mikefromsweden
SimpleCV problem
Mon Mar 19, 2018 6:00 pm
Hi everyone!
I have followed this https://www.open-electronics.org/comput ... pi-module/ and everything is installed but when I try to run simpleCV this is the output:
[email protected]:~ $ simplecv
/home/pi/.local/lib/python2.7/site-packages/IPython/config.py:13: ShimWarning: The `IPython.config` package has been deprecated since IPython 4.0. You should import from traitlets.config instead.
  "You should import from traitlets.config instead.", ShimWarning)
/home/pi/.local/lib/python2.7/site-packages/IPython/frontend.py:21: ShimWarning: The top-level `frontend` package has been deprecated since IPython 1.0. All its subpackages have been moved to the top `IPython` level.
  "All its subpackages have been moved to the top `IPython` level.", ShimWarning)
/home/pi/.local/lib/python2.7/site-packages/IPython/core/interactiveshell.py:449: UserWarning: As of IPython 5.0 `PromptManager` config will have no effect and has been replaced by TerminalInteractiveShell.prompts_class
  warn('As of IPython 5.0 `PromptManager` config will have no effect'
AttributeError                            Traceback (most recent call last)
/usr/local/bin/simplecv in <module>()
      9     sys.argv[0] = re.sub(r'(-script\.pyw?|\.exe)?$', '', sys.argv[0])
     10     sys.exit(
---> 11         load_entry_point('SimpleCV', 'console_scripts', 'simplecv')()
     12     )
/home/pi/.local/lib/python2.7/site-packages/SimpleCV/Shell/Shell.pyc in main(*args)
    255     init_logging(log_level)
    256     shellclear()
--> 257     scvShell = run_shell(interface)
/home/pi/.local/lib/python2.7/site-packages/SimpleCV/Shell/Shell.pyc in run_shell(shell)
    213     for shell in available_shells:
    214         try:
--> 215             return globals()[shell]()
    216         except ImportError:
    217             pass
/home/pi/.local/lib/python2.7/site-packages/SimpleCV/Shell/Shell.pyc in setup_ipython()
    125         scvShell = InteractiveShellEmbed(config=cfg, banner1=banner,
    126                                          exit_msg=exit_msg)
--> 127         scvShell.define_magic("tutorial", magic_tutorial)
    128         scvShell.define_magic("clear", magic_clear)
    129         scvShell.define_magic("example", magic_examples)
AttributeError: 'InteractiveShellEmbed' object has no attribute 'define_magic'
I tried to search this forum and tried Google but with no result or I didn't understand what to do.
What is wrong and how do I solve it?
Antiklesys
Re: SimpleCV problem
Sun Oct 21, 2018 1:15 pm
You can resolve this by doing:
sudo nano ./usr/local/lib/python2.7/dist-packages/SimpleCV/Shell/Shell.py
Around line 50 change
from IPython.config.loader import Config
to
from traitlets.config.loader import Config
Around line 51, change
from IPython.frontend.terminal.embed import InteractiveShellEmbed
to
from IPython.terminal.embed import InteractiveShellEmbed
and save the file with the changes.
Then run the following command: pip install IPython==4.2 --user
This will fix all these issues.
mikefromsweden
Mon Oct 22, 2018 9:07 am
Thank you Antiklesys!
I'll try that as soon as I have some free time.
ecoflex
Sat Nov 24, 2018 5:49 am
Yes, reinstalling ipython to v4.2 solved my problem exactly!!! THX!!!
