nopalpite
raspberry pi 3 freeze when wifi drop
Sat Feb 24, 2018 12:48 pm
On a fresh install of raspbian stretch lite, after configuring wifi with raspi-config, everything work like a charm...
But when i turn off wifi on router my raspberry pi freezing after 1 or 2 minutes (each time).
The only thing i can do is to turn off power supply and turn on on to resume.
I've tried on 3 SD card, still the same. I've check hash of downloaded img ( it's good). I've tried with 2 different official power supply, still the same.
Anybody for a solution ?
lbog
Re: raspberry pi 3 freeze when wifi drop
Sat Feb 24, 2018 1:43 pm
On a fresh install of raspbian stretch lite, ...
Try with the 4.14.21-Kernel:
sudo rpi-update
nopalpite
Sat Feb 24, 2018 2:08 pm
Ok,
I try rpi-update.
EDIT : After rpi-update, everything seems to be OK. Question is, why latest raspbian image is stil on a 4.9 kernel version ?
lbog
Sat Feb 24, 2018 4:27 pm
4.9 is the stable kernel version: https://github.com/raspberrypi/firmware ... le/modules
nopalpite
Sat Feb 24, 2018 9:29 pm
OK,
So now, my wifi problem seems to be OK.
GoofyHTS
Wed Feb 28, 2018 6:50 pm
I have the same problem, using the latest lite raspbian image released 2017-11-29
Is updating the kernel really the only way to resolve this?
nopalpite
Thu Mar 01, 2018 9:00 am
In my case, it's for now, the only working solution.
