I had problems installing the new release Raspbian-Stretch
Posted: Mon Feb 26, 2018 11:31 am
I had problems installing the new release Raspbian-Stretch from Nov.2017
I tried it several times with the same 8GB SD cards that I've used before.
I use the Etcher SD Flashing program like the instructions describe.
These sd cards always worked with Raspbian-Wheezy and Jessie release.
My one sd card still had Raspbian-Wheezy on it and this would still bootup.
When my RPi tries to bootup with the Stretch release, the screen would show the splash screen with the rainbow color box
On the next screen, I see the Raspberry icon in the upper left corner and the new Lightening Bolt icon in the upper right corner
But there's no bootup sequence thereafter, it goes into Reset and repeats the process.
I see the Leds on my RPi follow that sequence over and over again.
At first I thought my power supply was dying, my AC adapter is rated at 2.5A
So I had to continue using the Raspbian-Jessie release for now.
Has anyone experienced any issues with installing Raspbian-Stretch ?
