Wizardling
Contact: ICQ Yahoo Messenger AOL
Update error: "E: Sub-process /usr/bin/dpkg returned an error code (1)"
Tue Mar 13, 2018 10:57 pm
Any idea how to resolve this? TIA :-)
[email protected]:~ $ sudo apt update && sudo apt full-upgrade -y && sudo apt autoremove && sudo reboot now
Hit:1 http://archive.raspberrypi.org/debian jessie InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Segmentation fault
Setting up util-linux (2.29.2-1+deb9u1) ...
Segmentation fault
dpkg: error processing package util-linux (--configure):
subprocess installed post-installation script returned error exit status 139
util-linux
Frog blast the vent core!
ngineerken
Re: Update error: "E: Sub-process /usr/bin/dpkg returned an error code (1)"
Thu Mar 15, 2018 3:09 am
I have the same issue:
update-rc.d: error: initscript does not exist: /etc/init.d/hwclock.sh
util-linux
rosswiebe
Thu Mar 15, 2018 9:33 pm
Try this. I have had (more or less) the same problem and this worked for me. (It was with a different package but I don't know why it shouldn't work)
sudo apt remove util-linux
And
sudo apt-get install util-linux
Wizardling
Thu Mar 15, 2018 11:15 pm
Well, I'm afraid that broke my Raspbian Light install. I couldn't reinstall nor fix broken installs. Nor reboot. And couldn't connect after a hard restart. Don't worry, though. I'll start afresh.
ngineerken
Fri Mar 16, 2018 10:59 pm
Neither command worked.
You might want to run 'apt --fix-broken install' to correct these.
e2fsprogs : PreDepends: util-linux (>= 2.15~rc1-1) but it is not going to be installed
i2c-tools : Depends: udev but it is not going to be installed
initramfs-tools-core : Depends: udev but it is not going to be installed
mountall : Depends: udev but it is not going to be installed
Depends: plymouth but it is not going to be installed
openjdk-8-jre-headless : Depends: util-linux (>= 2.26.2-4) but it is not going to be installed
plymouth-themes : Depends: plymouth (= 0.9.2-4+rpi1) but it is not going to be installed
systemd : Depends: util-linux (>= 2.27.1) but it is not going to be installed
sysvinit-utils : Depends: util-linux (> 2.28-2~) but it is not going to be installed
udisks2 : Depends: udev but it is not going to be installed
Recommends: eject but it is not going to be installed
Recommends: exfat-utils but it is not going to be installed
Recommends: gdisk but it is not going to be installed
Recommends: ntfs-3g but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution)
rosswiebe
Mon Mar 19, 2018 3:43 pm
Ngineerken, you might be interested to know that posting a different subject on someone elses thread is called thread hijacking and is not supported on these forums. You should have posted your own thread. Otherwise i recommed following the kernels advice.
Wizardling
Mon Mar 19, 2018 4:06 pm
Seems like it's the same issue to me...?
rosswiebe
Mon Mar 19, 2018 4:14 pm
Do these look the same????
Wizardling wrote: Any idea how to resolve this? TIA :-)
Segmentation fault
Segmentation fault
util-linux
ngineerken wrote: I have the same issue:
util-linux
They look different to me.
ngineerken
Tue Mar 20, 2018 3:15 am
I have been posting directly from the Raspberry PI and it did not seem to work, then I posted from my Mac.
In all we are all getting to the same error:
The package is busted and it will not remove or install with out erroring out.
I have even tried from the GUI Add/Remove and the Synaptic package manager and they too error out
Tue Mar 20, 2018 5:53 am
For different reasons. Therefore it is a different problem.
The OP's error related to what looks like a corrupt program:
Segmentation fault
while yours was related to a missing file:
ngineerken
Tue Mar 20, 2018 10:55 pm
I fixed the problem of the missing " initscript does not exist: /etc/init.d/hwclock.sh" from a running Pi
it is now updating
