Sun Mar 18, 2018 10:59 am
Your pi should not be attempting to connect to the previous LAN connection address , even if you have set a static IP on the pi it will not attempt to connect until you connect it via a cable to a network.
you will get a default address 169.254.x.x range , if in fact your pi is trying to connect to the 172.16.10.80 then you may have a corrupted SD card.
I would try another SD card with the latest raspbian stretch image and see what happens then.
