profbit
SG92R servo motor moves during power up.
Thu Mar 08, 2018 12:51 pm
Good day,
I'm in trouble everytime I power up my raspberry pi. My servo motor always moves because of the shock (i think). I've googled some sort of solutions which include adding resistor. I'm new with resistor, so I have here my set of questions:
1) is it true that resistor will fix my problem?
2) If yes, how many ohms do I need on resistor if using SG92R?
3) Where should I solder it? without considering the use of breadboard.
Thanks in advance!
joan
Re: SG92R Electrical Shock
Thu Mar 08, 2018 12:55 pm
I have no idea why a resistor would help in any way.
I presume at start up the servo takes interference on the control line to be a pulse and tries to move in response.
A capacitor between the control line and ground might help.
profbit
Re: SG92R servo motor moves during power up.
Fri Mar 09, 2018 11:15 am
how do I add it?
can you link me a store page of recommended capacitor?
where should I solder/connect it?
PiGraham
Fri Mar 09, 2018 11:58 am
Good day,
I don't think it's unusual for servos to twitch at power on. Why does that matter to you?
profbit
Fri Mar 09, 2018 12:14 pm
Good day,
thank you for your response. The reason is that I use servo as my lock a chest
pcmanbob
Fri Mar 09, 2018 12:33 pm
Most if not all servos twitch on power up its because you are supplying power to the control circuit in the servo but no PWM pulse to set a position, just a random high or low voltage pulse.
Some add on driver boards for the pi have an option to set a default position for the servo on power up because the driver board is able to control the servo without pi input.
PiGraham
Fri Mar 09, 2018 12:35 pm
Good day,
How much does it move?
Does it move only one way? What if you change the locked position to the other end of travel? Does the move then become to lock rather than unlock?
profbit
Fri Mar 09, 2018 1:41 pm
Do you have any other options?
profbit
Fri Mar 09, 2018 1:42 pm
Good day,
Yup it’s moving making it unlocked.
pcmanbob
Fri Mar 09, 2018 1:44 pm
Another option is to control the power to your servo using another gpio and a 2N2222 transistor.
That way you can keep the transistor turned off until your program starts , then once you have started the PWM and set a default duty cycle you can power up the servo, with little movement but returning to the position set.
