darksky
Raspberry Pi 3 B Plus cannot use bridge networking (systemd-networkd)... bug?
Tue Mar 20, 2018 1:21 pm
Running Arch ARM (armv7h) on a 3 B Plus and cannot get bridge networking to work (systemd-networkd). Configuring it and rebooting leads it to simple crash on the startup waiting for the network.
(1 of 2 A start job is running for CLI Netfilter Manager (9min 21s / no limit)
(2 of 2 A start job is running for Network Service (9min 21s / no limit)
If I put the exact SD card unmodified into a 3 B, it boots fine. There is something unique about the B Plus causing the issue. Can other users get bridge networking to work on their 3 B Plus?
My setup:
/etc/systemd/network/br0.netdev
[NetDev]
Name=br0
Kind=bridge
[Match]
Name=br0
/etc/systemd/network/br0.network
[Network]
DHCP=ipv4
[Match]
Name=eth0
/etc/systemd/network/uplink.network
[Network]
Bridge=br0
Attached is the complete output of journalctl which includes the crash:
% journalctl -D /mnt/var/log/journal/546b8719a1c44a32aa0ece4dbed1b8be/ -b -o short
-- Logs begin at Mon 2018-03-12 20:40:22 EDT, end at Tue 2018-03-20 09:02:14 EDT. --
Mar 12 20:40:22 pi3 kernel: Booting Linux on physical CPU 0x0
Mar 12 20:40:22 pi3 kernel: Linux version 4.14.27-1-ARCH ([email protected]) (gcc version 7.2.1 20180116 (GCC)) #1 SMP Sat Mar 17 00:45:09 UTC 2018
Mar 12 20:40:22 pi3 kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Mar 12 20:40:22 pi3 kernel: CPU: div instructions available: patching division code
Mar 12 20:40:22 pi3 kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Mar 12 20:40:22 pi3 kernel: OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
Mar 12 20:40:22 pi3 kernel: Memory policy: Data cache writealloc
Mar 12 20:40:22 pi3 kernel: cma: Reserved 8 MiB at 0x31800000
Mar 12 20:40:22 pi3 kernel: On node 0 totalpages: 204800
Mar 12 20:40:22 pi3 kernel: free_area_init_node: node 0, pgdat 80f9c180, node_mem_map b10ee000
Mar 12 20:40:22 pi3 kernel:   Normal zone: 1800 pages used for memmap
Mar 12 20:40:22 pi3 kernel:   Normal zone: 0 pages reserved
Mar 12 20:40:22 pi3 kernel:   Normal zone: 204800 pages, LIFO batch:31
Mar 12 20:40:22 pi3 kernel: random: fast init done
Mar 12 20:40:22 pi3 kernel: percpu: Embedded 17 pages/cpu @b1097000 s39564 r8192 d21876 u69632
Mar 12 20:40:22 pi3 kernel: pcpu-alloc: s39564 r8192 d21876 u69632 alloc=17*4096
Mar 12 20:40:22 pi3 kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mar 12 20:40:22 pi3 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 203000
Mar 12 20:40:22 pi3 kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  root=/dev/mmcblk0p2 rw rootwait console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyS0,115200 elevator=noop
Mar 12 20:40:22 pi3 kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Mar 12 20:40:22 pi3 kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Mar 12 20:40:22 pi3 kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Mar 12 20:40:22 pi3 kernel: Memory: 781628K/819200K available (10240K kernel code, 696K rwdata, 2636K rodata, 1024K init, 746K bss, 29380K reserved, 8192K cma-reserved)
Mar 12 20:40:22 pi3 kernel: Virtual kernel memory layout:
                                vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                vmalloc : 0xb2800000 - 0xff800000   (1232 MB)
                                lowmem  : 0x80000000 - 0xb2000000   ( 800 MB)
                                modules : 0x7f000000 - 0x80000000   (  16 MB)
                                  .text : 0x80008000 - 0x80b00000   (11232 kB)
                                  .init : 0x80e00000 - 0x80f00000   (1024 kB)
                                  .data : 0x80f00000 - 0x80fae014   ( 697 kB)
                                   .bss : 0x80fb8f04 - 0x810737d4   ( 747 kB)
Mar 12 20:40:22 pi3 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mar 12 20:40:22 pi3 kernel: Hierarchical RCU implementation.
Mar 12 20:40:22 pi3 kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Mar 12 20:40:22 pi3 kernel: arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Mar 12 20:40:22 pi3 kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Mar 12 20:40:22 pi3 kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Mar 12 20:40:22 pi3 kernel: Switching to timer-based delay loop, resolution 52ns
Mar 12 20:40:22 pi3 kernel: Console: colour dummy device 80x30
Mar 12 20:40:22 pi3 kernel: console [tty1] enabled
Mar 12 20:40:22 pi3 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Mar 12 20:40:22 pi3 kernel: pid_max: default: 32768 minimum: 301
Mar 12 20:40:22 pi3 kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mar 12 20:40:22 pi3 kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mar 12 20:40:22 pi3 kernel: Disabling memory control group subsystem
Mar 12 20:40:22 pi3 kernel: CPU: Testing write buffer coherency: ok
Mar 12 20:40:22 pi3 kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Mar 12 20:40:22 pi3 kernel: Setting up static identity map for 0x100000 - 0x100054
Mar 12 20:40:22 pi3 kernel: Hierarchical SRCU implementation.
Mar 12 20:40:22 pi3 kernel: smp: Bringing up secondary CPUs ...
Mar 12 20:40:22 pi3 kernel: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Mar 12 20:40:22 pi3 kernel: CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Mar 12 20:40:22 pi3 kernel: CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Mar 12 20:40:22 pi3 kernel: smp: Brought up 1 node, 4 CPUs
Mar 12 20:40:22 pi3 kernel: SMP: Total of 4 processors activated (153.60 BogoMIPS).
Mar 12 20:40:22 pi3 kernel: CPU: All CPU(s) started in HYP mode.
Mar 12 20:40:22 pi3 kernel: CPU: Virtualization extensions available.
Mar 12 20:40:22 pi3 kernel: devtmpfs: initialized
Mar 12 20:40:22 pi3 kernel: VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Mar 12 20:40:22 pi3 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mar 12 20:40:22 pi3 kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
Mar 12 20:40:22 pi3 kernel: xor: measuring software checksum speed
Mar 12 20:40:22 pi3 kernel:    arm4regs  :   922.800 MB/sec
Mar 12 20:40:22 pi3 kernel:    8regs     :   686.800 MB/sec
Mar 12 20:40:22 pi3 kernel:    32regs    :   662.000 MB/sec
Mar 12 20:40:22 pi3 kernel:    neon      :  1049.200 MB/sec
Mar 12 20:40:22 pi3 kernel: xor: using function: neon (1049.200 MB/sec)
Mar 12 20:40:22 pi3 kernel: pinctrl core: initialized pinctrl subsystem
Mar 12 20:40:22 pi3 kernel: NET: Registered protocol family 16
Mar 12 20:40:22 pi3 kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Mar 12 20:40:22 pi3 kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Mar 12 20:40:22 pi3 kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
Mar 12 20:40:22 pi3 kernel: Serial: AMBA PL011 UART driver
Mar 12 20:40:22 pi3 kernel: bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Mar 12 20:40:22 pi3 kernel: uart-pl011 3f201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
Mar 12 20:40:22 pi3 kernel: raid6: int32x1  gen()   103 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: int32x1  xor()    95 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: int32x2  gen()   164 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: int32x2  xor()   124 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: int32x4  gen()   169 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: int32x4  xor()   134 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: int32x8  gen()   167 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: int32x8  xor()   124 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx1   gen()   351 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx1   xor()   350 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx2   gen()   524 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx2   xor()   491 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx4   gen()   750 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx4   xor()   652 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx8   gen()   720 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: neonx8   xor()   582 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: using algorithm neonx4 gen() 750 MB/s
Mar 12 20:40:22 pi3 kernel: raid6: .... xor() 652 MB/s, rmw enabled
Mar 12 20:40:22 pi3 kernel: raid6: using neon recovery algorithm
Mar 12 20:40:22 pi3 kernel: bcm2835-dma 3f007000.dma: DMA legacy API manager at b2813000, dmachans=0x1
Mar 12 20:40:22 pi3 kernel: SCSI subsystem initialized
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver usbfs
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver hub
Mar 12 20:40:22 pi3 kernel: usbcore: registered new device driver usb
Mar 12 20:40:22 pi3 kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2018-03-16 16:17
Mar 12 20:40:22 pi3 kernel: clocksource: Switched to clocksource arch_sys_counter
Mar 12 20:40:22 pi3 kernel: VFS: Disk quotas dquot_6.6.0
Mar 12 20:40:22 pi3 kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Mar 12 20:40:22 pi3 kernel: FS-Cache: Loaded
Mar 12 20:40:22 pi3 kernel: CacheFiles: Loaded
Mar 12 20:40:22 pi3 kernel: NET: Registered protocol family 2
Mar 12 20:40:22 pi3 kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Mar 12 20:40:22 pi3 kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Mar 12 20:40:22 pi3 kernel: TCP: Hash tables configured (established 8192 bind 8192)
Mar 12 20:40:22 pi3 kernel: UDP hash table entries: 512 (order: 2, 16384 bytes)
Mar 12 20:40:22 pi3 kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Mar 12 20:40:22 pi3 kernel: RPC: Registered named UNIX socket transport module.
Mar 12 20:40:22 pi3 kernel: RPC: Registered udp transport module.
Mar 12 20:40:22 pi3 kernel: RPC: Registered tcp transport module.
Mar 12 20:40:22 pi3 kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Mar 12 20:40:22 pi3 kernel: Unpacking initramfs...
Mar 12 20:40:22 pi3 kernel: Freeing initrd memory: 5140K
Mar 12 20:40:22 pi3 kernel: hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Mar 12 20:40:22 pi3 kernel: workingset: timestamp_bits=14 max_order=18 bucket_order=4
Mar 12 20:40:22 pi3 kernel: FS-Cache: Netfs 'nfs' registered for caching
Mar 12 20:40:22 pi3 kernel: NFS: Registering the id_resolver key type
Mar 12 20:40:22 pi3 kernel: Key type id_resolver registered
Mar 12 20:40:22 pi3 kernel: Key type id_legacy registered
Mar 12 20:40:22 pi3 kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Mar 12 20:40:22 pi3 kernel: JFS: nTxBlock = 6210, nTxLock = 49685
Mar 12 20:40:22 pi3 kernel: SGI XFS with ACLs, security attributes, realtime, no debug enabled
Mar 12 20:40:22 pi3 kernel: async_tx: api initialized (async)
Mar 12 20:40:22 pi3 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Mar 12 20:40:22 pi3 kernel: io scheduler noop registered (default)
Mar 12 20:40:22 pi3 kernel: io scheduler deadline registered
Mar 12 20:40:22 pi3 kernel: io scheduler cfq registered
Mar 12 20:40:22 pi3 kernel: io scheduler mq-deadline registered
Mar 12 20:40:22 pi3 kernel: io scheduler kyber registered
Mar 12 20:40:22 pi3 kernel: io scheduler bfq registered
Mar 12 20:40:22 pi3 kernel: BCM2708FB: allocated DMA memory f1900000
Mar 12 20:40:22 pi3 kernel: BCM2708FB: allocated DMA channel 0 @ b2813000
Mar 12 20:40:22 pi3 kernel: Console: switching to colour frame buffer device 82x26
Mar 12 20:40:22 pi3 kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Mar 12 20:40:22 pi3 kernel: vc-sm: Videocore shared memory driver
Mar 12 20:40:22 pi3 kernel: gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Mar 12 20:40:22 pi3 kernel: loop: module loaded
Mar 12 20:40:22 pi3 kernel: Loading iSCSI transport class v2.0-870.
Mar 12 20:40:22 pi3 kernel: libphy: Fixed MDIO Bus: probed
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver lan78xx
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ax88179_178a
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver smsc95xx
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver cdc_ncm
Mar 12 20:40:22 pi3 kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Mar 12 20:40:22 pi3 kernel: Core Release: 2.80a
Mar 12 20:40:22 pi3 kernel: Setting default values for core params
Mar 12 20:40:22 pi3 kernel: Finished setting default values for core params
Mar 12 20:40:22 pi3 kernel: Using Buffer DMA mode
Mar 12 20:40:22 pi3 kernel: Periodic Transfer Interrupt Enhancement - disabled
Mar 12 20:40:22 pi3 kernel: Multiprocessor Interrupt Enhancement - disabled
Mar 12 20:40:22 pi3 kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Mar 12 20:40:22 pi3 kernel: Dedicated Tx FIFOs mode
Mar 12 20:40:22 pi3 kernel: WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xb1914000 dma = 0xf1914000 len=9024
Mar 12 20:40:22 pi3 kernel: FIQ FSM acceleration enabled for :
                            Non-periodic Split Transactions
                            Periodic Split Transactions
                            High-Speed Isochronous Endpoints
                            Interrupt/Control Split Transaction hack enabled
Mar 12 20:40:22 pi3 kernel: dwc_otg: Microframe scheduler enabled
Mar 12 20:40:22 pi3 kernel: WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8084f0fc
Mar 12 20:40:22 pi3 kernel: WARN::hcd_init_fiq:460: FIQ ASM at 0x8084f474 length 36
Mar 12 20:40:22 pi3 kernel: WARN::hcd_init_fiq:486: MPHI regs_base at 0xb2bd1000
Mar 12 20:40:22 pi3 kernel: dwc_otg 3f980000.usb: DWC OTG Controller
Mar 12 20:40:22 pi3 kernel: dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Mar 12 20:40:22 pi3 kernel: dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
Mar 12 20:40:22 pi3 kernel: Init: Port Power? op_state=1
Mar 12 20:40:22 pi3 kernel: Init: Power Port (0)
Mar 12 20:40:22 pi3 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Mar 12 20:40:22 pi3 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 12 20:40:22 pi3 kernel: usb usb1: Product: DWC OTG Controller
Mar 12 20:40:22 pi3 kernel: usb usb1: Manufacturer: Linux 4.14.27-1-ARCH dwc_otg_hcd
Mar 12 20:40:22 pi3 kernel: usb usb1: SerialNumber: 3f980000.usb
Mar 12 20:40:22 pi3 kernel: hub 1-0:1.0: USB hub found
Mar 12 20:40:22 pi3 kernel: hub 1-0:1.0: 1 port detected
Mar 12 20:40:22 pi3 kernel: dwc_otg: FIQ enabled
Mar 12 20:40:22 pi3 kernel: dwc_otg: NAK holdoff enabled
Mar 12 20:40:22 pi3 kernel: dwc_otg: FIQ split-transaction FSM enabled
Mar 12 20:40:22 pi3 kernel: Module dwc_common_port init
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver uas
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver usb-storage
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-alauda
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-cypress
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-datafab
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums_eneub6250
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-freecom
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-isd200
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-jumpshot
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-karma
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-onetouch
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-realtek
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-sddr09
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-sddr55
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver ums-usbat
Mar 12 20:40:22 pi3 kernel: mousedev: PS/2 mouse device common for all mice
Mar 12 20:40:22 pi3 kernel: bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
Mar 12 20:40:22 pi3 kernel: device-mapper: uevent: version 1.0.3
Mar 12 20:40:22 pi3 kernel: device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: [email protected]
Mar 12 20:40:22 pi3 kernel: device-mapper: multipath round-robin: version 1.2.0 loaded
Mar 12 20:40:22 pi3 kernel: device-mapper: multipath queue-length: version 0.2.0 loaded
Mar 12 20:40:22 pi3 kernel: device-mapper: multipath service-time: version 0.3.0 loaded
Mar 12 20:40:22 pi3 kernel: device-mapper: raid: Loading target version 1.13.0
Mar 12 20:40:22 pi3 kernel: bcm2835-cpufreq: min=600000 max=1400000
Mar 12 20:40:22 pi3 kernel: sdhci: Secure Digital Host Controller Interface driver
Mar 12 20:40:22 pi3 kernel: sdhci: Copyright(c) Pierre Ossman
Mar 12 20:40:22 pi3 kernel: mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
Mar 12 20:40:22 pi3 kernel: sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Mar 12 20:40:22 pi3 kernel: Error: Driver 'sdhost-bcm2835' is already registered, aborting...
Mar 12 20:40:22 pi3 kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Mar 12 20:40:22 pi3 kernel: ledtrig-cpu: registered to indicate activity on CPUs
Mar 12 20:40:22 pi3 kernel: hidraw: raw HID events driver (C) Jiri Kosina
Mar 12 20:40:22 pi3 kernel: usbcore: registered new interface driver usbhid
Mar 12 20:40:22 pi3 kernel: usbhid: USB HID core driver
Mar 12 20:40:22 pi3 kernel: vchiq: vchiq_init_state: slot_zero = b1980000, is_master = 0
Mar 12 20:40:22 pi3 kernel: [vc_sm_connected_init]: start
Mar 12 20:40:22 pi3 kernel: [vc_sm_connected_init]: end - returning 0
Mar 12 20:40:22 pi3 kernel: Initializing XFRM netlink socket
Mar 12 20:40:22 pi3 kernel: NET: Registered protocol family 17
Mar 12 20:40:22 pi3 kernel: Key type dns_resolver registered
Mar 12 20:40:22 pi3 kernel: Registering SWP/SWPB emulation handler
Mar 12 20:40:22 pi3 kernel: registered taskstats version 1
Mar 12 20:40:22 pi3 kernel: Btrfs loaded, crc32c=crc32c-generic
Mar 12 20:40:22 pi3 kernel: Key type encrypted registered
Mar 12 20:40:22 pi3 kernel: uart-pl011 3f201000.serial: cts_event_workaround enabled
Mar 12 20:40:22 pi3 kernel: 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
Mar 12 20:40:22 pi3 kernel: mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
Mar 12 20:40:22 pi3 kernel: mmc-bcm2835 3f300000.mmc: DMA channel allocated
Mar 12 20:40:22 pi3 kernel: sdhost: log_buf @ b1913000 (f1913000)
Mar 12 20:40:22 pi3 kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Mar 12 20:40:22 pi3 kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 12 20:40:22 pi3 kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Mar 12 20:40:22 pi3 kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Mar 12 20:40:22 pi3 kernel: of_cfs_init
Mar 12 20:40:22 pi3 kernel: of_cfs_init: OK
Mar 12 20:40:22 pi3 kernel: Freeing unused kernel memory: 1024K
Mar 12 20:40:22 pi3 kernel: Indeed it is in host mode hprt0 = 00021501
Mar 12 20:40:22 pi3 kernel: mmc1: new high speed SDIO card at address 0001
Mar 12 20:40:22 pi3 kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Mar 12 20:40:22 pi3 kernel: mmc0: new high speed SDHC card at address aaaa
Mar 12 20:40:22 pi3 kernel: mmcblk0: mmc0:aaaa AFGCD 29.7 GiB
Mar 12 20:40:22 pi3 kernel:  mmcblk0: p1 p2 p3
Mar 12 20:40:22 pi3 kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
Mar 12 20:40:22 pi3 kernel: Indeed it is in host mode hprt0 = 00001101
Mar 12 20:40:22 pi3 kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=2514
Mar 12 20:40:22 pi3 kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 12 20:40:22 pi3 kernel: hub 1-1:1.0: USB hub found
Mar 12 20:40:22 pi3 kernel: hub 1-1:1.0: 4 ports detected
Mar 12 20:40:22 pi3 kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Mar 12 20:40:22 pi3 kernel: usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Mar 12 20:40:22 pi3 kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
Mar 12 20:40:22 pi3 kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 12 20:40:22 pi3 kernel: hub 1-1.1:1.0: USB hub found
Mar 12 20:40:22 pi3 kernel: hub 1-1.1:1.0: 3 ports detected
Mar 12 20:40:22 pi3 kernel: dwc_otg_handle_wakeup_detected_intr lxstate = 2
Mar 12 20:40:22 pi3 systemd[1]: System time before build time, advancing clock.
Mar 12 20:40:22 pi3 kernel: NET: Registered protocol family 10
Mar 12 20:40:22 pi3 kernel: Segment Routing with IPv6
Mar 12 20:40:22 pi3 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Mar 12 20:40:22 pi3 systemd[1]: systemd 238 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN +PCRE2 default-hierarchy=hybrid)
Mar 12 20:40:22 pi3 systemd[1]: Detected architecture arm.
Mar 12 20:40:22 pi3 systemd[1]: Set hostname to <pi3>.
Mar 12 20:40:22 pi3 kernel: usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
Mar 12 20:40:22 pi3 systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Mar 12 20:40:22 pi3 systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Mar 12 20:40:22 pi3 systemd[1]: Listening on Process Core Dump Socket.
Mar 12 20:40:22 pi3 systemd[1]: Listening on Device-mapper event daemon FIFOs.
Mar 12 20:40:22 pi3 systemd[1]: Listening on Journal Socket.
Mar 12 20:40:22 pi3 systemd[1]: Starting Create list of required static device nodes for the current kernel...
Mar 12 20:40:22 pi3 systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 12 20:40:22 pi3 kernel: usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
Mar 12 20:40:22 pi3 kernel: usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 12 20:40:22 pi3 kernel: snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Mar 12 20:40:22 pi3 systemd-journald[200]: Journal started
Mar 12 20:40:22 pi3 systemd-journald[200]: Runtime journal (/run/log/journal/546b8719a1c44a32aa0ece4dbed1b8be) is 4.8M, max 38.8M, 34.0M free.
Mar 12 20:40:22 pi3 systemd-modules-load[195]: Inserted module 'snd_bcm2835'
Mar 12 20:40:22 pi3 systemd[1]: Started Load Kernel Modules.
Mar 12 20:40:22 pi3 systemd[1]: Mounting Kernel Configuration File System...
Mar 12 20:40:22 pi3 systemd[1]: Starting Apply Kernel Variables...
Mar 12 20:40:22 pi3 systemd[1]: Starting Flush Journal to Persistent Storage...
Mar 12 20:40:22 pi3 systemd[1]: Started Load/Save Random Seed.
Mar 12 20:40:22 pi3 systemd[1]: Mounted Kernel Configuration File System.
Mar 12 20:40:22 pi3 systemd-journald[200]: Time spent on flushing to /var is 14.137ms for 275 entries.
Mar 12 20:40:22 pi3 systemd-journald[200]: System journal (/var/log/journal/546b8719a1c44a32aa0ece4dbed1b8be) is 40.0M, max 2.7G, 2.7G free.
Mar 12 20:40:23 pi3 kernel: libphy: lan78xx-mdiobus: probed
Mar 12 20:40:22 pi3 systemd[1]: Started Apply Kernel Variables.
Mar 12 20:40:22 pi3 systemd[1]: Starting CLI Netfilter Manager...
Mar 12 20:40:22 pi3 systemd[1]: Started udev Coldplug all Devices.
Mar 12 20:40:22 pi3 systemd[1]: Started Create System Users.
Mar 12 20:40:22 pi3 systemd[1]: Starting Create Static Device Nodes in /dev...
Mar 12 20:40:23 pi3 systemd[1]: Started Create Static Device Nodes in /dev.
Mar 12 20:40:23 pi3 systemd[1]: Starting udev Kernel Device Manager...
Mar 12 20:40:23 pi3 systemd[1]: Reached target Local File Systems (Pre).
Mar 12 20:40:23 pi3 systemd[1]: Started Flush Journal to Persistent Storage.
Mar 12 20:40:23 pi3 systemd[1]: Started udev Kernel Device Manager.
Mar 12 20:40:23 pi3 systemd[1]: Starting Network Service...
Mar 12 20:40:23 pi3 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mar 12 20:40:23 pi3 systemd-udevd[233]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Mar 12 20:40:23 pi3 kernel: bcm2835-rng 3f104000.rng: hwrng registered
Mar 12 20:40:23 pi3 kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Mar 12 20:40:23 pi3 kernel: nf_conntrack version 0.5.0 (13312 buckets, 53248 max)
Mar 12 20:40:23 pi3 systemd-udevd[235]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Mar 12 20:40:23 pi3 systemd-networkd[222]: br0: netdev ready
Mar 12 20:40:23 pi3 systemd-networkd[222]: Enumeration completed
Mar 12 20:40:23 pi3 systemd[1]: Started Network Service.
Mar 12 20:40:23 pi3 systemd-networkd[222]: lo: Removing non-existent address: ::1/128 (valid forever), ignoring
Mar 12 20:40:23 pi3 systemd-networkd[222]: eth0: Link is not managed by us
Mar 12 20:40:23 pi3 systemd-networkd[222]: lo: Link is not managed by us
Mar 12 20:40:23 pi3 systemd-networkd[222]: br0: IPv6 successfully enabled
Mar 12 20:40:23 pi3 kernel: IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready
Mar 12 20:40:23 pi3 systemd-udevd[225]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Mar 12 20:40:23 pi3 kernel: Unable to handle kernel NULL pointer dereference at virtual address 00000208
Mar 12 20:40:23 pi3 kernel: pgd = afda0000
Mar 12 20:40:23 pi3 kernel: [00000208] *pgd=00000000
Mar 12 20:40:23 pi3 kernel: Internal error: Oops: 5 [#1] SMP ARM
Mar 12 20:40:23 pi3 kernel: Modules linked in: nf_conntrack_netbios_ns nf_conntrack_broadcast nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack bridge bcm2835_rng stp llc rng_core fixed uio_pdrv_genirq uio iptable_filter sch_fq_codel snd_bcm2835(C) snd_pcm snd_timer snd ip_tables x_tables ipv6
Mar 12 20:40:23 pi3 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Mar 12 20:40:23 pi3 kernel: CPU: 3 PID: 222 Comm: systemd-network Tainted: G         C      4.14.27-1-ARCH #1
Mar 12 20:40:23 pi3 kernel: Hardware name: BCM2835
Mar 12 20:40:23 pi3 kernel: task: ae3f8f00 task.stack: b0ba8000
Mar 12 20:40:23 pi3 kernel: PC is at phy_ethtool_ksettings_get+0x10/0x84
Mar 12 20:40:23 pi3 kernel: LR is at lan78xx_get_link_ksettings+0x2c/0x3c
Mar 12 20:40:23 pi3 kernel: pc : [<807fa160>]    lr : [<80801bc0>]    psr: 60010013
Mar 12 20:40:23 pi3 kernel: sp : b0ba9b40  ip : add9a0c0  fp : 80f915c0
Mar 12 20:40:23 pi3 kernel: r10: ae4bb510  r9 : 00000001  r8 : 81030958
Mar 12 20:40:23 pi3 kernel: r7 : b0ba9bac  r6 : 00000000  r5 : 00000000  r4 : b0ba9bac
Mar 12 20:40:23 pi3 kernel: r3 : add9a194  r2 : 00000001  r1 : b0ba9bac  r0 : b0ba9bdc
Mar 12 20:40:23 pi3 kernel: Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Mar 12 20:40:23 pi3 kernel: Control: 10c5383d  Table: 2fda006a  DAC: 00000055
Mar 12 20:40:23 pi3 kernel: Process systemd-network (pid: 222, stack limit = 0xb0ba8210)
Mar 12 20:40:23 pi3 kernel: Stack: (0xb0ba9b40 to 0xb0baa000)
Mar 12 20:40:23 pi3 kernel: 9b40: b0ac5000 00000000 00000000 80801bc0 b0ac5000 80f03d08 b0ba9bac b0887540
Mar 12 20:40:23 pi3 kernel: 9b60: 81030958 80982a74 00000000 000000bb 00000000 b10d30b8 01d3d18c 00000000
Mar 12 20:40:23 pi3 kernel: 9b80: 01d3d18c 00000000 b09e3c80 a04d4479 00000000 64585035 80f03d08 b0ac5000
Mar 12 20:40:23 pi3 kernel: 9ba0: b0ac5000 7f1835fc 000000a2 00000000 00000000 00000000 00000000 00000000
Mar 12 20:40:23 pi3 kernel: 9bc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Mar 12 20:40:23 pi3 kernel: 9be0: 00000000 00000000 00000000 00000000 00000000 64585035 81030958 ae502600
Mar 12 20:40:23 pi3 kernel: 9c00: adcb1880 7f183e40 b0ac5000 b0ba9cc0 00000000 80f03d08 adc08000 b0ba9d74
Mar 12 20:40:23 pi3 kernel: 9c20: ae4bb510 80990f28 b0ba9c74 801599a8 00000001 80b6a05c b0ba9df4 00000000
Mar 12 20:40:23 pi3 kernel: 9c40: b10b1080 adc5da00 00000004 64585035 000f4240 b10d5c00 ae3854b8 00000000
Mar 12 20:40:23 pi3 kernel: 9c60: 00000003 00000003 80fb9d48 80f0419c b0804200 801471a0 ae4bb520 00000008
Mar 12 20:40:23 pi3 kernel: 9c80: 0000002c 64585035 b0ba9cc0 ae4bb500 80f03d08 adc08000 b0ba9df4 b0ac5000
Mar 12 20:40:24 pi3 kernel: 9ca0: adc08000 b0ba9df4 80f915c0 80991704 b0ba9cc0 b0ba9d74 00000000 00000000
Mar 12 20:40:24 pi3 kernel: 9cc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Mar 12 20:40:24 pi3 kernel: 9ce0: 00000000 00000000 ae4bb520 00000000 00000000 00000000 00000000 00000000
Mar 12 20:40:24 pi3 kernel: 9d00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Mar 12 20:40:24 pi3 kernel: 9d20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Mar 12 20:40:24 pi3 kernel: 9d40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Mar 12 20:40:24 pi3 kernel: 9d60: 00000000 00000000 00000000 00000000 00000000 64585000 80f03d08 b0221440
Mar 12 20:40:24 pi3 kernel: 9d80: 00000000 64585035 8106bacc 00000003 ae4bb500 00000024 80f03d08 809903f4
Mar 12 20:40:24 pi3 kernel: 9da0: 00000000 b0ba9db0 00000040 b0221440 b0157548 64585035 b0155aa0 80f03d08
Mar 12 20:40:24 pi3 kernel: 9dc0: ffff0000 64585035 b0ba9e80 adc08000 809901dc 80f03d08 ae4bb500 b0ba9e30
Mar 12 20:40:24 pi3 kernel: 9de0: 00000000 80f03d08 00000028 809b720c 00000000 00000000 00000000 00000000
Mar 12 20:40:24 pi3 kernel: 9e00: 00000000 00000000 00000000 00000000 00000000 64585035 b0ba9e30 b0a48000
Mar 12 20:40:24 pi3 kernel: 9e20: 00000001 ad852c00 adc08000 809b694c 7fffffff 64585035 00000000 b0ba9edc
Mar 12 20:40:24 pi3 kernel: 9e40: ad852c00 80f03d08 adc08000 014000c0 00000000 00000028 00000000 809b6e38
Mar 12 20:40:24 pi3 kernel: 9e60: b0b96780 801d7654 b0ba9eb8 01836c60 00000028 00000008 ae1d9c80 00000000
Mar 12 20:40:24 pi3 kernel: 9e80: 000000de 000000c1 000000c1 64585035 80f03d08 00000000 00000000 80f03d08
Mar 12 20:40:24 pi3 kernel: 9ea0: b0204700 80107ec4 b0ba8000 00000080 01832b20 8095bd28 00000000 8095ceec
Mar 12 20:40:24 pi3 kernel: 9ec0: b0ba9ee4 64585035 ffffe000 00000000 00000000 01836c60 00000028 b0ba9f0c
Mar 12 20:40:24 pi3 kernel: 9ee0: 00000010 00000001 00000000 00000000 b0ba9edc 00000000 b0221490 00000000
Mar 12 20:40:24 pi3 kernel: 9f00: 00000000 00000000 b0221490 00000010 00000000 00000000 00000000 b0221440
Mar 12 20:40:24 pi3 kernel: 9f20: b0155aa0 00000008 b0155af0 00080040 00080060 802ba174 b0ba9f74 00000000
Mar 12 20:40:24 pi3 kernel: 9f40: ffffff9c ae48ae80 00000000 ffffff9c 76f54b70 00000000 00000000 8029e298
Mar 12 20:40:24 pi3 kernel: 9f60: 00000000 00000001 00000002 64585035 b0ba9e5c ffffe000 b0ba9fb0 00000000
Mar 12 20:40:24 pi3 kernel: 9f80: 00000122 80107ec4 b0ba8000 64585035 7eee0984 7eee0984 00000010 00000000
Mar 12 20:40:24 pi3 kernel: 9fa0: 00000122 80107e90 7eee0984 00000010 00000003 01836c60 00000028 00000000
Mar 12 20:40:24 pi3 kernel: 9fc0: 7eee0984 00000010 00000000 00000122 000000de 00000000 004c35c4 01832b20
Mar 12 20:40:24 pi3 kernel: 9fe0: 00000000 7eee0960 76efeea8 76dcf5bc 60010010 00000003 0a0000b1 e51f1784
Mar 12 20:40:24 pi3 kernel: [<807fa160>] (phy_ethtool_ksettings_get) from [<80801bc0>] (lan78xx_get_link_ksettings+0x2c/0x3c)
Mar 12 20:40:24 pi3 kernel: [<80801bc0>] (lan78xx_get_link_ksettings) from [<80982a74>] (__ethtool_get_link_ksettings+0xbc/0xf8)
Mar 12 20:40:24 pi3 kernel: [<80982a74>] (__ethtool_get_link_ksettings) from [<7f1835fc>] (port_cost+0x20/0x94 [bridge])
Mar 12 20:40:24 pi3 kernel: [<7f1835fc>] (port_cost [bridge]) from [<7f183e40>] (br_add_if+0x158/0x5a8 [bridge])
Mar 12 20:40:24 pi3 kernel: [<7f183e40>] (br_add_if [bridge]) from [<80990f28>] (do_setlink+0x300/0x9fc)
Mar 12 20:40:24 pi3 kernel: [<80990f28>] (do_setlink) from [<80991704>] (rtnl_setlink+0xe0/0x138)
Mar 12 20:40:24 pi3 kernel: [<80991704>] (rtnl_setlink) from [<809903f4>] (rtnetlink_rcv_msg+0x218/0x294)
Mar 12 20:40:24 pi3 kernel: [<809903f4>] (rtnetlink_rcv_msg) from [<809b720c>] (netlink_rcv_skb+0xa8/0x104)
Mar 12 20:40:24 pi3 kernel: [<809b720c>] (netlink_rcv_skb) from [<809b694c>] (netlink_unicast+0x198/0x26c)
Mar 12 20:40:24 pi3 kernel: [<809b694c>] (netlink_unicast) from [<809b6e38>] (netlink_sendmsg+0x34c/0x390)
Mar 12 20:40:24 pi3 kernel: [<809b6e38>] (netlink_sendmsg) from [<8095bd28>] (sock_sendmsg+0x14/0x24)
Mar 12 20:40:24 pi3 kernel: [<8095bd28>] (sock_sendmsg) from [<8095ceec>] (SyS_sendto+0x94/0x108)
Mar 12 20:40:24 pi3 kernel: [<8095ceec>] (SyS_sendto) from [<80107e90>] (__sys_trace_return+0x0/0x10)
Mar 12 20:40:24 pi3 kernel: Code: e92d4070 e1a05000 e1a04001 e2810030 (e5951208)
Mar 12 20:40:24 pi3 kernel: ---[ end trace a5328c8443430fdc ]---
Mar 12 20:40:24 pi3 kernel: Bluetooth: Core ver 2.22
Mar 12 20:40:24 pi3 kernel: NET: Registered protocol family 31
Mar 12 20:40:24 pi3 kernel: Bluetooth: HCI device and connection manager initialized
Mar 12 20:40:24 pi3 kernel: Bluetooth: HCI socket layer initialized
Mar 12 20:40:24 pi3 kernel: Bluetooth: L2CAP socket layer initialized
Mar 12 20:40:24 pi3 kernel: Bluetooth: SCO socket layer initialized
Mar 12 20:40:24 pi3 kernel: Bluetooth: Generic Bluetooth SDIO driver ver 0.1
Mar 12 20:40:24 pi3 kernel: random: crng init done
Mar 12 20:40:24 pi3 kernel: Adding 1191420k swap on /dev/mmcblk0p3.  Priority:-2 extents:1 across:1191420k SSFS
Mar 12 20:40:23 pi3 systemd[1]: systemd-networkd.service: Main process exited, code=killed, status=11/SEGV
Mar 12 20:40:23 pi3 systemd[1]: systemd-networkd.service: Failed with result 'signal'.
Mar 12 20:40:23 pi3 systemd[1]: systemd-networkd.service: Service has no hold-off time, scheduling restart.
Mar 12 20:40:23 pi3 systemd[1]: systemd-networkd.service: Scheduled restart job, restart counter is at 1.
Mar 12 20:40:23 pi3 systemd[1]: Stopped Network Service.
Mar 12 20:40:23 pi3 systemd[1]: Found device /dev/mmcblk0p1.
Mar 12 20:40:23 pi3 systemd[1]: Found device /dev/mmcblk0p3.
Mar 12 20:40:23 pi3 systemd[1]: Reached target Bluetooth.
Mar 12 20:40:23 pi3 systemd[1]: Activating swap /dev/mmcblk0p3...
Mar 12 20:40:23 pi3 systemd[1]: Mounting /boot...
Mar 12 20:40:23 pi3 systemd[1]: Starting Load/Save RF Kill Switch Status...
Mar 12 20:40:23 pi3 systemd[1]: Activated swap /dev/mmcblk0p3.
Mar 12 20:40:23 pi3 systemd[1]: Started Load/Save RF Kill Switch Status.
Mar 12 20:40:23 pi3 systemd[1]: Reached target Swap.
Mar 12 20:40:23 pi3 systemd[1]: Mounting /scratch...
Mar 12 20:40:23 pi3 systemd[1]: Mounting Temporary Directory (/tmp)...
Mar 12 20:40:23 pi3 systemd[1]: Mounted /scratch.
Mar 12 20:40:23 pi3 systemd[1]: Mounted Temporary Directory (/tmp).
Mar 12 20:40:23 pi3 systemd[1]: Mounted /boot.
Mar 12 20:40:23 pi3 systemd[1]: Reached target Local File Systems.
Mar 12 20:40:23 pi3 systemd[1]: Starting Rebuild Dynamic Linker Cache...
Mar 12 20:40:23 pi3 systemd[1]: Starting Rebuild Journal Catalog...
Mar 12 20:40:23 pi3 systemd[1]: Starting Create Volatile Files and Directories...
Mar 12 20:40:24 pi3 systemd[1]: Started Create Volatile Files and Directories.
Mar 12 20:40:24 pi3 systemd[1]: Starting Network Time Synchronization...
Mar 12 20:40:24 pi3 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Mar 12 20:40:24 pi3 systemd[1]: Started Rebuild Journal Catalog.
Mar 12 20:40:24 pi3 systemd[1]: Started Update UTMP about System Boot/Shutdown.
Mar 12 20:40:24 pi3 systemd[1]: Started Rebuild Dynamic Linker Cache.
Mar 12 20:40:24 pi3 systemd[1]: Starting Update is Completed...
Mar 12 20:40:24 pi3 systemd[1]: Started Update is Completed.
Mar 12 20:40:24 pi3 systemd-timesyncd[284]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2018-03-20 08:54:44 EDT
Mar 20 08:54:44 pi3 systemd[1]: Started Network Time Synchronization.
Mar 20 08:54:44 pi3 systemd[1]: Reached target System Time Synchronized.
Mar 20 08:56:13 pi3 systemd[1]: systemd-networkd.service: Start operation timed out. Terminating.
Mar 20 08:57:44 pi3 systemd[1]: systemd-networkd.service: State 'stop-sigterm' timed out. Killing.
Mar 20 08:57:44 pi3 systemd[1]: systemd-networkd.service: Killing process 249 (systemd-network) with signal SIGKILL.
Mar 20 08:59:14 pi3 systemd[1]: systemd-networkd.service: Processes still around after SIGKILL. Ignoring.
Mar 20 09:00:44 pi3 systemd[1]: systemd-networkd.service: State 'stop-final-sigterm' timed out. Killing.
Mar 20 09:00:44 pi3 systemd[1]: systemd-networkd.service: Killing process 249 (systemd-network) with signal SIGKILL.
Mar 20 09:02:14 pi3 systemd[1]: systemd-networkd.service: Processes still around after final SIGKILL. Entering failed mode.
Mar 20 09:02:14 pi3 systemd[1]: systemd-networkd.service: Failed with result 'timeout'.
Mar 20 09:02:14 pi3 systemd[1]: Failed to start Network Service.
Mar 20 09:02:14 pi3 systemd[1]: systemd-networkd.service: Service has no hold-off time, scheduling restart.
Mar 20 09:02:14 pi3 systemd[1]: systemd-networkd.service: Scheduled restart job, restart counter is at 2.
Mar 20 09:02:14 pi3 systemd[1]: Stopped Network Service.
Mar 20 09:02:14 pi3 systemd[1]: systemd-networkd.service: Found left-over process 249 (systemd-network) in control group while starting unit. Ignoring.
Mar 20 09:02:14 pi3 systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Mar 20 09:02:14 pi3 systemd[1]: Starting Network Service...
SurferTim
Re: Raspberry Pi 3 B Plus cannot use bridge networking (systemd-networkd)... bug?
Tue Mar 20, 2018 1:28 pm
Which interfaces are you trying to bridge?
darksky
Tue Mar 20, 2018 1:31 pm
See my config files above. I am not actually connecting anything to the bridge at the point of the error (I do this later with a linux container).
wildfire
Tue Mar 20, 2018 3:06 pm
Stick with the 3B until Arch updates itself to the nuances of the 3B+
Scotty never said "I canae give her any more Captain, She'll blow".
B'Elanna Torres however did say "Get the cheese to the sickbay" :?:
darksky
Tue Mar 20, 2018 3:29 pm
Are you thinking of a specific package that needs to be updated or is your advice of a general nature? Arch is pretty "fresh" with regard to upstream versions.
wildfire
Tue Mar 20, 2018 3:39 pm
The 3B+ requires new firmware particularly regarding networking and power, your 64bit OS may have not caught up yet.
darksky
Tue Mar 20, 2018 3:51 pm
The firmware package was updated 2 days ago. I think it's in sync with upstream. Also, I am not running the 64-bit version (called aarch64), it is the 32-bit version (called armv7h).
burtyb
Tue Mar 20, 2018 4:29 pm
I had the same problem whilst updating Cluster HAT images (Based on Raspbian) and opened an issue a few days ago (https://github.com/raspberrypi/linux/issues/2437).
darksky
Tue Mar 20, 2018 5:20 pm
Thanks for the link; glad it's not just me. Let's see if upstream can fix it.
darksky
Thu Mar 22, 2018 11:17 pm
I tried building 4.14.29 with the patch pelwell mentioned but it does not fix the issue.
