TIR
Connecting Raspberry Pi With Arduino using Bluetooth
Sun Oct 21, 2012 8:09 pm
This is the setup
I have Raspberry Pi with USB BT dongle. I have installed bluetooth and the service is up.
hcitool scan
Scanning ...
        00:12:05:11:92:75       linvor
This is the rfcomm file
root@raspberrypi:/home/pi# cat /etc/bluetooth/rfcomm.conf
# RFCOMM configuration file.
rfcomm0 {
        # Automatically bind the device at startup
        bind no;
        # Bluetooth address of the device
        device 00:12:05:11:92:75;
        # RFCOMM channel for the connection
        channel 1;
        # Description of the connection
        comment "Linvor Bluetooth Device";
But when i try to connect to the device i get:
root@raspberrypi:/home/pi# rfcomm connect 0
Can't connect RFCOMM socket: Connection refused
The Linvor has passkey of 1234. Where should i entered it? There is no more hcid.conf.
root@raspberrypi:/home/pi# ls /etc/bluetooth/
audio.conf  main.conf     proximity.conf  serial.conf
input.conf  network.conf  rfcomm.conf
The os is Raspbian “wheezy”
supergiox
Re: Connecting Raspberry Pi With Arduino using Bluetooth
Wed Feb 20, 2013 4:00 pm
I think you need this command:
echo "1234" | bluez-simple-agent hci0 [MAC_ADDRESS]
tsh
Tue Apr 02, 2013 7:24 pm
Another one struggling with this. I can connect using blueman-manager, but I'm trying to get a command line setup working, and getting nowhere fast...
I have to edit /etc/bluetooth/rfcomm.conf, and got some odd syntax errors at first. I ended up cut/pasting the whole file and replacing with my address.
To set the pairing code, I used
sudo bluetooth-agent 1234 00:12:6F:20:FB:50
