------------------------------
15:12:16.744 T:1944736320 NOTICE: Starting Kodi (17.6 Git:a9a7a20). Platform: Linux ARM 32-bit
15:12:16.744 T:1944736320 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
15:12:16.744 T:1944736320 NOTICE: Kodi compiled Apr 13 2018 by GCC 6.2.0 for Linux ARM 32-bit version 4.9.80 (264528)
15:12:16.744 T:1944736320 NOTICE: Running on LibreELEC (official): 8.2.5, kernel: Linux ARM 32-bit version 4.9.80
15:12:16.744 T:1944736320 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
15:12:16.744 T:1944736320 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
15:12:16.744 T:1944736320 NOTICE: ARM Features: Neon enabled
15:12:16.744 T:1944736320 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
15:12:16.744 T:1944736320 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:12:16.744 T:1944736320 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
15:12:16.745 T:1944736320 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
15:12:16.745 T:1944736320 NOTICE: special://envhome/ is mapped to: /storage
15:12:16.745 T:1944736320 NOTICE: special://home/ is mapped to: /storage/.kodi
15:12:16.745 T:1944736320 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
15:12:16.745 T:1944736320 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
15:12:16.745 T:1944736320 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:12:16.745 T:1944736320 NOTICE: Local hostname: LibreELEC
15:12:16.745 T:1944736320 NOTICE: Log File is located: /storage/.kodi/temp//kodi.log
15:12:16.746 T:1944736320 NOTICE: -----------------------------------------------------------------------
15:12:16.913 T:1944736320 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
15:12:16.919 T:1944736320 NOTICE: load settings...
15:12:17.023 T:1944736320 NOTICE: Found 2 Lists of Devices
15:12:17.023 T:1944736320 NOTICE: Enumerated PI devices:
15:12:17.023 T:1944736320 NOTICE: Device 1
15:12:17.024 T:1944736320 NOTICE: m_deviceName : HDMI
15:12:17.024 T:1944736320 NOTICE: m_displayName : HDMI
15:12:17.024 T:1944736320 NOTICE: m_displayNameExtra:
15:12:17.024 T:1944736320 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:12:17.024 T:1944736320 NOTICE: m_channels : FL,FR
15:12:17.024 T:1944736320 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
15:12:17.024 T:1944736320 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
15:12:17.024 T:1944736320 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
15:12:17.024 T:1944736320 NOTICE: Device 2
15:12:17.024 T:1944736320 NOTICE: m_deviceName : Analogue
15:12:17.024 T:1944736320 NOTICE: m_displayName : Analogue
15:12:17.024 T:1944736320 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:12:17.024 T:1944736320 NOTICE: m_sampleRates : 48000
15:12:17.024 T:1944736320 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
15:12:17.024 T:1944736320 NOTICE: m_streamTypes : No passthrough capabilities
15:12:17.024 T:1944736320 NOTICE: Device 3
15:12:17.024 T:1944736320 NOTICE: m_deviceName : Both
15:12:17.024 T:1944736320 NOTICE: m_displayName : HDMI and Analogue
15:12:17.024 T:1944736320 NOTICE: Enumerated PULSE devices:
15:12:17.024 T:1944736320 NOTICE: Device 1
15:12:17.024 T:1944736320 NOTICE: m_deviceName : Default
15:12:17.024 T:1944736320 NOTICE: m_displayName : Default
15:12:17.024 T:1944736320 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
15:12:17.025 T:1944736320 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:12:17.025 T:1944736320 NOTICE: m_channels : FL,FR
15:12:17.025 T:1944736320 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
15:12:17.025 T:1944736320 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
15:12:17.025 T:1944736320 NOTICE: m_streamTypes : No passthrough capabilities
15:12:17.047 T:1944736320 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
15:12:17.047 T:1944736320 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<fanartres>720</fanartres>
<imageres>540</imageres>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
</advancedsettings>
15:12:17.049 T:1944736320 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:12:17.049 T:1944736320 NOTICE: Default Video Player: VideoPlayer
15:12:17.049 T:1944736320 NOTICE: Default Audio Player: paplayer
15:12:17.049 T:1944736320 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:12:17.049 T:1944736320 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:12:17.049 T:1944736320 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:12:17.051 T:1944736320 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:12:17.052 T:1944736320 NOTICE: Loaded playercorefactory configuration
15:12:17.052 T:1944736320 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:12:17.052 T:1944736320 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:12:17.168 T:1944736320 NOTICE: Running database version Addons27
15:12:17.335 T:1944736320 NOTICE: ADDONS: Using repository repository.kodi.game
15:12:17.335 T:1944736320 NOTICE: ADDONS: Using repository repository.libreelec.tv
15:12:17.335 T:1944736320 NOTICE: ADDONS: Using repository repository.xbmc.org
15:12:17.401 T:1944736320 NOTICE: Raspberry PI firmware version: Apr 6 2018 18:05:06
Copyright (c) 2012 Broadcom
version 6e5c0b2ea66e88157068fc38184b31a05a022892 (clean) (release)
15:12:17.401 T:1944736320 NOTICE: ARM mem: 768MB GPU mem: 256MB MPG2:0 WVC1:0
15:12:17.401 T:1944736320 NOTICE: cache.memorysize: 20MB libass.cache: 0MB
15:12:17.402 T:1944736320 NOTICE: Config:
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x33e140
desired_osc_freq_boost=0x3c45b0
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=43750
over_voltage_avs_boost=0x23186
over_voltage_sdram_p=2
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
sdram_freq=500
sdram_schmoo=0x2000020
second_boot=1
device_tree=-
15:12:17.402 T:1944736320 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 72.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 71.928070 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 75.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 72.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 71.928070 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 75.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 70.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 75.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 120.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 120.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 75.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
15:12:17.405 T:1944736320 NOTICE: Found (1920x1080@60.000000) at 45, setting to RES_DESKTOP at 16
15:12:17.405 T:1944736320 NOTICE: Checking resolution 16
15:12:17.692 T:1944736320 NOTICE: GL_VENDOR = Broadcom
15:12:17.692 T:1944736320 NOTICE: GL_RENDERER = VideoCore IV HW
15:12:17.692 T:1944736320 NOTICE: GL_VERSION = OpenGL ES 2.0
15:12:17.692 T:1944736320 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
15:12:17.692 T:1944736320 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
18:31:46.288 T:1857024928 NOTICE: Running database version Addons27
18:31:46.292 T:1857024928 NOTICE: Running database version ViewModes6
18:31:47.433 T:1815081888 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
18:31:47.492 T:1857024928 NOTICE: Running database version Textures13
18:31:47.507 T:1857024928 NOTICE: Running database version MyMusic60
18:31:47.884 T:1857024928 NOTICE: Running database version MyVideos107
18:31:47.889 T:1857024928 NOTICE: Running database version TV29
18:31:47.892 T:1857024928 NOTICE: Running database version Epg11
18:31:47.894 T:1944736320 NOTICE: start dvd mediatype detection
18:31:48.508 T:1944736320 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:31:48.938 T:1944736320 NOTICE: initialize done
18:31:48.938 T:1944736320 NOTICE: Running the application...
18:31:48.981 T:1944736320 NOTICE: starting zeroconf publishing
18:31:48.984 T:1944736320 NOTICE: CWebServer[8080]: Started
18:31:48.984 T:1944736320 NOTICE: starting upnp client
18:31:48.999 T:1616032672 NOTICE: ES: Starting UDP Event server on port 9777
18:31:48.999 T:1616032672 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
18:31:50.080 T:1759507360 ERROR: GetDirectory - Error getting /storage/.kodi/temp/plugin.video.youtube/
18:31:50.299 T:1707570080 WARNING: CSkinInfo: failed to load skin settings
18:31:54.996 T:1732244384 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:31:55.531 T:1857024928 WARNING: Previous line repeats 1 times.
18:31:55.531 T:1857024928 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/v8lKB02kw35dZYDtMU9NXuF2Hdo.jpg
18:31:56.701 T:1565946784 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:31:59.437 T:1732244384 WARNING: Previous line repeats 1 times.
18:31:59.437 T:1732244384 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/vo7oOEv1Gn0iLMFwE0dqKO8phTW.jpg
18:32:01.438 T:1740632992 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:32:01.438 T:1740632992 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/4mFhm1yu1tsfIkm3zN7zvih9ydv.jpg
18:32:01.796 T:1565946784 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:32:01.796 T:1565946784 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/5aS0FqABU3fTDTVDkQfmOcnpuZb.jpg
18:32:03.900 T:1857024928 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:32:06.640 T:1857024928 WARNING: Previous line repeats 1 times.
18:32:06.641 T:1857024928 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/ApS9EHRwfiOU0OTvaMR3nUqCCOE.jpg
18:33:42.604 T:1944736320 NOTICE: Samba is idle. Closing the remaining connections
Greets leon22
PS: ssh is also down
Posted: Wed Apr 18, 2018 3:33 pm
by LitterBugs
LitterBugs wrote: ↑Mon Apr 16, 2018 1:35 pm
At any rate, the replacement has been running on stock clocks over 24 hours now with no problems. Same SD with the same image reset to default clocking, same 2.5A power supply, Same powered USB SDR receiver, etc...
72 hours straight on the replacement hardware with no issues on stock clocking. Glad I opted to swap it out.
Regards,
LitterBug
Posted: Wed Apr 18, 2018 3:42 pm
by jamesh
LitterBugs wrote: ↑Wed Apr 18, 2018 3:33 pm
Regards,
LitterBug
Good news! Glad its better.
We have now received some of the badly behaved ones back in the office, and are testing them.
Posted: Wed Apr 18, 2018 4:41 pm
by Mig2008pt
Hope the cause of the problem is found soon... I keep watching for the news. Let us know if it will be necessary a hardware exchange or it will be fixable with software. Keep de good work, Thanks.
Posted: Wed Apr 18, 2018 5:19 pm
by e-raser
Mine can run memtester (sudo MEMTESTER_TEST_MASK=0x1000 memtester 128M) for - last try - 4 and a half hours before rebooting (default clockings).
Let it run on default clockings since this morning, quite stable.
Therefore I took a closer look to the config ==> Is this schmoo-Setting default? Didn’t rpi-update (never did on the 3 B+) and just wondering.
pi@raspberry:~$ vcgencmd get_config int
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
disable_l2cache=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_swap=1
gpu_freq=300
lcd_framerate=60
over_voltage_avs=56250
over_voltage_avs_boost=0x27ac4
overscan_bottom=16
overscan_left=24
overscan_right=24
overscan_top=16
sdram_freq=500
Posted: Wed Apr 18, 2018 8:33 pm
by jamesh
Mig2008pt wrote: ↑Wed Apr 18, 2018 4:41 pm
We expect to fix the huge huge majority with a software fix. And considering that the problem is only a small percentage of SoC's anyway, that should be almost, if not absolutely, everyone.
We did update the apt kernels etc today, so anyone with the problem might like to try an apt update/upgrade to see if any of fixes the in there help.
Posted: Wed Apr 18, 2018 8:47 pm
by that1guyrob
jamesh wrote: ↑Wed Apr 18, 2018 8:33 pm
I see a a kernel version 4.14.34 on github from 2 days ago. Is that the update that you're referring to, or have you since updated again?
I know this issue is still relatively new, but you seem confident that a software fix will resolve the issue. Would such a fix go beyond just clocking the memory or core frequency down to avoid the crashing?
- BTW, thanks for your hard work on this issue!
Posted: Thu Apr 19, 2018 6:20 am
by rodizio
Mine also is affected. Bought on 7th of April at Conrad Electronic in Germany.
Posted: Thu Apr 19, 2018 12:08 pm
by hjimbens
I just did an update with
. I also added
to /boot/config.txt so it is running with arm_freq=1200 and sdram_freq=450. It is more stable than before, but it still locks up under load (I am running an application that decodes two mpeg-dash streams and displays them using OpenGLES in addition to a news ticker).
After the last lock -up, I tried
. After an hour it is happily running at loop 41.
Posted: Thu Apr 19, 2018 12:46 pm
by Nachteule
I suppose it's the opposite. There are only a small percentage of SoC's that are working (and possible most of them are located in UK, in Cambridge) and the rest of them works instable
I got 2 Pi3B+ from different reseller/distributor and both are working instable. That means: 100% are broken
Posted: Thu Apr 19, 2018 1:11 pm
by RaTTuS
Nachteule wrote: ↑Thu Apr 19, 2018 12:46 pm
mine work fine.... even maxing out network traffic
Posted: Thu Apr 19, 2018 1:18 pm
by jamesh
Er. No. Entirely wrong. 100% of the two you have seen need some tweaks. But we've sold over 200 thousand Pi3B+. A tiny percentage are seeing problems, and its unfortunate and unlikely that you appear to have seen two. If a large percentage were seeing problems I would expect an absolute barrage of complaints, and really, that hasn't happened.
As for working ones in the UK, no , we are not wine makers - we don't keep the best stuff for internal use. The main production lines are all in the UK, and distribute the Pi's worldwide. There's no picking and choosing!
We expect that a SW fix to the shmoo setting (RAM setup) will fix the vast majority of issues for that small percentage of SoC's that are having difficulties.
Latest apt get will get 4.14.32 kernel BTW.
Posted: Thu Apr 19, 2018 1:29 pm
by that1guyrob
Glad to hear it! Thanks again for looking into this.
So this is strange, the kernel that was pulled down with apt-get was 4.14.34 You're saying that it really should have pulled down 4.14.32?
$ uname -a
Linux rpi-dev 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
Posted: Thu Apr 19, 2018 2:17 pm
by jamesh
that1guyrob wrote: ↑Thu Apr 19, 2018 1:29 pm
$ uname -a
Sorry, its 4.14.34 I believe.
Posted: Thu Apr 19, 2018 2:33 pm
by YorkshireTyke
I'm in the UK and the second RPi 3B+ I received in place of the faulty first one is also causing me problems.
So I still await a fix or a replacement (I'd gladly except just a model 3B).
Any way I'll try another apt-get update/upgrade to see what happens but I'm not holding my breath.
Posted: Thu Apr 19, 2018 2:35 pm
by jamesh
YorkshireTyke wrote: ↑Thu Apr 19, 2018 2:33 pm
Have you tried the 450 SDRAM freq setting and run memtester to exercise it?
Posted: Thu Apr 19, 2018 2:52 pm
by Catscrash
I have these issues as well, mine is locking up when running memtest after loop 7 even with 1200/450
Posted: Thu Apr 19, 2018 5:57 pm
by Nachteule
Catscrash wrote: ↑Thu Apr 19, 2018 2:52 pm
Wow, that's tough. Mine is running memtest for hours, but under real conditions I can wait for the crash
@jamesh
what is the probability that two users get two broken devices, hmmm?
Posted: Thu Apr 19, 2018 8:20 pm
by jamesh
Nachteule wrote: ↑Thu Apr 19, 2018 5:57 pm
@jamesh
Pretty low. but, and I'm guessing here, might be related to batch number of the Pi, so if you got them from the same supplier, they may be from the same batch, and that would skew the figures.
Posted: Thu Apr 19, 2018 8:46 pm
by that1guyrob
jamesh wrote: ↑Thu Apr 19, 2018 8:20 pm
@jamesh
Yeah, I was thinking the same thing. I bought 5x all at the same time from the same supplier, and 2 of the 5 exhibit this issue. Ironically, I chose that supplier because they were the only one at the time with 5+ in stock, and I could order them all at once
It's all good though, after the 4.14.34 kernel update yesterday, I ran memtester on them all for 14+ hours with no crashing, so it looks like the SDRAM freq 450 setting is an acceptable work around until the final resolution can be implemented (at least in my case).
Posted: Thu Apr 19, 2018 9:14 pm
by e-raser
e-raser wrote: ↑Wed Apr 18, 2018 5:19 pm
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
disable_l2cache=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_swap=1
gpu_freq=300
lcd_framerate=60
overscan_bottom=16
overscan_left=24
overscan_right=24
overscan_top=16
sdram_freq=500
Unfortunately no one answered this question. Anyway, after latest kernel/firmware updates (apt packages) it now looks a bit different:
aphy_params_current=819
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
disable_l2cache=1
dphy_params_current=547
force_eeprom_read=1
force_pwm_open=1
framebuffer_swap=1
gpu_freq=300
lcd_framerate=60
over_voltage_avs=50000
over_voltage_avs_boost=0x2625a
overscan_bottom=16
overscan_left=24
overscan_right=24
overscan_top=16
sdram_freq=450
==> no sdram_schmo setting anymore but sdram frequency cut down to 450.
