Pi 3 b+ with official supply refusing to boot and power led blinking
Posted: Mon Mar 19, 2018 8:28 pm
by AforAlex
Hi, I purchased the official raspberrypi power supply about a month ago and using perfectly well with the previous model of pi (pi 3 model b?... The one before the b+). I've tried the same sd card and same powersupply (official raspberrypi supply for pihut) and instead of booting all I get is the rainbow screen with a lighting logo in top right of screen and the red led light flashes.
The sd card has noobs installed along with openelec and rasbian (now updated to latest version) but the pi still refuses to boot.
Just wondering if others have had problems with the new pi 3 b+ model and the official supply?
Could it be that I either have an underpowered official supply or a rare defective pi 3b+?
Im willing to buy a new supply if that really is the issue but having got the official supply so recently I am assuming that it would be good enough to supply the power needs of the 3b+.
Could it be something else that I'm missing? Should I give cpc a shout about getting the 3b+ replaced?
Many thanks in advance to anyone that can offer any help with troubleshooting or if have had problems also.
Alex
Re: Pi 3 b+ with official supply refusing to boot and power led blinking
Posted: Mon Mar 19, 2018 8:44 pm
by davidcoton
Did you also update NOOBS to the latest (2.7.0 IIRC) version?
(Sorry I'm not a NOOBS user and don't know offhand how to do that.)
Posted: Mon Mar 19, 2018 9:01 pm
by AforAlex
Thanks, I've been doing some reading, and I think some of the sticky posts on the part have been updated since the last time I read, apparently the problem with stuck on the rainbow screen and lighting symbol is pointing at an issue with the version of the booting OS, in this case noobs, going to give that an update (never done before but sure can find some instructions).
Think this issue can be marked as probably solved. Many thanks
Posted: Mon Mar 19, 2018 9:06 pm
by davidcoton
You do that yourself. Edit your OP and add "[Solved]" to the title. Best to wait til you know that the fix worked, though 8-) :idea:
Posted: Mon Mar 19, 2018 10:09 pm
by AforAlex
Cheers, will do. Just trying to figure out how to get access to the recovery partition to noobs so can copy the updated files over. Noobs don't half make it tricky to update itself 😲 will edit once got it sorted, failed to find the partition under Ubuntu so going to try under windows tomorrow at work and see if fair any better.
Cheers
Posted: Mon Mar 19, 2018 10:48 pm
by HiassofT
We (LibreELEC) received several similar bug reports and I could reproduce the issue with old NOOBS versions on an RPi3B+.
I, too, had problems finding instructions how to officially update NOOBS. What finally worked for me (with an initial NOOBS 2.4.5 installation) were the infos buried in this pihut blog post: https://thepihut.com/blogs/raspberry-pi ... berry-pi-2
I've also posted instructions on how to do that from within LibreELEC here: https://forum.libreelec.tv/thread/11929 ... #post84991
But please keep in mind that I only did a quick test with a single NOOBS version and I can't guarantee this'll also work for your NOOBS version. If in doubt better contact the NOOBS developers and ask them about the official instructions how to update NOOBS. It could well be that official upgrades instructions are already published and I just didn't find them.
so long,
Hias
